Code runs on IDE's but not on nRF52 board
Hi. I have the following code which runs perfectly on several C IDEs ( including Eclipse, Dev-C++, Code:Blocks and on the Linux Terminal using gcc as well ). However, when I put it on the board ( using either Keil or Eclipse ), the board does not give back any results. The Expected results and the results being obtained are shown below:
Code:
#include <stdbool.h>
#include <stdint.h>
#include <stdio.h>
#include <string.h>
#include <stddef.h>
#include <stdlib.h>
#include "app_uart.h"
#include "app_error.h"
#include "nrf_delay.h"
#include "nrf_gpio.h"
#include "nrf.h"
#include "bsp.h"
#include "boards.h"
const uint8_t leds_list[LEDS_NUMBER] = LEDS_LIST;
float InitialArrayValue=-999;
char DispNumStr [15];
//================ UART INITIALIZATION SETTINGS ======================
#define MAX_TEST_DATA_BYTES (15U)            /**< max number of test bytes to be used for tx and rx. */
#define UART_TX_BUF_SIZE 256                 /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE 8                   /**< UART RX buffer size. */
uint32_t err_code;
uint8_t len;
void uart_error_handle(app_uart_evt_t * p_event)
	if (p_event->evt_type == APP_UART_COMMUNICATION_ERROR){
	else if (p_event->evt_type == APP_UART_FIFO_ERROR){
void SendString(const uint8_t * str)
  len = strlen((char *) str);
  for (uint8_t i = 0; i < len; i++)
    {err_code = app_uart_put(str[i]);
    APP_ERROR_CHECK(err_code);}
  nrf_delay_us(10000);
//================== STRUCTS AND FUNCTIONS FOR MAIN CODE ===============================
typedef struct ArrayStruct{
  float * array;
  int used;
  int size;
} Array;
// FREE ARRAY
void freeArray(Array *a) {
  free(a->array);
  a->array = NULL;
  a->used = 0;
  a->size = 0;
// INITIALIZE NULL ARRAY
void InitNullArray(Array * ArrayPtr){
  ArrayPtr->array=NULL;
  freeArray(ArrayPtr);
  ArrayPtr->array = (float *)malloc(1 * sizeof(float));
  ArrayPtr->used = 0;
  ArrayPtr->size = 1;
  ArrayPtr->array[0] = InitialArrayValue;
// INSERT ELEMENT INTO ARRAY
void insertArray(Array *a, float element) {
  if (a->used+1 == a->size) {
    a->size *= 2;
    a->array = (float *)realloc(a->array, a->size * sizeof(float));
  a->array[(a->used)+1] = element;
  a->used=a->used+1;
// SHOW CONTENTS OF ARRAY
void ShowArray(Array * GivenArray){
	int iTemp;
	for(iTemp=1;iTemp<=GivenArray->used;iTemp++){
		SendString((uint8_t *) "Array Index ");
		sprintf(DispNumStr,"%d",iTemp);
		SendString((uint8_t *) DispNumStr);
		SendString((uint8_t *) " has value ");
		sprintf(DispNumStr,"%0.3f",GivenArray->array[iTemp]);
		SendString((uint8_t *) " \n\r");
	SendString((uint8_t *) "SIZE:  ");
	sprintf(DispNumStr,"%d",GivenArray->size);
	SendString((uint8_t *) "   LENGTH: ");
	sprintf(DispNumStr,"%d",GivenArray->used);
	SendString((uint8_t *) " \n\n\r");
//================== UART INITIALIZATION CODE =====================
LEDS_CONFIGURE(LEDS_MASK);
LEDS_OFF(LEDS_MASK);
const app_uart_comm_params_t comm_params ={RX_PIN_NUMBER,TX_PIN_NUMBER,RTS_PIN_NUMBER,CTS_PIN_NUMBER,APP_UART_FLOW_CONTROL_ENABLED,false,UART_BAUDRATE_BAUDRATE_Baud9600};
APP_UART_FIFO_INIT(&comm_params,UART_RX_BUF_SIZE,UART_TX_BUF_SIZE,uart_error_handle,APP_IRQ_PRIORITY_LOW,err_code);
// =============== MY TESTING CODE OF MAIN PROGRAM ====================
SendString((uint8_t *) "Starting Program... \n\r");
	Array A1; InitNullArray(&A1);
	Array B1; InitNullArray(&B1);
	int i;
	for(i=0;i<=10;i++) {
	insertArray(&A1,i);
	for(i=11;i<=20;i++) {
	insertArray(&B1,i);
	ShowArray(&A1);
	ShowArray(&B1);
SendString((uint8_t *) "Program Complete. Going into infinite while loop...\n\r");
//=============== LEDS PATTERN CHANGING FUNCTION======================
    while (true)
        for (int i = 0; i < LEDS_NUMBER; i++)
            LEDS_INVERT(1 << leds_list[i]);
            nrf_delay_ms(500);
    return 0;
The Expected Results are:
Starting Program...
Array Index 1 has value 0
Array Index 2 has value 1
Array Index 3 has value 2
Array Index 4 has value 3
Array Index 5 has value 4
Array Index 6 has value 5
Array Index 7 has value 6
Array Index 8 has value 7
Array Index 9 has value 8
Array Index 10 has value 9
Array Index 11 has value 10
SIZE:  16   LENGTH: 11
Array Index 1 has value 11
Array Index 2 has value 12
Array Index 3 has value 13
Array Index 4 has value 14
Array Index 5 has value 15
Array Index 6 has value 16
Array Index 7 has value 17
Array Index 8 has value 18
Array Index 9 has value 19
Array Index 10 has value 20
SIZE:  16   LENGTH: 10
Results that are coming via UART from the nRF52 board are:
Starting Program...
SIZE:  16   LENGTH: 11
SIZE:  16   LENGTH: 10
This shows that the the board is failing to either store the values or is not able to read them back..... Please help.
