I'm using central_past sample on nrf5340 audio DK board, and select nrf5340dk_nrf5340_cpuapp_ns for Build Target.
I added the following config to enable RTT log in prj.conf, other than that I did not make any changes.
CONFIG_USE_SEGGER_RTT=y CONFIG_RTT_CONSOLE=y
I have used nRF Connect SDK 2.2.0, 2.4.0, 2.6.0 and 2.7.0, and the results are the same as follows:
SEGGER J-Link V7.94i - Real time terminal output SEGGER J-Link (unknown) V1.0, SN=1050135643 Process: JLink.exe *** Booting Zephyr OS build v3.3.99-ncs1 *** Starting Central Periodic Advertising Synchronization Transfer (PAST) Demo [00:00:00.405,975] <inf> bt_hci_core: hci_vs_init: HW Platform: Nordic Semiconductor (0x0002) [00:00:00.406,005] <inf> bt_hci_core: hci_vs_init: HW Variant: nRF53x (0x0003) [00:00:00.406,036] <inf> bt_hci_core: hci_vs_init: Firmware: Standard Bluetooth controller (0x00) Version 224.11902 Build 2231721665 [00:00:00.407,714] <inf> bt_hci_core: bt_dev_show_info: Identity: EE:59:95:D7:A5:0C (random) [00:00:00.407,745] <inf> bt_hci_core: bt_dev_show_info: HCI: version 5.4 (0x0d) revision 0x2077, manufacturer 0x0059 [00:00:00.407,775] <inf> bt_hci_core: bt_dev_show_info: LMP: version 5.4 (0x0d) subver 0x2077 Connection callbacks register Scan callbacks register Periodic Advertising callbacks register Start scanning...[00:00:00.410,125] <wrn> bt_hci_core: bt_hci_cmd_send_sync: opcode 0x2041 status 0x01 failed (err -5)
How can I make this sample run normally?
