CoAP - Callback function
Hello Nordic forum,
I must not quite understand how CoAP callbacks should work. Would anyone be able to give me any advice as to why my modified coap_client results in undefined behavior? In my main program, I'd call the function coap_send() at various points while varying the tx_payload string.
#include "coap.h"
#include <stdio.h>
#include <string.h>
#if defined(CONFIG_POSIX_API)
#include <zephyr/posix/arpa/inet.h>
#include <zephyr/posix/netdb.h>
#include <zephyr/posix/sys/socket.h>
#include <zephyr/posix/poll.h>
#else
#include <zephyr/net/socket.h>
#endif /* CONFIG_POSIX_API */
#include <zephyr/kernel.h>
#include <zephyr/sys/reboot.h>
#include <zephyr/net/coap.h>
#include <zephyr/net/conn_mgr_connectivity.h>
#include <zephyr/net/conn_mgr_monitor.h>
#include <zephyr/random/random.h>
#include <zephyr/net/coap_client.h>
#include <zephyr/logging/log_ctrl.h>
#include <modem/lte_lc.h>
LOG_MODULE_REGISTER(coap_client_sample, CONFIG_COAP_CLIENT_SAMPLE_LOG_LEVEL);
/* Macros used to subscribe to specific Zephyr NET management events. */
#define L4_EVENT_MASK (NET_EVENT_L4_CONNECTED | NET_EVENT_L4_DISCONNECTED)
#define CONN_LAYER_EVENT_MASK (NET_EVENT_CONN_IF_FATAL_ERROR)
/* Macro called upon a fatal error, reboots the device. */
#define FATAL_ERROR()					\
	LOG_ERR("Fatal error! Rebooting the device.");	\
	LOG_PANIC();					\
	IF_ENABLED(CONFIG_REBOOT, (sys_reboot(0)))
/* Zephyr NET management event callback structures. */
static struct net_mgmt_event_callback l4_cb;
static struct net_mgmt_event_callback conn_cb;
/* Variable used to indicate if network is connected. */
static bool is_connected;
/* Mutex and conditional variable used to signal network connectivity. */
K_MUTEX_DEFINE(network_connected_lock);
K_CONDVAR_DEFINE(network_connected);
static int server_resolve(struct sockaddr_storage *server)
	int err;
	struct addrinfo *result;
	struct addrinfo hints = {
		.ai_family = AF_INET,
		.ai_socktype = SOCK_DGRAM
	char ipv4_addr[NET_IPV4_ADDR_LEN];
	err = getaddrinfo(CONFIG_COAP_SAMPLE_SERVER_HOSTNAME, NULL, &hints, &result);
	if (err) {
		LOG_ERR("getaddrinfo, error: %d", err);
		return err;
	if (result == NULL) {
		LOG_ERR("Address not found");
		return -ENOENT;
	/* IPv4 Address. */
	struct sockaddr_in *server4 = ((struct sockaddr_in *)server);
	server4->sin_addr.s_addr = ((struct sockaddr_in *)result->ai_addr)->sin_addr.s_addr;
	server4->sin_family = AF_INET;
	server4->sin_port = htons(CONFIG_COAP_SAMPLE_SERVER_PORT);
	inet_ntop(AF_INET, &server4->sin_addr.s_addr, ipv4_addr, sizeof(ipv4_addr));
	LOG_INF("IPv4 Address found %s", ipv4_addr);
	/* Free the address. */
	freeaddrinfo(result);
	return 0;
static void wait_for_network(void)
	k_mutex_lock(&network_connected_lock, K_FOREVER);
	if (!is_connected) {
		LOG_INF("Waiting for network connectivity");
		k_condvar_wait(&network_connected, &network_connected_lock, K_FOREVER);
	k_mutex_unlock(&network_connected_lock);
static void response_cb(int16_t code, size_t offset, const uint8_t *payload,
			size_t len, bool last_block, void *user_data)
	if (code >= 0) {
		//LOG_INF("CoAP response code: 0x%x", code);
		//Achim's suggestion.
		LOG_INF("CoAP response: code: 0x%x, payload: %u bytes", code, len);
	} else {
		LOG_INF("Response received with error code: %d", code);
static int periodic_coap_request_loop(char* tx_payload)
	size_t tx_payload_len = strlen(tx_payload);
	int err, sock = 0;
	struct sockaddr_storage server = { 0 };
	struct coap_client coap_client = { 0 };
	struct coap_client_request req = {
		.method = COAP_METHOD_POST,
		.confirmable = true,
		.fmt = COAP_CONTENT_FORMAT_TEXT_PLAIN,
		.payload = tx_payload,
		.cb = response_cb,
		.len = tx_payload_len,
		.path = ""
	err = server_resolve(&server);
	if (err) {
		LOG_ERR("Failed to resolve server name");
		return err;
	sock = socket(AF_INET, SOCK_DGRAM, IPPROTO_UDP);
	if (sock < 0) {
		LOG_ERR("Failed to create CoAP socket: %d.", -errno);
		return -errno;
	else {
		LOG_INF("Socket created");
	static bool coap_client_init_done = false;
	if (coap_client_init_done == false) {
		LOG_INF("Initializing CoAP client");
		err = coap_client_init(&coap_client, NULL);
		if (err) {
			LOG_ERR("Failed to initialize CoAP client: %d", err);
			return err;
		coap_client_init_done = true;
	wait_for_network();
	/* Send request */
	err = coap_client_req(&coap_client, sock, (struct sockaddr *)&server, &req, NULL);
	if (err) {
		LOG_ERR("Failed to send request: %d", err);
		return err;
	LOG_INF("CoAP POST request sent sent to %s", CONFIG_COAP_SAMPLE_SERVER_HOSTNAME);
	LOG_INF("Sent request, closing socket in 3 seconds");
	k_sleep(K_SECONDS(3));
	/* Close socket */
	close(sock);
	return 0;
static void l4_event_handler(struct net_mgmt_event_callback *cb,
			     uint32_t event,
			     struct net_if *iface)
	switch (event) {
	case NET_EVENT_L4_CONNECTED:
		LOG_INF("Network connectivity established");
		is_connected = true;
		k_condvar_signal(&network_connected);
	case NET_EVENT_L4_DISCONNECTED:
		LOG_INF("Network connectivity lost");
		is_connected = false;
		/* Don't care */
		return;
static void connectivity_event_handler(struct net_mgmt_event_callback *cb,
						uint32_t event,
	if (event == NET_EVENT_CONN_IF_FATAL_ERROR) {
		LOG_ERR("NET_EVENT_CONN_IF_FATAL_ERROR");
		FATAL_ERROR();
		return;
int coap_send(char* tx_payload)
	int err;
	LOG_INF("The CoAP client started.");
	/* Setup handler for Zephyr NET Connection Manager events and Connectivity layer. */
	net_mgmt_init_event_callback(&l4_cb, l4_event_handler, L4_EVENT_MASK);
	net_mgmt_add_event_callback(&l4_cb);
	net_mgmt_init_event_callback(&conn_cb, connectivity_event_handler, CONN_LAYER_EVENT_MASK);
	net_mgmt_add_event_callback(&conn_cb);
	/* Bring all network interfaces up.
	 * Wi-Fi or LTE depending on the board that the sample was built for.
	LOG_INF("Bringing network interface up and connecting to the network");
	k_sleep(K_SECONDS(1));
	err = conn_mgr_all_if_up(true);
	if (err) {
		LOG_ERR("conn_mgr_all_if_up, error: %d", err);
		FATAL_ERROR();
		return err;
	err = conn_mgr_all_if_connect(true);
	if (err) {
		LOG_ERR("conn_mgr_all_if_connect, error: %d", err);
		FATAL_ERROR();
		return err;
	/* Resend connection status if the sample is built for NATIVE_SIM.
	 * This is necessary because the network interface is automatically brought up
	 * at SYS_INIT() before main() is called.
	 * This means that NET_EVENT_L4_CONNECTED fires before the
	 * appropriate handler l4_event_handler() is registered.
	if (IS_ENABLED(CONFIG_BOARD_NATIVE_SIM)) {
		conn_mgr_mon_resend_status();
	wait_for_network();
	err = periodic_coap_request_loop(tx_payload);
	if (err) {
		LOG_ERR("periodic_coap_request_loop, error: %d", err);
		FATAL_ERROR();
		return err;
	LOG_INF("periodic_coap_request_loop completed!");
	return 0;
The first time coap_send() is called, everything works fine. Message gets sent and callback is received. The second time, however, the message gets sent (verified by looking at my endpoint), but I never get the LOG_INF notifying me of the server response.
When I build my program using the default optimizations, the program crashes without warning directly after sending the second message. Interestingly, when I build my program using the debugging optimization, the program will actually work and send messages correctly, but I will not receive a server response.
To me, this seems to indicate a problem with how I'm doing the response callback.
  • Here is sample output from when I run the program after it's built using the debugging optimization. As you can see, the messages are sending, but only the first callback is received.
    CoAP --> DEVICE ON.
    [00:00:01.386,871] <inf> coap_client_sample: The CoAP client started.
    [00:00:01.386,901] <inf> coap_client_sample: Bringing network interface up and connecting to the network
    [00:00:02.720,336] <inf> coap_client_sample: Waiting for network connectivity
    [00:00:05.857,421] <inf> coap_client_sample: Network connectivity established
    [00:00:07.178,405] <inf> coap_client_sample: IPv4 Address found 10.60.10.132
    [00:00:07.178,771] <inf> coap_client_sample: Socket created
    [00:00:07.178,771] <inf> coap_client_sample: Initializing CoAP client
    [00:00:07.180,786] <inf> coap_client_sample: CoAP POST request sent sent to coap.os.1nce.com
    [00:00:07.180,816] <inf> coap_client_sample: Sent request, closing socket in 3 seconds
    [00:00:07.484,283] <inf> coap_client_sample: CoAP response: code: 0x44, payload: 0 bytes
    [00:00:10.181,182] <inf> coap_client_sample: periodic_coap_request_loop completed!
    Exiting startup() in 2 seconds.
    CoAP --> OK!
    [00:00:33.185,394] <inf> coap_client_sample: The CoAP client started.
    [00:00:33.185,424] <inf> coap_client_sample: Bringing network interface up and connecting to the network
    [00:00:35.206,695] <inf> coap_client_sample: IPv4 Address found 10.60.10.132
    [00:00:35.212,890] <inf> coap_client_sample: Socket created
    [00:00:35.221,496] <inf> coap_client_sample: CoAP POST request sent sent to coap.os.1nce.com
    [00:00:35.221,496] <inf> coap_client_sample: Sent request, closing socket in 3 seconds
    [00:00:38.221,893] <inf> coap_client_sample: periodic_coap_request_loop completed!
    Returning to the start of operate() in 3 seconds.
    Entering operate()
    CoAP --> OK!
    [00:01:02.226,135] <inf> coap_client_sample: The CoAP client started.
    [00:01:02.226,165] <inf> coap_client_sample: Bringing network interface up and connecting to the network
    [00:01:04.238,739] <inf> coap_client_sample: IPv4 Address found 10.60.10.132
    [00:01:04.244,934] <inf> coap_client_sample: Socket created
    [00:01:04.253,540] <inf> coap_client_sample: CoAP POST request sent sent to coap.os.1nce.com
    [00:01:04.253,540] <inf> coap_client_sample: Sent request, closing socket in 3 seconds
    [00:01:07.253,936] <inf> coap_client_sample: periodic_coap_request_loop completed!
  • Lastly, in my coap_client_req() function call, I'm passing NULL for the coap_transmission_parameters which should resolve as the CoAP default values. Looking at the RFC 7252 spec, the default ACK_TIMEOUT is 2 seconds which seems sufficient.
  • Hello, I've been assigned your ticket and will look into this. Are you still using the slightly modified coap_client sample as in  Errors when running coap_client sample from 2.9.0 SDK ?
    Could you please elaborate what changes you have done and with what configuration?
    Øyvind
  • Hello there, thank you for your reply. I actually figured this one out on my own. The problem was related to my poor understanding of C, but we're getting better!
  • Hey, that's excellent! Always good to solve the issue on your own. May I ask what the issue was?
    Øyvind
