ADV data parse, system assert Invalid spinlock
Hi
I have a beacon sending out some data, and I have already finish the TX side, I also want to have a RX side to receive the data, in addition, as there are many other deivices advertising, I want to only receive one device, the name is "TX beacon".
I have write my code like below:
 #include <zephyr/types.h>
 #include <stddef.h>
 #include <string.h>
 #include <zephyr/kernel.h>
 #include <zephyr/bluetooth/hci.h>
 static bool manuf_data_print(struct bt_data *data, void *user_data)
	 if (data->type == BT_DATA_MANUFACTURER_DATA) {
		 printk("Manufacturer Data (len %u): ", data->data_len);
		 for (uint8_t i = 0; i < data->data_len; i++) {
			 printk("%02X ", data->data[i]);
		 printk("\n");
	 return true;
 static bool parse_name_cb(struct bt_data *data, void *user_data)
	 char *dev_name = user_data;
	 if (data->type == BT_DATA_NAME_COMPLETE || data->type == BT_DATA_NAME_SHORTENED) {
		 memcpy(dev_name, data->data, data->data_len);
		 dev_name[data->data_len] = '\0';
		 return false;
	 return true;
 static void scan_recv_cb(const bt_addr_le_t *addr, int8_t rssi,
	uint8_t adv_type, struct net_buf_simple *buf)
char addr_str[BT_ADDR_LE_STR_LEN];
char dev_name[31] = {0};
uint8_t backup_buf[buf->len];
memcpy(backup_buf, buf->data, buf->len);
struct net_buf_simple backup;
net_buf_simple_init_with_data(&backup, backup_buf, buf->len);
bt_data_parse(buf, parse_name_cb, dev_name);
if (strcmp(dev_name, "TX beacon") == 0) {printk("Target device found!\n");
// // bt_addr_le_to_str(addr, addr_str, sizeof(addr_str));
// // printk("Target device found: %s (RSSI %d)\n", addr_str, rssi);
bt_data_parse(&backup, manuf_data_print, NULL);}
	 int err;
	 printk("BLE Scanner started\n");
	 err = bt_enable(NULL);
	 if (err) {
		 printk("Bluetooth init failed (err %d)\n", err);
		 return err;
	 printk("Bluetooth initialized\n");
	 struct bt_le_scan_param scan_param = {
		 .type     = BT_LE_SCAN_TYPE_ACTIVE,
		 .options  = BT_LE_SCAN_OPT_NONE,
		 .interval = 0x0060,  /* 扫描间隔:60 * 0.625 = 37.5ms */
		 .window   = 0x0030,  /* 扫描窗口:约18.75ms */
	 err = bt_le_scan_start(&scan_param, scan_recv_cb);
	 if (err) {
		 printk("Starting scanning failed (err %d)\n", err);
		 return err;
	 printk("Scanning successfully started\n");
	 while (1) {
		 k_sleep(K_SECONDS(1));
	 return 0;
My config is:
# 启用蓝牙子系统
CONFIG_BT=y
# Enable the UART driver
CONFIG_UART_ASYNC_API=y
CONFIG_NRFX_UARTE0=y
CONFIG_SERIAL=y
CONFIG_CONSOLE=y
CONFIG_UART_CONSOLE=y
# 启用观察者角色,允许扫描广告数据
CONFIG_BT_OBSERVER=y
# 启用 BLE 扫描相关 API
CONFIG_BT_SCAN=y
# Config logger
CONFIG_LOG=y
CONFIG_USE_SEGGER_RTT=y
CONFIG_LOG_BACKEND_RTT=y
CONFIG_LOG_BACKEND_UART=n
CONFIG_LOG_PRINTK=y
CONFIG_ASSERT=y
#scan
CONFIG_BT_SCAN=y
CONFIG_BT_SCAN_FILTER_ENABLE=y
CONFIG_BT_SCAN_NAME_CNT=3
1.At this time, the filter is no functioning,
if (strcmp(dev_name, "TX beacon") == 0) {printk("Target device found!\n");}
the result is :
00> Manufacturer Data (len 9): 4C 00 10 05 26 98 DA 17 15
00> Manufacturer Data (len 29): 06 00 01 0F 20 02 5E F5 2E 1A 02 45 7A EE 22 54 08 E9 52 50 --- 7 messages dropped ---
00> C1 7B
00> Manufacturer Data (len 26): 4C 00 0C 0E 00 C8 6C 8A 31 39 28 A6 49 47 16 B1 FB C8 10 06 45 1D A9 0A 48 58
00> Manufacturer Data (len 11): 4C 00 10 07 3A 1F 09 B8 D8 BB 58
00> Manufacturer Data (len 13): 4C 00 0F 05 90 00 D7 1E BC 10 02 25 04
00> Manufacturer Data (len 22): 4C 00 09 08 13 7D C0 A8 12 79 1B 58 13 08 4A DA C8 97 F4 E5 F6 00
00> Manufacturer Data (len 29): 06 00 01 0F 20 22 3F E9 2A AF BE 54 A4 C3 E6 A0 02 32 BF CA 13 2D --- 8 messages dropped ---
00> Manufacturer Data (len 29): 06 00 01 09 20 22 67 00 E8 CB 15 62 06 96 DD DD C4 0F 96 E7 1B EF 77 61 7D 49 93 43 13
00> Manufacturer Data (len 13): 4C 00 0F 05 90 00 5C 70 C6 10 02 20 04
00> Manufacturer Data (len 5): 65 00 01 C9 04
00> Manufacturer Data (len 20): 7D 02 FF 00 00 FF 00 00 FF 00 00 FF 00 00 FF 00 00 FF 00 00
00> Target device found!
So I am sure when  bt_data_parse(buf, parse_name_cb, dev_name) and bt_data_parse(&backup, manuf_data_print, NULL); functions well separetely.
2.However, when my code go to
Strange thing happen, bt_data_parse(&backup, manuf_data_print, NULL) can not work and the result is:
I try to debug it and it will stop at  __ASSERT(z_spin_lock_valid(l), "Invalid spinlock %p", l); which is really strange!
Could you help me figure out what is happening? Or is there some easier way to do the NAME filter like "bt_scan_filter_add" and "bt_scan_filter_enable", Thank you so much for your time!
