I am migrating from a child_image type project to the newer sysbuild system used in ncs v2.9.0.
My application is based on the ncs nrf5340_audio application, but my application and hardware target are both out-of-tree.
Using ncs v2.6.1 I was able to build this application so it supported mcuboot serial recovery using USB CDC and the application also supported DFU using USB CDC, but now that I am building this application using ncs v2.9.0 with sysbuild, I can no longer get the serial recovery to work correctly.
After building, I program the nrf5340 with the zephyr.hex file in the build\b0n\zephyr and build\mcuboot\zephyr directories. After this step, I can reboot the system into serial recovery mode and I see the following output on the logging interface:
[0:0:0.355,773] <inf> spi_nor: mx25r64@0: 8 MiBy flash *** Booting My Application v2.1.0-dev-12e5ee106034 *** *** Using nRF Connect SDK v2.9.0-7787b2649840 *** *** Using Zephyr OS v3.7.99-1f8f3dc29142 *** [0:0:0.359,161] <inf> mcuboot: Starting bootloader [0:0:0.359,893] <inf> mcuboot: Enter the serial recovery mode
I then use AuTerm to download the application images. For the network core I download the file build\signed_by_mcuboot_and_b0_ipc_radio.bin into image #3 and I download the file build\<product>\zephyr\zephyr.signed.bin into image #0.
If I then reboot the system, the application fails to load and the system appears to be hung/crashed.
I debugged the bootloader and discovered that it is failing to open the flash area for BOOT_SECONDARY_SLOT in <ncs>\mcuboot\boot\bootutil\src\loader.c near line 2688.
This system does use an external spi flash (mx25r64) and I was able to use this flash for DFU using ncs v2.6.1 so I'm sure the hardware is working, but in the serial recover mode, I think mcuboot should download the application image into the on-chip flash so I don't understand why the bootloader can't access the flash BOOT_SECONDARY_SLOT area.
I'll insert my project configuration files below:
In sysbuild_dfu.conf:
SB_CONFIG_BOOTLOADER_MCUBOOT=y SB_CONFIG_PARTITION_MANAGER=y # Step 6.3 - Configure project to use external flash for DFU SB_CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY=y # Step 7.2 - Add b0n image SB_CONFIG_SECURE_BOOT_NETCORE=y # nRF Connect SDK ipc_radio image SB_CONFIG_NETCORE_IPC_RADIO=y # Step 7.3 - Set up multiple partitions SB_CONFIG_MCUBOOT_UPDATEABLE_IMAGES=2 # Step 7.4 - Add support to netcore for DFU SB_CONFIG_NETCORE_APP_UPDATE=y # Step 7.5 - Add support to mcuboot for updating # two cores simultaneously SB_CONFIG_MCUBOOT_NRF53_MULTI_IMAGE_UPDATE=y # Step 7.6 - Simultaneous FOTA does not support rollback SB_CONFIG_MCUBOOT_MODE_OVERWRITE_ONLY=y
In prj_dfu.conf:
##### # Use nRF5340 IPC BT controller #CONFIG_BT_LL_ACS_NRF53=y #CONFIG_MAIN_STACK_SIZE=3000 CONFIG_BT_MAX_CONN=2 ##### # Items added for UPF CONFIG_BT_AUDIO_CODEC_CAP_MAX_METADATA_SIZE=30 CONFIG_NRF_APPROTECT_USE_UICR=n CONFIG_BT_L2CAP_TX_MTU=128 ##### # nRF5340 Audio CONFIG_NRF5340_AUDIO=y CONFIG_AUDIO_SOURCE_USB=y # HEADSET = 1, GATEWAY = 2 CONFIG_AUDIO_DEV=2 #CONFIG_TRANSPORT_CIS=y #CONFIG_TRANSPORT_BIS=y # The device to scan for is now set in the PtdSettings struct #CONFIG_BT_DEVICE_NAME="INZONE Buds" #CONFIG_BT_DEVICE_NAME="Galaxy Buds2 Pro" # The Sony WF-1000XM5 earbuds require more than the default 5 codec capabilities CONFIG_CODEC_CAP_COUNT_MAX=12 ##### # We need to enable the STREAM_BIDIRECTIONAL option so the zephyr code will # compile with this feature enabled. The g_settings.biDirAudio flag will # be used in the PTD app to decide what to do at run time. CONFIG_STREAM_BIDIRECTIONAL=y ##### # Sample Rate Converter items # Requied for bi-dir audio with USB because the system # uses 24 kHz for both source and sink streams. CONFIG_SAMPLE_RATE_CONVERTER=y CONFIG_SAMPLE_RATE_CONVERTER_FILTER_SIMPLE=y ##### # Debug items ##### # General CONFIG_DEBUG=y CONFIG_DEBUG_INFO=y CONFIG_WDT_CTLR=n CONFIG_ASSERT=n CONFIG_STACK_USAGE=n CONFIG_THREAD_MONITOR=n CONFIG_THREAD_NAME=y CONFIG_THREAD_RUNTIME_STATS=n CONFIG_THREAD_RUNTIME_STATS_USE_TIMING_FUNCTIONS=n CONFIG_STACK_SENTINEL=y CONFIG_INIT_STACKS=y CONFIG_STATS=n CONFIG_STATS_SHELL=n ##### # I2C Eeprom support CONFIG_I2C=y CONFIG_EEPROM=y CONFIG_EEPROM_AT24=y CONFIG_EEPROM_SHELL=n ##### # Settings CONFIG_SETTINGS=y CONFIG_BT_SETTINGS=y CONFIG_SETTINGS_RUNTIME=y CONFIG_SETTINGS_SHELL=n ##### # Enable USB features CONFIG_USB_DEVICE_STACK=y CONFIG_USB_COMPOSITE_DEVICE=y CONFIG_USB_DEVICE_INITIALIZE_AT_BOOT=n CONFIG_USB_DEVICE_MANUFACTURER="Portland Tool And Die" CONFIG_USB_DEVICE_PRODUCT="PTD BQC-4150" CONFIG_USB_DEVICE_VID=0x1915 CONFIG_USB_DEVICE_PID=0xEA9C ##### # Enable USB CDC uart support CONFIG_USB_CDC_ACM=y CONFIG_UART_LINE_CTRL=y CONFIG_UART_INTERRUPT_DRIVEN=y # Uart driver #CONFIG_SERIAL=y ##### # Logging CONFIG_LOG=y #CONFIG_LOG_BUFFER_SIZE=2048 CONFIG_NEWLIB_LIBC_FLOAT_PRINTF=y CONFIG_LOG_TAG_MAX_LEN=2 CONFIG_LOG_TAG_DEFAULT="--" CONFIG_PRINTK=y # Don't mix the log output with the shell uart IO CONFIG_LOG_BACKEND_UART=y CONFIG_SHELL_LOG_BACKEND=n #CONFIG_LOG_DEFAULT_LEVEL=4 #CONFIG_LOG_MODE_DEFERRED=n #CONFIG_LOG_MODE_IMMEDIATE=y #CONFIG_LOG_PROCESS_THREAD=y # Console related defines CONFIG_CONSOLE=y CONFIG_UART_CONSOLE=y # Shell related defines CONFIG_BOOT_BANNER=n CONFIG_SHELL=y CONFIG_USE_SEGGER_RTT=n ## Disable logs on RTT CONFIG_SHELL_RTT_INIT_LOG_LEVEL_NONE=n CONFIG_SHELL_BACKEND_RTT=n CONFIG_SHELL_BACKEND_SERIAL=y CONFIG_SHELL_BACKEND_SERIAL_CHECK_DTR=y #CONFIG_SHELL_BACKEND_SERIAL_INIT_PRIORITY=51 CONFIG_SHELL_VT100_COLORS=n CONFIG_SHELL_STACK_SIZE=2048 CONFIG_SHELL_CMD_BUFF_SIZE=1024 ## Reduce shell memory usage CONFIG_SHELL_WILDCARD=n CONFIG_SHELL_HELP_ON_WRONG_ARGUMENT_COUNT=n CONFIG_SHELL_STATS=n CONFIG_SHELL_CMDS=n CONFIG_SHELL_HISTORY=n CONFIG_SHELL_PROMPT_UART="BQC-4150>" # Turn off default shell commands CONFIG_I2C_SHELL=n CONFIG_HWINFO_SHELL=n CONFIG_CLOCK_CONTROL_NRF_SHELL=n CONFIG_FLASH_SHELL=n CONFIG_DEVICE_SHELL=n CONFIG_KERNEL_SHELL=n CONFIG_BT_SHELL=n CONFIG_BT_TESTING=n # Suppress err msg from sd_check_card_type. Because SPI_SDHC has no card presence method, # assume card is in slot. Thus error message is always shown if card is not inserted #CONFIG_SD_LOG_LEVEL_OFF=y ##### # Serial boot loader items # Enable mcumgr. CONFIG_BOOTLOADER_MCUBOOT=y CONFIG_MCUMGR_TRANSPORT_SHELL=y CONFIG_MCUMGR_GRP_IMG=y CONFIG_IMG_ERASE_PROGRESSIVELY=y CONFIG_BASE64=y CONFIG_CRC=y #CONFIG_BOOT_SIGNATURE_KEY_FILE="D:\Azure-ptd\BQC-4150\CodeSigningKey\bqc4150_private_key.pem" # External SPI Flash CONFIG_SPI=y CONFIG_SPI_NOR=y CONFIG_SPI_NOR_SFDP_DEVICETREE=y # Enable flash operations CONFIG_FLASH=y CONFIG_FLASH_MAP=y CONFIG_FLASH_PAGE_LAYOUT=y CONFIG_MULTITHREADING=y CONFIG_SPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096 CONFIG_SOC_FLASH_NRF_EMULATE_ONE_BYTE_WRITE_ACCESS=y #CONFIG_FPROTECT=n # The network core cannot access external flash directly. The flash simulator must be used to # provide a memory region that is used to forward the new firmware to the network core CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY=y CONFIG_PCD_APP=y CONFIG_NRF53_UPGRADE_NETWORK_CORE=y CONFIG_UPDATEABLE_IMAGE_NUMBER=2 CONFIG_ADD_MCUBOOT_MEDIATE_SIM_FLASH_DTS=y # Only enable the external driver check override if we are not # using the Nordic QSPI flash driver. #CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK=y - moved to sysbuild.conf ##### # BT security features # SMP = Security Management Protocol CONFIG_BT_SMP=y # If CONFIG_BT_PRIVACY is no, then the system should use public addressees, otherwise RPA. CONFIG_BT_PRIVACY=n CONFIG_BT_BONDABLE=y # we do not want to enforce MITM as this requires authenticated pairing CONFIG_BT_SMP_ENFORCE_MITM=n # we want to overwrite old bonds from the same device (optional, security risk) CONFIG_BT_SMP_ALLOW_UNAUTH_OVERWRITE=n CONFIG_BT_ID_UNPAIR_MATCHING_BONDS=n # Enable CONFIG_BT_LOG_SNIFFER_INFO to have the shell print the link keys on pairing events CONFIG_BT_LOG_SNIFFER_INFO=n ##### # BLE audio features for unicast client # MPL = Media Player CONFIG_BT_BAP_UNICAST_CLIENT=y CONFIG_BT_CAP_INITIATOR=y CONFIG_BT_CSIP_SET_COORDINATOR=y CONFIG_BT_BAP_UNICAST_CLIENT_ASE_SNK_COUNT=2 CONFIG_BT_BAP_UNICAST_CLIENT_ASE_SRC_COUNT=2 CONFIG_BT_BAP_UNICAST_CONFIGURABLE=y CONFIG_BT_MPL=y # MCS = Media Control Service CONFIG_BT_MCS=y # VCP = Volume Control Profile CONFIG_BT_VCP_VOL_CTLR=y ##### # BLE audio features for broadcast source CONFIG_AURACAST=n CONFIG_BT_ISO_BROADCASTER=y CONFIG_BT_BAP_BROADCAST_SOURCE=y # Need to use the CONFIG_BT_AUDIO_BROADCAST_CONFIGURABLE to support 48kHz audio from USB CONFIG_BT_AUDIO_BROADCAST_CONFIGURABLE=y CONFIG_BT_AUDIO_BITRATE_BROADCAST_SRC=96000 #CONFIG_BT_BAP_BROADCAST_16_2_2=n #CONFIG_BT_BAP_BROADCAST_24_2_1=n CONFIG_BT_DEVICE_NAME="PTD BIS SOURCE" CONFIG_BT_AUDIO_BROADCAST_NAME="PTD BIS SOURCE" #CONFIG_BT_AUDIO_BROADCAST_NAME_ALT="PTD 2" #CONFIG_BT_AUDIO_BROADCAST_ENCRYPTED=n #CONFIG_BT_AUDIO_BROADCAST_ENCRYPTION_KEY="PTD_KEY" ##### # BLE audio features for unicast server #CONFIG_BT_VCP_VOL_REND=y #CONFIG_BT_CSIP_SET_MEMBER=y
In sysbuild\mcuboot\prj_dfu.conf:
#CONFIG_DEBUG=y #CONFIG_DEBUG_INFO=y CONFIG_SIZE_OPTIMIZATIONS=y CONFIG_MAIN_STACK_SIZE=20480 CONFIG_MBEDTLS_CFG_FILE="mcuboot-mbedtls-cfg.h" CONFIG_PCD_APP=y #CONFIG_MCUMGR=y #CONFIG_MCUMGR_GRP_STAT=n #CONFIG_MCUMGR_GRP_OS=y #CONFIG_MCUMGR_GRP_IMG=y # Enable mcuboot serial over USB CDC port CONFIG_MCUBOOT_LOG_LEVEL_INF=y #CONFIG_MCUBOOT_LOG_LEVEL_DBG=y CONFIG_MCUBOOT_SERIAL=y CONFIG_BOOT_SERIAL_CDC_ACM=y CONFIG_USB_DEVICE_MANUFACTURER="Portland Tool And Die" CONFIG_USB_DEVICE_PRODUCT="PTD BQC-4150" CONFIG_USB_DEVICE_VID=0x1915 CONFIG_USB_DEVICE_PID=0xEA9C # Stay in serial recovery mode if no valid app is found CONFIG_BOOT_SERIAL_NO_APPLICATION=y # Configure loggging CONFIG_CONSOLE=y CONFIG_CBPRINTF_NANO=y CONFIG_LOG=y # We need to enable UART_CONSOLE even though we are using USB CDC. CONFIG_UART_CONSOLE=y # External SPI Flash CONFIG_SPI=y CONFIG_SPI_NOR=y CONFIG_SPI_NOR_SFDP_DEVICETREE=y # Enable flash operations CONFIG_FLASH=y #CONFIG_IMG_MANAGER=y #CONFIG_STREAM_FLASH=y CONFIG_FLASH_MAP=y CONFIG_FLASH_PAGE_LAYOUT=y CONFIG_BOOT_MAX_IMG_SECTORS=512 CONFIG_MULTITHREADING=y # Change default flash erase size for flexible flash layout # The Nordic QSPI driver does not use the SPI_NOR_FLASH_LAYOUT_PAGE_SIZE variable CONFIG_SPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096 CONFIG_BOOT_ERASE_PROGRESSIVELY=y CONFIG_SOC_FLASH_NRF_EMULATE_ONE_BYTE_WRITE_ACCESS=y CONFIG_FPROTECT=y # The following configurations are required to support simultaneous multi-image update # These options have moved to the top level sysbuild config file. CONFIG_UPDATEABLE_IMAGE_NUMBER=2 CONFIG_BOOT_UPGRADE_ONLY=y # The network core cannot access external flash directly. The flash simulator must be used to # provide a memory region that is used to forward the new firmware to the network core CONFIG_FLASH_SIMULATOR=y CONFIG_FLASH_SIMULATOR_DOUBLE_WRITES=y CONFIG_FLASH_SIMULATOR_STATS=n CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY=y # Add support for programming the network processor as part of the DFU system # These options have moved to the top level sysbuild config file. CONFIG_NRF53_MULTI_IMAGE_UPDATE=y CONFIG_BOOT_IMAGE_ACCESS_HOOKS=y CONFIG_MCUBOOT_SERIAL_DIRECT_IMAGE_UPLOAD=y #CONFIG_NRF53_RECOVERY_NETWORK_CORE=y # Only enable the external driver check override if we are not # using the Nordic QSPI flash driver. # These options have moved to the top level sysbuild config file. CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK=y # Use button0 to enter serial recovery mode CONFIG_BOOT_SERIAL_ENTRANCE_GPIO=y
In pm_static_dfu.yml:
mcuboot:
address: 0x0
placement:
before:
- mcuboot_primary
region: flash_primary
mcuboot_pad:
address: 0x16000
placement:
align:
start: 0x4000
before:
- mcuboot_primary_app
mcuboot_primary:
address: 0x16000
orig_span: &id001
- mcuboot_pad
- app
span: *id001
app:
address: 0x16200
mcuboot_primary_app:
address: 0x16200
orig_span: &id002
- app
span: *id002
settings_storage:
address: 0xfd000
end_address: 0xff000
placement:
align:
start: 0x4000
before:
- end
EMPTY_0:
address: 0xff000
placement:
after:
- settings_storage
mcuboot_primary_1:
address: 0x0
device: flash_ctrl
region: ram_flash
mcuboot_secondary:
address: 0x00000
device: mx25r64
region: external_flash
placement:
align:
start: 0x4
mcuboot_secondary_1:
address: 0xec000
device: mx25r64
external_flash:
address: 0x12C000
device: mx25r64
pcd_sram:
address: 0x20000000
region: sram_primary
rpmsg_nrf53_sram:
address: 0x20070000
end_address: 0x20080000
placement:
before:
- end
sram_primary:
address: 0x20002000
end_address: 0x20070000
otp:
address: 0xff8100
end_address: 0xff83fc
region: otp
Please let me know if you have any ideas for how to fix this issue or if there are other tests I should run to help debug this issue.
Kristopher
