Azure IoT hub Documentation/Sample not working on nRF9160
Hey folks,
i have to use the nrf9160 board to create a PoC for a project of our company. The main topic of the PoC is not important here because i cant even connect to an Azure IoT Hub.
I use the code of the nrf sdk sample with the Toolchain version 2.9 : sdk-nrf/samples/net/azure_iot_hub at main · nrfconnect/sdk-nrf
The code runs in a west workspace.
The LTE Connection works fine so far.
The board is able to build everything (it was hard to reach this point).
I use the Visual Studio extension to work with nrf.
I know that the Problem is the Certificate, i followed the documentation to generate and provision the Certificates.
After everything is done i get this error =>
*** Booting nRF Connect SDK v2.9.0-7787b2649840 ***
*** Using Zephyr OS v3.7.99-1f8f3dc29142 ***
[00:00:00.253,784] <inf> azure_iot_hub_sample: Azure IoT Hub sample started
[00:00:00.253,845] <inf> azure_iot_hub_sample: Bringing network interface up and connecting to the network
[00:00:00.525,634] <inf> azure_iot_hub_sample: Device ID: XXXXXXXXX
[00:00:00.525,695] <inf> azure_iot_hub_sample: Host name: XXXXXXXXXXXXXXXXX
+CEREG: 2,"67C0","01AA1300",7
+CSCON: 1
+CGEV: ME PDN ACT 0,0
+CNEC_ESM: 50,0
%MDMEV: SEARCH STATUS 2
+CEREG: 5,"67C0","01AA1300",7,,,"00001010","01011111"
[00:00:05.561,889] <inf> azure_iot_hub_sample: Network connectivity established and IP address assigned
[00:00:05.562,011] <inf> azure_iot_hub_sample: Connected to network
[00:00:05.562,805] <inf> azure_fota: Current firmware version: 0.0.0-dev
[00:00:05.562,835] <inf> azure_iot_hub_sample: Azure IoT Hub library initialized
[00:00:05.562,835] <inf> azure_iot_hub_sample: AZURE_IOT_HUB_EVT_CONNECTING
[00:00:07.714,813] <inf> azure_iot_hub_sample: Connection request sent to IoT Hub
[00:00:07.798,614] <err> azure_iot_hub: Connection was rejected with return code 5
[00:00:07.798,645] <wrn> azure_iot_hub: Is the device certificate valid?
[00:00:07.798,645] <inf> azure_iot_hub_sample: AZURE_IOT_HUB_EVT_CONNECTION_FAILED
[00:00:07.798,675] <inf> azure_iot_hub_sample: Error code received from IoT Hub: 5
[00:00:07.799,896] <wrn> azure_iot_hub: DISCONNECT, result: -111
[00:00:07.799,926] <inf> azure_iot_hub_sample: AZURE_IOT_HUB_EVT_DISCONNECTED
[00:00:07.799,926] <err> mqtt_helper: Cloud MQTT input error: -111
+CEREG: 5,"67C0","01AA1302",7,,,"00001010","01011111"
I made sure to set the
CONFIG_MQTT_HELPER_SEC_TAG
CONFIG_MQTT_HELPER_SECONDARY_SEC_TAG
To the chosen values, this is the stuff i get from nrfcredstore COM11 list:
Secure tag Key type SHA
4242 ROOT_CA_CERT 0E0A61E2E78D28EEA66B15A9B10C1F4E5E8AD379FEA9131D02EC4A2473F9AB9C
4242 CLIENT_CERT 36AF6EF65D6EC7E800F407E7B7239301D3A359B81FC5475DED8851D87E5B6905
4242 CLIENT_KEY 2F38805AF55755FFEDFE71CC2D38C7AAA7AD20633BCA49E920796CEB768D5B8C
4343 ROOT_CA_CERT 44866CF6914A1AD1100147FA8432387FD5E63A5B5DFDD5A967A507AFEB78639B
The Device i created in the IoT Hub uses x509_ca like mentioned in the documentation.
I even tried the self signed or Connection string but nothing worked.... i varied the creation of the Certificate in some ways but nothing led to success.
Does somebody know how to fix it ? I read some post in this Dev Zone but nothing helped.
  • I used modem generated private key.
    So do i get this right ? after the step for the CN i note down the CN and create a device in azure with the CN as Device id ?
  • i just tried to redo the step of Device creation but with the twist that i use the CN as DeviceID but it did not change the outcome Disappointed
  • Hello, are you seeing the same outcome as first reported? Could you please share full logs from the last try?
    Thanks!
    Øyvind
  • It is the same output:
    *** Booting MCUboot v2.1.0-dev-12e5ee106034 ***
    *** Using nRF Connect SDK v2.9.0-7787b2649840 ***
    I: Starting bootloader
    I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    I: Boot source: none
    I: Image index: 0, Swap type: none
    I: Bootloader chainload address offset: 0x10000
    [00:00:00.253,814] <inf> azure_iot_hub_sample: Azure IoT Hub sample started
    [00:00:00.253,875] <inf> azure_iot_hub_sample: Bringing network interface up and connecting to the network
    [00:00:00.525,787] <inf> azure_iot_hub_sample: Device ID: 504e5737-3230-4fa3-80cc-131febc1a6cb
    [00:00:00.525,848] <inf> azure_iot_hub_sample: Host name: TestThisShitIAmOut.azure-devices.net
    +CEREG: 2,"67C0","028A060A",7
    +CSCON: 1
    +CSCON: 0
    +CSCON: 1
    +CNEC_ESM: 50,0
    [00:00:29.064,758] <inf> azure_iot_hub_sample: Network connectivity established and IP address assigned
    [00:00:29.064,880] <inf> azure_iot_hub_sample: Connected to network
    [00:00:29.065,673] <inf> azure_fota: Current firmware version: 0.0.0-dev
    [00:00:29.065,704] <inf> azure_iot_hub_sample: Azure IoT Hub library initialized
    [00:00:29.065,704] <inf> azure_iot_hub_sample: AZURE_IOT_HUB_EVT_CONNECTING
    [00:00:31.142,822] <inf> azure_iot_hub_sample: Connection request sent to IoT Hub
    [00:00:31.285,430] <err> azure_iot_hub: Connection was rejected with return code 5
    [00:00:31.285,461] <wrn> azure_iot_hub: Is the device certificate valid?
    [00:00:31.285,461] <inf> azure_iot_hub_sample: AZURE_IOT_HUB_EVT_CONNECTION_FAILED
    [00:00:31.285,491] <inf> azure_iot_hub_sample: Error code received from IoT Hub: 5
    [00:00:31.286,712] <wrn> azure_iot_hub: DISCONNECT, result: -111
    [00:00:31.286,743] <inf> azure_iot_hub_sample: AZURE_IOT_HUB_EVT_DISCONNECTED
    [00:00:31.286,773] <err> mqtt_helper: Cloud MQTT input error: -111
    This still looks like an issue with the certificate, but our experts can't replicate it. There must be a misconfiguration in the certificates either on the server side or device side.
    If the device has this device ID on both server and device, and has used the same CN, we are not able to see why it would fail.
    Cedric A. said:
    dont use the Device Provisioning f
    Did you retry using device provisioning just to see if that changes the outcom?
    Øyvind
