CST816S input driver i2c failed to read
I have problem with i2c that can't read the cst816s, its always return log message `<err> cst816s: failed reading chip id` and `<err> cst816s: Could not read x data` when touched. i'm using the nRF52832. is there any configuration i need to do?
the board device tree:
/dts-v1/;
#include <nordic/nrf52832_qfaa.dtsi>
&flash0 {
	partitions {
		#address-cells = <1>;
		#size-cells = <1>;
		boot_partition: partition@0 {
			label = "mcuboot";
			reg = <0x00000000 DT_SIZE_K(48)>;
		slot0_partition: partition@c000 {
			label = "image-0";
			reg = <0x0000c000 DT_SIZE_K(220)>;
		slot1_partition: partition@43000 {
			label = "image-1";
			reg = <0x00043000 DT_SIZE_K(220)>;
		storage_partition: partition@7a000 {
			label = "storage";
			reg = <0x0007a000 DT_SIZE_K(24)>;
&gpio0 {
	status = "okay";
&gpiote {
	status = "okay";
&rtc2 {
	status = "okay";
&uart0 {
	status = "okay";
	pinctrl-0 = <&uart0_default>;
	pinctrl-1 = <&uart0_sleep>;
	current-speed = <115200>;
&i2c1 {
	status = "okay";
	pinctrl-0 = <&i2c1_default>;
	pinctrl-1 = <&i2c1_sleep>;
the pinctrl file:
&pinctrl {
	uart0_default: uart0_default {
		group1 {
			psels = <NRF_PSEL(UART_TX, 0, 24)>, <NRF_PSEL(UART_RX, 0, 23)>;
	uart0_sleep: uart0_sleep {
		group1 {
			low-power-enable;
	spi0_default: spi0_default {
		group1 {
			psels = <NRF_PSEL(SPIM_MOSI, 0, 29)>, <NRF_PSEL(SPIM_SCK, 0, 28)>;
	spi0_sleep: spi0_sleep {
		group1 {
			low-power-enable;
	i2c1_sleep: i2c1_sleep {
		group1 {
			psels = <NRF_PSEL(TWIM_SDA, 0, 9)>, <NRF_PSEL(TWIM_SCL, 0, 10)>;
			low-power-enable;
	i2c1_default: i2c1_default {
		group1 {
the overlay file:
    chosen {
        zephyr,display = &display;
        zephyr,keyboard-scan = &touch_screen;
    aliases {
        input = &touch_screen;
    leds {
        compatible = "gpio-leds";
        lcd_backlight: lcd_backlight {
            gpios = <&gpio0 11 GPIO_ACTIVE_LOW>;
            label = "LCD Backlight";
    lvgl_pointer_input:lvgl_pointer {
        compatible = "zephyr,lvgl-pointer-input";
        input = <&touch_screen>;
&spi0 {
	status = "okay";
	pinctrl-0 = <&spi0_default>;
	pinctrl-1 = <&spi0_sleep>;
	cs-gpios = <&gpio0 30 GPIO_ACTIVE_LOW>;
	display: st7789v@0 {
        label = "ST7789 Display";
		compatible = "sitronix,st7789v";
        spi-max-frequency = <20000000>;
        reg = <0>;
        cmd-data-gpios = < &gpio0 27 GPIO_ACTIVE_LOW>;
        reset-gpios = < &gpio0 31 GPIO_ACTIVE_LOW>;
        width = <240>;
        height = <240>;
        x-offset = <0>;
        y-offset = <0>;
        vcom = <0x19>;
        gctrl = <0x35>;
        vrhs = <0x12>;
        vdvs = <0x20>;
        mdac = <0x00>;
        gamma = <0x01>;
        colmod = <0x05>;
        lcm = <0x2c>;
        porch-param = [0c 0c 00 33 33];
        cmd2en-param = [5a 69 02 01];
        pwctrl1-param = [a4 a1];
        pvgam-param = [D0 04 0D 11 13 2B 3F 54 4C 18 0D 0B 1F 23];
        nvgam-param = [D0 04 0C 11 13 2C 3F 44 51 2F 1F 1F 20 23];
        ram-param = [00 F0];
        rgb-param = [CD 08 14];
&i2c1 {
    clock-frequency = <I2C_BITRATE_FAST>;
    touch_screen: cst186s@15 {
        label = "CST816S Touch Screen";
        status = "okay";
        compatible = "hynitron,cst816s";
        reg = <0x15>;
        irq-gpios = <&gpio0 26 GPIO_ACTIVE_LOW>;
        rst-gpios = <&gpio0 21 GPIO_ACTIVE_LOW>;
  • I have tried the blinky sample for the SCL and SDA pins (GPIO 9 and 10) and it works. As for other pins for LCD display such as SPI, backlight, and Interrupt, all work fine. It can run the display and provide log message output for interrupts.
    blinky sample code:
     * Copyright (c) 2016 Intel Corporation
    #include <stdio.h>
    #include <zephyr/kernel.h>
    /* 1000 msec = 1 sec */
    #define SLEEP_TIME_MS   1000
    /* The devicetree node identifier for the "led0" alias. */
    #define LED0_NODE DT_ALIAS(led0)
    #define LED1_NODE DT_ALIAS(led1)
     * A build error on this line means your board is unsupported.
     * See the sample documentation for information on how to fix this.
    static const struct gpio_dt_spec led0 = GPIO_DT_SPEC_GET(LED0_NODE, gpios);
    static const struct gpio_dt_spec led1 = GPIO_DT_SPEC_GET(LED1_NODE, gpios);
    	int ret;
    	bool led_state = true;
    	if (!gpio_is_ready_dt(&led0)) {
    		return 0;
    	if (!gpio_is_ready_dt(&led1)) {
    		return 0;
    	ret = gpio_pin_configure_dt(&led0, GPIO_OUTPUT_ACTIVE);
    	if (ret < 0) {
    		return 0;
    	ret = gpio_pin_configure_dt(&led1, GPIO_OUTPUT_ACTIVE);
    	if (ret < 0) {
    		return 0;
    	while (1) {
    		ret = gpio_pin_toggle_dt(&led0);
    		if (ret < 0) {
    			return 0;
    		ret = gpio_pin_toggle_dt(&led1);
    		if (ret < 0) {
    			return 0;
    		led_state = !led_state;
    		printf("LED state: %s\n", led_state ? "ON" : "OFF");
    		k_msleep(SLEEP_TIME_MS);
    	return 0;
    overlay file:
        aliases {
            led0 = &led0;
            led1 = &led1;
        leds {
            led0: led0 {
                label = "LED0";
                gpios = <&gpio0 9 GPIO_ACTIVE_LOW>;
            led1: led1 {
                label = "LED1";
                gpios = <&gpio0 10 GPIO_ACTIVE_LOW>;
  • Hm, if the pins works but I2C does not do anything, I am getting out of ideas here.
    From your trace below, you get nothing on I2C. That is odd, as the nRF should send something.
    Perhaps it is just going to fast, and the oscilloscope does not pick up the signal if it is not repeated?
    Can you try to look at the I2C lines again, and then make them log for a longer time. Then reset the device multople times, and see if you can see some initial I2C communication. Do you still see nothing?
  • Still nothing on the I2C output, just a low signal on reset in I2C.
    There may be something with the PCF8574 firmware (with other platforms) that triggers I2C on the nRF, I don't know about that yet.
  • That config is deprecated, set this in device tree:
    &uicr {
    	nfct-pins-as-gpios;
