nRF9160 fails to connect to server with IP and port number. Gives 116 (timeout error)?
I have nRF9160, modem FW = 1.3.6 and nrf sdk version 2.7.0.
I am trying to create an outgoing socket with connects to specific port num and ip address but I am getting timeout error with value 116. I am attaching the code snippet below for your reference.
int sock = socket(AF_INET, SOCK_STREAM, IPPROTO_TCP);
    if (sock < 0)
        printk("Failed to create socket: %d\n", errno);
        return AtJsonTypes::CONNECT_FAILED;
    struct sockaddr_in server;
    server.sin_family = AF_INET;
    server.sin_port = htons(SERVER_PORT);
    if (inet_pton(AF_INET, SERVER_IP, &server.sin_addr) <= 0)
        printk("Invalid address/ Address not supported\n");
        close(sock);
    if (CellConnection::IsCellConnected() == CellConnection::CONNECTED)
        printk("Modem is conneted to network\n");
        printk("No modem connection\n");
    int retries = 3;
    while (retries > 0)
        printk("Device IP is %s and Port num is %d\n", SERVER_IP, SERVER_PORT);
        int ret = connect(sock, (struct sockaddr *)&server, sizeof(server));
        if (ret == 0)
            // Connection successful
            printk("Connected to %s at port num %d\n", SERVER_IP, SERVER_PORT);
        else if (errno == ETIMEDOUT)
            // Handle timeout
            printk("Failed to connect socket timeout: %d\n", errno);
            retries--;
            sleep(1); // Wait before retrying
            // Handle other errors
            printk("Failed to connect socket: %d\n", errno);
Could you please help?
  • #define CONFIG_GA_LISTEN_SOCKETS_ENABLE 1
    #define CONFIG_ETN_FW_V_MAJOR 0
    #define CONFIG_ETN_FW_V_MINOR 0
    #define CONFIG_ETN_FW_V_REVISION 8
    #define CONFIG_ETN_FW_V_UID ""
    #define CONFIG_ETN_FW_BUILD_TIME 1744020030
    #define CONFIG_ETN_FW_BUILD_TYPE "local"
    #define CONFIG_NET_IPV6 1
    #define CONFIG_SPI 1
    #define CONFIG_BOARD "nrf9160dk_nrf9160"
    #define CONFIG_BUILD_WITH_TFM 1
    #define CONFIG_TFM_FLASH_MERGED_BINARY 1
    #define CONFIG_FLASH_LOAD_SIZE 0x30000
    #define CONFIG_FLASH_LOAD_OFFSET 0x50000
    #define CONFIG_SOC "nRF9160_SICA"
    #define CONFIG_SOC_SERIES "nrf91"
    #define CONFIG_NUM_IRQS 65
    #define CONFIG_NRF_RTC_TIMER 1
    #define CONFIG_LOG_DOMAIN_NAME ""
    #define CONFIG_CLOCK_CONTROL 1
    #define CONFIG_SYS_CLOCK_HW_CYCLES_PER_SEC 32768
    #define CONFIG_SYS_CLOCK_TICKS_PER_SEC 32768
    #define CONFIG_ARCH_HAS_CUSTOM_BUSY_WAIT 1
    #define CONFIG_BUILD_OUTPUT_HEX 1
    #define CONFIG_SOC_HAS_TIMING_FUNCTIONS 1
    #define CONFIG_GPIO 1
    #define CONFIG_DT_HAS_ARM_ARMV8M_MPU_ENABLED 1
    #define CONFIG_DT_HAS_ARM_CORTEX_M33F_ENABLED 1
    #define CONFIG_DT_HAS_ARM_V8M_NVIC_ENABLED 1
    #define CONFIG_DT_HAS_FIXED_PARTITIONS_ENABLED 1
    #define CONFIG_DT_HAS_GPIO_KEYS_ENABLED 1
    #define CONFIG_DT_HAS_GPIO_LEDS_ENABLED 1
    #define CONFIG_DT_HAS_JEDEC_SPI_NOR_ENABLED 1
    #define CONFIG_DT_HAS_MMIO_SRAM_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_CLOCK_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_DPPIC_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_EGU_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_GPIO_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_GPIOTE_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_GPREGRET_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_IPC_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_KMU_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_PINCTRL_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_POWER_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_REGULATORS_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_SPIM_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_TIMER_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_UARTE_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_VMC_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_WDT_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF91_FLASH_CONTROLLER_ENABLED 1
    #define CONFIG_DT_HAS_PWM_LEDS_ENABLED 1
    #define CONFIG_DT_HAS_SOC_NV_FLASH_ENABLED 1
    #define CONFIG_DT_HAS_ZEPHYR_BT_HCI_ENTROPY_ENABLED 1
    #define CONFIG_DT_HAS_ZEPHYR_PSA_CRYPTO_RNG_ENABLED 1
    #define CONFIG_NUM_METAIRQ_PRIORITIES 0
    #define CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE 1152
    #define CONFIG_MAIN_STACK_SIZE 3072
    #define CONFIG_INIT_STACKS 1
    #define CONFIG_NET_IPV6_NBR_CACHE 1
    #define CONFIG_NET_IPV6_MLD 1
    #define CONFIG_NET_PKT_RX_COUNT 4
    #define CONFIG_NET_PKT_TX_COUNT 4
    #define CONFIG_MBEDTLS_CIPHER_MODE_CFB 1
    #define CONFIG_MBEDTLS_CIPHER_MODE_OFB 1
    #define CONFIG_MBEDTLS_SHA512_C 1
    #define CONFIG_MBEDTLS_PSA_KEY_SLOT_COUNT 32
    #define CONFIG_ISR_STACK_SIZE 2048
    #define CONFIG_IDLE_STACK_SIZE 320
    #define CONFIG_MPSL_WORK_STACK_SIZE 1024
    #define CONFIG_NET_RX_STACK_SIZE 1500
    #define CONFIG_NET_TX_STACK_SIZE 1200
    #define CONFIG_MBEDTLS 1
    #define CONFIG_MBEDTLS_MD_C 1
    #define CONFIG_MBEDTLS_LEGACY_CRYPTO_C 1
    #define CONFIG_TFM_MCUBOOT_IMAGE_NUMBER 1
    #define CONFIG_TFM_CRYPTO_RNG_MODULE_ENABLED 1
    #define CONFIG_TFM_PARTITION_CRYPTO 1
    #define CONFIG_TFM_PARTITION_PLATFORM 1
    #define CONFIG_ROM_START_OFFSET 0x0
    #define CONFIG_WARN_EXPERIMENTAL 1
    #define CONFIG_PRIVILEGED_STACK_SIZE 1024
    #define CONFIG_INIT_ARCH_HW_AT_BOOT 1
    #define CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE 4096
    #define CONFIG_FLASH_BASE_ADDRESS 0x0
    #define CONFIG_FLASH_SIZE 1024
    #define CONFIG_UPDATEABLE_IMAGE_NUMBER 1
    #define CONFIG_PM_PARTITION_SIZE_PROVISION 0x280
    #define CONFIG_PM_PARTITION_SIZE_B0_IMAGE 0x8000
    #define CONFIG_SB_VALIDATION_INFO_MAGIC 0x86518483
    #define CONFIG_SB_VALIDATION_POINTER_MAGIC 0x6919b47e
    #define CONFIG_SB_VALIDATION_INFO_CRYPTO_ID 1
    #define CONFIG_SB_VALIDATION_INFO_VERSION 2
    #define CONFIG_SB_VALIDATION_METADATA_OFFSET 0
    #define CONFIG_SB_VALIDATE_FW_SIGNATURE 1
    #define CONFIG_SYSTEM_WORKQUEUE_PRIORITY -1
    #define CONFIG_HEAP_MEM_POOL_SIZE 16384
    #define CONFIG_PCD_VERSION_PAGE_BUF_SIZE 2046
    #define CONFIG_NRF_CLOUD_CLIENT_ID_SRC_IMEI 1
    #define CONFIG_NRF_CLOUD_CLIENT_ID_PREFIX "nrf-"
    #define CONFIG_FOTA_USE_NRF_CLOUD_SETTINGS_AREA 1
    #define CONFIG_FOTA_DL_TIMEOUT_MIN 15
    #define CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_DEFAULT 1
    #define CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL 1
    #define CONFIG_NRF_CLOUD_LOG_OUTPUT_LEVEL 1
    #define CONFIG_NRF_CLOUD_LOG_BUF_SIZE 256
    #define CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_DEFAULT 1
    #define CONFIG_NRF_CLOUD_LOG_LOG_LEVEL 1
    #define CONFIG_NRF_CLOUD_LOG_LEVEL_DEFAULT 1
    #define CONFIG_NRF_CLOUD_LOG_LEVEL 1
    #define CONFIG_MPSL_FEM_LOG_LEVEL_DEFAULT 1
    #define CONFIG_MPSL_FEM_LOG_LEVEL 1
    #define CONFIG_MPSL_THREAD_COOP_PRIO 8
    #define CONFIG_MPSL_TIMESLOT_SESSION_COUNT 0
    #define CONFIG_MPSL_LOG_LEVEL_DEFAULT 1
    #define CONFIG_MPSL_LOG_LEVEL 1
    #define CONFIG_PARTITION_MANAGER_ENABLED 1
    #define CONFIG_FLASH_MAP_CUSTOM 1
    #define CONFIG_SRAM_SIZE 128
    #define CONFIG_SRAM_BASE_ADDRESS 0x20020000
    #define CONFIG_PM_SINGLE_IMAGE 1
    #define CONFIG_PM_EXTERNAL_FLASH_HAS_DRIVER 1
    #define CONFIG_PM_EXTERNAL_FLASH_BASE 0x0
    #define CONFIG_PM_EXTERNAL_FLASH_ENABLED 1
    #define CONFIG_PM_EXTERNAL_FLASH_PATH "/soc/peripheral@40000000/spi@b000/mx25r6435f@0"
    #define CONFIG_PM_EXTERNAL_FLASH_SIZE_BITS 67108864
    #define CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY 1
    #define CONFIG_PM_SRAM_BASE 0x20000000
    #define CONFIG_PM_SRAM_SIZE 0x40000
    #define CONFIG_MGMT_FMFU_LOG_LEVEL_DEFAULT 1
    #define CONFIG_MGMT_FMFU_LOG_LEVEL 1
    #define CONFIG_MGMT_SUITFU_TRIGGER_UPDATE_RESET_DELAY_MS 100
    #define CONFIG_MGMT_SUITFU_AUTO_REGISTER_HANDLERS 1
    #define CONFIG_MGMT_SUITFU_GRP_IMG 1
    #define CONFIG_MGMT_SUITFU_IMAGE_NUMBER 0
    #define CONFIG_MGMT_SUITFU_LOG_LEVEL_DEFAULT 1
    #define CONFIG_MGMT_SUITFU_LOG_LEVEL 1
    #define CONFIG_NORDIC_SECURITY_BACKEND 1
    #define CONFIG_NRF_SECURITY 1
    #define CONFIG_MBEDTLS_CFG_FILE "nrf-config.h"
    #define CONFIG_MBEDTLS_USER_CONFIG_FILE "nrf-config-user-empty.h"
    #define CONFIG_MBEDTLS_PSA_CRYPTO_CONFIG_FILE "nrf-psa-crypto-want-config.h"
    #define CONFIG_MBEDTLS_PSA_CRYPTO_USER_CONFIG_FILE "nrf-psa-crypto-config.h"
    #define CONFIG_GENERATE_MBEDTLS_CFG_FILE 1
    #define CONFIG_MBEDTLS_PSA_CRYPTO_C 1
    #define CONFIG_MBEDTLS_PSA_CRYPTO_CLIENT 1
    #define CONFIG_PSA_WANT_GENERATE_RANDOM 1
    #define CONFIG_PSA_WANT_ALG_HMAC_DRBG 1
    #define CONFIG_PSA_CORE_OBERON 1
    #define CONFIG_MBEDTLS_PSA_CRYPTO_DRIVERS 1
    #define CONFIG_PSA_DEFAULT_OFF 1
    #define CONFIG_PSA_CRYPTO_DRIVER_OBERON 1
    #define CONFIG_PSA_USE_HMAC_DRBG_DRIVER 1
    #define CONFIG_PSA_USE_CC3XX_HMAC_DRBG_DRIVER 1
    #define CONFIG_PSA_WANT_AES_KEY_SIZE_128 1
    #define CONFIG_PSA_WANT_AES_KEY_SIZE_192 1
    #define CONFIG_PSA_WANT_AES_KEY_SIZE_256 1
    #define CONFIG_PSA_MAX_RSA_KEY_BITS 0
    #define CONFIG_PSA_ACCEL_GENERATE_RANDOM 1
    #define CONFIG_PSA_NEED_CC3XX_HMAC_DRBG_DRIVER 1
    #define CONFIG_CRACEN_LOG_LEVEL_DEFAULT 1
    #define CONFIG_CRACEN_LOG_LEVEL 1
    #define CONFIG_MBEDTLS_PLATFORM_MEMORY 1
    #define CONFIG_MBEDTLS_PLATFORM_C 1
    #define CONFIG_MBEDTLS_MEMORY_C 1
    #define CONFIG_MBEDTLS_MEMORY_BUFFER_ALLOC_C 1
    #define CONFIG_MBEDTLS_ENTROPY_HARDWARE_ALT 1
    #define CONFIG_MBEDTLS_AES_SETKEY_ENC_ALT 1
    #define CONFIG_MBEDTLS_AES_SETKEY_DEC_ALT 1
    #define CONFIG_MBEDTLS_AES_ENCRYPT_ALT 1
    #define CONFIG_MBEDTLS_AES_DECRYPT_ALT 1
    #define CONFIG_MBEDTLS_CHACHA20_ALT 1
    #define CONFIG_MBEDTLS_POLY1305_ALT 1
    #define CONFIG_MBEDTLS_ECDH_GEN_PUBLIC_ALT 1
    #define CONFIG_MBEDTLS_ECDH_COMPUTE_SHARED_ALT 1
    #define CONFIG_MBEDTLS_ECDSA_GENKEY_ALT 1
    #define CONFIG_MBEDTLS_ECDSA_SIGN_ALT 1
    #define CONFIG_MBEDTLS_ECDSA_VERIFY_ALT 1
    #define CONFIG_MBEDTLS_ECJPAKE_ALT 1
    #define CONFIG_MBEDTLS_SHA1_ALT 1
    #define CONFIG_MBEDTLS_SHA224_ALT 1
    #define CONFIG_MBEDTLS_SHA256_ALT 1
    #define CONFIG_MBEDTLS_ENTROPY_FORCE_SHA256 1
    #define CONFIG_MBEDTLS_ENTROPY_MAX_SOURCES 1
    #define CONFIG_MBEDTLS_NO_PLATFORM_ENTROPY 1
    #define CONFIG_OBERON_ONLY_PSA_ENABLED 1
    #define CONFIG_OBERON_ONLY_ENABLED 1
    #define CONFIG_MBEDTLS_MPI_WINDOW_SIZE 6
    #define CONFIG_MBEDTLS_MPI_MAX_SIZE 256
    #define CONFIG_OBERON_BACKEND 1
    #define CONFIG_MBEDTLS_CTR_DRBG_USE_128_BIT_KEY 1
    #define CONFIG_MBEDTLS_HMAC_DRBG_C 1
    #define CONFIG_MBEDTLS_AES_C 1
    #define CONFIG_MBEDTLS_HKDF_C 1
    #define CONFIG_MBEDTLS_MD5_C 1
    #define CONFIG_MBEDTLS_SHA224_C 1
    #define CONFIG_MBEDTLS_SHA256_C 1
    #define CONFIG_MBEDTLS_SHA384_C 1
    #define CONFIG_MBEDTLS_CIPHER_C 1
    #define CONFIG_MBEDTLS_LIBRARY_NRF_SECURITY 1
    #define CONFIG_AUDIO_MODULE_NAME_SIZE 20
    #define CONFIG_AUDIO_MODULE_LOG_LEVEL_DEFAULT 1
    #define CONFIG_AUDIO_MODULE_LOG_LEVEL 1
    #define CONFIG_POSIX_MAX_FDS 8
    #define CONFIG_NET_MGMT_EVENT_STACK_SIZE 768
    #define CONFIG_NET_SOCKETS_POLL_MAX 3
    #define CONFIG_WFA_QT_LOG_LEVEL_DEFAULT 1
    #define CONFIG_WFA_QT_LOG_LEVEL 1
    #define CONFIG_WFA_QT_THREAD_STACK_SIZE 4096
    #define CONFIG_WFA_QT_REBOOT_TIMEOUT_MS 1000
    #define CONFIG_WFA_QT_DEFAULT_INTERFACE "nordic_wlan0"
    #define CONFIG_WPAS_READY_TIMEOUT_MS 10000
    #define CONFIG_NRF_MODEM_LIB 1
    #define CONFIG_NRF_MODEM_LIB_HEAP_SIZE 1024
    #define CONFIG_NRF_MODEM_LIB_SHMEM_CTRL_SIZE 0x4e8
    #define CONFIG_NRF_MODEM_LIB_SHMEM_TX_SIZE 8320
    #define CONFIG_NRF_MODEM_LIB_SHMEM_RX_SIZE 8192
    #define CONFIG_NRF_MODEM_LIB_SHMEM_TRACE_SIZE 0
    #define CONFIG_NRF_MODEM_LIB_SENDMSG_BUF_SIZE 128
    #define CONFIG_NRF_MODEM_LIB_ON_FAULT_DO_NOTHING 1
    #define CONFIG_NRF_MODEM_LIB_CFUN_HOOKS 1
    #define CONFIG_NRF_MODEM_LIB_IPC_IRQ_PRIO 1
    #define CONFIG_NRF_MODEM_LIB_LOG_LEVEL_DEFAULT 1
    #define CONFIG_NRF_MODEM_LIB_LOG_LEVEL 1
    #define CONFIG_AT_MONITOR 1
    #define CONFIG_AT_MONITOR_HEAP_SIZE 256
    #define CONFIG_AT_MONITOR_LOG_LEVEL_DEFAULT 1
    #define CONFIG_AT_MONITOR_LOG_LEVEL 1
    #define CONFIG_LTE_LINK_CONTROL 1
    #define CONFIG_LTE_PLMN_SELECTION_OPTIMIZATION 1
    #define CONFIG_LTE_PSM_REQ_FORMAT_STRING 1
    #define CONFIG_LTE_PSM_REQ_RPTAU "00000011"
    #define CONFIG_LTE_PSM_REQ_RAT "00100001"
    #define CONFIG_LTE_PSM_REQ_RPTAU_SECONDS 1800
    #define CONFIG_LTE_PSM_REQ_RAT_SECONDS 60
    #define CONFIG_LTE_EDRX_REQ_VALUE_LTE_M "1001"
    #define CONFIG_LTE_EDRX_REQ_VALUE_NBIOT "1001"
    #define CONFIG_LTE_PTW_VALUE_LTE_M ""
    #define CONFIG_LTE_PTW_VALUE_NBIOT ""
    #define CONFIG_LTE_NETWORK_MODE_LTE_M_GPS 1
    #define CONFIG_LTE_MODE_PREFERENCE_AUTO 1
    #define CONFIG_LTE_MODE_PREFERENCE_VALUE 0
    #define CONFIG_LTE_NETWORK_TIMEOUT 60
    #define CONFIG_LTE_LC_TAU_PRE_WARNING_TIME_MS 5000
    #define CONFIG_LTE_LC_TAU_PRE_WARNING_THRESHOLD_MS 1200000
    #define CONFIG_LTE_NEIGHBOR_CELLS_MAX 10
    #define CONFIG_LTE_LC_MODEM_SLEEP_PRE_WARNING_TIME_MS 5000
    #define CONFIG_LTE_LC_MODEM_SLEEP_NOTIFICATIONS_THRESHOLD_MS 1200000
    #define CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_DEFAULT 1
    #define CONFIG_LTE_LINK_CONTROL_LOG_LEVEL 1
    #define CONFIG_NRF_SPU_FLASH_REGION_SIZE 0x8000
    #define CONFIG_FPROTECT_BLOCK_SIZE 0x8000
    #define CONFIG_AT_HOST_LIBRARY 1
    #define CONFIG_AT_HOST_UART_INIT_TIMEOUT 500
    #define CONFIG_CR_TERMINATION 1
    #define CONFIG_AT_HOST_TERMINATION 1
    #define CONFIG_AT_HOST_CMD_MAX_LEN 4096
    #define CONFIG_AT_HOST_THREAD_PRIO 10
    #define CONFIG_AT_HOST_STACK_SIZE 1024
    #define CONFIG_AT_HOST_LOG_LEVEL_DEFAULT 1
    #define CONFIG_AT_HOST_LOG_LEVEL 1
    #define CONFIG_AT_CMD_PARSER 1
    #define CONFIG_MODEM_INFO 1
    #define CONFIG_MODEM_INFO_MAX_AT_PARAMS_RSP 10
    #define CONFIG_MODEM_INFO_BUFFER_SIZE 128
    #define CONFIG_MODEM_INFO_ADD_NETWORK 1
    #define CONFIG_MODEM_INFO_ADD_DATE_TIME 1
    #define CONFIG_MODEM_INFO_ADD_SIM 1
    #define CONFIG_MODEM_INFO_ADD_SIM_ICCID 1
    #define CONFIG_MODEM_INFO_ADD_SIM_IMSI 1
    #define CONFIG_MODEM_INFO_ADD_DEVICE 1
    #define CONFIG_RESET_ON_FATAL_ERROR 1
    #define CONFIG_FATAL_ERROR_LOG_LEVEL_DEFAULT 1
    #define CONFIG_FATAL_ERROR_LOG_LEVEL 1
    #define CONFIG_HW_UNIQUE_KEY_SUPPORTED 1
    #define CONFIG_HW_UNIQUE_KEY_PARTITION_SIZE 0x0
    #define CONFIG_NCS_BOOT_BANNER 1
    #define CONFIG_NCS_NCS_BOOT_BANNER_STRING "nRF Connect SDK"
    #define CONFIG_NCS_ZEPHYR_BOOT_BANNER_STRING "Zephyr OS"
    #define CONFIG_NRFX_GPIOTE_NUM_OF_EVT_HANDLERS 1
    #define CONFIG_NET_TC_TX_COUNT 0
    #define CONFIG_NET_INTERFACE_NAME_LEN 8
    #define CONFIG_NET_MGMT_EVENT_QUEUE_SIZE 5
    #define CONFIG_ZTEST_MULTICORE_DEFAULT_SETTINGS 1
    #define CONFIG_ZEPHYR_NRF_MODULE 1
    #define CONFIG_SIGN_IMAGES 1
    #define CONFIG_MCUBOOT_BUILD_STRATEGY_FROM_SOURCE 1
    #define CONFIG_MCUBOOT_FLASH_WRITE_BLOCK_SIZE 4
    #define CONFIG_DT_FLASH_WRITE_BLOCK_SIZE 4
    #define CONFIG_ADD_MCUBOOT_MEDIATE_SIM_FLASH_DTS 1
    #define CONFIG_ZEPHYR_MCUBOOT_MODULE 1
    #define CONFIG_ZEPHYR_MBEDTLS_MODULE 1
    #define CONFIG_DISABLE_MBEDTLS_BUILTIN 1
    #define CONFIG_MBEDTLS_LOG_LEVEL_DEFAULT 1
    #define CONFIG_MBEDTLS_LOG_LEVEL 1
    #define CONFIG_MBEDTLS_INIT 1
    #define CONFIG_APP_LINK_WITH_MBEDTLS 1
    #define CONFIG_ZEPHYR_OBERON_PSA_CRYPTO_MODULE 1
    #define CONFIG_TFM_BOARD "_9160/nrf/modules/trusted-firmware-m/tfm_boards/nrf9160"
    #define CONFIG_TFM_ISOLATION_LEVEL 1
    #define CONFIG_TFM_QCBOR_PATH "_9160/modules/tee/tf-m/trusted-firmware-m/../qcbor"
    #define CONFIG_BOOTLOADER_MCUBOOT 1
    #define CONFIG_ZEPHYR_TRUSTED_FIRMWARE_M_MODULE 1
    #define CONFIG_TFM_KEY_FILE_S "_9160/modules/tee/tf-m/trusted-firmware-m/bl2/ext/mcuboot/root-RSA-3072.pem"
    #define CONFIG_TFM_KEY_FILE_NS "_9160/modules/tee/tf-m/trusted-firmware-m/bl2/ext/mcuboot/root-RSA-3072_1.pem"
    #define CONFIG_TFM_CMAKE_BUILD_TYPE_DEBUG 1
    #define CONFIG_TFM_PARTITION_PLATFORM_CUSTOM_REBOOT 1
    #define CONFIG_TFM_BL2_NOT_SUPPORTED 1
    #define CONFIG_TFM_IMAGE_VERSION_S "0.0.0+0"
    #define CONFIG_TFM_IMAGE_VERSION_NS "0.0.0+0"
    #define CONFIG_TFM_SFN 1
    #define CONFIG_TFM_PSA_TEST_NONE 1
    #define CONFIG_TFM_SPM_LOG_LEVEL_INFO 1
    #define CONFIG_TFM_EXCEPTION_INFO_DUMP 1
    #define CONFIG_TFM_PLATFORM_SERVICE_INPUT_BUFFER_SIZE 64
    #define CONFIG_TFM_PLATFORM_SERVICE_OUTPUT_BUFFER_SIZE 64
    #define CONFIG_TFM_PLATFORM_SP_STACK_SIZE 0x500
    #define CONFIG_TFM_PLATFORM_NV_COUNTER_MODULE_DISABLED 1
    #define CONFIG_TFM_CRYPTO_ENGINE_BUF_SIZE 1
    #define CONFIG_TFM_CRYPTO_CONC_OPER_NUM 1
    #define CONFIG_TFM_CRYPTO_IOVEC_BUFFER_SIZE 1024
    #define CONFIG_TFM_CRYPTO_PARTITION_STACK_SIZE 0x800
    #define CONFIG_PM_PARTITION_SIZE_TFM_SRAM 0x8000
    #define CONFIG_PM_PARTITION_SIZE_TFM 0xFE00
    #define CONFIG_PM_PARTITION_SIZE_TFM_PROTECTED_STORAGE 0x0
    #define CONFIG_PM_PARTITION_SIZE_TFM_INTERNAL_TRUSTED_STORAGE 0x0
    #define CONFIG_PM_PARTITION_SIZE_TFM_OTP_NV_COUNTERS 0x0
    #define CONFIG_NRF_UARTE1_SECURE 1
    #define CONFIG_NRF_GPIO0_PIN_MASK_SECURE 0x00000000
    #define CONFIG_NRF_DPPI_CHANNEL_MASK_SECURE 0x00000000
    #define CONFIG_NRF_VMC_SECURE 1
    #define CONFIG_TFM_PROFILE_TYPE_MINIMAL 1
    #define CONFIG_TFM_SECURE_UART 1
    #define CONFIG_TFM_SECURE_UART_SHARE_INSTANCE 1
    #define CONFIG_TFM_SECURE_UART1 1
    #define CONFIG_TFM_HW_INIT_RESET_ON_BOOT 1
    #define CONFIG_TFM_HW_INIT_NRF_PERIPHERALS 1
    #define CONFIG_TFM_ALLOW_NON_SECURE_RESET 1
    #define CONFIG_TFM_ALLOW_NON_SECURE_FAULT_HANDLING 1
    #define CONFIG_TFM_S_CODE_VECTOR_TABLE_SIZE 0x144
    #define CONFIG_ZEPHYR_PSA_ARCH_TESTS_MODULE 1
    #define CONFIG_ZEPHYR_SOC_HWMV1_MODULE 1
    #define CONFIG_ZEPHYR_CJSON_MODULE 1
    #define CONFIG_ZEPHYR_AZURE_SDK_FOR_C_MODULE 1
    #define CONFIG_ZEPHYR_CIRRUS_LOGIC_MODULE 1
    #define CONFIG_ZEPHYR_OPENTHREAD_MODULE 1
    #define CONFIG_SUIT_ENVELOPE_TEMPLATE ""
    #define CONFIG_SUIT_ENVELOPE_TARGET ""
    #define CONFIG_SUIT_ENVELOPE_OUTPUT_ARTIFACT "merged.hex"
    #define CONFIG_SUIT_ENVELOPE_OUTPUT_MPI_MERGE 1
    #define CONFIG_ZEPHYR_SUIT_GENERATOR_MODULE 1
    #define CONFIG_SUIT_PLATFORM_DRY_RUN_SUPPORT 1
    #define CONFIG_ZEPHYR_SUIT_PROCESSOR_MODULE 1
    #define CONFIG_ZEPHYR_MEMFAULT_FIRMWARE_SDK_MODULE 1
    #define CONFIG_ZEPHYR_COREMARK_MODULE 1
    #define CONFIG_ZEPHYR_CANOPENNODE_MODULE 1
    #define CONFIG_ZEPHYR_CHRE_MODULE 1
    #define CONFIG_ZEPHYR_LZ4_MODULE 1
    #define CONFIG_ZEPHYR_NANOPB_MODULE 1
    #define CONFIG_ZEPHYR_TF_M_TESTS_MODULE 1
    #define CONFIG_ZEPHYR_ZSCILIB_MODULE 1
    #define CONFIG_ZEPHYR_CMSIS_MODULE 1
    #define CONFIG_HAS_CMSIS_CORE 1
    #define CONFIG_HAS_CMSIS_CORE_M 1
    #define CONFIG_ZEPHYR_CMSIS_DSP_MODULE 1
    #define CONFIG_ZEPHYR_CMSIS_NN_MODULE 1
    #define CONFIG_ZEPHYR_FATFS_MODULE 1
    #define CONFIG_ZEPHYR_HAL_NORDIC_MODULE 1
    #define CONFIG_HAS_NRFX 1
    #define CONFIG_NRFX_CLOCK 1
    #define CONFIG_NRFX_CLOCK_LFXO_TWO_STAGE_ENABLED 1
    #define CONFIG_NRFX_DPPI 1
    #define CONFIG_NRFX_GPIOTE 1
    #define CONFIG_NRFX_GPIOTE1 1
    #define CONFIG_NRFX_IPC 1
    #define CONFIG_NRFX_NVMC 1
    #define CONFIG_NRFX_SPIM 1
    #define CONFIG_NRFX_SPIM3 1
    #define CONFIG_NRFX_TIMER 1
    #define CONFIG_NRFX_TIMER1 1
    #define CONFIG_NRFX_TIMER2 1
    #define CONFIG_NRFX_UARTE 1
    #define CONFIG_NRFX_UARTE0 1
    #define CONFIG_NRFX_UARTE1 1
    #define CONFIG_ZEPHYR_HAL_ST_MODULE 1
    #define CONFIG_ZEPHYR_HAL_WURTHELEKTRONIK_MODULE 1
    #define CONFIG_ZEPHYR_LIBMETAL_MODULE 1
    #define CONFIG_ZEPHYR_LIBLC3_MODULE 1
    #define CONFIG_ZEPHYR_LITTLEFS_MODULE 1
    #define CONFIG_ZEPHYR_LORAMAC_NODE_MODULE 1
    #define CONFIG_ZEPHYR_LVGL_MODULE 1
    #define CONFIG_ZEPHYR_MIPI_SYS_T_MODULE 1
    #define CONFIG_ZEPHYR_NRF_HW_MODELS_MODULE 1
    #define CONFIG_ZEPHYR_OPEN_AMP_MODULE 1
    #define CONFIG_ZEPHYR_PICOLIBC_MODULE 1
    #define CONFIG_ZEPHYR_SEGGER_MODULE 1
    #define CONFIG_HAS_SEGGER_RTT 1
    #define CONFIG_USE_SEGGER_RTT 1
    #define CONFIG_SEGGER_RTT_CUSTOM_LOCKING 1
    #define CONFIG_SEGGER_RTT_MAX_NUM_UP_BUFFERS 3
    #define CONFIG_SEGGER_RTT_MAX_NUM_DOWN_BUFFERS 3
    #define CONFIG_SEGGER_RTT_BUFFER_SIZE_UP 1024
    #define CONFIG_SEGGER_RTT_BUFFER_SIZE_DOWN 16
    #define CONFIG_SEGGER_RTT_PRINTF_BUFFER_SIZE 64
    #define CONFIG_SEGGER_RTT_MODE_NO_BLOCK_SKIP 1
    #define CONFIG_SEGGER_RTT_MODE 0
    #define CONFIG_SEGGER_RTT_SECTION_NONE 1
    #define CONFIG_ZEPHYR_TINYCRYPT_MODULE 1
    #define CONFIG_ZEPHYR_UOSCORE_UEDHOC_MODULE 1
    #define CONFIG_ZEPHYR_ZCBOR_MODULE 1
    #define CONFIG_ZCBOR 1
    #define CONFIG_ZCBOR_ASSERT 1
    #define CONFIG_ZCBOR_MAX_STR_LEN 256
    #define CONFIG_NRF_MODEM 1
    #define CONFIG_NRF_MODEM_LINK_BINARY_CELLULAR 1
    #define CONFIG_NRF_MODEM_SHMEM_CTRL_SIZE 0x4e8
    #define CONFIG_HAS_HW_NRF_CC3XX 1
    #define CONFIG_NRF_OBERON 1
    #define CONFIG_NRF_802154_SOURCE_NRFXLIB 1
    #define CONFIG_ZEPHYR_NRFXLIB_MODULE 1
    #define CONFIG_ZEPHYR_CONNECTEDHOMEIP_MODULE 1
    #define CONFIG_MCUBOOT_CMAKE_WEST_SIGN_PARAMS "--quiet"
    #define CONFIG_MCUBOOT_SIGNATURE_KEY_FILE ""
    #define CONFIG_MCUBOOT_IMGTOOL_SIGN_VERSION "0.0.0+0"
    #define CONFIG_MCUBOOT_EXTRA_IMGTOOL_ARGS ""
    #define CONFIG_MCUBOOT_BOOTLOADER_MODE_SWAP_WITHOUT_SCRATCH 1
    #define CONFIG_MCUBOOT_BOOTLOADER_MODE_HAS_NO_DOWNGRADE 1
    #define CONFIG_MCUBOOT_BOOTUTIL_LIB 1
    #define CONFIG_MCUBOOT_BOOTUTIL_LIB_OWN_LOG 1
    #define CONFIG_MCUBOOT_UTIL_LOG_LEVEL_DEFAULT 1
    #define CONFIG_MCUBOOT_UTIL_LOG_LEVEL 1
    #define CONFIG_BOARD_REVISION ""
    #define CONFIG_BOARD_TARGET ""
    #define CONFIG_BOARD_SIGNETIK_GWLP_NS 1
    #define CONFIG_SOC_SERIES_NRF91X 1
    #define CONFIG_NRF_SPU_FLASH_REGION_ALIGNMENT 0x8000
    #define CONFIG_NRF_SPU_RAM_REGION_SIZE 0x2000
    #define CONFIG_NRF_SPU_RAM_REGION_ALIGNMENT 0x2000
    #define CONFIG_SOC_FAMILY "nordic_nrf"
    #define CONFIG_SOC_FAMILY_NORDIC_NRF 1
    #define CONFIG_SOC_FAMILY_NRF 1
    #define CONFIG_HAS_HW_NRF_CC310 1
    #define CONFIG_HAS_HW_NRF_CLOCK 1
    #define CONFIG_HAS_HW_NRF_DPPIC 1
    #define CONFIG_HAS_HW_NRF_EGU0 1
    #define CONFIG_HAS_HW_NRF_EGU1 1
    #define CONFIG_HAS_HW_NRF_EGU2 1
    #define CONFIG_HAS_HW_NRF_EGU3 1
    #define CONFIG_HAS_HW_NRF_EGU4 1
    #define CONFIG_HAS_HW_NRF_EGU5 1
    #define CONFIG_HAS_HW_NRF_GPIO0 1
    #define CONFIG_HAS_HW_NRF_GPIOTE1 1
    #define CONFIG_HAS_HW_NRF_IPC 1
    #define CONFIG_HAS_HW_NRF_KMU 1
    #define CONFIG_HAS_HW_NRF_NVMC_PE 1
    #define CONFIG_HAS_HW_NRF_POWER 1
    #define CONFIG_HAS_HW_NRF_REGULATORS 1
    #define CONFIG_HAS_HW_NRF_SPIM3 1
    #define CONFIG_HAS_HW_NRF_TIMER0 1
    #define CONFIG_HAS_HW_NRF_TIMER1 1
    #define CONFIG_HAS_HW_NRF_TIMER2 1
    #define CONFIG_HAS_HW_NRF_UARTE0 1
    #define CONFIG_HAS_HW_NRF_UARTE1 1
    #define CONFIG_HAS_HW_NRF_VMC 1
    #define CONFIG_HAS_HW_NRF_WDT0 1
    #define CONFIG_NRF_ENABLE_ICACHE 1
    #define CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT 0
    #define CONFIG_SOC_NRF9160 1
    #define CONFIG_SOC_NRF9160_SICA 1
    #define CONFIG_NRF_SOC_SECURE_SUPPORTED 1
    #define CONFIG_TFM_NRF_NS_STORAGE 1
    #define CONFIG_NRF_APPROTECT_USE_UICR 1
    #define CONFIG_SOC_LOG_LEVEL_DEFAULT 1
    #define CONFIG_SOC_LOG_LEVEL 1
    #define CONFIG_SOC_COMPATIBLE_NRF 1
    #define CONFIG_ARCH "arm"
    #define CONFIG_CPU_CORTEX 1
    #define CONFIG_CPU_CORTEX_M 1
    #define CONFIG_ISA_THUMB2 1
    #define CONFIG_ASSEMBLER_ISA_THUMB2 1
    #define CONFIG_COMPILER_ISA_THUMB2 1
    #define CONFIG_STACK_ALIGN_DOUBLE_WORD 1
    #define CONFIG_PLATFORM_SPECIFIC_INIT 1
    #define CONFIG_FAULT_DUMP 2
    #define CONFIG_BUILTIN_STACK_GUARD 1
    #define CONFIG_ARM_STACK_PROTECTION 1
    #define CONFIG_ARM_NONSECURE_FIRMWARE 1
    #define CONFIG_ARM_NONSECURE_PREEMPTIBLE_SECURE_CALLS 1
    #define CONFIG_ARM_STORE_EXC_RETURN 1
    #define CONFIG_FP16 1
    #define CONFIG_FP16_IEEE 1
    #define CONFIG_CPU_CORTEX_M33 1
    #define CONFIG_CPU_CORTEX_M_HAS_SYSTICK 1
    #define CONFIG_DCACHE_LINE_SIZE 32
    #define CONFIG_ICACHE_LINE_SIZE 32
    #define CONFIG_CPU_CORTEX_M_HAS_DWT 1
    #define CONFIG_CPU_CORTEX_M_HAS_BASEPRI 1
    #define CONFIG_CPU_CORTEX_M_HAS_VTOR 1
    #define CONFIG_CPU_CORTEX_M_HAS_SPLIM 1
    #define CONFIG_CPU_CORTEX_M_HAS_PROGRAMMABLE_FAULT_PRIOS 1
    #define CONFIG_CPU_CORTEX_M_HAS_CMSE 1
    #define CONFIG_ARMV7_M_ARMV8_M_MAINLINE 1
    #define CONFIG_ARMV8_M_MAINLINE 1
    #define CONFIG_ARMV8_M_SE 1
    #define CONFIG_ARMV7_M_ARMV8_M_FP 1
    #define CONFIG_ARMV8_M_DSP 1
    #define CONFIG_GEN_ISR_TABLES 1
    #define CONFIG_NULL_POINTER_EXCEPTION_DETECTION_NONE 1
    #define CONFIG_ARM_TRUSTZONE_M 1
    #define CONFIG_GEN_IRQ_VECTOR_TABLE 1
    #define CONFIG_ARM_MPU 1
    #define CONFIG_ARM_MPU_REGION_MIN_ALIGN_AND_SIZE 32
    #define CONFIG_MPU_ALLOW_FLASH_WRITE 1
    #define CONFIG_CUSTOM_SECTION_MIN_ALIGN_SIZE 32
    #define CONFIG_CPU_HAS_ARM_MPU 1
    #define CONFIG_CPU_HAS_NRF_IDAU 1
    #define CONFIG_ARM 1
    #define CONFIG_ARCH_IS_SET 1
    #define CONFIG_ARCH_LOG_LEVEL_DEFAULT 1
    #define CONFIG_ARCH_LOG_LEVEL 1
    #define CONFIG_LITTLE_ENDIAN 1
    #define CONFIG_TRUSTED_EXECUTION_NONSECURE 1
    #define CONFIG_HW_STACK_PROTECTION 1
    #define CONFIG_KOBJECT_TEXT_AREA 256
    #define CONFIG_KOBJECT_DATA_AREA_RESERVE_EXTRA_PERCENT 100
    #define CONFIG_KOBJECT_RODATA_AREA_EXTRA_BYTES 16
    #define CONFIG_GEN_PRIV_STACKS 1
    #define CONFIG_ISR_TABLES_LOCAL_DECLARATION_SUPPORTED 1
    #define CONFIG_ARCH_IRQ_VECTOR_TABLE_ALIGN 4
    #define CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_ADDRESS 1
    #define CONFIG_GEN_SW_ISR_TABLE 1
    #define CONFIG_ARCH_SW_ISR_TABLE_ALIGN 4
    #define CONFIG_GEN_IRQ_START_VECTOR 0
    #define CONFIG_EXCEPTION_DEBUG 1
    #define CONFIG_ARCH_HAS_SINGLE_THREAD_SUPPORT 1
    #define CONFIG_ARCH_HAS_TIMING_FUNCTIONS 1
    #define CONFIG_ARCH_HAS_TRUSTED_EXECUTION 1
    #define CONFIG_ARCH_HAS_STACK_PROTECTION 1
    #define CONFIG_ARCH_HAS_USERSPACE 1
    #define CONFIG_ARCH_HAS_EXECUTABLE_PAGE_BIT 1
    #define CONFIG_ARCH_HAS_RAMFUNC_SUPPORT 1
    #define CONFIG_ARCH_HAS_NESTED_EXCEPTION_DETECTION 1
    #define CONFIG_ARCH_SUPPORTS_COREDUMP 1
    #define CONFIG_ARCH_SUPPORTS_ARCH_HW_INIT 1
    #define CONFIG_ARCH_SUPPORTS_ROM_START 1
    #define CONFIG_ARCH_HAS_EXTRA_EXCEPTION_INFO 1
    #define CONFIG_ARCH_HAS_THREAD_LOCAL_STORAGE 1
    #define CONFIG_ARCH_HAS_SUSPEND_TO_RAM 1
    #define CONFIG_ARCH_HAS_THREAD_ABORT 1
    #define CONFIG_ARCH_HAS_CODE_DATA_RELOCATION 1
    #define CONFIG_CPU_HAS_TEE 1
    #define CONFIG_CPU_HAS_FPU 1
    #define CONFIG_CPU_HAS_MPU 1
    #define CONFIG_MPU 1
    #define CONFIG_MPU_LOG_LEVEL_DEFAULT 1
    #define CONFIG_MPU_LOG_LEVEL 1
    #define CONFIG_MPU_REQUIRES_NON_OVERLAPPING_REGIONS 1
    #define CONFIG_MPU_GAP_FILLING 1
    #define CONFIG_SRAM_REGION_PERMISSIONS 1
    #define CONFIG_TOOLCHAIN_HAS_BUILTIN_FFS 1
    #define CONFIG_KERNEL_LOG_LEVEL_DEFAULT 1
    #define CONFIG_KERNEL_LOG_LEVEL 1
    #define CONFIG_MULTITHREADING 1
    #define CONFIG_NUM_COOP_PRIORITIES 16
    #define CONFIG_NUM_PREEMPT_PRIORITIES 15
    #define CONFIG_MAIN_THREAD_PRIORITY 0
    #define CONFIG_COOP_ENABLED 1
    #define CONFIG_PREEMPT_ENABLED 1
    #define CONFIG_PRIORITY_CEILING -127
    #define CONFIG_THREAD_STACK_INFO 1
    #define CONFIG_SCHED_DUMB 1
    #define CONFIG_WAITQ_DUMB 1
    #define CONFIG_ERRNO 1
    #define CONFIG_BOOT_DELAY 0
    #define CONFIG_THREAD_MONITOR 1
    #define CONFIG_THREAD_NAME 1
    #define CONFIG_THREAD_MAX_NAME_LEN 32
    #define CONFIG_INSTRUMENT_THREAD_SWITCHING 1
    #define CONFIG_THREAD_RUNTIME_STATS 1
    #define CONFIG_SCHED_THREAD_USAGE 1
    #define CONFIG_SCHED_THREAD_USAGE_ALL 1
    #define CONFIG_SCHED_THREAD_USAGE_AUTO_ENABLE 1
    #define CONFIG_BARRIER_OPERATIONS_ARCH 1
    #define CONFIG_ATOMIC_OPERATIONS_BUILTIN 1
    #define CONFIG_TIMESLICING 1
    #define CONFIG_TIMESLICE_SIZE 0
    #define CONFIG_TIMESLICE_PRIORITY 0
    #define CONFIG_POLL 1
    #define CONFIG_NUM_MBOX_ASYNC_MSGS 10
    #define CONFIG_EVENTS 1
    #define CONFIG_KERNEL_MEM_POOL 1
    #define CONFIG_ARCH_HAS_CUSTOM_SWAP_TO_MAIN 1
    #define CONFIG_SWAP_NONATOMIC 1
    #define CONFIG_SYS_CLOCK_EXISTS 1
    #define CONFIG_TIMEOUT_64BIT 1
    #define CONFIG_SYS_CLOCK_MAX_TIMEOUT_DAYS 365
    #define CONFIG_XIP 1
    #define CONFIG_STACK_POINTER_RANDOM 0
    #define CONFIG_ARCH_MEM_DOMAIN_SUPPORTS_ISOLATED_STACKS 1
    #define CONFIG_MEM_DOMAIN_ISOLATED_STACKS 1
    #define CONFIG_MP_NUM_CPUS 1
    #define CONFIG_MP_MAX_NUM_CPUS 1
    #define CONFIG_TICKLESS_KERNEL 1
    #define CONFIG_TOOLCHAIN_SUPPORTS_THREAD_LOCAL_STORAGE 1
    #define CONFIG_KERNEL_INIT_PRIORITY_OBJECTS 30
    #define CONFIG_KERNEL_INIT_PRIORITY_DEFAULT 40
    #define CONFIG_KERNEL_INIT_PRIORITY_DEVICE 50
    #define CONFIG_APPLICATION_INIT_PRIORITY 90
    #define CONFIG_CLOCK_CONTROL_INIT_PRIORITY 30
    #define CONFIG_CLOCK_CONTROL_LOG_LEVEL_DEFAULT 1
    #define CONFIG_CLOCK_CONTROL_LOG_LEVEL 1
    #define CONFIG_CLOCK_CONTROL_NRF 1
    #define CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL 1
    #define CONFIG_CLOCK_CONTROL_NRF_K32SRC_50PPM 1
    #define CONFIG_CLOCK_CONTROL_NRF_ACCURACY 50
    #define CONFIG_CONSOLE 1
    #define CONFIG_CONSOLE_INPUT_MAX_LINE_LEN 128
    #define CONFIG_CONSOLE_HAS_DRIVER 1
    #define CONFIG_CONSOLE_INIT_PRIORITY 40
    #define CONFIG_RTT_CONSOLE 1
    #define CONFIG_RTT_TX_RETRY_CNT 2
    #define CONFIG_RTT_TX_RETRY_DELAY_MS 2
    #define CONFIG_UART_CONSOLE_LOG_LEVEL_DEFAULT 1
    #define CONFIG_UART_CONSOLE_LOG_LEVEL 1
    #define CONFIG_ENTROPY_GENERATOR 1
    #define CONFIG_ENTROPY_LOG_LEVEL_DEFAULT 1
    #define CONFIG_ENTROPY_LOG_LEVEL 1
    #define CONFIG_ENTROPY_INIT_PRIORITY 50
    #define CONFIG_ENTROPY_PSA_CRYPTO_RNG 1
    #define CONFIG_ENTROPY_HAS_DRIVER 1
    #define CONFIG_FLASH_HAS_DRIVER_ENABLED 1
    #define CONFIG_FLASH_HAS_EX_OP 1
    #define CONFIG_FLASH_HAS_PAGE_LAYOUT 1
    #define CONFIG_FLASH_JESD216 1
    #define CONFIG_FLASH 1
    #define CONFIG_FLASH_LOG_LEVEL_DEFAULT 1
    #define CONFIG_FLASH_LOG_LEVEL 1
    #define CONFIG_FLASH_PAGE_LAYOUT 1
    #define CONFIG_FLASH_INIT_PRIORITY 50
    #define CONFIG_SOC_FLASH_NRF 1
    #define CONFIG_SOC_FLASH_NRF_RADIO_SYNC_NONE 1
    #define CONFIG_SPI_NOR 1
    #define CONFIG_SPI_NOR_SFDP_MINIMAL 1
    #define CONFIG_SPI_NOR_INIT_PRIORITY 80
    #define CONFIG_SPI_NOR_CS_WAIT_DELAY 0
    #define CONFIG_SPI_NOR_SLEEP_WHILE_WAITING_UNTIL_READY 1
    #define CONFIG_SPI_NOR_FLASH_LAYOUT_PAGE_SIZE 65536
    #define CONFIG_GPIO_LOG_LEVEL_DEFAULT 1
    #define CONFIG_GPIO_LOG_LEVEL 1
    #define CONFIG_GPIO_INIT_PRIORITY 40
    #define CONFIG_GPIO_NRFX 1
    #define CONFIG_GPIO_NRFX_INTERRUPT 1
    #define CONFIG_INTC_INIT_PRIORITY 40
    #define CONFIG_INTC_LOG_LEVEL_DEFAULT 1
    #define CONFIG_INTC_LOG_LEVEL 1
    #define CONFIG_PINCTRL 1
    #define CONFIG_PINCTRL_LOG_LEVEL_DEFAULT 1
    #define CONFIG_PINCTRL_LOG_LEVEL 1
    #define CONFIG_PINCTRL_STORE_REG 1
    #define CONFIG_PINCTRL_NRF 1
    #define CONFIG_SERIAL 1
    #define CONFIG_SERIAL_HAS_DRIVER 1
    #define CONFIG_SERIAL_SUPPORT_ASYNC 1
    #define CONFIG_SERIAL_SUPPORT_INTERRUPT 1
    #define CONFIG_SERIAL_INIT_PRIORITY 50
    #define CONFIG_UART_LOG_LEVEL_DEFAULT 1
    #define CONFIG_UART_LOG_LEVEL 1
    #define CONFIG_UART_ASYNC_API 1
    #define CONFIG_UART_NRFX 1
    #define CONFIG_UART_NRFX_UARTE 1
    #define CONFIG_UART_NRFX_UARTE_LEGACY_SHIM 1
    #define CONFIG_UART_ASYNC_TX_CACHE_SIZE 8
    #define CONFIG_UART_0_ASYNC 1
    #define CONFIG_UART_0_ENHANCED_POLL_OUT 1
    #define CONFIG_UART_0_NRF_TX_BUFFER_SIZE 32
    #define CONFIG_UART_0_NRF_HW_ASYNC 1
    #define CONFIG_UART_0_NRF_HW_ASYNC_TIMER 1
    #define CONFIG_UART_0_GPIO_MANAGEMENT 1
    #define CONFIG_UART_1_ASYNC 1
    #define CONFIG_UART_1_ENHANCED_POLL_OUT 1
    #define CONFIG_UART_1_NRF_TX_BUFFER_SIZE 32
    #define CONFIG_UART_1_NRF_HW_ASYNC 1
    #define CONFIG_UART_1_NRF_HW_ASYNC_TIMER 2
    #define CONFIG_UART_1_GPIO_MANAGEMENT 1
    #define CONFIG_SPI_INIT_PRIORITY 50
    #define CONFIG_SPI_COMPLETION_TIMEOUT_TOLERANCE 200
    #define CONFIG_SPI_LOG_LEVEL_DEFAULT 1
    #define CONFIG_SPI_LOG_LEVEL 1
    #define CONFIG_SPI_NRFX 1
    #define CONFIG_SPI_NRFX_SPIM 1
    #define CONFIG_SPI_NRFX_RAM_BUFFER_SIZE 8
    #define CONFIG_SPI_NRFX_WAKE_TIMEOUT_US 200
    #define CONFIG_SYSTEM_CLOCK_INIT_PRIORITY 0
    #define CONFIG_TICKLESS_CAPABLE 1
    #define CONFIG_SYSTEM_TIMER_HAS_DISABLE_SUPPORT 1
    #define CONFIG_SYSTEM_CLOCK_WAIT_FOR_STABILITY 1
    #define CONFIG_NRF_USBD_COMMON_LOG_LEVEL_DEFAULT 1
    #define CONFIG_NRF_USBD_COMMON_LOG_LEVEL 1
    #define CONFIG_USBC_LOG_LEVEL_DEFAULT 1
    #define CONFIG_USBC_LOG_LEVEL 1
    #define CONFIG_NET_TCP_WORKQ_STACK_SIZE 1024
    #define CONFIG_REQUIRES_FULL_LIBC 1
    #define CONFIG_FULL_LIBC_SUPPORTED 1
    #define CONFIG_MINIMAL_LIBC_SUPPORTED 1
    #define CONFIG_NEWLIB_LIBC_SUPPORTED 1
    #define CONFIG_PICOLIBC_SUPPORTED 1
    #define CONFIG_NATIVE_LIBC_INCOMPATIBLE 1
    #define CONFIG_NEWLIB_LIBC 1
    #define CONFIG_HAS_NEWLIB_LIBC_NANO 1
    #define CONFIG_COMMON_LIBC_ABORT 1
    #define CONFIG_NEWLIB_LIBC_MIN_REQUIRED_HEAP_SIZE 8192
    #define CONFIG_STDOUT_CONSOLE 1
    #define CONFIG_NEED_LIBC_MEM_PARTITION 1
    #define CONFIG_CPP 1
    #define CONFIG_STD_CPP11 1
    #define CONFIG_FULL_LIBCPP_SUPPORTED 1
    #define CONFIG_GLIBCXX_LIBCPP 1
    #define CONFIG_CPP_EXCEPTIONS 1
    #define CONFIG_CPP_STATIC_INIT_GNU 1
    #define CONFIG_CRC 1
    #define CONFIG_SYS_HEAP_ALLOC_LOOPS 3
    #define CONFIG_SYS_HEAP_AUTO 1
    #define CONFIG_FDTABLE 1
    #define CONFIG_REBOOT 1
    #define CONFIG_HAS_POWEROFF 1
    #define CONFIG_CBPRINTF_COMPLETE 1
    #define CONFIG_CBPRINTF_FULL_INTEGRAL 1
    #define CONFIG_CBPRINTF_N_SPECIFIER 1
    #define CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DEFAULT 1
    #define CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL 1
    #define CONFIG_CBPRINTF_CONVERT_CHECK_PTR 1
    #define CONFIG_POSIX_API 1
    #define CONFIG_PTHREAD_IPC 1
    #define CONFIG_POSIX_ASYNCHRONOUS_IO 1
    #define CONFIG_PTHREAD_BARRIER 1
    #define CONFIG_MAX_PTHREAD_BARRIER_COUNT 5
    #define CONFIG_PTHREAD_BARRIER_LOG_LEVEL_DEFAULT 1
    #define CONFIG_PTHREAD_BARRIER_LOG_LEVEL 1
    #define CONFIG_POSIX_CLOCK 1
    #define CONFIG_PTHREAD_COND 1
    #define CONFIG_MAX_PTHREAD_COND_COUNT 5
    #define CONFIG_PTHREAD_COND_LOG_LEVEL_DEFAULT 1
    #define CONFIG_PTHREAD_COND_LOG_LEVEL 1
    #define CONFIG_POSIX_CONFSTR 1
    #define CONFIG_POSIX_ENV_LOG_LEVEL_DEFAULT 1
    #define CONFIG_POSIX_ENV_LOG_LEVEL 1
    #define CONFIG_EVENTFD 1
    #define CONFIG_EVENTFD_MAX 1
    #define CONFIG_FNMATCH 1
    #define CONFIG_PTHREAD_KEY 1
    #define CONFIG_MAX_PTHREAD_KEY_COUNT 5
    #define CONFIG_PTHREAD_KEY_LOG_LEVEL_DEFAULT 1
    #define CONFIG_PTHREAD_KEY_LOG_LEVEL 1
    #define CONFIG_POSIX_MQUEUE 1
    #define CONFIG_MSG_COUNT_MAX 16
    #define CONFIG_MSG_SIZE_MAX 16
    #define CONFIG_MQUEUE_NAMELEN_MAX 16
    #define CONFIG_HEAP_MEM_POOL_ADD_SIZE_MQUEUE 1024
    #define CONFIG_PTHREAD_MUTEX 1
    #define CONFIG_MAX_PTHREAD_MUTEX_COUNT 5
    #define CONFIG_PTHREAD_MUTEX_LOG_LEVEL_DEFAULT 1
    #define CONFIG_PTHREAD_MUTEX_LOG_LEVEL 1
    #define CONFIG_POSIX_NETWORKING 1
    #define CONFIG_PTHREAD 1
    #define CONFIG_MAX_PTHREAD_COUNT 5
    #define CONFIG_PTHREAD_LOG_LEVEL_DEFAULT 1
    #define CONFIG_PTHREAD_LOG_LEVEL 1
    #define CONFIG_PTHREAD_RECYCLER_DELAY_MS 100
    #define CONFIG_POSIX_PTHREAD_ATTR_STACKSIZE_BITS 23
    #define CONFIG_POSIX_PTHREAD_ATTR_GUARDSIZE_BITS 9
    #define CONFIG_POSIX_PTHREAD_ATTR_GUARDSIZE_DEFAULT 0
    #define CONFIG_PTHREAD_RWLOCK 1
    #define CONFIG_MAX_PTHREAD_RWLOCK_COUNT 5
    #define CONFIG_PTHREAD_RWLOCK_LOG_LEVEL_DEFAULT 1
    #define CONFIG_PTHREAD_RWLOCK_LOG_LEVEL 1
    #define CONFIG_POSIX_PRIORITY_SCHEDULING 1
    #define CONFIG_SEM_VALUE_MAX 32767
    #define CONFIG_SEM_NAMELEN_MAX 16
    #define CONFIG_POSIX_RTSIG_MAX 31
    #define CONFIG_POSIX_SIGNAL 1
    #define CONFIG_POSIX_SIGNAL_STRING_DESC 1
    #define CONFIG_POSIX_LIMITS_RTSIG_MAX 8
    #define CONFIG_PTHREAD_SPINLOCK 1
    #define CONFIG_MAX_PTHREAD_SPINLOCK_COUNT 5
    #define CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL_DEFAULT 1
    #define CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL 1
    #define CONFIG_POSIX_PUTMSG 1
    #define CONFIG_POSIX_SYSCONF 1
    #define CONFIG_POSIX_PAGE_SIZE_BITS 12
    #define CONFIG_POSIX_SYSCONF_IMPL_FULL 1
    #define CONFIG_POSIX_SYSLOG 1
    #define CONFIG_TIMER 1
    #define CONFIG_MAX_TIMER_COUNT 5
    #define CONFIG_TIMER_LOG_LEVEL_DEFAULT 1
    #define CONFIG_TIMER_LOG_LEVEL 1
    #define CONFIG_TIMER_CREATE_WAIT 100
    #define CONFIG_TIMER_DELAYTIMER_MAX 20
    #define CONFIG_POSIX_UNAME 1
    #define CONFIG_POSIX_UNAME_VERSION_LEN 70
    #define CONFIG_POSIX_UNAME_NODENAME_LEN 6
    #define CONFIG_LIBGCC_RTLIB 1
    #define CONFIG_NOTIFY 1
    #define CONFIG_ONOFF 1
    #define CONFIG_THREAD_ANALYZER 1
    #define CONFIG_THREAD_ANALYZER_LOG_LEVEL_DEFAULT 1
    #define CONFIG_THREAD_ANALYZER_LOG_LEVEL 1
    #define CONFIG_THREAD_ANALYZER_USE_PRINTK 1
    #define CONFIG_THREAD_ANALYZER_ISR_STACK_USAGE 1
    #define CONFIG_THREAD_ANALYZER_RUN_UNLOCKED 1
    #define CONFIG_PRINTK 1
    #define CONFIG_EARLY_CONSOLE 1
    #define CONFIG_ASSERT 1
    #define CONFIG_ASSERT_LEVEL 2
    #define CONFIG_SPIN_VALIDATE 1
    #define CONFIG_ASSERT_VERBOSE 1
    #define CONFIG_DEBUG_THREAD_INFO 1
    #define CONFIG_IMG_MANAGER 1
    #define CONFIG_MCUBOOT_IMG_MANAGER 1
    #define CONFIG_MCUBOOT_TRAILER_SWAP_TYPE 1
    #define CONFIG_MCUBOOT_UPDATE_FOOTER_SIZE 0x0
    #define CONFIG_IMG_BLOCK_BUF_SIZE 512
    #define CONFIG_IMG_MANAGER_LOG_LEVEL_DEFAULT 1
    #define CONFIG_IMG_MANAGER_LOG_LEVEL 1
    #define CONFIG_LLEXT_EDK_NAME "llext-edk"
    #define CONFIG_LOG 1
    #define CONFIG_LOG_CORE_INIT_PRIORITY 0
    #define CONFIG_LOG_MODE_IMMEDIATE 1
    #define CONFIG_LOG_DEFAULT_LEVEL 1
    #define CONFIG_LOG_OVERRIDE_LEVEL 0
    #define CONFIG_LOG_MAX_LEVEL 4
    #define CONFIG_LOG_PRINTK 1
    #define CONFIG_LOG_TRACE_SHORT_TIMESTAMP 1
    #define CONFIG_LOG_FUNC_NAME_PREFIX_DBG 1
    #define CONFIG_LOG_BACKEND_SHOW_COLOR 1
    #define CONFIG_LOG_TAG_MAX_LEN 0
    #define CONFIG_LOG_BACKEND_FORMAT_TIMESTAMP 1
    #define CONFIG_LOG_BACKEND_RTT 1
    #define CONFIG_LOG_BACKEND_RTT_MODE_BLOCK 1
    #define CONFIG_LOG_BACKEND_RTT_OUTPUT_TEXT 1
    #define CONFIG_LOG_BACKEND_RTT_OUTPUT_DEFAULT 0
    #define CONFIG_LOG_BACKEND_RTT_OUTPUT_BUFFER_SIZE 16
    #define CONFIG_LOG_BACKEND_RTT_RETRY_CNT 4
    #define CONFIG_LOG_BACKEND_RTT_RETRY_DELAY_MS 5
    #define CONFIG_LOG_BACKEND_RTT_BUFFER 0
    #define CONFIG_LOG_BACKEND_RTT_FORCE_PRINTK 1
    #define CONFIG_LOG_DOMAIN_ID 0
    #define CONFIG_LOG_USE_VLA 1
    #define CONFIG_LOG_SIMPLE_MSG_OPTIMIZE 1
    #define CONFIG_LOG_ALWAYS_RUNTIME 1
    #define CONFIG_LOG_OUTPUT 1
    #define CONFIG_MEM_ATTR 1
    #define CONFIG_NET_BUF 1
    #define CONFIG_NET_BUF_LOG_LEVEL_DEFAULT 1
    #define CONFIG_NET_BUF_LOG_LEVEL 1
    #define CONFIG_NET_BUF_ALIGNMENT 0
    #define CONFIG_NETWORKING 1
    #define CONFIG_NET_IP 1
    #define CONFIG_NET_NATIVE 1
    #define CONFIG_NET_NATIVE_IP 1
    #define CONFIG_NET_NATIVE_IPV6 1
    #define CONFIG_NET_NATIVE_IPV4 1
    #define CONFIG_NET_NATIVE_TCP 1
    #define CONFIG_NET_NATIVE_UDP 1
    #define CONFIG_NET_OFFLOADING_SUPPORT 1
    #define CONFIG_NET_INIT_PRIO 90
    #define CONFIG_NET_IP_DSCP_ECN 1
    #define CONFIG_NET_IF_MAX_IPV6_COUNT 1
    #define CONFIG_NET_IF_UNICAST_IPV6_ADDR_COUNT 2
    #define CONFIG_NET_IF_MCAST_IPV6_ADDR_COUNT 3
    #define CONFIG_NET_IF_IPV6_PREFIX_COUNT 2
    #define CONFIG_NET_IPV6_MTU 1280
    #define CONFIG_NET_INITIAL_HOP_LIMIT 64
    #define CONFIG_NET_INITIAL_MCAST_HOP_LIMIT 1
    #define CONFIG_NET_IPV6_MAX_NEIGHBORS 8
    #define CONFIG_NET_IPV6_ND 1
    #define CONFIG_NET_IPV6_DAD 1
    #define CONFIG_NET_IPV6_LOG_LEVEL_DEFAULT 1
    #define CONFIG_NET_IPV6_LOG_LEVEL 1
    #define CONFIG_NET_IPV6_ND_LOG_LEVEL_DEFAULT 1
    #define CONFIG_NET_IPV6_ND_LOG_LEVEL 1
    #define CONFIG_NET_IPV6_PE_LOG_LEVEL_DEFAULT 1
    #define CONFIG_NET_IPV6_PE_LOG_LEVEL 1
    #define CONFIG_NET_ICMPV6_LOG_LEVEL_DEFAULT 1
    #define CONFIG_NET_ICMPV6_LOG_LEVEL 1
    #define CONFIG_NET_IPV6_NBR_CACHE_LOG_LEVEL_DEFAULT 1
    #define CONFIG_NET_IPV6_NBR_CACHE_LOG_LEVEL 1
    #define CONFIG_NET_IPV4 1
    #define CONFIG_NET_INITIAL_TTL 64
    #define CONFIG_NET_INITIAL_MCAST_TTL 1
    #define CONFIG_NET_IF_MAX_IPV4_COUNT 1
    #define CONFIG_NET_IF_UNICAST_IPV4_ADDR_COUNT 1
    #define CONFIG_NET_IF_MCAST_IPV4_ADDR_COUNT 1
    #define CONFIG_NET_IF_MCAST_IPV4_SOURCE_COUNT 1
    #define CONFIG_NET_IPV4_LOG_LEVEL_DEFAULT 1
    #define CONFIG_NET_IPV4_LOG_LEVEL 1
    #define CONFIG_NET_ICMPV4_LOG_LEVEL_DEFAULT 1
    #define CONFIG_NET_ICMPV4_LOG_LEVEL 1
    #define CONFIG_NET_TC_RX_COUNT 1
    #define CONFIG_NET_TC_THREAD_COOPERATIVE 1
    #define CONFIG_NET_TC_NUM_PRIORITIES 16
    #define CONFIG_NET_TC_MAPPING_STRICT 1
    #define CONFIG_NET_TX_DEFAULT_PRIORITY 1
    #define CONFIG_NET_RX_DEFAULT_PRIORITY 0
    #define CONFIG_NET_IP_ADDR_CHECK 1
    #define CONFIG_NET_MAX_ROUTERS 2
    #define CONFIG_NET_ROUTE 1
    #define CONFIG_NET_MAX_ROUTES 8
    #define CONFIG_NET_MAX_NEXTHOPS 8
    #define CONFIG_NET_TCP 1
    #define CONFIG_NET_TCP_LOG_LEVEL_DEFAULT 1
    #define CONFIG_NET_TCP_LOG_LEVEL 1
    #define CONFIG_NET_TCP_WORKER_PRIO 2
    #define CONFIG_NET_TCP_TIME_WAIT_DELAY 1500
    #define CONFIG_NET_TCP_ACK_TIMEOUT 1000
    #define CONFIG_NET_TCP_INIT_RETRANSMISSION_TIMEOUT 200
    #define CONFIG_NET_TCP_RANDOMIZED_RTO 1
    #define CONFIG_NET_TCP_RETRY_COUNT 9
    #define CONFIG_NET_TCP_MAX_SEND_WINDOW_SIZE 0
    #define CONFIG_NET_TCP_MAX_RECV_WINDOW_SIZE 0
    #define CONFIG_NET_TCP_RECV_QUEUE_TIMEOUT 2000
    #define CONFIG_NET_TCP_PKT_ALLOC_TIMEOUT 100
    #define CONFIG_NET_TCP_CHECKSUM 1
    #define CONFIG_NET_TCP_FAST_RETRANSMIT 1
    #define CONFIG_NET_TCP_CONGESTION_AVOIDANCE 1
    #define CONFIG_NET_TCP_REJECT_CONN_WITH_RST 1
    #define CONFIG_NET_UDP 1
    #define CONFIG_NET_UDP_CHECKSUM 1
    #define CONFIG_NET_UDP_MISSING_CHECKSUM 1
    #define CONFIG_NET_UDP_LOG_LEVEL_DEFAULT 1
    #define CONFIG_NET_UDP_LOG_LEVEL 1
    #define CONFIG_NET_MAX_CONN 8
    #define CONFIG_NET_MAX_CONTEXTS 6
    #define CONFIG_NET_CONTEXT_SYNC_RECV 1
    #define CONFIG_NET_CONTEXT_CHECK 1
    #define CONFIG_NET_CONTEXT_DSCP_ECN 1
    #define CONFIG_NET_CONTEXT_REUSEADDR 1
    #define CONFIG_NET_CONTEXT_REUSEPORT 1
    #define CONFIG_NET_BUF_RX_COUNT 16
    #define CONFIG_NET_BUF_TX_COUNT 16
    #define CONFIG_NET_BUF_FIXED_DATA_SIZE 1
    #define CONFIG_NET_BUF_DATA_SIZE 128
    #define CONFIG_NET_PKT_BUF_USER_DATA_SIZE 4
    #define CONFIG_NET_DEFAULT_IF_FIRST 1
    #define CONFIG_NET_INTERFACE_NAME 1
    #define CONFIG_NET_MGMT 1
    #define CONFIG_NET_MGMT_EVENT 1
    #define CONFIG_NET_MGMT_EVENT_THREAD 1
    #define CONFIG_NET_MGMT_EVENT_QUEUE 1
    #define CONFIG_NET_MGMT_EVENT_QUEUE_TIMEOUT 10
    #define CONFIG_NET_MGMT_EVENT_LOG_LEVEL_DEFAULT 1
    #define CONFIG_NET_MGMT_EVENT_LOG_LEVEL 1
    #define CONFIG_NET_STATISTICS 1
    #define CONFIG_NET_STATISTICS_LOG_LEVEL_DEFAULT 1
    #define CONFIG_NET_STATISTICS_LOG_LEVEL 1
    #define CONFIG_NET_STATISTICS_PER_INTERFACE 1
    #define CONFIG_NET_STATISTICS_IPV4 1
    #define CONFIG_NET_STATISTICS_IPV6 1
    #define CONFIG_NET_STATISTICS_IPV6_ND 1
    #define CONFIG_NET_STATISTICS_ICMP 1
    #define CONFIG_NET_STATISTICS_UDP 1
    #define CONFIG_NET_STATISTICS_TCP 1
    #define CONFIG_NET_STATISTICS_MLD 1
    #define CONFIG_NET_LOG 1
    #define CONFIG_NET_PKT_LOG_LEVEL_DEFAULT 1
    #define CONFIG_NET_PKT_LOG_LEVEL 1
    #define CONFIG_NET_DEBUG_NET_PKT_EXTERNALS 0
    #define CONFIG_NET_CORE_LOG_LEVEL_DEFAULT 1
    #define CONFIG_NET_CORE_LOG_LEVEL 1
    #define CONFIG_NET_IF_LOG_LEVEL_DEFAULT 1
    #define CONFIG_NET_IF_LOG_LEVEL 1
    #define CONFIG_NET_TC_LOG_LEVEL_DEFAULT 1
    #define CONFIG_NET_TC_LOG_LEVEL 1
    #define CONFIG_NET_UTILS_LOG_LEVEL_DEFAULT 1
    #define CONFIG_NET_UTILS_LOG_LEVEL 1
    #define CONFIG_NET_CONTEXT_LOG_LEVEL_DEFAULT 1
    #define CONFIG_NET_CONTEXT_LOG_LEVEL 1
    #define CONFIG_NET_CONN_LOG_LEVEL_DEFAULT 1
    #define CONFIG_NET_CONN_LOG_LEVEL 1
    #define CONFIG_NET_ROUTE_LOG_LEVEL_DEFAULT 1
    #define CONFIG_NET_ROUTE_LOG_LEVEL 1
    #define CONFIG_NET_HTTP_LOG_LEVEL_DEFAULT 1
    #define CONFIG_NET_HTTP_LOG_LEVEL 1
    #define CONFIG_NET_HTTP_SERVER_LOG_LEVEL_DEFAULT 1
    #define CONFIG_NET_HTTP_SERVER_LOG_LEVEL 1
    #define CONFIG_NET_CONFIG_LOG_LEVEL_DEFAULT 1
    #define CONFIG_NET_CONFIG_LOG_LEVEL 1
    #define CONFIG_NET_CONFIG_SETTINGS 1
    #define CONFIG_NET_CONFIG_AUTO_INIT 1
    #define CONFIG_NET_CONFIG_INIT_PRIO 95
    #define CONFIG_NET_CONFIG_INIT_TIMEOUT 30
    #define CONFIG_NET_CONFIG_MY_IPV6_ADDR ""
    #define CONFIG_NET_CONFIG_PEER_IPV6_ADDR ""
    #define CONFIG_NET_CONFIG_MY_IPV4_ADDR ""
    #define CONFIG_NET_CONFIG_MY_IPV4_NETMASK "255.255.255.0"
    #define CONFIG_NET_CONFIG_MY_IPV4_GW ""
    #define CONFIG_NET_CONFIG_PEER_IPV4_ADDR ""
    #define CONFIG_NET_SOCKETS 1
    #define CONFIG_NET_SOCKETS_PRIORITY_DEFAULT 50
    #define CONFIG_NET_SOCKETS_CONNECT_TIMEOUT 3000
    #define CONFIG_NET_SOCKET_MAX_SEND_WAIT 10000
    #define CONFIG_NET_SOCKETS_TLS_PRIORITY 45
    #define CONFIG_NET_SOCKETS_TLS_SET_MAX_FRAGMENT_LENGTH 1
    #define CONFIG_NET_SOCKETS_OFFLOAD 1
    #define CONFIG_NET_SOCKETS_OFFLOAD_PRIORITY 40
    #define CONFIG_NET_SOCKETS_LOG_LEVEL_ERR 1
    #define CONFIG_NET_SOCKETS_LOG_LEVEL 1
    #define CONFIG_NET_DHCPV6_DUID_MAX_LEN 22
    #define CONFIG_PM_DEVICE 1
    #define CONFIG_PM_DEVICE_LOG_LEVEL_DEFAULT 1
    #define CONFIG_PM_DEVICE_LOG_LEVEL 1
    #define CONFIG_PM_DEVICE_POWER_DOMAIN 1
    #define CONFIG_TIMER_RANDOM_INITIAL_STATE 123456789
    #define CONFIG_ENTROPY_DEVICE_RANDOM_GENERATOR 1
    #define CONFIG_CSPRNG_ENABLED 1
    #define CONFIG_HARDWARE_DEVICE_CS_GENERATOR 1
    #define CONFIG_FLASH_MAP 1
    #define CONFIG_STREAM_FLASH 1
    #define CONFIG_STREAM_FLASH_LOG_LEVEL_DEFAULT 1
    #define CONFIG_STREAM_FLASH_LOG_LEVEL 1
    #define CONFIG_COVERAGE_GCOV_HEAP_SIZE 16384
    #define CONFIG_TOOLCHAIN_ZEPHYR_0_16 1
    #define CONFIG_TOOLCHAIN_ZEPHYR_SUPPORTS_THREAD_LOCAL_STORAGE 1
    #define CONFIG_LINKER_ORPHAN_SECTION_WARN 1
    #define CONFIG_HAS_FLASH_LOAD_OFFSET 1
    #define CONFIG_USE_DT_CODE_PARTITION 1
    #define CONFIG_ROM_END_OFFSET 0x0
    #define CONFIG_LD_LINKER_SCRIPT_SUPPORTED 1
    #define CONFIG_LD_LINKER_TEMPLATE 1
    #define CONFIG_KERNEL_ENTRY "__start"
    #define CONFIG_LINKER_SORT_BY_ALIGNMENT 1
    #define CONFIG_SRAM_OFFSET 0x0
    #define CONFIG_LINKER_GENERIC_SECTIONS_PRESENT_AT_BOOT 1
    #define CONFIG_LINKER_LAST_SECTION_ID 1
    #define CONFIG_LINKER_LAST_SECTION_ID_PATTERN 0xE015E015
    #define CONFIG_LINKER_USE_RELAX 1
    #define CONFIG_LINKER_ITERABLE_SUBALIGN 4
    #define CONFIG_LINKER_DEVNULL_SUPPORT 1
    #define CONFIG_STD_C99 1
    #define CONFIG_TOOLCHAIN_SUPPORTS_GNU_EXTENSIONS 1
    #define CONFIG_DEBUG_OPTIMIZATIONS 1
    #define CONFIG_COMPILER_TRACK_MACRO_EXPANSION 1
    #define CONFIG_COMPILER_COLOR_DIAGNOSTICS 1
    #define CONFIG_FORTIFY_SOURCE_COMPILE_TIME 1
    #define CONFIG_COMPILER_OPT ""
    #define CONFIG_RUNTIME_ERROR_CHECKS 1
    #define CONFIG_KERNEL_BIN_NAME "zephyr"
    #define CONFIG_OUTPUT_STAT 1
    #define CONFIG_OUTPUT_PRINT_MEMORY_USAGE 1
    #define CONFIG_BUILD_OUTPUT_BIN 1
    #define CONFIG_BUILD_OUTPUT_META 1
    #define CONFIG_BUILD_OUTPUT_STRIP_PATHS 1
    #define CONFIG_CHECK_INIT_PRIORITIES 1
    #define CONFIG_WARN_DEPRECATED 1
    #define CONFIG_ENFORCE_ZEPHYR_STDINT 1
    #define CONFIG_ENABLE_RTT_LOGS 1
    #define CONFIG_DEBUG_UART_DISABLED 1
    #define CONFIG_GA_THREAD_ANALYZER 1
    #define CONFIG_GA_INCLUDE_BOOTLOADER 1
    #define CONFIG_GA_EXTERNAL_FLASH 1
    #define CONFIG_EXT_FLASH_SELF_TEST_ENABLED 1
    Hi Hakon,
    I am having modem firmware 1.3.6 and nordic sdk version 2.7.0.
    Please find the attached autoconf and can you please verify if I am missing out on some config which is needed for server connection.
    Also, I tried some AT commands such as
    1. "AT+CFUN=1"
    2. "AT+CEREG?"
    The above listed commands work fine commands related to socket creation; connection does not work. e.g. "AT#XSOCKET=1,1,1" gives error.
    Can you please help me with why I am not able to connect to server and why socket related AT commands does not work.
    Akshay
  • AR Jadhav said:
    Also, can you tell, how much memory it takes when modem trace is enabled?
    Have you tried running west build -d build/appimage -t ram_report to see what is taking up the space?
  • Have you tried reducing NRF_MODEM_LIB_SHMEM_TRACE_SIZE?
  • I have not tried this, But with the latest updates my issue got resolved
