nRF9160 fails to connect to server with IP and port number. Gives 116 (timeout error)?
I have nRF9160, modem FW = 1.3.6 and nrf sdk version 2.7.0.
I am trying to create an outgoing socket with connects to specific port num and ip address but I am getting timeout error with value 116. I am attaching the code snippet below for your reference.
int sock = socket(AF_INET, SOCK_STREAM, IPPROTO_TCP);
    if (sock < 0)
        printk("Failed to create socket: %d\n", errno);
        return AtJsonTypes::CONNECT_FAILED;
    struct sockaddr_in server;
    server.sin_family = AF_INET;
    server.sin_port = htons(SERVER_PORT);
    if (inet_pton(AF_INET, SERVER_IP, &server.sin_addr) <= 0)
        printk("Invalid address/ Address not supported\n");
        close(sock);
    if (CellConnection::IsCellConnected() == CellConnection::CONNECTED)
        printk("Modem is conneted to network\n");
        printk("No modem connection\n");
    int retries = 3;
    while (retries > 0)
        printk("Device IP is %s and Port num is %d\n", SERVER_IP, SERVER_PORT);
        int ret = connect(sock, (struct sockaddr *)&server, sizeof(server));
        if (ret == 0)
            // Connection successful
            printk("Connected to %s at port num %d\n", SERVER_IP, SERVER_PORT);
        else if (errno == ETIMEDOUT)
            // Handle timeout
            printk("Failed to connect socket timeout: %d\n", errno);
            retries--;
            sleep(1); // Wait before retrying
            // Handle other errors
            printk("Failed to connect socket: %d\n", errno);
Could you please help?
