NRF54 BLE UART PERIPHERAL works only when the debugger is connected
We are currently working on a new product based on NRF54L15.
Goal :
We are trying to set up the "Bluetooth LE UART service" example in order to transmit and receive data via BLE (nrf connect for mobile) and display the data in a serial monitor.
Configuration :
1) This is the schematic
2) This is the "nrf54l15dk_nrf54l15_cpuapp.overlay"
	chosen {
		nordic,nus-uart = &uart20;
&spi00 {
	status = "disabled";
&uart20_default {
	group1 {
		psels = <NRF_PSEL(UART_TX, 2, 2)>, <NRF_PSEL(UART_RTS, 2, 4)>;
	group2 {
		psels = <NRF_PSEL(UART_RX, 2, 0)>, <NRF_PSEL(UART_CTS, 2, 5)>;
&lfxo {
&uart20_sleep {
	group1 {
				<NRF_PSEL(UART_RTS, 2, 4)>,
3) This is the "prj.conf"
# Enable the UART driver
CONFIG_UART_ASYNC_API=y
CONFIG_NRFX_UARTE0=y
CONFIG_SERIAL=y
CONFIG_GPIO=y
# Make sure printk is printing to the UART console
CONFIG_CONSOLE=y
CONFIG_UART_CONSOLE=y
CONFIG_HEAP_MEM_POOL_SIZE=2048
CONFIG_BT=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_DEVICE_NAME="Nordic_UART_Service"
CONFIG_BT_MAX_CONN=1
CONFIG_BT_MAX_PAIRED=1
# Enable the NUS service
CONFIG_BT_NUS=y
# Enable bonding
CONFIG_BT_SETTINGS=y
CONFIG_FLASH=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_FLASH_MAP=y
# Enable DK LED and Buttons library
CONFIG_DK_LIBRARY=y
# This example requires more stack
CONFIG_MAIN_STACK_SIZE=1152
# Config logger
CONFIG_LOG=n
CONFIG_USE_SEGGER_RTT=n
CONFIG_LOG_BACKEND_RTT=n
CONFIG_LOG_BACKEND_UART=n
CONFIG_LOG_PRINTK=n
CONFIG_ASSERT=y
CONFIG_SPI_NOR=n
CONFIG_CLOCK_CONTROL_FIXED_RATE_CLOCK=y
4) We are using nrf v2.9.1 sdk, v2.9.1 toolchain with nrf connect vs code extension.
5) The debugger is a j-link.
6) Chip reference nRF54L15-QFBB
Behaviour :
1) When the program starts we observe the following message :
** Booting My Application v2.9.1-e9d3107cba3d ***
*** Using nRF Connect SDK v2.9.1-60d0d6c8d42d ***
*** Using Zephyr OS v3.799-ca954a6216c9 ***
Starting Nordic UART service example
2) When we transmit via RX characteristic "hello\nworld\n" here is the message displayed :
3) When we transmit "test\n" via the serial monitor, the TX characteristic doesn't display anything.
4) After connecting the debugger (*). We then transmit via RX characteristic "nordic\nsemi\n". Here is the message displayed :
4) While the the debugger is still connected (*). We then transmit "nrf\n" via the serial monitor the TX characteristic. Here is the message displayed :
"nnrf"
(*): The debugger has to be plugged and connected. The debugger uses SWD.
Questions
  1. Debugger Dependency Issue:
    The application only runs when the debugger is attached. How can we ensure it functions properly in standalone mode ?
  2. Character Rendering Problem:
    Some characters appear missing or corrupted. What steps can we take to diagnose and resolve this issue ?
Thank you for your help.
