nrfx_gppi samples broken
The samples "nrfx_gppi/fork" and "nrfx_gppi/one_to_one" are both broken and fail to compile.  I have confirmed this for NCS 2.8.0 and 2.9.1 on Linux, and 2.8.0 on Windows.
How to reproduce:
  • VSCode->nRF Connect->Browse Samples
  • choose 2.9.1, then "nrfx_gppi/fork"
  • add a build configuration, and then build it.  I chose nRF52833DK:
  • The compile fails:
   * Running CMake for fork *
CMake Error at CMakeLists.txt:11 (GET_DEVICE_CONFIG_FILES):
  GET_DEVICE_CONFIG_FILES Macro invoked with incorrect arguments for macro
  named: GET_DEVICE_CONFIG_FILES
-- Application: /a2/home/dmc/blo/nrf-dmc/ncs/v2.9.1/modules/hal/nordic/nrfx/samples/src/nrfx_gppi/fork
-- CMake version: 3.21.0
-- Found Python3: /a2/home/dmc/blo/nrf-dmc/ncs/toolchains/b77d8c1312/usr/local/bin/python (found suitable version "3.12.4", minimum required is "3.8") found components: Interpreter
-- Cache files will be written to: /home/dmc2/.cache/zephyr
-- Zephyr version: 3.7.99 (/a2/home/dmc/blo/nrf-dmc/ncs/v2.9.1/zephyr)
-- Board: nrf52833dk, qualifiers: nrf52833
-- Found host-tools: zephyr 0.17.0 (/a2/home/dmc/blo/nrf-dmc/ncs/toolchains/b77d8c1312/opt/zephyr-sdk)
-- Found toolchain: zephyr 0.17.0 (/a2/home/dmc/blo/nrf-dmc/ncs/toolchains/b77d8c1312/opt/zephyr-sdk)
-- Found Dtc: /a2/home/dmc/blo/nrf-dmc/ncs/toolchains/b77d8c1312/usr/bin/dtc (found suitable version "1.5.0", minimum required is "1.4.6")
-- Found BOARD.dts: /a2/home/dmc/blo/nrf-dmc/ncs/v2.9.1/zephyr/boards/nordic/nrf52833dk/nrf52833dk_nrf52833.dts
-- Generated zephyr.dts: /a2/home/dmc/blo/nrf-dmc/ncs/v2.9.1/modules/hal/nordic/nrfx/samples/src/nrfx_gppi/fork/build/fork/zephyr/zephyr.dts
-- Generated devicetree_generated.h: /a2/home/dmc/blo/nrf-dmc/ncs/v2.9.1/modules/hal/nordic/nrfx/samples/src/nrfx_gppi/fork/build/fork/zephyr/include/generated/zephyr/devicetree_generated.h
-- Including generated dts.cmake file: /a2/home/dmc/blo/nrf-dmc/ncs/v2.9.1/modules/hal/nordic/nrfx/samples/src/nrfx_gppi/fork/build/fork/zephyr/dts.cmake
Parsing /a2/home/dmc/blo/nrf-dmc/ncs/v2.9.1/zephyr/Kconfig
Loaded configuration '/a2/home/dmc/blo/nrf-dmc/ncs/v2.9.1/zephyr/boards/nordic/nrf52833dk/nrf52833dk_nrf52833_defconfig'
Merged configuration '/a2/home/dmc/blo/nrf-dmc/ncs/v2.9.1/modules/hal/nordic/nrfx/samples/common/common.conf'
Merged configuration '/a2/home/dmc/blo/nrf-dmc/ncs/v2.9.1/modules/hal/nordic/nrfx/samples/src/nrfx_gppi/fork/prj.conf'
Merged configuration '/a2/home/dmc/blo/nrf-dmc/ncs/v2.9.1/modules/hal/nordic/nrfx/samples/src/nrfx_gppi/fork/build/fork/zephyr/.config.sysbuild'
Configuration saved to '/a2/home/dmc/blo/nrf-dmc/ncs/v2.9.1/modules/hal/nordic/nrfx/samples/src/nrfx_gppi/fork/build/fork/zephyr/.config'
Kconfig header saved to '/a2/home/dmc/blo/nrf-dmc/ncs/v2.9.1/modules/hal/nordic/nrfx/samples/src/nrfx_gppi/fork/build/fork/zephyr/include/generated/zephyr/autoconf.h'
-- Found GnuLd: /a2/home/dmc/blo/nrf-dmc/ncs/toolchains/b77d8c1312/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi/bin/ld.bfd (found version "2.38")
-- Found assembler: /a2/home/dmc/blo/nrf-dmc/ncs/toolchains/b77d8c1312/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc
-- Setting build type to 'MinSizeRel' as none was specified.
-- Using ccache: /a2/home/dmc/blo/nrf-dmc/ncs/toolchains/b77d8c1312/usr/bin/ccache
CMake Warning at /a2/home/dmc/blo/nrf-dmc/ncs/v2.9.1/zephyr/CMakeLists.txt:2133 (message):
See also "/a2/home/dmc/blo/nrf-dmc/ncs/v2.9.1/modules/hal/nordic/nrfx/samples/src/nrfx_gppi/fork/build/fork/CMakeFiles/CMakeOutput.log".
See also "/a2/home/dmc/blo/nrf-dmc/ncs/v2.9.1/modules/hal/nordic/nrfx/samples/src/nrfx_gppi/fork/build/fork/CMakeFiles/CMakeError.log".
CMake Error at cmake/modules/sysbuild_extensions.cmake:514 (message):
  CMake configure failed for Zephyr project: fork
  cmake/modules/sysbuild_images.cmake:20 (ExternalZephyrProject_Cmake)
  cmake/modules/sysbuild_default.cmake:20 (include)
  /a2/home/dmc/blo/nrf-dmc/ncs/v2.9.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:75 (include)
  /a2/home/dmc/blo/nrf-dmc/ncs/v2.9.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
  /a2/home/dmc/blo/nrf-dmc/ncs/v2.9.1/zephyr/share/sysbuild-package/cmake/SysbuildConfig.cmake:8 (include)
  template/CMakeLists.txt:10 (find_package)
See also "/a2/home/dmc/blo/nrf-dmc/ncs/v2.9.1/modules/hal/nordic/nrfx/samples/src/nrfx_gppi/fork/build/CMakeFiles/CMakeOutput.log".
FATAL ERROR: command exited with status 1: /a2/home/dmc/blo/nrf-dmc/ncs/toolchains/b77d8c1312/usr/local/bin/cmake -DWEST_PYTHON=/a2/home/dmc/blo/nrf-dmc/ncs/toolchains/b77d8c1312/usr/local/bin/python3.12 -B/a2/home/dmc/blo/nrf-dmc/ncs/v2.9.1/modules/hal/nordic/nrfx/samples/src/nrfx_gppi/fork/build -GNinja -DBOARD=nrf52833dk/nrf52833 -DNCS_TOOLCHAIN_VERSION=NONE -S/a2/home/dmc/blo/nrf-dmc/ncs/v2.9.1/zephyr/share/sysbuild -DAPP_DIR:PATH=/a2/home/dmc/blo/nrf-dmc/ncs/v2.9.1/modules/hal/nordic/nrfx/samples/src/nrfx_gppi/fork
 *  The terminal process terminated with exit code: 1.
    Thanks for reporting. These samples has not been updated for sysbuild, but they can be built if you select "No sysbuild" when making the build configuration (the same as described here).
  • Thank you Einar for the prompt response.  I can confirm that selecting "No sysbuild" allows a successful build.
    In the related ticket you linked to it mentions that at least one other sample is similarly broken:
    I suspect it's related to the project is not setup to use sysbuild, if you build it without sysbuild I suspect it works. At least a quick check works using no-sysbuild: \modules\hal\nordic\nrfx\samples\src\nrfx_spim\non_blocking
    For information to update the example on how to work with sysbuild check out:
    https://academy.nordicsemi.com/courses/nrf-connect-sdk-intermediate/lessons/lesson-8-sysbuild/topic/sysbuild-configuration/
    I have to say I was a bit shocked to see what looked to me like "here is how you can fix our broken sample", but perhaps that's not what was intended.
    Where to go from here?  Arguably these samples provided with 2.8.0 etc are broken, and (also arguably) these samples should have been updated as part of the move to sysbuild and the release of 2.8.0 and future versions. (But based on other posts I have read here I get the impression that this sort of issue isn't seen to be a particular priority).
    In a related matter, these two samples "nrfx_gppi/fork" and "nrfx_gppi/one_to_one" are overly trivial, by which I mean that learning how to the "gppi" library/API is hindered by their poor design:
    • only a limited number of devices are supported (nRF54L15DK notably absent)
    • lots of hardcoded "#define" done in static file "nrfx_example.h", rather than using devicetree
    I hope to offer some constructive feedback on what to do about that but it might take me a day or two to write that up.  I will leave this ticket open until then, if that is OK?
    Thank you for your feedback, I see your point. You are right that ideally the samples should be updated, but these samples are low-level sampels demonstrating the nrfx APIs that are normally not what is recommended for use, and the nrfx samples are not listed in the sample documentation. Sysbuild support has not been prioritized up to now. You can think of thses esamples as an added bonus (they were previously not included in the SDK though we had them internally) for showhing direct usage of the low-level nrfx drivers.
    The nrf samples which are thous listed under samples in the SDK documentation, all supports sysbuild and did so when we made the switch to sysbuild. (But then again, all samples that come from the Zephyr project do not).
