Hi, guys. I encountered some software issues while using VS Code for development on the nRF5340 DK. During the build configuration, the code reports an error saying it cannot find the board. I’ve checked that both Python and West are properly installed and added to the system environment path, so the setup should be correct. The error appears on line 196 of the boards.cmake file. The SDK is v2.9.1 and also the toolchain is v2.9.1.
At the same time, I ran into a problem with a software called SFXWiz32-gcc, which gives an “insufficient memory” error during execution. I’ve confirmed that my system has enough memory, and I’ve also configured virtual memory. My computer is running Windows 11, and based on my checks, this software is supposed to work on a 64-bit system. However, the issue persists. I also tried manually extracting the file using tools like 7-Zip, but access to the file is denied.
Are these two problems related? Has anyone encountered similar issues and found a solution? I greatly appreciate any guidance or help. Thank you.
