DFU issue - bt_mesh_cli: dropping
Dear,
I’m experiencing an issue with performing DFU over BLE Mesh. I have a setup with one node acting as provisioner and distributor. This node has a new image loaded (with a modified advertising name and updated imgtool_sign_version). Additionally, there is one target node (node 3) added in ble mesh.
I’ve uploaded the image to the distributor, added a slot, and registered the receiver. However, when I start the distribution and check the status, I receive a response indicating phase 10 and status 0.
This setup used to work occasionally when using SDK v2.6.2. However, after migrating to SDK v2.7.0, the issue consistently appears.
Do you have any idea what might be causing this?
Here is Seggers rtt output:
And commands from app:
I have also tried with image index 1, but nothing...
Any idea, inputs?
Thank you
Matej
  • Hi Amanda,
    I performed few more tests... E: JEDEC id [ff ff ff] expect [c2 28 17] presents on custom board - but there is no external flash.
    Here is situation I'm using two nrf52 dks, one as provisioner, another one as node and one custom board as node.
    FW updated was successful and switched but provisioning info was lost.
    Then I have implemented bugfix - swapped arguments
    And here on the left is log from provisioner, and on the right side are nodes, where FW should be updated but it was not. Nevertheless if there is written that upload succeeded and FW was applying.
    In the red on the left side you can see error 3 - log from provisioner, while on the right side there is log from nodes where i'm missing message "Distribution phase changed to Idle"...
    For more detailed log it would take more effort since we are already used almost all of the flash. If needed we will need to disable half of features...
    Any idea why could applying fix could trigger something like this? Is there any other code where fix should also be applied? maybe switching arguments is needed also within bootloader or what did i miss?
    Thank you.
    BR,
    Matej
    https://github.com/nrfconnect/sdk-nrf/pull/22642/files
    It seems more modification than scripts/bluetooth/mesh/mesh_dfu_metadata.py.
    # get PULL request
    cd <your NCS folder>/nrf
    git fetch ncs pull/22642/head:pr-22642
    git checkout pr-22642
    west update
    Could you try again and let me know the result?
    -Amanda H.
  • Hi Amanda,
    I've cherry-picked all the changes, and everything is working as expected now. I initially assumed the other changes weren't necessary since they were located in the test folder, and it was mentioned that this is a one-line fix. However, it looks like the provisioning info is now retained correctly.
    The provisioner is still showing some errors, even though the firmware update was successfully applied to the nodes.
    What is the recommended procedure for updating the firmware on the provisioner itself? I initially assumed that once the firmware will be distributed to the nodes, the provisioner would also be updated automatically.
    In my test scenario, I had the provisioner with ID 2, and two nodes with IDs 4 and 6. The nodes were in phase 2, and the provisioner—which already had the image—showed phase 10 as expected during the transfer
    Could you also clarify the standard approach for updating the provisioner? I noticed that using the app and selecting "Test + Confirm" successfully updated the provisioner's firmware without any issues.
    Also, do you have any information on the planned release date for v3.1.0? I’ve seen that some preview versions are already available.
    Thank youfor info!
    Matej
    The same flow as you did. See this note in the testing
  • What about release date for v3.1.0?
    Do you have any information on the planned release date for v3.1.0? I’ve seen that some preview versions are already available.
    Thanks.
    BR,
    Matej
