I added MCUboot and SMP BT Service to the OpenThread CLI routine to implement the device firmware upgrade function.
I found that after DFU is completed, the Thread activity data set will be lost, in fact, all the data in Settings NVS will be lost.
SDK:ncs 2.9.0
board:NRF52840DK-NRF52840
The project configuration is as follows:
sysbuild.conf
# MCUboot
SB_CONFIG_BOOTLOADER_MCUBOOT=y
# MCUboot should use external flash
SB_CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY=y
SB_CONFIG_BOOT_SIGNATURE_TYPE_NONE=y
prj.conf
CONFIG_NCS_BOOT_BANNER=n
CONFIG_BOOT_BANNER=n
CONFIG_NORDIC_QSPI_NOR=y
# Network shell
CONFIG_SHELL=y
CONFIG_OPENTHREAD_SHELL=y
CONFIG_SHELL_ARGC_MAX=26
CONFIG_SHELL_CMD_BUFF_SIZE=416
# Increase Settings storage size
CONFIG_PM_PARTITION_SIZE_SETTINGS_STORAGE=0x8000
# Enable OpenThread features set
CONFIG_OPENTHREAD_NORDIC_LIBRARY_MASTER=y
CONFIG_NET_L2_OPENTHREAD=y
# Generic networking options
CONFIG_NETWORKING=y
# Enable Zephyr logging
CONFIG_LOG=y
# Increase the default RX stack size
CONFIG_IEEE802154_NRF5_RX_STACK_SIZE=832
# Use separate thread for logging
CONFIG_LOG_MODE_DEFERRED=y
# Enable OpenThread logging
CONFIG_OPENTHREAD_DEBUG=y
# Option for configuring log level in OpenThread
CONFIG_OPENTHREAD_LOG_LEVEL_INFO=y
# Enable RTT logging backend
CONFIG_USE_SEGGER_RTT=y
CONFIG_LOG_BACKEND_RTT=y
# Disable UART logging backend
CONFIG_LOG_BACKEND_UART=n
# augment system workqueue stack size
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=2144
# Enable and configure Bluetooth LE
CONFIG_BT=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_DEVICE_NAME="device"
CONFIG_BT_DEVICE_APPEARANCE=833
# Enable FOTA over Bluetooth LE
CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU=y
sysbuild/mcuboot.conf
# Enable logging for MCUboot
CONFIG_LOG=y
# Turn on a LED so we can see when Serial Recovery mode is active
CONFIG_MCUBOOT_INDICATION_LED=n
# Increase number of sectors
# This is 512 for the nRF54L15 but can be smaller for other chips
# This configuration should match the largest image that you support.
# 128*4k = 512k. If your images are larger, you should adjust this value. It is typically 256 for a 1MB flash device, such as nRF52840.
CONFIG_BOOT_MAX_IMG_SECTORS=512
sysbuild/mcuboot.overlay
aliases {
mcuboot-button0 = &button1;
mcuboot-led0 = &led1;
/* Add external flash to MCUboot */
&mx25r64 {
status = "okay";
chosen {
nordic,pm-ext-flash = &mx25r64;
boards/nrf52840dk_nrf52840.overlay
/* Copyright (c) 2020 Nordic Semiconductor ASA
&uart0 {
status = "okay";
hw-flow-control;
/* Add external flash to application */
&mx25r64 {
status = "okay";
chosen {
* In some default configurations within the nRF Connect SDK,
* e.g. on nRF52840, the chosen zephyr,entropy node is &cryptocell.
* This devicetree overlay ensures that default is overridden wherever it
* is set, as this application uses the RNG node for entropy exclusively.
chosen {
zephyr,entropy = &rng;
What causes data loss?
