Rotate st7789v display with LVGL
Im trying to rotate my st7789v 240x240 display with LVGL commands. Im using nRF5340.
My .dts
	mipi_dbi_st7789v {
		compatible = "zephyr,mipi-dbi-spi";
		spi-dev = <&spi1>;
        dc-gpios = <&gpio1 11 GPIO_ACTIVE_HIGH>;
        reset-gpios = <&gpio1 5 GPIO_ACTIVE_LOW>;
		write-only;
		#address-cells = <1>;
		#size-cells = <0>;
		st7789v: st7789v@0 {
			compatible = "sitronix,st7789v";
			mipi-max-frequency = <8000000>;
			reg = <0>;
			width = <240>;
			height = <240>;
			x-offset = <0>;
			y-offset = <0>;
			vcom = <0x19>;
			gctrl = <0x35>;
			vrhs = <0x12>;
			vdvs = <0x20>;
			mdac = <0x00>;
			gamma = <0x01>;
			colmod = <0x05>;
			lcm = <0x2c>;
			porch-param = [0c 0c 00 33 33];
			cmd2en-param = [5a 69 02 01];
			pwctrl1-param = [a4 a1];
			pvgam-param = [D0 04 0D 11 13 2B 3F 54 4C 18 0D 0B 1F 23];
			nvgam-param = [D0 04 0C 11 13 2C 3F 44 51 2F 1F 1F 20 23];
			ram-param = [00 F0];
			rgb-param = [CD 08 14];
			mipi-mode = <MIPI_DBI_MODE_SPI_4WIRE>;
My code:
void ui_init(void)
    lv_disp_t * dispp = lv_disp_get_default();
    lv_disp_set_rotation(dispp, LV_DISP_ROT_270);
    lv_theme_t * theme = lv_theme_default_init(dispp, lv_palette_main(LV_PALETTE_BLUE), lv_palette_main(LV_PALETTE_RED),
                                               true, LV_FONT_DEFAULT);
    lv_disp_set_theme(dispp, theme);
    ui_screenMain_screen_init();
    ui____initial_actions0 = lv_obj_create(NULL);
    lv_disp_load_scr(ui_screenMain);
But this dont make any change on my rotation.
Someone can help me with this?
Tanks a lot.
  • mipi_dbi_st7789v {
    spi-dev = <&spi1>;
    write-only;
    #size-cells = <0>;
    reg = <0>;
    width = <240>;
    height = <240>;
    x-offset = <80>;
    y-offset = <0>;
    vcom = <0x19>;
    gctrl = <0x35>;
    vrhs = <0x12>;
    vdvs = <0x20>;
    mdac = <0xA0>;
    gamma = <0x01>;
    colmod = <0x05>;
    lcm = <0x2c>;
    Change to this, I can able to rotate display on 270 degrees.
    You need to define st7789v dispaly under SPI subnode.
