Why am I receiving data through /dev/ttyACM1 while transmitting over pin 8 (UART1 TX) on nRF9151?
Hi, I'm working with the nRF9151DK and Zephyr RTOS (v3.7.99 / NCS 2.9.1). I’ve configured UART1 to send and receive data via GPIO pins:
  • TX: pin 8 (P0.08)
  • RX: pin 9 (P0.09)
devicetree.overlay:
    chosen {
        zephyr,console = &uart1;
&uart1 {
    status = "okay";
    current-speed = <115200>;
    pinctrl-0 = <&uart1_default>;
    pinctrl-1 = <&uart1_sleep>;
&pinctrl {
    uart1_default: uart1_default {
        group1 {
            psels = <NRF_PSEL(UART_TX, 0, 8)>,
                    <NRF_PSEL(UART_RX, 0, 9)>;
    uart1_sleep: uart1_sleep {
        group1 {
            low-power-enable;
prj.conf:
CONFIG_SERIAL=y
CONFIG_UART_CONSOLE=n
CONFIG_USB_DEVICE_STACK=n
CONFIG_PRINTK=y
main.c:
#include <zephyr/device.h>
#include <zephyr/drivers/uart.h>
#include <zephyr/kernel.h>
#define UART_NODE DT_NODELABEL(uart1)
void main(void) {
    const struct device *uart_dev = DEVICE_DT_GET(UART_NODE);
    if (!device_is_ready(uart_dev)) {
        return;
    uint8_t ch;
    int ret;
    while (1) {
        uart_poll_out(uart_dev, 'H');
        uart_poll_out(uart_dev, 'i');
        uart_poll_out(uart_dev, '\n');
        ret = uart_poll_in(uart_dev, &ch);
        if (ret == 0) {
            uart_poll_out(uart_dev, ch); // Simple echo
        k_sleep(K_MSEC(1000));
 Current Behavior:
  • Data is transmitted correctly through pin 8 (UART1 TX) using an external USB-to-Serial adapter.
  • But data is only received via /dev/ttyACM1, which seems to correspond to the USB interface (UART0?).
Question:
Why does Zephyr still receive input through /dev/ttyACM1 even though UART0 is disabled and UART1 is enabled and routed to GPIO pins?
Am I missing a configuration step to fully detach the USB UART console and use only physical UART1 (pins 8/9) for both TX and RX?
Thank you in advance for your help! Pray
    did you check in zephyr.dts and .config that UART0 has been disabled in the build?
  • Hi Hakon, thank you very much for your help.
    Indeed, UART0 was already showing as disabled. I’m not sure if this is the best solution, but I managed to fix the issue and it works!
    I found out that button_1 and the RX pin (P0.09) share the same physical pin. In the visual configuration of the .overlay file, the RX pin had the lightning symbol (activation) set to high, while button_1 was set to low.
    So what I did was invert the RX activation, matching it to button_1… and that’s when it started receiving data correctly! Tada
    Thanks again for your support — really appreciate it!
