Hi all,
I'm working on a BLE peripheral using Zephyr and have run into an issue when enabling both dynamic device naming and long advertising intervals.
I enabled dynamic naming via CONFIG_BT_DEVICE_NAME_DYNAMIC and set the name at runtime with:
bt_set_name(device_name);
Then I start advertising with a slow interval (every ~10 seconds):
struct bt_le_adv_param connection_adv_param = {
.interval_min = 0x3FFF, // ~10239.375 ms
.interval_max = 0x4000, // ~10240 ms
.options = BT_LE_ADV_OPT_CONNECTABLE,
.id = 0,
.sid = 0,
.secondary_max_skip = 0,
.peer = NULL,
struct bt_data ad[3] = {
BT_DATA_BYTES(BT_DATA_FLAGS, (BT_LE_AD_GENERAL | BT_LE_AD_NO_BREDR)),
BT_DATA_BYTES(BT_DATA_SOLICIT16, BT_UUID_16_ENCODE(BT_UUID_CTS_VAL)),
.type = BT_DATA_NAME_COMPLETE,
.data_len = strlen(device_name),
.data = (const uint8_t *)device_name,
bt_le_adv_start(&connection_adv_param, ad, ARRAY_SIZE(ad), sd, ARRAY_SIZE(sd));
When both dynamic name and this slow advertising interval are used, I frequently get this error:
bt_att: ATT Timeout for device XX:XX:XX:XX:XX:XX (random). Disconnecting...
But if I disable CONFIG_BT_DEVICE_NAME_DYNAMIC, it works more reliably—though not completely stable either.
I'm wondering:
Is this related to the CTS timing out?
Is there a configurable timeout for CTS or ATT I can adjust?
Would it be better to reduce (shorter) the advertising interval after a connection is established?
Any best practice for using
bt_set_name()with advertising?
Any tips would be appreciated!
