DECT NR+: How to configure the Physical Layer Control Field Type 2 Header
Hey,
I’m currently evaluating DECT NR+ using two nRF9151 DKs with the nRF Connect SDK v2.9.0.
According to the ETSI specification (ETSI TS 103 636-4 V2.1.1), the Physical Layer Control Field Type 1 is only used for beacon messages. Based on this, I tried modifying the sample to use Type 2 for broadcast or unicast messages. Unfortunately, I haven’t been able to get it working. Could you please provide more information on how to configure the header properly?
Here’s my current configuration: I changed the phy_type in tx_op_params to 1 and added the required fields to the header. However, I’m unsure how to correctly specify the feedback option. The ETSI spec mentions an option for "no feedback," which would be sufficient for my testing, but I couldn’t figure out how to set this using your implementation (referring to Table 6.2.2-1).
uint32_t receiver_id = 0xffff;
struct phy_ctrl_field_type_2 header = {
	.header_format = 0x0,
	.packet_length_type = 0x0,
	.packet_length = 0x01,
	.short_network_id = (CONFIG_NETWORK_ID & 0xff),
	.transmitter_id_hi = (device_id >> 8),
	.transmitter_id_lo = (device_id & 0xff),
	.transmit_power = CONFIG_TX_POWER,
	.df_mcs = CONFIG_MCS,
	.receiver_id_hi = (receiver_id >> 8),
	.receiver_id_lo = (receiver_id & 0xff),
	.df_harq_process_num = 0x0,
	.df_new_data_indication = 0x1,
	.df_redundancy_version = 0x0,
	.num_spatial_streams = 0x0,
	.feedback = {},
struct nrf_modem_dect_phy_tx_params tx_op_params = {
	.start_time = 0,
	.handle = handle,
	.network_id = CONFIG_NETWORK_ID,
	.phy_type = 1,
	.lbt_rssi_threshold_max = 0,
	.carrier = CONFIG_CARRIER,
	.lbt_period = NRF_MODEM_DECT_LBT_PERIOD_MAX,
	.phy_header = (union nrf_modem_dect_phy_hdr *)&header,
	.data = data,
	.data_size = data_len,
err = nrf_modem_dect_phy_tx(&tx_op_params);
Any help or guidance would be greatly appreciated.
Best regards
Luca
