sd card not connecting with external micro sd adapter with nrf9160 d
I am trying to interface an SD card with the nRF9160-DK using an SD card adapter module. My goal is to write the string "hello" to a .txt file on the SD card. I believe I have correctly connected the SD card module using SPI connections. However, when I run the code, the serial monitor only displays the message "error init", indicating that the SD card initialization is
failing.  i have provided main code
//main code
#include <zephyr/kernel.h>
    #include <zephyr/device.h>
    #include <zephyr/drivers/spi.h>
    #include <zephyr/fs/fs.h>
    #include <zephyr/storage/disk_access.h>
    LOG_MODULE_REGISTER(main, LOG_LEVEL_DBG);
    #define MOUNT_POINT "/SD"
    #define FILE_PATH MOUNT_POINT "/hello.txt"
    static struct fs_mount_t fs_mount_sd = {
        .type = FS_FATFS,
        .mnt_point = MOUNT_POINT,
        .fs_data = NULL,
        .storage_dev = (void *)"SD",
    bool sd_initialized = false;
    // Function to initialize SPI device
    const struct device *init_spi_device() {
        const struct device *spi_dev = DEVICE_DT_GET(DT_NODELABEL(spi2));
        if (!spi_dev) {
            printk("SPI device not found!\n");
        } else {
            printk("SPI device found: %p\n", spi_dev);
            printk("SPI device name: %s\n", spi_dev->name);
        return spi_dev;
    // Initialize SD card
    int initialize_sd_card() {
        printk("Attempting to initialize SD card...\n");
        // Check SPI device availability
        const struct device *spi_dev = init_spi_device();
        if (!spi_dev) {
            printk("Cannot proceed without SPI device!\n");
            return -ENODEV;
        int ret = disk_access_init("SD");
        if (ret != 0) {
            printk("SD card initialization failed. Error: %d\n", ret);
            LOG_WRN("SD card initialization failed. Card may be removed.");
            return ret;
        printk("SD card initialization successful.\n");
        ret = fs_mount(&fs_mount_sd);
        if (ret == 0) {
            printk("SD card mounted successfully at %s.\n", MOUNT_POINT);
            LOG_INF("SD card initialized successfully.");
            sd_initialized = true;
            return 0;
        } else {
            printk("Failed to mount SD card. Error: %d\n", ret);
            LOG_ERR("Failed to mount SD card: %d", ret);
            return ret;
    // Write to SD card
    void write_string_to_file(const char *str) {
        printk("Preparing to write to file: %s\n", FILE_PATH);
        struct fs_file_t file;
        fs_file_t_init(&file);
        int ret = fs_open(&file, FILE_PATH, FS_O_WRITE | FS_O_CREATE | FS_O_APPEND);
        if (ret < 0) {
            printk("Failed to open hello.txt for writing. Error: %d\n", ret);
            LOG_ERR("Failed to open hello.txt for writing: %d", ret);
            return;
        printk("File opened successfully. Writing data...\n");
        ret = fs_write(&file, str, strlen(str));
        if (ret < 0) {
            printk("Failed to write to hello.txt. Error: %d\n", ret);
            LOG_ERR("Failed to write to hello.txt: %d", ret);
        } else {
            printk("Data written successfully to hello.txt: %s\n", str);
            LOG_INF("Written to hello.txt: %s", str);
        fs_close(&file);
        printk("File closed.\n");
    void main(void) {
        printk("Starting SD card test with SPI on nRF9160 DK...\n");
        if (initialize_sd_card() == 0) {
            write_string_to_file("Hello, SPI MicroSD!");
        while (1) {
            if (sd_initialized) {
                printk("SD card is initialized. Writing data...\n");
                write_string_to_file("Hello from Zephyr over SPI!");
            } else {
                printk("SD card not initialized. Retrying...\n");
                LOG_WRN("SD card not initialized. Retrying...");
                initialize_sd_card();
            k_sleep(K_SECONDS(5));
   this is prj config file
// prj config
CONFIG_SPI=y
CONFIG_DISK_ACCESS=y
CONFIG_FILE_SYSTEM=y
CONFIG_FAT_FILESYSTEM_ELM=y
CONFIG_LOG=y
CONFIG_DISK_DRIVER_SDMMC=y
CONFIG_LOG_DEFAULT_LEVEL=4
CONFIG_SPI_NRFX=y
CONFIG_SDHC=y
   this is overlay file
//overlay file
&spi2 {
    status = "okay";
    cs-gpios = <&gpio0 19 GPIO_ACTIVE_LOW>;
    pinctrl-0 = <&spi1_default>;
    pinctrl-names = "default";
    sdcard: sd@0 {
		compatible = "zephyr,sdhc-spi-slot";
        reg = <0x0>;
        spi-max-frequency = <8000000>;
&pinctrl {
	spi1_default:spi1_default{
		group0{
			psels=<NRF_PSEL(SPIM_MISO,0,16)>,
					<NRF_PSEL(SPIM_MOSI,0,17)>,
					<NRF_PSEL(SPIM_SCK,0,18)>;
     this is the error i have been getting        can anyone pls help me with this, and initialization of sd card.
