Failed to program thingy91x
I recently bought a Thingy91x; before that, I was using a Thingy91. I activated it and successfully programmed the Hello nRF Cloud firmware via the Quick Start in nRF Connect. It worked perfectly. Then, I wanted to program it using the VS Code project, but out of habit, I loaded the Asset Tracker v2 project for the Thingy91 and programmed the nRF5340.
Since then, I’ve been unable to reprogram it using either nRF Connect or VS Code — even when using the correct project this time. I get the following error messages:
On nRF Connect:
Failed to program the Application core.
Contact support on DevZone and provide the Log if the problem persists.
On VS Code (v2.9.1) following the guide hello-nrfcloud.github.io/.../gsg_guide.html :
C:\dev\firmwares\hello-nrfcloud\project> west thingy91x-dfu
Trying to put nRF91 in bootloader mode...
nrf91 on THINGY91X_XX is in bootloader mode
[00:00:20] ###### 100% [4/4 THINGY91X_XX] Failed, Error when programming through MCUBoot: Unable to program mu
Error: One or more program tasks failed:
* THINGY91X_XX: Error when programming through MCUBoot: Unable to program multi-image file from file 'build/dfu_application.zip'. Error code: 603 (Timeout). (McubootTimeout)
Do I have a chance to recover my device?
Thanks in advance
  • I've tried on Ubuntu, with the hello-nrfcloud firmware, thingy91x is flashed by a nrf5240dk:
    -- west flash: using runner nrfutil
    -- runners.nrfutil: reset after flashing requested
    Using board 001050240536
    -- runners.nrfutil: Flashing file: /home/sylvain/dev/firmwares/recover/hello-nrfcloud/project/build/merged.hex
    Error: One or more batch tasks failed:
    * 1050240536: Device error: QSPI is not a valid peripheral option for external flash programming (Generic)
    FATAL ERROR: command exited with status 1: nrfutil --json device x-execute-batch --batch-path /home/sylvain/dev/firmwares/recover/hello-nrfcloud/project/build/generated_nrfutil_batch.json --serial-number 1050240536
    The nRF52840DK is not compliant with the Thingy:91 X. Neither the nRF9151 nor nRF5340 are supported by the onboard debugger of the nRF52840DK. This is due to these devices being Arm Cortex-M33.
    Did you program the nRF5340 with the Asset Tracker? If so, you will need to reprogram the nRF5340 with the thingy91x_nrf53_connectivity_bridge_v2.0.1 image, found in the Precompiled application and modem firmware package.
    Øyvind
  • Okay I tried with a nrf7002dk as debugger and I have this:
    nrfutil device program --firmware thingy91x_nrf53_connectivity_bridge_v2.0.1.hex --serial-number 1050744317
    [00:00:00] ###### 100% [1/2 1050744317] Failed, Device error: Address range 0x01000000..0x01005634 is not covered by any known memory region
    * 1050744317: Device error: Address range 0x01000000..0x01005634 is not covered by any known memory region (Generic)
    Thingy 91X is powered and switch is on nRF53
  • Hello, apologies for the late reply. I will have a look at this today and get back to you within end of day.
    Øyvind
  • Are you able to program the device using the programmer app in nRF Connect for Desktop?
