DFU on NR54L15. The image in slot 1 was gone after the device power cycle.
I'm using ncs 2.9.0.
1. I flashed the firmware V0.15.1 on the device. And .
2. Update it "Confirm only" with nRF Connect Device Manager App to V0.15.2The update was Compelete.
3. Then I reconnected to the device and read the images:
4. I powered cycle the device and read the images. again:
The image in Slot 1 is gone.
The update log is as follows:
[00:00:01.142,531] <inf> ieee802154_nrf5: nRF5 802154 radio initialized
[00:00:01.148,279] <inf> fs_zms: 4 Sectors of 4096 bytes
[00:00:01.148,292] <inf> fs_zms: alloc wra: 0, fc0
[00:00:01.148,301] <inf> fs_zms: data wra: 0, 0
[00:06:51.263,420] <wrn> bt_l2cap: Ignoring data for unknown channel ID 0x003a
[00:06:52.193,496] <inf> mcuboot_util: Image index: 0, Swap type: none
[00:06:52.467,832] <inf> mcuboot_util: Image index: 0, Swap type: none
[00:06:52.467,868] <inf> mcuboot_util: Image index: 0, Swap type: none
[00:06:52.467,891] <inf> nordic_dfu_ble: DFU in progress, image 0: 0 B / 728290 B
[00:06:52.467,954] <inf> nordic_dfu_ble: Current image version: 0.15.1
[00:06:52.467,991] <inf> nordic_dfu_ble: New image version: 0.15.2
[00:06:52.468,002] <inf> nordic_dfu_ble: Enter update mode
[00:06:52.468,029] <inf> nordic_dfu_ble: DFU Started
[00:06:52.733,428] <inf> nordic_dfu_ble: DFU in progress, image 0: 1972 B / 728290 B
[00:08:00.395,757] <inf> nordic_dfu_ble: DFU in progress, image 0: 721812 B / 728290 B
[00:08:09.507,486] <inf> ieee802154_nrf5: nRF5 802154 radio initialized
[00:08:09.513,018] <inf> fs_zms: 4 Sectors of 4096 bytes
[00:08:09.513,031] <inf> fs_zms: alloc wra: 0, f00
[00:08:09.513,040] <inf> fs_zms: data wra: 0, c0
[00:08:09.529,476] <inf> bt_sdc_hci_driver: SoftDevice Controller build revision:
                                            2d 79 a1 c8 6a 40 b7 3c  f6 74 f9 0b 22 d3 c4 80 |-y..j@.< .t.."...
                                            74 72 82 ba                                      |tr..
[00:08:09.532,302] <inf> bt_hci_core: Identity: C2:C0:46:12:4B:D6 (random)
[00:08:09.532,323] <inf> bt_hci_core: HCI: version 6.0 (0x0e) revision 0x306b, manufacturer 0x0059
[00:08:09.532,340] <inf> bt_hci_core: LMP: version 6.0 (0x0e) subver 0x306b
[00:09:16.697,336] <inf> mcuboot_util: Image index: 0, Swap type: perm
I tested "Test and Confirm", too. The result is the same.
Could you give me some advice?
Thanks in advance!
    Thanks for your reply and sorry for the delay.
    The versions I used are nearly the same except the version number(CONFIG_MCUBOOT_IMGTOOL_SIGN_VERSION).
    The partitions.yml is as follow:
    app:
      address: 0x8000
      end_address: 0xc0400
      region: flash_primary
    mcuboot:
      address: 0x0
      end_address: 0x7800
    mcuboot_pad:
      address: 0x7800
      end_address: 0x8000
    mcuboot_primary:
      address: 0x7800
      end_address: 0xc0000
      orig_span: &id001
      - app
      - mcuboot_pad
      span: *id001
    mcuboot_primary_app:
      address: 0x8000
      orig_span: &id002
      - app
      span: *id002
    mcuboot_secondary:
      address: 0xc0400
      end_address: 0x179000
      orig_span: &id003
      - mcuboot_secondary_pad
      - mcuboot_secondary_app
      span: *id003
    mcuboot_secondary_app:
      address: 0xc0c00
    mcuboot_secondary_pad:
      address: 0xc0400
      end_address: 0xc0c00
    otp:
      address: 0xffd500
      end_address: 0xffd9fc
      region: otp
    settings_storage:
      address: 0x179000
      end_address: 0x17d000
    sram_primary:
      address: 0x20000000
      end_address: 0x20040000
      region: sram_primary
    I added the
    "CONFIG_LOG=y
    CONFIG_MCUBOOT_LOG_LEVEL_DBG=y"
    in sysbuild/mcuboot/prj.conf.
    But I got "region `FLASH' overflowed by 7540 bytes" when I built.
    It seems that there is not enough space for the log.
    BR.
  • Hello, you can increase the size of the mcuboot partition with the CONFIG_PM_PARTITION_SIZE_MCUBOOT setting. For example, you can CONFIG_PM_PARTITION_SIZE_MCUBOOT=0x12000 to your sysbuild/mcuboot/prj.conf file.
    I'm very sorry for the delay.
    I added CONFIG_PM_PARTITION_SIZE_MCUBOOT=0x12000. But it still showed "region `FLASH' overflowed by 3024 bytes" .
    It showed "3024 bytes" whether I didn't set CONFIG_PM_PARTITION_SIZE_MCUBOOT or I set it a larger size, like 0x13000.
    I  modified the size 0x7800 of mcuboot in partition.yml to 0x8000, the overflowed size would decrease to "976 bytes".
    When I increase it to 0x8400,  the building was still failed, but without "overflow xxx bytes"
    [180/185] Linking C executable zephyr/zephyr_pre0.elf
    FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map /opt/nordic/ncs/v2.9.0/ac1/build_ac1_debug/mcuboot/zephyr/zephyr_pre0.map
    : && ccache /opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -Os -DNDEBUG -gdwarf-4 -gdwarf-4 zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj -o zephyr/zephyr_pre0.elf  zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj  -T  zephyr/linker_zephyr_pre0.cmd  -Wl,-Map=/opt/nordic/ncs/v2.9.0/ac1/build_ac1_debug/mcuboot/zephyr/zephyr_pre0.map  -Wl,--whole-archive  app/libapp.a  zephyr/libzephyr.a  zephyr/arch/common/libarch__common.a  zephyr/arch/arch/arm/core/libarch__arm__core.a  zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a  zephyr/arch/arch/arm/core/cortex_m/cmse/libarch__arm__core__cortex_m__cmse.a  zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a  zephyr/lib/libc/minimal/liblib__libc__minimal.a  zephyr/lib/libc/common/liblib__libc__common.a  zephyr/soc/soc/nrf54l15/libsoc__nordic.a  zephyr/drivers/cache/libdrivers__cache.a  zephyr/drivers/clock_control/libdrivers__clock_control.a  zephyr/drivers/flash/libdrivers__flash.a  zephyr/drivers/timer/libdrivers__timer.a  modules/mcuboot/boot/bootutil/zephyr/libmcuboot_util.a  modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a  -Wl,--no-whole-archive  zephyr/kernel/libkernel.a  -L/opt/nordic/ncs/v2.9.0/ac1/build_ac1_debug/mcuboot/zephyr  zephyr/arch/common/libisr_tables.a  -mcpu=cortex-m33  -mthumb  -mabi=aapcs  -mfp16-format=ieee  -fuse-ld=bfd  -Wl,--gc-sections  -Wl,--build-id=none  -Wl,--sort-common=descending  -Wl,--sort-section=alignment  -Wl,-u,_OffsetAbsSyms  -Wl,-u,_ConfigAbsSyms  -nostdlib  -static  -Wl,-X  -Wl,-N  -Wl,--orphan-handling=warn  -Wl,-no-pie -L"/opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/thumb/v8-m.main/nofp" -lc -lgcc && cd /opt/nordic/ncs/v2.9.0/ac1/build_ac1_debug/mcuboot/zephyr && /opt/homebrew/Cellar/cmake/3.26.3/bin/cmake -E true
    /opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.c.obj): in function `k_sem_give':
    /opt/nordic/ncs/v2.9.0/ac1/build_ac1_debug/mcuboot/zephyr/include/generated/zephyr/syscalls/kernel.h:1120: undefined reference to `z_impl_k_sem_give'
    /opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.c.obj): in function `k_thread_create':
    /opt/nordic/ncs/v2.9.0/ac1/build_ac1_debug/mcuboot/zephyr/include/generated/zephyr/syscalls/kernel.h:85: undefined reference to `z_impl_k_thread_create'
    /opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.c.obj): in function `k_thread_name_set':
    /opt/nordic/ncs/v2.9.0/ac1/build_ac1_debug/mcuboot/zephyr/include/generated/zephyr/syscalls/kernel.h:436: undefined reference to `z_impl_k_thread_name_set'
    /opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.c.obj): in function `k_sem_take':
    /opt/nordic/ncs/v2.9.0/ac1/build_ac1_debug/mcuboot/zephyr/include/generated/zephyr/syscalls/kernel.h:1103: undefined reference to `z_impl_k_sem_take'
    collect2: error: ld returned 1 exit status
    [10/20] No configure step for 'ac1'
    FAILED: _sysbuild/sysbuild/images/bootloader/mcuboot-prefix/src/mcuboot-stamp/mcuboot-build /opt/nordic/ncs/v2.9.0/ac1/build_ac1_debug/_sysbuild/sysbuild/images/bootloader/mcuboot-prefix/src/mcuboot-stamp/mcuboot-build
    cd /opt/nordic/ncs/v2.9.0/ac1/build_ac1_debug/mcuboot && /opt/homebrew/Cellar/cmake/3.26.3/bin/cmake --build .
    FATAL ERROR: command exited with status 1: /opt/homebrew/bin/cmake --build /opt/nordic/ncs/v2.9.0/ac1/build_ac1_debug
    Is 0x8000 the upper limit ?
    Is there any way to decrease the usage of mcuboot?
    BR.
    Did you add it to your mcuboot configuration? Also note that this configuration will be ignored if you are using a static partition layout (pm_static.yaml). Please test without the static partitioning file if you are using one.
    Thanks for your reply.
    After I removed the pm_static.yml, it built successfully.
    But I didn't find any log of mcuboot on RTTViewer during DFU and reboot.
    I have set "CONFIG_USE_SEGGER_RTT=y" in sys build/mcuboot/prj.conf.
    But the DFU became normal. I can update the device to 0.15.2 from 0.15.1, and then update it to 0.15.3 from 0.15.2. It didn't reboot itself when the second update starts. The image in slot 1 isn't gone. It's Flags are "Bootable", without "Pending" and "Permanent".
    BR.
