Thingy91 LTE BLE Gateway Sample not working
Hello everyone!
I am rather new to firmware development with Nordic products and am experiencing some trouble with the Thingy91 LTE BLE Gateway sample.
What is the problem?
I am trying to flash the sample onto the Thingy91 (via a Debugger and the SWD connector), but there are 2 issues:
  • no LTE connection can be established wiuth the NRF Cloud
  • the LPUART sample on the nrf52840 is not detected properly by the nrf9160
As a result, it is stuck in the connection establishment process to the cloud, as described below.
LTE Issue
It is precisely stuck in this state:
  • LED 4 blinking: The device is connecting to nRF Cloud.
Apparently it tries to connect to a seemingly random port and not 8883 for MQTT.
The antenna itself is fine though and the asset_tracker_v2 firmware works as well.
BLE Issue
The nrf9160 does not detect the lpuart firmware on the nrf52840 and logs an error similar to:
"could not detect bluetooth core"
I have no idea how to resolve this problem.
Equipment / Config
As required by the sample I do have a JLink Debugger to flash the chips directly and am using the VS Code extension to do so.
The board config is respectively set to thingy91/nrf9160/ns and thingy91/nrf52840.
I am grateful for all ideas / help and happy to supply more details!
TK
    Which applications have you flashed on nrf9160 and what on nrf52840?
    Which NCS version do you use?
    Can you show complete error logs?
    Dejan
  • Hi Dejan,
    thanks for your reply.
    Applications:
    lte_ble_gateway on the nrf9160
    hci_lpuart on the nrf52840
    I am using the nRF Connect SDK v2.9.0
    Here is the log from the nrf9160:
    00> *** Booting nRF Connect SDK v2.9.0-7787b2649840 ***
    00> *** Using Zephyr OS v3.7.99-1f8f3dc29142 ***
    00> [00:00:00.255,737] <inf> lte_ble_gw: LTE Sensor Gateway sample started
    00> [00:00:00.255,920] <inf> lte_ble_gw: Initializing Bluetooth..
    00> [00:00:00.255,920] <err> bt_hci_core: No HCI driver registered
    00> [00:00:00.255,950] <err> lte_ble_gw: Bluetooth init failed (err -19)
    00> [00:00:00.495,605] <inf> lte_ble_gw: Establishing LTE link (this may take some time) ...
    00> [00:00:01.942,260] <wrn> lpuart: req pin low when expected high
    00> [00:00:01.942,352] <err> lpuart: Empty receiver state:4
    00> [00:00:03.677,307] <wrn> lpuart: req pin low when expected high
    00> [00:00:03.677,429] <err> lpuart: Empty receiver state:4
    00> [00:00:05.393,615] <wrn> lpuart: req pin low when expected high
    00> [00:00:05.393,737] <err> lpuart: Empty receiver state:4
    00> [00:00:06.355,316] <inf> nrf_cloud_info: Device ID: nrf-<MY-ID>
    00> [00:00:06.355,743] <inf> nrf_cloud_info: IMEI:      <MY-ID>
    00> [00:00:06.356,201] <inf> nrf_cloud_info: Modem FW:  mfw_nrf9160_1.3.5
    00> [00:00:06.356,231] <inf> nrf_cloud_info: Protocol:          MQTT
    00> [00:00:06.356,262] <inf> nrf_cloud_info: Download protocol: HTTPS
    00> [00:00:06.356,292] <inf> nrf_cloud_info: Sec tag:           <NUMERIC-SEC-TAG>
    00> [00:00:06.356,323] <inf> nrf_cloud_info: Host name:         mqtt.nrfcloud.com
    00> [00:00:06.622,955] <err> nrf_cloud_transport: Could not connect to nRF Cloud MQTT Broker mqtt.nrfcloud.com, port: 45858. err: -111
    00> [00:00:07.103,759] <wrn> lpuart: req pin low when expected high
    00> [00:00:07.103,851] <err> lpuart: Empty receiver state:4
    00> [00:00:08.825,286] <wrn> lpuart: req pin low when expected high
    00> [00:00:08.825,408] <err> lpuart: Empty receiver state:4
    00> [00:00:10.558,349] <wrn> lpuart: req pin low when expected high
    00> [00:00:10.558,441] <err> lpuart: Empty receiver state:4
    00> [00:00:12.238,342] <wrn> lpuart: req pin low when expected high
    00> [00:00:12.238,464] <err> lpuart: Empty receiver state:4
    00> [00:00:13.951,049] <wrn> lpuart: req pin low when expected high
    00> [00:00:13.951,171] <err> lpuart: Empty receiver state:4
    Logs from the nrf52840:
    00> [00:00:00.000,366] <wrn> swdp: cpu_clock 64000000, delay 10
    00> [00:00:00.000,457] <inf> usb_msc: Sect Count 128
    00> [00:00:00.000,488] <inf> usb_msc: Memory Size 65536
    00> [00:00:00.001,007] <inf> bt_sdc_hci_driver: SoftDevice Controller build revision:
    00> 2d 79 a1 c8 6a 40 b7 3c f6 74 f9 0b 22 d3 c4 80 |-y..j@.< .t.."...
    00> 74 72 82 ba |tr..
    00> [00:00:00.006,988] <inf> bt_hci_core: HW Platform: Nordic Semiconductor (0x0002)
    00> [00:00:00.007,019] <inf> bt_hci_core: HW Variant: nRF52x (0x0002)
    00> [00:00:00.007,049] <inf> bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 45.41337 Build 3074452168
    00> [00:00:00.008,331] <inf> bt_hci_core: Identity: E1:3F:5F:D9:40:ED (random)
    Thank you for your time.
    Best,
    TK
  • Hi TK,
    I suggest that you switch to previous NCS v2.8.0 and make following changes to the samples:
    changes to lte_ble_gateway sample
    --- a/samples/cellular/lte_ble_gateway/boards/nrf9160dk_nrf9160_ns.overlay
    +++ b/samples/cellular/lte_ble_gateway/boards/nrf9160dk_nrf9160_ns.overlay
    @@ -3,6 +3,7 @@
            chosen {
                    zephyr,bt-uart=&lpuart;
    +               zephyr,bt-hci = &bt_hci_uart;
    @@ -23,6 +24,11 @@
                    status = "okay";
                    req-pin = <21>; /* <&interface_to_nrf52840 3 0>; */
                    rdy-pin = <19>; /* <&interface_to_nrf52840 2 0>; */
    +               bt_hci_uart: bt_hci_uart {
    +                       compatible = "zephyr,bt-hci-uart";
    +                       status = "okay";
    diff --git a/samples/cellular/lte_ble_gateway/prj.conf b/samples/cellular/lte_ble_gateway/prj.conf
    index ad2bfa98cf..59e09b386a 100644
    --- a/samples/cellular/lte_ble_gateway/prj.conf
    +++ b/samples/cellular/lte_ble_gateway/prj.conf
    @@ -53,6 +53,8 @@ CONFIG_CONSOLE_GETCHAR=y
    # Enable Bluetooth stack and libraries
    CONFIG_BT=y
    CONFIG_BT_H4=y
    +CONFIG_BT_HCI=y
    +CONFIG_BT_CTLR=n
    CONFIG_BT_WAIT_NOP=y
    changes to hci_lpuart sample
    - no changes are needed for sample from NCS v2.7.0
    - remove disable-rx from the sample's devicetree overlay for UART0 for sample in NCS v2.8.0
    - alternatively, for NCS v2.8.0, apply changes from this pull request
    Dejan
  • Hi Dejan,
    thanks for your input!
    I switched to the NCS v2.8.0 for both samples:
    BLE is now detected properly by the nrf9160, the empty receiver state only occurs once before logging "Bluetooth ready" and "Scanning...", so it overcomes that problem !
    To build both samples, I have applied your changes to the overlay files of the thingy91/... instead of nrf9160dk/..., and disabled sysbuild for both scenarios as I couldn't build the nrf52840 sample with it being active.
    Nonetheless, I still experience the nRF Cloud connectivity error as described below:
    Do you have any ideas what is going on here? As I would like to switch to a custom MQTT endpoint later on, maybe that is worth trying already? I do not know how to accomplish connecting to my own MQTT broker, though.
    Anyway, thanks for your effort once again! :)
    Best,
    TK
    This could be a certificate related problem. You can look at this troubleshooting guide and this quick start guide.
    Dejan
