Power Profiler PPK2 stuck in bootloader
PPK2 is stuck in bootloader after trying to flash the latest firmware on Power Profiler 4.2.1 (Windows 10).
The error is "serialport could not be opened ". The same issue is reported in Programmer.
The prompt comes up to flash the firmware but hangs when clicking Program.
On Linux there is no error until hitting program but then it reports the errors at the bottom
Logs Windows 10:
2025-04-13T21:01:59.743Z INFO Initialising the bundled nrfutil device
2025-04-13T21:01:59.756Z DEBUG Application data folder: C:\Users\Dom\AppData\Roaming\nrfconnect\pc-nrfconnect-ppk
2025-04-13T21:01:59.826Z DEBUG Sending event "ppk: running nrfutil device"
2025-04-13T21:01:59.849Z DEBUG App pc-nrfconnect-ppk v4.2.1 (official)
2025-04-13T21:01:59.850Z DEBUG App path: C:\Users\Dom\.nrfconnect-apps\node_modules\pc-nrfconnect-ppk
2025-04-13T21:01:59.850Z DEBUG nRFConnect 5.1.0, required by the app is (>=5.0.1)
2025-04-13T21:01:59.850Z DEBUG nRFConnect path: C:\Users\Dom\AppData\Local\Programs\nrfconnect\resources\app.asar
2025-04-13T21:01:59.850Z DEBUG HomeDir: C:\Users\Dom
2025-04-13T21:01:59.850Z DEBUG TmpDir: C:\Users\Dom\AppData\Local\Temp
2025-04-13T21:02:00.363Z DEBUG Sending event "ppk: running nrfutil device"
2025-04-13T21:02:00.578Z DEBUG Sending event "ppk: running nrfutil device"
2025-04-13T21:02:00.593Z DEBUG Sending event "ppk: running nrfutil device"
2025-04-13T21:02:00.640Z INFO Using the bundled core version for nrfutil device: 8.0.0
2025-04-13T21:02:01.197Z INFO Using nrfutil-device version: 2.6.4
2025-04-13T21:02:01.197Z INFO Using nrf-device-lib version: 0.17.35
2025-04-13T21:02:01.198Z INFO Using nrfjprog DLL version: 10.24.2
2025-04-13T21:02:01.198Z INFO Using JLink version: JLink_V7.94i
2025-04-13T21:02:01.435Z INFO Getting serial port options from the persistent store for EA2ADC2BB2D4.pc-nrfconnect-ppk
2025-04-13T21:02:01.436Z INFO Device Connected SN:EA2ADC2BB2D4
2025-04-13T21:02:01.437Z DEBUG Sending event "ppk: device connected"
2025-04-13T21:02:01.438Z DEBUG Sending event "ppk: device connected"
2025-04-13T21:02:06.548Z INFO Selecting device with the serial number EA2ADC2BB2D4
2025-04-13T21:02:06.568Z DEBUG Sending event "ppk: running nrfutil device"
2025-04-13T21:02:08.784Z ERROR Error: Failed with exit code 1.
Failed to device info one or more devices:
 * EA2ADC2BB2D4: [sdfu] serialport could not be opened, code: FileOpenFailed.
Message: Operation device-info failed, [sdfu] serialport could not be opened.
2025-04-13T21:02:08.785Z INFO Selected device with the serial number EA2ADC2BB2D4
2025-04-13T21:02:08.785Z INFO Validating firmware for device with s/n EA2ADC2BB2D4
2025-04-13T21:02:08.786Z DEBUG Sending event "ppk: device selected"
2025-04-13T21:02:10.915Z DEBUG Sending event "ppk: running nrfutil device"
Logs Ubuntu 24.10
2025-04-13T21:06:09.300Z INFO Initialising the bundled nrfutil device
2025-04-13T21:06:09.331Z DEBUG Application data folder: /home/dom/.config/nrfconnect/pc-nrfconnect-ppk
2025-04-13T21:06:09.529Z DEBUG Sending event "ppk: running nrfutil device"
2025-04-13T21:06:09.531Z DEBUG App pc-nrfconnect-ppk v4.2.1 (official)
2025-04-13T21:06:09.531Z DEBUG App path: /home/dom/.nrfconnect-apps/node_modules/pc-nrfconnect-ppk
2025-04-13T21:06:09.533Z DEBUG nRFConnect 5.1.0, required by the app is (>=5.0.1)
2025-04-13T21:06:09.534Z DEBUG nRFConnect path: /tmp/.mount_nrf-covQGMlh/resources/app.asar
2025-04-13T21:06:09.534Z DEBUG HomeDir: /home/dom
2025-04-13T21:06:09.534Z DEBUG TmpDir: /tmp
2025-04-13T21:06:09.836Z DEBUG Sending event "ppk: running nrfutil device"
2025-04-13T21:06:10.097Z DEBUG Sending event "ppk: running nrfutil device"
2025-04-13T21:06:10.105Z DEBUG Sending event "ppk: running nrfutil device"
2025-04-13T21:06:10.106Z INFO Using the bundled core version for nrfutil device: 8.0.0
2025-04-13T21:06:10.295Z INFO Using nrfutil-device version: 2.6.4
2025-04-13T21:06:10.295Z INFO Using nrf-device-lib version: 0.17.35
2025-04-13T21:06:10.295Z INFO Using nrfjprog DLL version: 10.24.2
2025-04-13T21:06:10.295Z INFO Using JLink version: JLink_V7.94e
2025-04-13T21:06:10.295Z WARN Installed JLink version does not match the expected version (JLink_V7.94i)
2025-04-13T21:06:10.674Z INFO Getting serial port options from the persistent store for EA2ADC2BB2D4.pc-nrfconnect-ppk
2025-04-13T21:06:10.674Z INFO Device Connected SN:EA2ADC2BB2D4
2025-04-13T21:06:10.676Z DEBUG Sending event "ppk: device connected"
2025-04-13T21:06:12.385Z INFO Selecting device with the serial number EA2ADC2BB2D4
2025-04-13T21:06:12.406Z DEBUG Sending event "ppk: running nrfutil device"
2025-04-13T21:06:13.516Z INFO Selected device with the serial number EA2ADC2BB2D4
2025-04-13T21:06:13.516Z INFO Validating firmware for device with s/n EA2ADC2BB2D4
2025-04-13T21:06:13.517Z DEBUG Sending event "ppk: device selected"
2025-04-13T21:06:20.006Z DEBUG Sending event "ppk: running nrfutil device"
2025-04-13T21:06:21.116Z DEBUG EA2ADC2BB2D4 on is now in DFU-Bootloader...
2025-04-13T21:06:21.189Z DEBUG DFU finished:  [object Object]
2025-04-13T21:06:21.193Z DEBUG Starting DFU
2025-04-13T21:06:21.203Z DEBUG Sending event "ppk: running nrfutil device"
2025-04-13T21:06:23.522Z ERROR Error: Failed with exit code 1.
One or more program tasks failed:
 * EA2ADC2BB2D4: [sdfu] , code: SdfuExtVerificationFailed.
Message: Failed, [sdfu].
2025-04-13T21:06:23.523Z ERROR Failed to write to the target device: Failed with exit code 1.
2025-04-13T21:06:23.524Z ERROR Error while setting up device with the serial number EA2ADC2BB2D4
2025-04-13T21:06:23.524Z ERROR Error: Failed with exit code 1.
2025-04-13T21:06:23.531Z INFO Deselected device
2025-04-13T21:06:23.531Z INFO Deselecting device
2025-04-13T21:06:23.531Z DEBUG Sending event "ppk: device deselected "
