How to custom cluster in Matter
Hello, Nordic Team,
I'm currently working on implementing a custom cluster in the Matter application. However, I've encountered issues where the methods described in your documentation simply don’t work. Some of the commands mentioned are non-existent.
I followed this documentation: ​​Creating custom clusters in Matter application
But encountered an error stating that the --clusters parameter does not exist:
PS D:\Code\ncs291\custom_cluster> west zap-gui --clusters C:\ncs\v2.9.0\modules\lib\matter\data_model\1.4\clusters\OnOff.xml
usage: west zap-gui [-h] [-z ZAP_FILE] [-j ZCL_JSON] [-m MATTER_PATH]
west zap-gui: error: unexpected arguments: ['--clusters', 'C:\\ncs\\v2.9.0\\modules\\lib\\matter\\data_model\\1.4\\clusters\\OnOff.xml']
Even after manually adding the XML file to the ZAP GUI, issues persist. For example, device types become unavailable (all options disappear, including standard ones like "Generic Switch").
I also reviewed Google’s documentation, but parts of it are outdated. For instance:
Create a sample cluster  |  Matter  |  Google Home Developers
The referenced file all.xml no longer exists at the specified path:
src/app/zap-templates/zcl/data-model/all.xml:
<?xml version="1.0"?>
<all xmlns:xi="http://www.w3.org/2001/XInclude">
   <xi:include href="chip/access-control-cluster.xml" />
+  <xi:include href="chip/sample-mei-cluster.xml" />
</all>
Additionally, the Matter documentation provides only general guidance, lacking implementation details:
Implementing New Clusters & Device Types — Matter documentation
Adding new clusters and device types to the codegen — Matter documentation
While these documents outline which files to modify, I struggle with the code generation process due to my unfamiliarity with the workflow. Errors occur, but I can’t pinpoint their root cause.
​My questions:​​
  1. How can I properly create a custom cluster?
  2. Which tutorial is currently valid and functional?
  3. Are there known issues with the zap-gui tool or recent changes to the workflow?
Any guidance or examples would be greatly appreciated. Thank you!
