nRF21540 FEM Not Improving Range in ESB Project (NCS 2.9 / 3.0.1)
We are currently working on a project based on Enhanced ShockBurst (ESB) and would like to use Front-End Module (FEM) support with the nRF21540.
In your Enhanced ShockBurst samples, you mention that there is support for the nRF21540 FEM. The Enhanced ShockBurst (ESB) documentation states:
“ESB requires the MPSL library for front-end module support. This library is always linked into the build, however, it is not initialized by default to provide your application and the ESB protocol with access to all hardware resources. See MPSL FEM-only configuration for more details.”
We have been testing the esb_ptx and esb_prx examples for a week now. We're evaluating the range of different setups using the nRF52840, the nRF21540-DK, and the nRF52840 with the nRF21540-EK.
We made a small modification to the esb_prx source code to read and log the RSSI value directly when a packet is received.
We are following the instructions provided in the Enhanced ShockBurst documentation. During build time, we can see confirmation that the FEM configuration is recognized. For example:
  • With the nRF21540-DK: -- Board: nrf21540dk, qualifiers: nrf52840
  • With the nRF52840 + nRF21540-EK: -- Shield(s): nrf21540ek
However, we are not observing any improvement in range when using the nRF21540, neither in transmission nor reception. In your blog and documentation, you mention that the FEM can significantly extend the range, even up to 8x.
We’ve reviewed various blogs and Q&A threads, but due to many recent changes in the SDK, we’ve lost track of the correct procedure. Most resources are based on older SDK versions and no longer apply.
We have a few specific questions:
Q1: We are only using ESB (not Bluetooth). Do we need to explicitly initialize MPSL in our code to enable FEM functionality?
Q2: Should I see additional log output at startup when MPSL is active? Right now, this is all we see:
*** Booting nRF Connect SDK v2.9.0-7787b2649840 ***
*** Using Zephyr OS v3.7.99-1f8f3dc29142 ***
[00:00:00.259,063] <inf> esb_prx: Enhanced ShockBurst prx sample
[00:00:00.266,052] <dbg> esb_prx: clocks_start: HF clock started
[00:00:00.272,857] <inf> esb_prx: Initialization complete
[00:00:00.278,930] <inf> esb_prx: Setting up for packet reception
[00:06:10.058,044] <dbg> esb_prx: event_handler: Packet received, 0xde, RSSI: 79 dBm
[00:06:14.964,416] <dbg> esb_prx: event_handler: Packet received, 0x0f, RSSI: 79 dBm
[00:06:15.164,001] <dbg> esb_prx: event_handler: Packet received, 0x11, RSSI: 78 dBm
Q3: How can we properly increase the TX output power? We’ve come across many examples, but are unsure which ones are correct for SDK v2.9 / 3.0.1.
Q4: How can we improve reception quality? Ideally, we want to use the nRF52840 + nRF21540-EK with an external antenna. Do we need to manually activate the LNA for this?
Q5: It would be very helpful if the ESB documentation or samples included more detailed instructions about FEM configuration, especially regarding what is required vs optional. A lot has changed in the SDK over the past years, and many online examples no longer work with SDK v2.9 / 3.0.1.
  • Hello Kazi,
    I’m curious to know if you’ve been able to raise the issue with development yet? I really think something needs to be done about the documentation—it doesn’t match the current situation in several areas and is also very sparsely described.
    I’ve been busy testing over the past week. What I found is that the TX output power has to be increased in a different way than what’s documented. I’m currently setting the power using:
    esb_set_tx_power(22);
    or with
    esb_set_tx_power(CONFIG_MPSL_FEM_NRF21540_TX_GAIN_DB);
    If I don’t do this, the range is less than or equal to the situation without a FEM.
    I’m now getting really good range with the nRF21540 FEM. I did an outdoor test today using an nRF21540-DK on the PTX side and was able to reach a distance of over 500 meters with ESB at 1 Mbps and FEM support at 22 dBm. There was no direct line of sight—many trees and even houses were between the transmitter and receiver. The PRX receiver was a basic nRF54L15-DK.
    There is still something strange on the PTX side with the nRF21540: the ESB_EVENT_TX gives a failed event at just 5 to 10 meters distance, even though my PRX is receiving the packets correctly. I don’t see this issue when I use, for example, an nRF54L15. So apparently, the nRF21540 is still not properly receiving ACK packets due to insufficient receive gain or configuration.
    I also couldn’t get it working on the nRF7002-DK + nRF21540-DK (while it does work on an nRF5340-DK, same SoC). Something goes wrong during the build process—so that’s another bug.
    I’ve updated my test example again; see the attachment on the right side (“ESB-RSSI (version 3-7-2025)”).
    In short, there are several bugs in the ESB module and also undocumented functionality. This makes it extra complex to work properly with ESB. But if you fix these bugs and update the documentation, it will be a very nice protocol to work with.
    Thanks in advance for your response,
    Herke Dekker
    Sample: 3771.ESB-RSSI (version 26-7-2025).zip
  • Hello Herke,
    ESB+FEM issue seems resolved with PR https://github.com/nrfconnect/sdk-nrf/pull/23190, but it seems like maybe it was tested with the 3rd party FEMs, not with nRF21540.
  • Hi Kazi,
    Thanks for the update. I’ll go ahead and test the fix.
    I also think it’s very important that you update the documentation — it doesn’t reflect the latest SDK versions at all. As far as I can see, there haven’t been any improvements yet. For example, the documentation around configuring TX power or the required physical connection on the board using the MXHS83QE3000 cable along with an ADP-SMAM-SMAM-G RF adapter is still unclear. Nordic is really making it unnecessarily difficult to work with the nRF21540-EK this way.
    I’ll follow up shortly to confirm whether the fix you provided resolves the issue. In any case, directly connecting the PDN to VDD worked well, and we were able to carry out our tests successfully.
    Herke
  • Hi Kazi,
    I still need to test the fix you’ve made, but the wired connection is working great. It looks like SDK 3.1 will be available very soon as well.
    I’m running into another issue. I’m trying to connect the nRF7002-DK with the nRF21540-EK shield, but as soon as I combine the two, I get a build error (note: the nRF5340-DK + nRF21540-EK setup works fine). Something seems to go wrong in the devicetree. Could you help me resolve this issue as well?
    If this setup works, I’ll be able to build a gateway with excellent range using ESB or Bluetooth, and forward the data over Wi-Fi to a central computer.
    Thanks in advance,
    Herke
    Please create a new case, for this new issue.
