Time sychronization in BLE communication
Hi
I am developing some nodes that all using BLE in nordic chip, I want each node get some data at the same time and send to one central device, the central device can fuse the same time data together and send to a computer to do some process. I am not sure about the sychronization, the timeliness of data is important, could you give me some advice? I can only think about the time stamp.
  • Hello Ziyao,
    This highly depends on the data rate and number of nodes, requirement for latency and packet losses.
    Below I list a few potential technologies and some relevant overviews. You can use this as a starting point and look further into each technology to see which suits your need best.
    • Periodic Advertising with Response
      • Precise/strict packet timing, no timestamp needed, as data can only be transferred in specific timeslot.
      • Packet losses possible.
      • Limited throughput.
      • Reference time synchronization might not be necessary, but also possible thanks to strict packet schedule.
    • BLE Connection
      • No timing guaranteed at application layer, timestamp needed.
      • Packet losses not possible, the connection itself is terminated in case of loss.
      • High throughput.
      • Reference time synchronization might be a challenge. Refer: BLE Time Synchronization between devices
    • Bluetooth Mesh with Time Models
      • Time Models provide a mean for reference time synchronization.
    Hieu
