So I've been playing around with some code example to make UART work (which I did eventually) using NRF SDK 5 (v17). However the last version of SES (8.22a) requires some tweaks in order to make it work. Like setting Library I/O setting to RTT (because otherwise stdout will throw errors) and also removing the limit of .rodata and .text sections (this is irrelevant I guess anyway). The code looks like this:
#include <stdbool.h>
#include <stdint.h>
#include <stdio.h>
#include "app_uart.h"
#include "app_error.h"
#include "nrf_delay.h"
#include "nrf.h"
#include "bsp.h"
#include "nrf_uart.h"
#include "SEGGER_RTT.h"
#define RX_SIZE 256
#define TX_SIZE 256
#define UART_HWFC APP_UART_FLOW_CONTROL_DISABLED
// A simple error handler for uart if something goes wrong...
void uart_err_handle(app_uart_evt_t * p)
printf("HERE: %d", p->evt_type);
//printf("Board Loaded");
bsp_board_init(BSP_INIT_LEDS); // initialize leds
uint32_t err_code; // a variable to hold the error value
const app_uart_comm_params_t com_params = // struct to hold the uart configurations
RX_PIN_NUMBER,
TX_PIN_NUMBER,
RTS_PIN_NUMBER,
CTS_PIN_NUMBER,
UART_HWFC, // hardware flow control disabled
false, // parity = none
NRF_UART_BAUDRATE_115200 // set this baud rate for communication
APP_UART_FIFO_INIT(&com_params, RX_SIZE, TX_SIZE, uart_err_handle, APP_IRQ_PRIORITY_LOWEST, err_code);
while(true)
uint8_t rx_ch;
while (app_uart_get(&rx_ch) != NRF_SUCCESS);
if (rx_ch == 't')
bsp_board_leds_on();
printf("Leds Turned On!!\r\n");
else if (rx_ch == 'k')
bsp_board_leds_off();
printf("Leds Turned Off!!\r\n");
As you can see it's just a basic example, but my question is this, IF I compile it with SES 5.42 (which I understand is the latest tested on v17) THEN everything works fine, but if I compile it with SES 8.22a (RTT option enabled) the function app_uart_get() never gets a result back... why is this ? and should I always use SES 5.42 ? are there any drawbacks ?
