SETUP:
2 x NRF54L15 DK
initiator/reflector sample (as of 4/8/2025)
Major RTT settings below - RTT (BT_CONN_LE_CS_MAIN_MODE_1) with 1M phy, 32 bit random RTT (will add settings and prj.conf below)
QUESTIONS:
1. 1phy data is OK but a lot of negative TOF values which is confusing me. Is there an issue with the hex conversion of this data or something im missing as to why? (obfuscated in bt_ras_rreq_rd_subevent_data_parse "helper for parsing ranging data-formatted buffer"). I'm reminded of the 4-3 byte conversion from the early AOA days...
2. the 2M phy data is consistent, but always shifted about -7m.Is this just the the current state of the parse helper not accounting for the 2m phy mode? ( changed the .cs_sync_phy & .phy to 2M and enabled 2M in the prj.conf of the initiator, then enabled 2M in prj.conf on refl)
3. Any suggestions on more levers to pull to improve this setup? Not using channel switching or a subevent confused me in the setup quite a bit.
2M PHY data example (each data point from multiple events)
n delta TOF (uS) toa_tod_initiator (uS) tod_toa_reflector(uS) E: 0 6.5 70 44 E: 1 -5 42 62 E: 2 -22 21 109 E: 4 7 77 49 E: 5 5.5 70 48 E: 7 -0.75 59 62 E: 8 23.5 118 24 E: 9 10.25 91 50 E: 10 4.75 72 53 E: 18 0.25 66 65 E: 22 2.75 79 68 E: 32 -29 36 152 E: 33 -1.75 64 71 E: 35 -11.75 38 85 E: 38 3 71 59 E: 44 -17.75 42 113 E: 45 -27.75 4 115 E: 47 17.5 90 20 E: 48 8 85 53 E: 50 -22.5 23 113 E: 51 -14.5 49 107 E: 52 -8.75 68 103 E: 54 1.25 71 66 E: 56 1.25 82 77 E: 58 -15.75 52 115 E: 59 -20.5 39 121 E: 60 -11.5 49 95 E: 61 -12.25 45 94 E: 62 -10.25 67 108 E: 63 -12.5 57 107 E: 64 10.25 94 53 E: 65 -0.5 83 85 E: 0 -0.5 -36 -34 E: 1 -3 -32 -20 E: 2 2.75 -18 -29 E: 3 4.25 -14 -31 E: 4 4.5 -16 -34 E: 5 3.25 -12 -25 E: 6 -9.25 -35 2 E: 7 -1 -20 -16 E: 8 -11 -50 -6 E: 9 4.25 -12 -29 E: 10 -12.5 -47 3 E: 11 -13.5 -46 8 E: 12 11.25 -12 -57 E: 14 8.75 4 -31 E: 15 -6.5 -32 -6 E: 16 1.25 -14 -19 E: 17 1.25 -31 -36 E: 18 -15.75 -53 10 E: 19 -24.5 -68 30 E: 21 7 -9 -37 E: 22 -9.25 -26 11 E: 23 7 -3 -31 E: 24 -25 -75 25 E: 25 -17.25 -51 18 E: 26 0.25 -16 -17 E: 27 -1.25 -30 -25 E: 28 -17.75 -59 12 E: 29 -17.75 -64 7 E: 30 -10 -42 -2 E: 31 -2.75 -15 -4 E: 32 5 6 -14 E: 33 -11.75 -39 8 E: 34 -7.25 -27 2 E: 35 1.25 -8 -13 E: 36 0.5 -19 -21 E: 37 -11.25 -38 7 E: 38 1 -18 -22 E: 39 7 4 -24 E: 40 18.25 12 -61 E: 41 -3 -14 -2 E: 42 -20.5 -65 17 E: 43 -15.75 -50 13 E: 44 13 12 -40 E: 45 4.25 -6 -23 E: 46 -5.5 -22 0 E: 47 -2 -20 -12 E: 48 -6 -24 0 E: 49 3 -5 -17 E: 50 -0.5 -19 -17 E: 51 3 -12 -24 E: 52 13.5 25 -29 E: 53 0.5 -6 -8 E: 54 -2.25 -11 -2 E: 55 -19 -48 28 E: 56 14.75 23 -36 E: 57 9.75 6 -33 E: 59 -4.75 -17 2 E: 60 -27 -51 57 E: 61 6.75 5 -22 E: 62 0.75 -4 -7 E: 63 -6 -11 13 E: 64 -11.75 -30 17 E: 65 1 -10 -14 E: 0 0.75 -18 -21 E: 1 0.25 -19 -20 E: 2 -4.75 -33 -14 E: 3 5.25 -9 -30 E: 4 11.75 7 -40 E: 5 -11 -37 7 E: 6 -7.5 -34 -4 E: 7 -1 -19 -15 E: 8 5.5 -5 -27 E: 9 8.25 -3 -36 E: 10 -7 -36 -8 E: 11 -14 -49 7
SETTINGS
struct bt_scan_init_param param = {
.scan_param = NULL,
.conn_param = BT_LE_CONN_PARAM(20, 20, 0, 400), // 30–50 ms
.connect_if_match = 1
struct bt_le_cs_create_config_params config_params = {
.id = CS_CONFIG_ID,
.main_mode_type = BT_CONN_LE_CS_MAIN_MODE_1,
.sub_mode_type = BT_CONN_LE_CS_SUB_MODE_UNUSED,
.min_main_mode_steps = 1,
.max_main_mode_steps = 1,
.main_mode_repetition = 0,
.mode_0_steps = NUM_MODE_0_STEPS,
.role = BT_CONN_LE_CS_ROLE_INITIATOR,
.rtt_type = BT_CONN_LE_CS_RTT_TYPE_32_BIT_RANDOM,
.cs_sync_phy = BT_CONN_LE_CS_SYNC_1M_PHY,
.channel_map_repetition = 5,
.channel_selection_type = BT_CONN_LE_CS_CHSEL_TYPE_3B,
.ch3c_shape = BT_CONN_LE_CS_CH3C_SHAPE_HAT,
.ch3c_jump = 2,
const struct bt_le_cs_set_procedure_parameters_param procedure_params = {
.config_id = CS_CONFIG_ID,
.max_procedure_len = 50,
.min_procedure_interval = 60,
.max_procedure_interval = 60,
.max_procedure_count = 0,
.min_subevent_len = 15000,
.max_subevent_len = 15000,
.tone_antenna_config_selection = BT_LE_CS_TONE_ANTENNA_CONFIGURATION_INDEX_ONE,
.phy = BT_LE_CS_PROCEDURE_PHY_1M,
.tx_power_delta = 0x80,
.preferred_peer_antenna = BT_LE_CS_PROCEDURE_PREFERRED_PEER_ANTENNA_1,
.snr_control_initiator = BT_LE_CS_INITIATOR_SNR_CONTROL_NOT_USED,
.snr_control_reflector = BT_LE_CS_REFLECTOR_SNR_CONTROL_NOT_USED,
PRJ.conf
CONFIG_NCS_SAMPLES_DEFAULTS=y CONFIG_DK_LIBRARY=y CONFIG_BT=y CONFIG_BT_SMP=y CONFIG_BT_CENTRAL=y CONFIG_BT_MAX_CONN=1 CONFIG_BT_BONDABLE=n CONFIG_BT_GATT_CLIENT=y CONFIG_BT_GATT_DYNAMIC_DB=y CONFIG_BT_CHANNEL_SOUNDING=y CONFIG_BT_RAS=y CONFIG_BT_RAS_RREQ=y CONFIG_BT_SCAN=y CONFIG_BT_SCAN_FILTER_ENABLE=y CONFIG_BT_SCAN_UUID_CNT=1 CONFIG_BT_CTLR_PHY_2M=n # The Ranging Profile recommends a MTU of at least 247 octets. CONFIG_BT_L2CAP_TX_MTU=498 CONFIG_BT_BUF_ACL_TX_SIZE=502 CONFIG_BT_BUF_ACL_RX_SIZE=502 CONFIG_BT_ATT_PREPARE_COUNT=3 CONFIG_BT_CTLR_DATA_LENGTH_MAX=251 # This allows CS and ACL to use different PHYs # CONFIG_BT_TRANSMIT_POWER_CONTROL=y # This improves the performance of floating-point operations CONFIG_FPU=y CONFIG_FPU_SHARING=y CONFIG_CBPRINTF_FP_SUPPORT=y CONFIG_BT_CTLR_TX_PWR_PLUS_4=y # Enable basic logging CONFIG_LOG=y CONFIG_LOG_MODE_DEFERRED=n # Use RTT as the console backend CONFIG_USE_SEGGER_RTT=y CONFIG_RTT_CONSOLE=y CONFIG_LOG_BACKEND_RTT=y # Disable UART console and UART logging to avoid conflicts CONFIG_UART_CONSOLE=n CONFIG_LOG_BACKEND_UART=n CONFIG_LOG_DEFAULT_LEVEL=1 CONFIG_LOG_MAX_LEVEL=1 # Optional: Increase RTT buffer size for lots of logging CONFIG_SEGGER_RTT_BUFFER_SIZE_UP=1024 CONFIG_SEGGER_RTT_BUFFER_SIZE_DOWN=16 CONFIG_LOG_BUFFER_SIZE=2048
in .config
CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y
CONFIG_CLOCK_CONTROL_NRF_K32SRC_50PPM=y
