Sysbuild: Problem with DevAcademy Intemediate, Lesson 8, Exercise 1
I downloaded https://github.com/NordicDeveloperAcademy/ncs-inter/tree/main/v2.9.0-v2.7.0/l8/l8_e1 and tried to build it for nrf54l15dk/nrf54l15/cpuapp/ns . There are several warnings but no error. However VS code does not recognize build as successful. Pristine Build output is:
 *  Executing task: nRF Connect: Generate config nrf54l15dk/nrf54l15/cpuapp/ns for sysbuild
Building sysbuild
C:\WINDOWS\system32\cmd.exe /d /s /c "west build --build-dir h:/nordic/sysbuild/build h:/nordic/sysbuild --pristine --board nrf54l15dk/nrf54l15/cpuapp/ns --sysbuild --cmake-only -- -DNCS_TOOLCHAIN_VERSION=NONE -DBOARD_ROOT=h:/nordic"
Loading Zephyr module(s) (Zephyr base): sysbuild_default
-- Found Python3: C:/ncs/toolchains/b620d30767/opt/bin/python.exe (found suitable version "3.12.4", minimum required is "3.8") found components: Interpreter
-- Cache files will be written to: C:/ncs/v2.9.1/zephyr/.cache
-- Board: nrf54l15dk, qualifiers: nrf54l15/cpuapp/ns
Parsing C:/ncs/v2.9.1/zephyr/share/sysbuild/Kconfig
Loaded configuration 'H:/nordic/sysbuild/build/_sysbuild/empty.conf'
Merged configuration 'h:/nordic/sysbuild/sysbuild.conf'
Configuration saved to 'H:/nordic/sysbuild/build/zephyr/.config'
Kconfig header saved to 'H:/nordic/sysbuild/build/_sysbuild/autoconf.h'
   * Running CMake for mcuboot *
-- Application: C:/ncs/v2.9.1/bootloader/mcuboot/boot/zephyr
-- CMake version: 3.21.0
-- Zephyr version: 3.7.99 (C:/ncs/v2.9.1/zephyr)
-- Found host-tools: zephyr 0.17.0 (C:/ncs/toolchains/b620d30767/opt/zephyr-sdk)
-- Found toolchain: zephyr 0.17.0 (C:/ncs/toolchains/b620d30767/opt/zephyr-sdk)
-- Found Dtc: C:/ncs/toolchains/b620d30767/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found BOARD.dts: C:/ncs/v2.9.1/zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l15_cpuapp.dts
-- Found devicetree overlay: C:/ncs/v2.9.1/bootloader/mcuboot/boot/zephyr/app.overlay
unit address and first address in 'reg' (0x5004c000) don't match for /soc/peripheral@50000000/vpr@4c000/mailbox@1
-- Generated zephyr.dts: H:/nordic/sysbuild/build/mcuboot/zephyr/zephyr.dts
-- Generated devicetree_generated.h: H:/nordic/sysbuild/build/mcuboot/zephyr/include/generated/zephyr/devicetree_generated.h
-- Including generated dts.cmake file: H:/nordic/sysbuild/build/mcuboot/zephyr/dts.cmake
warning: FPROTECT_ALLOW_COMBINED_REGIONS (defined at C:/ncs/v2.9.1/nrf\lib\fprotect/Kconfig:76) was
assigned the value 'y' but got the value 'n'. Check these unsatisfied dependencies: FPROTECT (=n).
See http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_FPROTECT_ALLOW_COMBINED_REGIONS and/or
look up FPROTECT_ALLOW_COMBINED_REGIONS in the menuconfig/guiconfig interface. The Application
Development Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices sections of
the manual might be helpful too.
warning: NRF_RTC_TIMER_USER_CHAN_COUNT (defined at
C:/ncs/v2.9.1/zephyr/soc/nordic\nrf53\Kconfig.sync_rtc:23, drivers/timer/Kconfig.nrf_rtc:20) was
assigned the value '0' but got the value ''. Check these unsatisfied dependencies: ((NRF53_SYNC_RTC
&& SOC_SERIES_NRF53X && SOC_FAMILY_NORDIC_NRF) || (NRF_RTC_TIMER && SYS_CLOCK_EXISTS)) (=n). See
http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT and/or look
up NRF_RTC_TIMER_USER_CHAN_COUNT in the menuconfig/guiconfig interface. The Application Development
Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual
warning: UART_CONSOLE (defined at drivers/console/Kconfig:42) was assigned the value 'y' but got the
value 'n'. Check these unsatisfied dependencies: SERIAL (=n), SERIAL_HAS_DRIVER (=n). See
http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_UART_CONSOLE and/or look up UART_CONSOLE in
the menuconfig/guiconfig interface. The Application Development Primer, Setting Configuration
Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful too.
Parsing C:/ncs/v2.9.1/bootloader/mcuboot/boot/zephyr/Kconfig
Loaded configuration 'C:/ncs/v2.9.1/zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l15_cpuapp_defconfig'
Merged configuration 'C:/ncs/v2.9.1/bootloader/mcuboot/boot/zephyr/prj.conf'
Merged configuration 'C:/ncs/v2.9.1/bootloader/mcuboot/boot/zephyr/boards/nrf54l15dk_nrf54l15_cpuapp.conf'
Merged configuration 'H:/nordic/sysbuild/sysbuild/mcuboot.conf'
Merged configuration 'C:/ncs/v2.9.1/nrf/modules/mcuboot/tfm.conf'
Merged configuration 'C:/ncs/v2.9.1/nrf/modules/mcuboot/fih_low_enable.conf'
Merged configuration 'H:/nordic/sysbuild/build/mcuboot/zephyr/.config.sysbuild'
Configuration saved to 'H:/nordic/sysbuild/build/mcuboot/zephyr/.config'
Kconfig header saved to 'H:/nordic/sysbuild/build/mcuboot/zephyr/include/generated/zephyr/autoconf.h'
-- Found GnuLd: c:/ncs/toolchains/b620d30767/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi/bin/ld.bfd.exe (found version "2.38")
-- Found assembler: C:/ncs/toolchains/b620d30767/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
-- Setting build type to 'MinSizeRel' as none was specified.
CMake Warning at C:/ncs/v2.9.1/zephyr/CMakeLists.txt:952 (message):
  No SOURCES given to Zephyr library: drivers__console
  Excluding target from build.
MCUBoot bootloader key file: C:/ncs/v2.9.1/bootloader/mcuboot/root-rsa-2048.pem
-- Configuring done
-- Generating done
-- Build files have been written to: H:/nordic/sysbuild/build/mcuboot
   * Running CMake for sysbuild *
-- Application: H:/nordic/sysbuild
-- Found BOARD.dts: C:/ncs/v2.9.1/zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l15_cpuapp_ns.dts
-- Generated zephyr.dts: H:/nordic/sysbuild/build/sysbuild/zephyr/zephyr.dts
-- Generated devicetree_generated.h: H:/nordic/sysbuild/build/sysbuild/zephyr/include/generated/zephyr/devicetree_generated.h
-- Including generated dts.cmake file: H:/nordic/sysbuild/build/sysbuild/zephyr/dts.cmake
unit address and first address in 'reg' (0x4004c000) don't match for /soc/peripheral@40000000/vpr@4c000/mailbox@1
warning: UPDATEABLE_IMAGE_NUMBER (defined at
C:/ncs/v2.9.1/nrf\samples\common\mcumgr_bt_ota_dfu/Kconfig:89, subsys/dfu/Kconfig:95) was assigned
the value '1' but got the value ''. Check these unsatisfied dependencies:
(((BOARD_THINGY53_NRF5340_CPUAPP || BOARD_THINGY53_NRF5340_CPUAPP_NS) && SOC_SERIES_NRF53X &&
NCS_SAMPLE_MCUMGR_BT_OTA_DFU) || (!MCUBOOT && IMG_MANAGER)) (=n). See
http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_UPDATEABLE_IMAGE_NUMBER and/or look up
UPDATEABLE_IMAGE_NUMBER in the menuconfig/guiconfig interface. The Application Development Primer,
Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be
helpful too.
warning: MCUBOOT_UPDATE_FOOTER_SIZE (defined at subsys/dfu/Kconfig:54) was assigned the value
'0x5000' but got the value ''. Check these unsatisfied dependencies: MCUBOOT_IMG_MANAGER (=n),
IMG_MANAGER (=n). See
http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_MCUBOOT_UPDATE_FOOTER_SIZE and/or look up
MCUBOOT_UPDATE_FOOTER_SIZE in the menuconfig/guiconfig interface. The Application Development
warning: Experimental symbol TFM_EXPERIMENTAL is enabled.
Parsing C:/ncs/v2.9.1/zephyr/Kconfig
Loaded configuration 'C:/ncs/v2.9.1/zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l15_cpuapp_ns_defconfig'
Merged configuration 'H:/nordic/sysbuild/prj.conf'
Merged configuration 'H:/nordic/sysbuild/build/sysbuild/zephyr/.config.sysbuild'
Configuration saved to 'H:/nordic/sysbuild/build/sysbuild/zephyr/.config'
Kconfig header saved to 'H:/nordic/sysbuild/build/sysbuild/zephyr/include/generated/zephyr/autoconf.h'
=========== Generating psa_crypto_config ===============
Backup: CONFIG_MBEDTLS_PSA_CRYPTO_SPM: False
Backup: CONFIG_MBEDTLS_PSA_CRYPTO_C: False
Backup: CONFIG_MBEDTLS_PSA_CRYPTO_KEY_ID_ENCODES_OWNER: False
Backup: CONFIG_MBEDTLS_PLATFORM_SETUP_TEARDOWN_ALT: False
Backup: CONFIG_MBEDTLS_THREADING: False
Backup: CONFIG_MBEDTLS_THREADING_ALT: False
=========== Checkpoint: backup ===============
Restore: CONFIG_MBEDTLS_PSA_CRYPTO_SPM: False
Restore: CONFIG_MBEDTLS_PSA_CRYPTO_C: False
Restore: CONFIG_MBEDTLS_PSA_CRYPTO_KEY_ID_ENCODES_OWNER: False
Restore: CONFIG_MBEDTLS_PLATFORM_SETUP_TEARDOWN_ALT: False
Restore: CONFIG_MBEDTLS_THREADING: False
Restore: CONFIG_MBEDTLS_THREADING_ALT: False
=========== End psa_crypto_config ===============
=========== Generating psa_crypto_library_config ===============
Backup: CONFIG_MBEDTLS_USE_PSA_CRYPTO: True
Backup: CONFIG_MBEDTLS_PLATFORM_PRINTF_ALT: False
Restore: CONFIG_MBEDTLS_USE_PSA_CRYPTO: True
Restore: CONFIG_MBEDTLS_PLATFORM_PRINTF_ALT: False
=========== End psa_crypto_library_config ===============
-- Including signing script: C:/ncs/v2.9.1/nrf/cmake/sysbuild/image_signing.cmake
-- Configuring done
-- Generating done
-- Build files have been written to: H:/nordic/sysbuild/build/sysbuild
CMake Warning at C:/ncs/v2.9.1/nrf/cmake/sysbuild/partition_manager.cmake:106 (message):
        --- WARNING: Using a bootloader without pm_static.yml.            ---
        --- There are cases where a deployed product can consist of       ---
        --- multiple images, and only a subset of these images can be     ---
        --- upgraded through a firmware update mechanism. In such cases,  ---
        --- the upgradable images must have partitions that are static    ---
        --- and are matching the partition map used by the bootloader     ---
        --- programmed onto the device.                                   ---
  C:/ncs/v2.9.1/nrf/cmake/sysbuild/partition_manager.cmake:634 (partition_manager)
  C:/ncs/v2.9.1/nrf/sysbuild/CMakeLists.txt:703 (include)
  cmake/modules/sysbuild_extensions.cmake:583 (nrf_POST_CMAKE)
  cmake/modules/sysbuild_extensions.cmake:583 (cmake_language)
  cmake/modules/sysbuild_images.cmake:23 (sysbuild_module_call)
  cmake/modules/sysbuild_default.cmake:20 (include)
  C:/ncs/v2.9.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:75 (include)
  C:/ncs/v2.9.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
  C:/ncs/v2.9.1/zephyr/share/sysbuild-package/cmake/SysbuildConfig.cmake:8 (include)
  template/CMakeLists.txt:10 (find_package)
Dropping partition 'nonsecure_storage' since it is empty.
-- Configuring done
-- Generating done
As I am unable to figure out, what is wrong, please advise me how to resolve the issue.
