Hi
I am using an nRF54L15 and trying to use pins for I2C, but to do this I have to disable the NFC pins.
I did the following:
CONFIG_NFCT_PINS_AS_GPIOS=y
But that wasn't enough.
I noticed if, in debug mode, I disabled the NFCT | PADCONFIG, then my i2c bus worked.
So in software I now do the following:
static int disable_nfc_pins_early(const struct device *dev)
ARG_UNUSED(dev);
// Disable NFC function on NFC pins
NRF_NFCT->PADCONFIG = 0;
return 0;
SYS_INIT(disable_nfc_pins_early, PRE_KERNEL_1, 0);
And I still have this setting in the prj,conf file:
Is there a way to do this just through configuration, using our own board definition files and prj.conf?
Thanks
