I am currently working on connecting a Thingy:91x to a Cube Orange autopilot (Pixhawk 2.1) in order to receive telemetry data over UART using the MAVLink protocol. The goal is for the Thingy:91x to act as a receiver for MAVLink messages being emitted by the flight controller.
The Cube Orange exposes several UART interfaces via connectors such as TELEM2, which provide:
TX (Cube output)
RX (Cube input)
GND
Questions:
Which pins should I use from the Thingy to connect with UART and read the telem?
Is there any specific configuration required in the device tree or Kconfig to properly enable and use
uart0
on the Thingy:91x? -
Are there any official examples or recommended approaches within Zephyr/NCS for receiving a continuous data stream (such as MAVLink) over UART?
What is the recommended way to debug incoming UART data on the Thingy:9x1? Is it possible to redirect the UART output to USB for inspection via a terminal like
minicom
Are there any considerations regarding buffer size, flow control, or DMA configuration when handling continuous traffic such as MAVLink (~10-20Hz message rate)?
