nrf5340 Internal RC Oscillator and NET core
I have a project where we did not populate the external oscillator for our custom board which has an nrf5340 on it. I did most of my BLE testing on the nrf5340 devkit and everything worked. As I've been bringing up the nrf5340 on our custom board I had to add a few extra lines to the build config to enable the internal oscillator as mentioned in other posts on the forums which I found:
Now everything else on the board is working fine but when I try to use BLE upon calling bt_enable() I always get:
I found a very similar issue here: https://devzone.nordicsemi.com/f/nordic-q-a/113492/nrf5340-internal-rc-oscillator
One difference is I am now using sysbuild, so in order to make a custom config for the NET core I created the directory <project root>/sysbuild/ipc_radio.conf which contains the above config parameters. I am able to check the autoconf.h file for both the APP and NET cores and they both have CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC set to 1. So does this mean this is probably not a clock problem? I was under the impression that "ipc_radio" was the correct image for the NET core in the nrf5340, as opposed to the "hci_rpmsg" image used on the nrf52832 for example. Is there a different image I'm supposed to be using here?
I am using NCS v2.8.0
Let me know if there's any more info I can provide to help figure out what might be going wrong. Thank you!!
