NRF54L15 DK soft bricked?
Hi!
I have somehow softbricked my nrf54L15 dk. This happened by using nrf conncet board configurator. First symptom was no uart logs and now I get this crash via RTT logging. Program is Blink sample
RTT viewer log:
(Connection lost)
00> 7F 85 8B
00> [00:00:00.430,51[00:00:00.430,525] <dbg> os: setup_thread_stack: stack 0x2000b2e8 for thread 0x20002318: obj_size=320 buf_start=0x2000b2e8  buf_size 320 stack_ptr=0x2000b428
00> [00:00:00.430,547] <dbg> clock_control: clkstarted_handle: lfclk: Clock started
00> [00:00:00.430,562] <dbg> os: setup_thread_stack: stack 0x2000a7e8 for thread 0x200001c0: obj_size=768 buf_start=0x2000a7e8  buf_size 768 stack_ptr=0x2000aae8
00> *** Booting nRF Connect SDK v2.7.0-5cb85570ca43 ***
00> *** Using Zephyr OS v3.6.99-100befc70c74 ***
00> [00:00:00.430,611] <dbg> os: k_sched_unlock: scheduler unlocked (0x20002398:0)
00> [00:00:00.430,632] <dbg> os: z_impl_k_mutex_lock: 0x20002398 took mutex 0x20000198, count: 1, orig prio: 0
00> [00:00:00.430,639] <dbg> os: z_impl_k_mutex_unlock: mutex 0x20000198 lock_count: 1
00> [00:00:00.430,648] <dbg> os: z_impl_k_mutex_unlock: new owner of mutex 0x20000198: 0 (prio: -1000)
00> Testtest RTT[00:00:00.432,320] <dbg> os: z_tick_sleep: thread 0x20002398 for 1 ticks
00> [00:00:00.432,387] <err> os: ***** USAGE FAULT *****
00> [00:00:00.432,392] <err> os:   Stack overflow (context area not valid)
00> [00:00:00.432,400] <err> os: r0/a1:  0x2000a8d8  r1/a2:  0x0000001c  r2/a3:  0x00000000
00> [00:00:00.432,407] <err> os: r3/a4:  0x2000a88c r12/ip:  0x00000000 r14/lr:  0x00001c25
00> [00:00:00.432,411] <err> os:  xpsr:  0x61000200
00> [00:00:00.432,415] <err> os: Faulting instruction address (r15/pc): 0x000010c0
00> [00:00:00.432,432] <err> os: >>> ZEPHYR FATAL ERROR 2: Stack overflow on CPU 0
00> [00:00:00.432,446] <err> os: Current thread: 0x200001c0 (unknown)
00> [00:00:02.734,831] <err> os: Halting system
(Connection lost)
00> 7F 85 8B
00> [00:00:00.430,51[00:00:00.430,575] <dbg> os: setup_thread_stack: stack 0x20004828 for thread 0x200023d8: obj_size=320 buf_start=0x20004828  buf_size 320 stack_ptr=0x20004968
00> [00:00:00.430,614] <dbg> clock_control: clkstarted_handle: lfclk: Clock started
00> [00:00:00.430,630] <dbg> os: setup_thread_stack: stack 0x20003d28 for thread 0x20000260: obj_size=768 buf_start=0x20003d28  buf_size 768 stack_ptr=0x20004028
00> [00:00:00.430,714] <dbg> os: setup_thread_stack: stack 0x20003928 for thread 0x200001c0: obj_size=1024 buf_start=0x20003928  buf_size 1024 stack_ptr=0x20003d28
00> [00:00:00.430,774] <dbg> os: k_sched_unlock: scheduler unlocked (0x20002478:0)
00> [00:00:00.430,792] <dbg> os: z_impl_k_mutex_lock: 0x20002478 took mutex 0x20000198, count: 1, orig prio: 0
00> [00:00:00.430,800] <dbg> os: z_impl_k_mutex_unlock: mutex 0x20000198 lock_count: 1
00> [00:00:00.430,808] <dbg> os: z_impl_k_mutex_unlock: new owner of mutex 0x20000198: 0 (prio: -1000)
00> Testtest RTT[00:00:00.432,479] <dbg> os: z_tick_sleep: thread 0x20002478 for 1 ticks
00> [00:00:00.432,553] <err> os: ***** USAGE FAULT *****
00> [00:00:00.432,557] <err> os:   Stack overflow (context area not valid)
00> [00:00:00.432,566] <err> os: r0/a1:  0x20003e18  r1/a2:  0x0000001c  r2/a3:  0x00000000
00> [00:00:00.432,573] <err> os: r3/a4:  0x20003dcc r12/ip:  0x00000000 r14/lr:  0x00001d71
00> [00:00:00.432,577] <err> os:  xpsr:  0x61000200
00> [00:00:00.432,581] <err> os: Faulting instruction address (r15/pc): 0x000010c0
00> [00:00:00.432,599] <err> os: >>> ZEPHYR FATAL ERROR 2: Stack overflow on CPU 0
00> [00:00:00.432,613] <err> os: Current thread: 0x20000260 (unknown)
00> [00:00:02.953,158] <err> os: Halting system
What might cause this? I have tried already recovery command.
1. No uart logs
2. Debugger does not reach main - It crashes before my breakpoint.
3. No blink
Only way I got these were using RTT. prj.conf
CONFIG_LOG=y
CONFIG_LOG_BUFFER_SIZE=8192
CONFIG_UART_ASYNC_API=y
CONFIG_UART_CONSOLE=n
CONFIG_LOG_BACKEND_UART=n
CONFIG_LOG_BACKEND_RTT=y
CONFIG_USE_SEGGER_RTT=y
CONFIG_SEGGER_RTT_BUFFER_SIZE_UP=4096
#32768
CONFIG_SEGGER_RTT_BUFFER_SIZE_DOWN=64
CONFIG_SEGGER_RTT_MODE_NO_BLOCK_SKIP=y
# General config
CONFIG_LOG=y
CONFIG_LOG_DEFAULT_LEVEL=4
CONFIG_EARLY_CONSOLE=y
CONFIG_THREAD_ANALYZER=y
CONFIG_THREAD_ANALYZER_AUTO=y
