It seems the "reset" button on my nrf52840dk doesn't do anything anymore. I believe this started happening after I enabled mcuboot in sysbuild. Is this expected?
After trying again with the j-link debugger (I found out I also had to keep the DK's usb plugged in for power), I was able to run `nrfjprog --recover` and flash it.
After running `nrfjprog --recover` using segger:
$ nrfjprog --recover master ✗ Recovering device. This operation might take 30s. Erasing user code and UICR flash areas. Writing image to disable ap protect. $ nrfjprog --memrd 0x10001200 master ✗ 0x10001200: FFFFFFFF |....|
Unfortunately, even after recovering, if I try to build with the onboard debugger afterwards, it still fails:
Flashing build_dk to 1050227950 west flash -d .../firmware/build_dk --dev-id 1050227950 --erase -- west flash: rebuilding [0/10] Performing build step for 'mcuboot' ninja: no work to do. [1/10] Performing build step for 'firmware' ninja: no work to do. [4/10] cd .../firmware/build_dk/_sysbuild && /opt/nordic/ncs/toolchains/b8efef2ad5/Cellar/cmake/3.21.0/bin/cmake -E true [6/10] No install step for 'firmware' [7/10] Completed 'firmware' [8/10] cd .../firmware/build_dk/_sysbuild && /opt/nordic/ncs/toolchains/b8efef2ad5/Cellar/cmake/3.21.0/bin/cmake -E true -- west flash: using runner nrfjprog -- runners.nrfjprog: mass erase requested -- runners.nrfjprog: reset after flashing requested -- runners.nrfjprog: Flashing file: .../firmware/build_dk/merged.hex [error] [ Client] - Encountered error -102: Command read_device_info executed for 126 milliseconds with result -102 [error] [ Worker] - An unknown error. [error] [ Client] - Encountered error -102: Command read_memory_descriptors executed for 25 milliseconds with result -102 Failed to read device memories. [error] [ Worker] - An unknown error. ERROR: JLinkARM DLL reported an error. Try again. If error condition ERROR: persists, run the same command again with argument --log, contact Nordic ERROR: Semiconductor and provide the generated log.log file to them. NOTE: For additional output, try running again with logging enabled (--log). NOTE: Any generated log error messages will be displayed. FATAL ERROR: command exited with status 33: nrfjprog --program .../firmware/build_dk/merged.hex --chiperase --verify -f NRF52 --snr 1050227950 * The terminal process terminated with exit code: 33. * Terminal will be reused by tasks, press any key to close it.
But flashing using segger works. So it seems there is an issue with the onboard debugger?
After flashing my firmware with segger:
-- west flash: using runner nrfjprog -- runners.nrfjprog: mass erase requested -- runners.nrfjprog: reset after flashing requested -- runners.nrfjprog: Flashing file: /Users/redacted/code/alpha21/keyvo/firmware/build_dk/merged.hex [ #################### ] 0.216s | Erase file - Done erasing [ #################### ] 1.919s | Program file - Done programming [ #################### ] 1.996s | Verify file - Done verifying Enabling pin reset. Applying pin reset. -- runners.nrfjprog: Board with serial number 802000342 flashed successfully.
It seems, the nRESET register is correct:
$ nrfjprog --memrd 0x10001200; nrfjprog --memrd 0x10001204 master ✗ 0x10001200: 00000012 |....| 0x10001204: 00000012 |....|
When I connect to the onboard debugger, I still see VCOM0 and VCOM1 and application logs when I connect to VCOM0. Clicking the "Reset" button is not rebooting the MCU though.
Is the "Reset" button not working issue related to the issue with flashing using the onboard debugger? I am guessing there is a link between both issue but not sure what it is.
Sounds like there could be a problem with the firmware running on the debugger chip. By default, the reset button is not connected directly to the nRF54L15 chip (SB1 is open):
The button connects to the DBGR_RESET input on the debugger chip, which will trigger a reset of the nRF54L15 chip on the DK.
Can you try to install a newer version of J-Link, start J-Link Configuration, select the debugger and click "Update firmware of selected probes and programmers"?
Jørgen
I was able to update the debugger chip firmware but I'm still having issues with flashing.
error] [ Client] - Encountered error -102: Command read_device_info executed for 132 milliseconds with result -102
