nRF54L15-DK does not wake up from GRTC after sys_poweroff()
Hi everyone,
I'm using the nRF54L15-DK and trying to implement a simple low-power cycle where the board:
  1. Measures sensor values
  2. Sends them via CoAP over OpenThread
  3. Enters system off
  4. Wakes up after a fixed delay using the GRTC timer
Setup:
  • Board Version: 0.9.1 (2024.44)
  • NRF Connect (VS Code)
  • Toolchain: 2.9.0
  • SDK: 2.9.0
  • Build type: secure
After calling z_nrf_grtc_wakeup_prepare() followed by sys_poweroff(), the board enters system off correctly. I also see current dropping to around 1.2 µA, which looks good — but the board never wakes up again, even after the defined timeout.
I’ve pieced the code together from various SDK samples (so I know it might not be perfect), but I can't figure out what’s missing or incorrect with the GRTC configuration.
For simplicity, I’ve uploaded the complete project to GitHub:
https://github.com/wyssalan/nrf_grtc_wakeup/
In the attached image, you can see the program output before it gets stuck. After the "Retunr to main Program" log, it already goes into deepsleep.
Thanks in advance,
Alan
  • I reviewed your code, and the low power cycle is mostly set up correctly. The reason your board doesn't wake up from system off is due to how z_nrf_grtc_wakeup_prepare() is used.
    You are passing DEEP_SLEEP_TIME_S * USEC_PER_SEC directly into z_nrf_grtc_wakeup_prepare() and that value for example 5,000,000 for 5 seconds is being interpreted as an absolute wakeup time, not a delay from now.
    The GRTC expects an absolute timestamp in microseconds. If the current GRTC counter is already well past 5 million, which it usually is, the wakeup point you've given it is in the past. As a result, the wakeup never triggers.
    To fix this, first read the current GRTC counter with z_nrf_grtc_read(), add your desired delay to it, and pass that new value to z_nrf_grtc_wakeup_prepare():
    uint64_t now = z_nrf_grtc_read();
    uint64_t wakeup_at = now + DEEP_SLEEP_TIME_S * USEC_PER_SEC;
    int err = z_nrf_grtc_wakeup_prepare(wakeup_at);
    if (err) {
        // handle your error
    sys_poweroff();
  • Thank you for your feedback!
    I integrated your suggested code. I couldn’t find a function named z_nrf_grtc_read(), but I assume you meant z_nrf_grtc_timer_read() to get the current "now" value. However, even with that change, the board still doesn't wake up.
  • Hello AllWhy,
    From your code, I assume you already checked the System OFF sample. Just to have a sanity check, could you please see if that sample runs correctly on your setup?
    I looked into z_nrf_grtc_wakeup_prepare() and it seems that it takes into account the current GRTC counter value already. Therefore, adding "now" to the timer value was not a correct direction. Our apologies.
    Hieu
