nrf5340: How to set image version (SDK is ncs V2.5.2)
Hi Support Team,
I tried several ways to set the image version but failed. My SDK is ncs V2.5.2.
1. set(CONFIG_MCUBOOT_IMAGE_VERSION "1.0.0") in CMakeLists.txt: did not work.
2. try to set CONFIG_MCUBOOT_IMAGE_VERSION="1.0.0" in prj.conf or child_image\mcuboot.conf: both results are undefined symbol MCUBOOT_IMAGE_VERSION
3. try to set CONFIG_FW_INFO_FIRMWARE_VERSION=1 in child_image and \mcuboot.conf: , did not work.
When I use the below command to check the image version, it always is version: 0.0.0+0:
python C:\ncs\v2.5.2\bootloader\mcuboot\scripts\imgtool.py dumpinfo app_update.bin
Printing content of signed image: app_update.bin
#### Image header (offset: 0x0) ############################
magic:              0x96f3b83d
load_addr:          0x0
hdr_size:           0x200
protected_tlv_size: 0x0
img_size:           0x4afe0
flags:              0x0
version:            0.0.0+0
Could you help clarify the config in prj.conf and child_image\mcuboot.conf for the image version setting? When I upload the new image to the slot 1, MCUboot not swap and run it, I guess the reason is both new and old image have the same version 0.0.0+0.
Thank you very much.
Yanpeng Wu
