Clarification needed - MCUboot + Watchdog (SDK v2.9.0)
Dear nordic team,
even if enabled for mcuboot via CONFIG_WATCHDOG / CONFIG_BOOT_WATCHDOG_FEED, our device performs a reset when swapping the image. More precisely: when erasing the flash. When a look at the source code, it seems that the watchdog is not re-set during the erase operation. Is this correct? In that case, the time-out for the wdt has to be set accordingly, taking into consideration the maximum time it needs to erase the sectors for the image (e.g. roughly 256 pages * 85 ms = 21760 ms). Could you please confirm? Would'nt it make sense to add MCUBOOT_WATCHDOG_FEED() to the erase operation as wel int that case?
Regards
Ulf
