Hi Nordic Team,
What is the difference between 10 bit, 12 bit and 14 bit operation mode and 8/10/12/14 bit resolution in SAADC of nRF54L?
Bhavya
Hi Nordic Team,
Bhavya
Hello Bhavya,
The three modes indicates the resolution that you will get. If a really high sample rate is important for you, while the accuracy is not, then it would make sense to use 10 bit, but if accuracy is more important than speed, then you can use 12 bit, or even 14-bit (requires oversampling, meaning that it will take many samples at 12 bit, to give an average value in 14-bit).
Edvin
Thank you Edvin for the response. So as per data sheet there no any operation mode to get 8 bit resolution?
It is lacking the sample rate number for 8 bit, but it is possible to set it in 8 bit mode:
https://docs.nordicsemi.com/bundle/ps_nrf54L15/page/saadc.html#ariaid-title53
BR,
Edvin
