nRF21540 FEM Not Improving Range in ESB Project (NCS 2.9 / 3.0.1)
We are currently working on a project based on Enhanced ShockBurst (ESB) and would like to use Front-End Module (FEM) support with the nRF21540.
In your Enhanced ShockBurst samples, you mention that there is support for the nRF21540 FEM. The Enhanced ShockBurst (ESB) documentation states:
“ESB requires the MPSL library for front-end module support. This library is always linked into the build, however, it is not initialized by default to provide your application and the ESB protocol with access to all hardware resources. See MPSL FEM-only configuration for more details.”
We have been testing the esb_ptx and esb_prx examples for a week now. We're evaluating the range of different setups using the nRF52840, the nRF21540-DK, and the nRF52840 with the nRF21540-EK.
We made a small modification to the esb_prx source code to read and log the RSSI value directly when a packet is received.
We are following the instructions provided in the Enhanced ShockBurst documentation. During build time, we can see confirmation that the FEM configuration is recognized. For example:
  • With the nRF21540-DK: -- Board: nrf21540dk, qualifiers: nrf52840
  • With the nRF52840 + nRF21540-EK: -- Shield(s): nrf21540ek
However, we are not observing any improvement in range when using the nRF21540, neither in transmission nor reception. In your blog and documentation, you mention that the FEM can significantly extend the range, even up to 8x.
We’ve reviewed various blogs and Q&A threads, but due to many recent changes in the SDK, we’ve lost track of the correct procedure. Most resources are based on older SDK versions and no longer apply.
We have a few specific questions:
Q1: We are only using ESB (not Bluetooth). Do we need to explicitly initialize MPSL in our code to enable FEM functionality?
Q2: Should I see additional log output at startup when MPSL is active? Right now, this is all we see:
*** Booting nRF Connect SDK v2.9.0-7787b2649840 ***
*** Using Zephyr OS v3.7.99-1f8f3dc29142 ***
[00:00:00.259,063] <inf> esb_prx: Enhanced ShockBurst prx sample
[00:00:00.266,052] <dbg> esb_prx: clocks_start: HF clock started
[00:00:00.272,857] <inf> esb_prx: Initialization complete
[00:00:00.278,930] <inf> esb_prx: Setting up for packet reception
[00:06:10.058,044] <dbg> esb_prx: event_handler: Packet received, 0xde, RSSI: 79 dBm
[00:06:14.964,416] <dbg> esb_prx: event_handler: Packet received, 0x0f, RSSI: 79 dBm
[00:06:15.164,001] <dbg> esb_prx: event_handler: Packet received, 0x11, RSSI: 78 dBm
Q3: How can we properly increase the TX output power? We’ve come across many examples, but are unsure which ones are correct for SDK v2.9 / 3.0.1.
Q4: How can we improve reception quality? Ideally, we want to use the nRF52840 + nRF21540-EK with an external antenna. Do we need to manually activate the LNA for this?
Q5: It would be very helpful if the ESB documentation or samples included more detailed instructions about FEM configuration, especially regarding what is required vs optional. A lot has changed in the SDK over the past years, and many online examples no longer work with SDK v2.9 / 3.0.1.
  • Hello Herke,
    ''Thanks for your response and for testing. I understand that you're using the nRF21540-DK for the ESB PTX and the nRF52840 (with the nRF21540-EK?!?) on the ESB PRX receiving side.''
    without the nRF21540EK.
    For exb_prx, this is the default sample from NCS (C:\ncs\v3.0.2\nrf\samples\esb\esb_prx).
    For esb_ptx, I have added the code in my previous comment what you need to add in the main.c file of esb_ptx sample.
  • Hi Kazi,
    I did exactly what you did. I upgraded from SDK 3.0.1 to SDK 3.0.2 to eliminate any potential differences there. I also properly took the ESB examples from the v3.0.2 folder.
    I'm not entirely sure why you added the RSSI code on the PTX side — I’ve placed it on the PRX side in my case.
    I also assume that FEM support (MPSL) needs to be enabled in prj.conf. I've added that as well and tested it both with and without.
    I tested thoroughly with esb_set_tx_power(10), esb_set_tx_power(8), and esb_set_tx_power(0). For me, this makes no difference in the RSSI values. In all cases, I can only keep my PTX and PRX boards about 5 cm apart — otherwise, the signal does not come through on the PRX side. I consistently get RSSI values around -83 to -84 dBm.
    When I use a standard nRF52, nRF54, or nRF54 board from Nordic, I do get proper reception, and I can place the boards about 10 meters apart without issues. So something is definitely not right — I should be getting better reception, not significantly worse.
    I'm really curious what’s different in your setup compared to mine. Could you show me your setup and maybe zip and share your project code?
    You don't need to do any changes on the PRX code.
    I did some test in the lab by watching the improvement of TX output on the spectrum analyzer. Because -60 to -73 dbm (which we saw in the putty output as RSSI) is not optimal at all. So, the idea was to check the TX output. TX output power did not show any improvement on the spectrum analyzer which proved some pins of the Pin did not work.
    I checked the FEM pin (PDN, TX, RX and PDN) on the nRF21540 if those were working properly. When we forcefully made the PDN pin up by connecting the pin to vdd then I got the tx value on spectrum analyzer. The RSSI value
    You can try to do the same on your nRF21540 DK.
    I also have made little changed in the code. Hvae set CONFIG_MPSL_FEM_NRF21540_TX_GAIN_DB=20 in the prj.conf file. Now esb_set_tx_power(20) function is declared as an error return after some activities (clock_start(), dk_kleds_init(), esb_initialize()) and
    Got this as output on the spectrum analyzer which proves PDN is working(after this forcefully made it up)
    and improved RSSI value
  • Hi Kazi,
    When I manually forced the PDN pin high by connecting it to VDD, I achieved proper TX power on my setup using the nRF52840-DK with the nRF21540-EK. The RSSI value in my ESB example increased by 25 dBm.
    I applied the same workaround on the nRF21540-DK, which previously had almost no output. After forcing the PDN pin high on that board as well, it started functioning correctly, and I observed excellent reception on the PRX side.
    Conclusion:
    The current workaround is to manually force the PDN pin high by connecting it to VDD. However, this is clearly not a proper solution. I believe the hardware is working correctly, and—as I have been pointing out for over six months across multiple support requests—this confirms that there is indeed a bug in the Nordic Connect SDK (versions 2.8.0, 2.9.0, and newer).
    Documentation Tip:
    I recommend updating the documentation to clearly state that an external cable is required to connect the nRF21540-EK. There is currently no mention or image explaining this. For example, a warning like:
    "Warning: A connection is required between your development board (J1) and this port to include the FEM in your RF path."
    I also strongly suggest including this cable in the box by default. It is quite difficult to find the correct one online. If you choose not to include it, please at least specify the exact cable type (brand and part number).
    Question:
    Can Nordic fix this bug in the Nordic Connect SDK as soon as possible?
    Thanks in advance,
    Herke Dekker
    Photo 1: nRF52840-DK + nRF21540-EK (with wire connecting PDN to VDD)
    Photo 2: nRF21540-DK (with wire connecting PDN to VDD)
    Yes you are right. There might be an issue in esb_fem_for_tx_set() function - this requires further debugging, I think. It seems PDN is not set by the driver. We are working to fix this.
