Issue of build centre_uart sample
Hi Support Team
I fail to build the original centre_uart sample. The attachment is the build log. Many thanks.
*  Executing task: nRF Connect: Generate config nrf54l15dk/nrf54l15/cpuapp for e:\ncs\VCS\central_uart
Building central_uart
C:\WINDOWS\system32\cmd.exe /d /s /c "west build --build-dir e:/ncs/VCS/central_uart/build e:/ncs/VCS/central_uart --pristine --board nrf54l15dk/nrf54l15/cpuapp -- -DNCS_TOOLCHAIN_VERSION=NONE -DCONF_FILE=e:/ncs/VCS/central_uart/prj.conf -DBOARD_ROOT=e:/ncs/vcs/central_uart"
Loading Zephyr module(s) (Zephyr base): sysbuild_default
-- Found Python3: C:/ncs/toolchains/b620d30767/opt/bin/python.exe (found suitable version "3.12.4", minimum required is "3.8") found components: Interpreter
-- Cache files will be written to: E:/ncs/v2.9.1/zephyr/.cache
CMake Error at E:/ncs/v2.9.1/zephyr/cmake/modules/boards.cmake:196 (message):
  Error finding board: nrf54l15dk
  Error message: Traceback (most recent call last):
    File "E:\ncs\v2.9.1\zephyr\scripts\list_boards.py", line 469, in <module>
      dump_v2_boards(args)
    File "E:\ncs\v2.9.1\zephyr\scripts\list_boards.py", line 416, in dump_v2_boards
      boards = find_v2_boards(args)
    File "E:\ncs\v2.9.1\zephyr\scripts\list_boards.py", line 341, in find_v2_boards
      b, e = load_v2_boards(args.board, board_yml, systems)
    File "E:\ncs\v2.9.1\zephyr\scripts\list_boards.py", line 230, in load_v2_boards
      b = yaml.load(f.read(), Loader=SafeLoader)
  UnicodeDecodeError: 'gbk' codec can't decode byte 0xa2 in position 46:
  illegal multibyte sequence
  cmake/modules/sysbuild_default.cmake:15 (include)
  E:/ncs/v2.9.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:75 (include)
  E:/ncs/v2.9.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
  E:/ncs/v2.9.1/zephyr/share/sysbuild-package/cmake/SysbuildConfig.cmake:8 (include)
  template/CMakeLists.txt:10 (find_package)
See also "E:/ncs/VCS/central_uart/build/CMakeFiles/CMakeOutput.log".
FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\b620d30767\opt\bin\cmake.EXE' -DWEST_PYTHON=C:/ncs/toolchains/b620d30767/opt/bin/python.exe '-Be:\ncs\VCS\central_uart\build' -GNinja -DBOARD=nrf54l15dk/nrf54l15/cpuapp -DNCS_TOOLCHAIN_VERSION=NONE -DCONF_FILE=e:/ncs/VCS/central_uart/prj.conf -DBOARD_ROOT=e:/ncs/vcs/central_uart '-SE:\ncs\v2.9.1\zephyr\share\sysbuild' '-DAPP_DIR:PATH=e:\ncs\VCS\central_uart'
 *  The terminal process terminated with exit code: 1.
