Cannot flash, debug or connect to my custom nrf5340 board. It had been working and now I am getting this message in VSCode:
-- west flash: using runner nrfjprog -- runners.nrfjprog: reset after flashing requested -- runners.nrfjprog: Flashing file: /Users/********/Projects/GitHub/********/blinky_custom_board/build_customboard/merged.hex [error] [ Client] - Encountered error -102: Command select_coprocessor executed for 25 milliseconds with result -102 ERROR: Failed when selecting coprocessor APPLICATION [error] [ Worker] - An unknown error. ERROR: JLinkARM DLL reported an error. Try again. If error condition ERROR: persists, run the same command again with argument --log, contact Nordic ERROR: Semiconductor and provide the generated log.log file to them. NOTE: For additional output, try running again with logging enabled (--log). NOTE: Any generated log error messages will be displayed. FATAL ERROR: command exited with status 33: nrfjprog --program /Users/********/Projects/GitHub/********/blinky_custom_board/build_customboard/merged.hex --sectorerase --verify -f NRF53 --coprocessor CP_APPLICATION --snr ********
I have also gotten this one on another copy of the same custom board:
[error] [ Client] - Encountered error -5: Command select_coprocessor executed for 11 milliseconds with result -5 ERROR: Failed when selecting coprocessor APPLICATION [error] [ Worker] - Encountered unexpected debug port ID 0, expected 6 ERROR: The --family option given with the command (or the default from ERROR: nrfjprog.ini) does not match the device connected. NOTE: For additional output, try running again with logging enabled (--log). NOTE: Any generated log error messages will be displayed. FATAL ERROR: command exited with status 18: nrfjprog --program /Users/********/Projects/GitHub/********/blinky_custom_board/build_customboard/merged.hex --sectorerase --verify -f NRF53 --coprocessor CP_APPLICATION --snr *********
I see the BLE advertising from the nRF Connect iOS app.
When I try and connect using jlinkrttviewer I generally get:
and when I say yes I get
Same thing with jlinkexe:
Type "connect" to establish a target connection, '?' for help J-Link>connect Please specify device / core. <Default>: NRF5340_XXAA_APP Type '?' for selection dialog Device> Please specify target interface: J) JTAG (Default) S) SWD T) cJTAG TIF>s Specify target interface speed [kHz]. <Default>: 4000 kHz Speed> Device "NRF5340_XXAA_APP" selected. Connecting to target via SWD ConfigTargetSettings() start ConfigTargetSettings() end - Took 6us InitTarget() start InitTarget() end - Took 102ms Failed to attach to CPU. Trying connect under reset. ConfigTargetSettings() start ConfigTargetSettings() end - Took 12us InitTarget() start Device will be unsecured now. InitTarget() end - Took 315s Error occurred: Could not connect to the target device. For troubleshooting steps visit: https://wiki.segger.com/J-Link_Troubleshooting J-Link>
This is the 2nd board I seem to have lost connection with and I can't get back.
I ran this nrfjprog --recover --log
and got:
[2025-Apr-19 15:35:57] [debug] -------------------------------------------------------------------------------- [2025-Apr-19 15:35:57] [debug] nrfjprog --recover --log [2025-Apr-19 15:35:57] [debug] nrfjprog version 10.21.0 external [2025-Apr-19 15:35:57] [debug] -------------------------------------------------------------------------------- [2025-Apr-19 15:35:57] [ info] Load library at /Applications/Nordic Semiconductor/lib/libnrfjprogdll.dylib. [2025-Apr-19 15:35:57] [ info] Library loaded, loading member functions. [2025-Apr-19 15:35:57] [ info] Member functions succesfully loaded. [2025-Apr-19 15:35:57] [debug] [ Client] - open [2025-Apr-19 15:35:57] [debug] [ Client] - start [2025-Apr-19 15:35:57] [ info] [ Client] - stdout: Jlinkarm nRF Worker ready. Handling sequence e1de2433-b321-4ef7-aae0-1b47917af22b. [2025-Apr-19 15:35:57] [trace] [ Client] - Command open executed for 12 milliseconds with result 0 [2025-Apr-19 15:35:57] [debug] [ Client] - config [2025-Apr-19 15:35:57] [trace] [ Client] - Command config executed for 6 milliseconds with result 0 [2025-Apr-19 15:35:57] [debug] [ Client] - enum_emu_snr [2025-Apr-19 15:35:57] [debug] [SeggerBackend] - Logger sink registered in Segger backend logger [2025-Apr-19 15:35:57] [debug] [ JLink] - Logger sink registered in JLink logger [2025-Apr-19 15:35:57] [debug] [ nRFXX] - open [2025-Apr-19 15:35:57] [debug] [ nRFXX] - just_check_family [2025-Apr-19 15:35:57] [debug] [SeggerBackend] - open_dll [2025-Apr-19 15:35:57] [debug] [SeggerBackend] - No J-Link DLL path was provided. Attempting to auto detect. [2025-Apr-19 15:35:57] [ info] [SeggerBackend] - Load library at /Applications/SEGGER/JLink/libjlinkarm.8.dylib. [2025-Apr-19 15:35:57] [ info] [SeggerBackend] - Library loaded, loading member functions. [2025-Apr-19 15:35:57] [ info] [SeggerBackend] - Member functions succesfully loaded. [2025-Apr-19 15:35:57] [debug] [SeggerBackend] - Set batch mode [2025-Apr-19 15:35:57] [debug] [SeggerBackend] - dll_version [2025-Apr-19 15:35:57] [ info] [SeggerBackend] - Segger dll version 8.26. loaded. [2025-Apr-19 15:35:57] [trace] [ Worker] - Command open executed for 5 milliseconds with result 0 [2025-Apr-19 15:35:57] [debug] [ nRFXX] - config [2025-Apr-19 15:35:57] [debug] [SeggerBackend] - enum_emu_snr [2025-Apr-19 15:35:57] [trace] [ Worker] - Command config executed for 2 milliseconds with result 0 [2025-Apr-19 15:35:57] [trace] [ Client] - Command enum_emu_con_info executed for 17 milliseconds with result 0 [2025-Apr-19 15:35:57] [debug] [ Client] - connect_to_emu_with_snr [2025-Apr-19 15:35:57] [debug] [ nRFXX] - enum_emu_con_info [2025-Apr-19 15:35:57] [debug] [SeggerBackend] - is_connected_to_emu [2025-Apr-19 15:35:57] [debug] [SeggerBackend] - enum_emu_con_info [2025-Apr-19 15:35:57] [debug] [SeggerBackend] - is_connected_to_emu [2025-Apr-19 15:35:57] [trace] [ Worker] - Command enum_emu_con_info executed for 9 milliseconds with result 0 [2025-Apr-19 15:35:57] [debug] [ nRFXX] - connect_to_emu_with_snr [2025-Apr-19 15:35:57] [debug] [SeggerBackend] - is_connected_to_emu [2025-Apr-19 15:35:57] [debug] [SeggerBackend] - connect_to_emu_with_snr [2025-Apr-19 15:35:57] [debug] [SeggerBackend] - is_connected_to_emu [2025-Apr-19 15:35:57] [debug] [SeggerBackend] - ---just_enum_emu_snr [2025-Apr-19 15:35:57] [debug] [SeggerBackend] - ---just_get_num_emus [2025-Apr-19 15:35:57] [debug] [SeggerBackend] - ---just_connect_to_emu_with_snr [2025-Apr-19 15:35:57] [debug] [SeggerBackend] - ---just_connect_to_emu_without_snr [2025-Apr-19 15:35:57] [debug] [SeggerBackend] - Segger logging enabled. [2025-Apr-19 15:35:57] [trace] [ JLink] - Firmware: J-Link V11 compiled Apr 1 2025 10:02:30 [2025-Apr-19 15:35:57] [trace] [ JLink] - Firmware: J-Link V11 compiled Apr 1 2025 10:02:30 [2025-Apr-19 15:35:57] [trace] [ JLink] - Hardware: V11.00 [2025-Apr-19 15:35:57] [trace] [ JLink] - S/N: ********* [2025-Apr-19 15:35:57] [trace] [ JLink] - OEM: SEGGER [2025-Apr-19 15:35:57] [trace] [ JLink] - Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB [2025-Apr-19 15:35:57] [trace] [ JLink] - Bootloader: 2019 Jul 04 [2025-Apr-19 15:35:57] [trace] [ JLink] - USB speed mode: High speed (480 MBit/s) [2025-Apr-19 15:35:57] [trace] [ JLink] - TELNET listener socket opened on port 19021 [2025-Apr-19 15:35:57] [trace] [ JLink] - WEBSRV WEBSRV_Init(): Starting webserver thread(s) [2025-Apr-19 15:35:57] [trace] [ JLink] - WEBSRV Failed to put socket into listener state (port 19080) [2025-Apr-19 15:35:57] [trace] [ JLink] - WEBSRV Webserver running on local port 19081 [2025-Apr-19 15:35:57] [trace] [ JLink] - Looking for J-Link GUI Server exe at: /Applications/SEGGER/JLink_V826/JLinkGUIServerExe [2025-Apr-19 15:35:57] [trace] [ JLink] - Forking J-Link GUI Server: /Applications/SEGGER/JLink_V826/JLinkGUIServerExe [2025-Apr-19 15:35:57] [trace] [ JLink] - J-Link GUI Server info: "J-Link GUI server V8.12a " [2025-Apr-19 15:35:57] [trace] [ JLink] - - 10.720ms returns "O.K." [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_Lock() [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_ExecCommand("SetRestartOnClose = 0", ...). [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.003ms returns 0x01 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_ExecCommand("DisableFlashDL", ...). [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.001ms returns 0x00 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...). [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.000ms returns 0x00 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_SetHookUnsecureDialog [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_SetHookUnsecureDialog(...) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.004ms returns 0 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_TIF_Select(JLINKARM_TIF_SWD) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.713ms returns 0x00 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_GetSpeedInfo() [2025-Apr-19 15:35:57] [trace] [ JLink] - 180000000 Hz / n, n >= 12 [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.003ms [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [debug] [SeggerBackend] - Connected emulator supports SWD speeds up to 15000kHz [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_SetSpeed(2000) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.180ms [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_GetSpeed() [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.007ms returns 2000 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [debug] [SeggerBackend] - SWD clock set to 2000kHz [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_GetSN() [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.001ms returns ********* [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.002ms [2025-Apr-19 15:35:57] [debug] [ nRFXX] - read_device_family [2025-Apr-19 15:35:57] [debug] [ nRFXX] - read_device_family [2025-Apr-19 15:35:57] [debug] [SeggerBackend] - is_connected_to_emu [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_IsOpen() [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.001ms returns 0x01 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_Lock() [2025-Apr-19 15:35:57] [debug] [SeggerBackend] - is_connected_to_emu [2025-Apr-19 15:35:57] [debug] [SeggerBackend] - read_debug_port_idr [2025-Apr-19 15:35:57] [debug] [SeggerBackend] - read_debug_port_register [2025-Apr-19 15:35:57] [debug] [SeggerBackend] - ---just_read_debug_port_register [2025-Apr-19 15:35:57] [debug] [SeggerBackend] - coresight_configure [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_GetHWStatus(...) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.255ms returns 0 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_CORESIGHT_Configure() [2025-Apr-19 15:35:57] [trace] [ JLink] - - 100.426ms returns 0 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [debug] [SeggerBackend] - read_debug_port_idr [2025-Apr-19 15:35:57] [debug] [SeggerBackend] - read_debug_port_register [2025-Apr-19 15:35:57] [debug] [SeggerBackend] - ---just_read_debug_port_register [2025-Apr-19 15:35:57] [debug] [SeggerBackend] - ---just_select_debug_port_register [2025-Apr-19 15:35:57] [debug] [SeggerBackend] - Select AP 255, DP Bank 0, AP Bank 255 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.775ms returns -1 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [debug] [SeggerBackend] - ---just_abort_debug_action [2025-Apr-19 15:35:57] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection. [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.634ms returns -1 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.645ms returns -1 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.721ms returns -1 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.641ms returns -1 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.683ms returns -1 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.621ms returns -1 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.614ms returns -1 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [debug] [SeggerBackend] - ---just_abort_debug_action [2025-Apr-19 15:35:57] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection. [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.690ms returns -1 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.768ms returns -1 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.725ms returns -1 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.759ms returns -1 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.735ms returns -1 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.725ms returns -1 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.716ms returns -1 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [debug] [SeggerBackend] - ---just_abort_debug_action [2025-Apr-19 15:35:57] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection. [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.721ms returns -1 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.725ms returns -1 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.688ms returns -1 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.746ms returns -1 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.740ms returns -1 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.765ms returns -1 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.705ms returns -1 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [debug] [SeggerBackend] - ---just_abort_debug_action [2025-Apr-19 15:35:57] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection. [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:35:57] [error] [ Client] - Encountered error -102: Command connect_to_emu_with_snr executed for 178 milliseconds with result -102 [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.705ms returns -1 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.730ms returns -1 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.764ms returns -1 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.727ms returns -1 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.627ms returns -1 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.600ms returns -1 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.599ms returns -1 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [debug] [SeggerBackend] - ---just_abort_debug_action [2025-Apr-19 15:35:57] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection. [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.607ms returns -1 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.647ms returns -1 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.643ms returns -1 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.634ms returns -1 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.622ms returns -1 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.605ms returns -1 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.546ms returns -1 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [debug] [SeggerBackend] - ---just_abort_debug_action [2025-Apr-19 15:35:57] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection. [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.597ms returns -1 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.599ms returns -1 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.573ms returns -1 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.626ms returns -1 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.661ms returns -1 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.590ms returns -1 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.062ms [2025-Apr-19 15:35:57] [error] [ Worker] - An unknown error. [2025-Apr-19 15:35:57] [trace] [ Worker] - Command connect_to_emu_with_snr executed for 168 milliseconds with result -102 [2025-Apr-19 15:35:57] [debug] [ nRFXX] - close [2025-Apr-19 15:35:57] [debug] [SeggerBackend] - is_connected_to_emu [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_IsOpen() [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.005ms returns 0x01 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_Lock() [2025-Apr-19 15:35:57] [debug] [SeggerBackend] - close [2025-Apr-19 15:35:57] [debug] [SeggerBackend] - disconnect_from_emu [2025-Apr-19 15:35:57] [debug] [SeggerBackend] - ---just_disconnect_from_emu [2025-Apr-19 15:35:57] [debug] [SeggerBackend] - is_connected_to_device [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_IsConnected() [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.003ms returns FALSE [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [debug] [SeggerBackend] - ---just_is_debug_region_powered [2025-Apr-19 15:35:57] [debug] [SeggerBackend] - ---just_read_debug_port_register [2025-Apr-19 15:35:57] [debug] [SeggerBackend] - ---just_select_debug_port_register [2025-Apr-19 15:35:57] [debug] [SeggerBackend] - Select AP 255, DP Bank 0, AP Bank 255 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.752ms returns -1 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [debug] [SeggerBackend] - ---just_abort_debug_action [2025-Apr-19 15:35:57] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection. [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.667ms returns -1 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.705ms returns -1 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.726ms returns -1 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.645ms returns -1 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.597ms returns -1 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.603ms returns -1 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.596ms returns -1 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [debug] [SeggerBackend] - ---just_abort_debug_action [2025-Apr-19 15:35:57] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection. [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.620ms returns -1 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.636ms returns -1 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.621ms returns -1 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.521ms returns -1 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.749ms returns -1 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.615ms returns 0 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.680ms returns -1 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [debug] [SeggerBackend] - ---just_abort_debug_action [2025-Apr-19 15:35:57] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection. [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.676ms returns 0 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.721ms returns -1 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [debug] [SeggerBackend] - ---just_abort_debug_action [2025-Apr-19 15:35:57] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection. [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.764ms returns -1 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:35:57] [trace] [ JLink] - - 0.652ms returns 0 [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000) [2025-Apr-19 15:35:58] [trace] [ JLink] - - 0.702ms returns -1 [2025-Apr-19 15:35:58] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:58] [debug] [SeggerBackend] - ---just_abort_debug_action [2025-Apr-19 15:35:58] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection. [2025-Apr-19 15:35:58] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:35:58] [trace] [ JLink] - - 0.588ms returns -1 [2025-Apr-19 15:35:58] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:58] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:35:58] [trace] [ JLink] - - 0.629ms returns -1 [2025-Apr-19 15:35:58] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:58] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:35:58] [trace] [ JLink] - - 0.626ms returns -1 [2025-Apr-19 15:35:58] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:58] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:35:58] [trace] [ JLink] - - 0.576ms returns -1 [2025-Apr-19 15:35:58] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:58] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:35:58] [trace] [ JLink] - - 0.592ms returns -1 [2025-Apr-19 15:35:58] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:58] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:35:58] [trace] [ JLink] - - 0.615ms returns -1 [2025-Apr-19 15:35:58] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:58] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000) [2025-Apr-19 15:35:58] [trace] [ JLink] - - 0.614ms returns -1 [2025-Apr-19 15:35:58] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:35:58] [debug] [SeggerBackend] - ---just_abort_debug_action [2025-Apr-19 15:35:58] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port
Running nrfjprog --reset --log
resulted in this:
[2025-Apr-19 15:43:46] [debug] -------------------------------------------------------------------------------- [2025-Apr-19 15:43:46] [debug] nrfjprog --reset --log [2025-Apr-19 15:43:46] [debug] nrfjprog version 10.21.0 external [2025-Apr-19 15:43:46] [debug] -------------------------------------------------------------------------------- [2025-Apr-19 15:43:46] [ info] Load library at /Applications/Nordic Semiconductor/lib/libnrfjprogdll.dylib. [2025-Apr-19 15:43:46] [ info] Library loaded, loading member functions. [2025-Apr-19 15:43:46] [ info] Member functions succesfully loaded. [2025-Apr-19 15:43:46] [debug] [ Client] - open [2025-Apr-19 15:43:46] [debug] [ Client] - start [2025-Apr-19 15:43:46] [ info] [ Client] - stdout: Jlinkarm nRF Worker ready. Handling sequence f003d0e0-5006-4c22-9e12-5af350ee5a42. [2025-Apr-19 15:43:46] [trace] [ Client] - Command open executed for 12 milliseconds with result 0 [2025-Apr-19 15:43:46] [debug] [ Client] - config [2025-Apr-19 15:43:46] [trace] [ Client] - Command config executed for 6 milliseconds with result 0 [2025-Apr-19 15:43:46] [debug] [ Client] - enum_emu_snr [2025-Apr-19 15:43:46] [debug] [SeggerBackend] - Logger sink registered in Segger backend logger [2025-Apr-19 15:43:46] [debug] [ JLink] - Logger sink registered in JLink logger [2025-Apr-19 15:43:46] [debug] [ nRFXX] - open [2025-Apr-19 15:43:46] [debug] [ nRFXX] - just_check_family [2025-Apr-19 15:43:46] [debug] [SeggerBackend] - open_dll [2025-Apr-19 15:43:46] [debug] [SeggerBackend] - No J-Link DLL path was provided. Attempting to auto detect. [2025-Apr-19 15:43:46] [ info] [SeggerBackend] - Load library at /Applications/SEGGER/JLink/libjlinkarm.8.dylib. [2025-Apr-19 15:43:46] [ info] [SeggerBackend] - Library loaded, loading member functions. [2025-Apr-19 15:43:46] [ info] [SeggerBackend] - Member functions succesfully loaded. [2025-Apr-19 15:43:46] [debug] [SeggerBackend] - Set batch mode [2025-Apr-19 15:43:46] [debug] [SeggerBackend] - dll_version [2025-Apr-19 15:43:46] [ info] [SeggerBackend] - Segger dll version 8.26. loaded. [2025-Apr-19 15:43:46] [trace] [ Worker] - Command open executed for 4 milliseconds with result 0 [2025-Apr-19 15:43:46] [debug] [ nRFXX] - config [2025-Apr-19 15:43:46] [debug] [SeggerBackend] - enum_emu_snr [2025-Apr-19 15:43:46] [trace] [ Worker] - Command config executed for 2 milliseconds with result 0 [2025-Apr-19 15:43:46] [trace] [ Client] - Command enum_emu_con_info executed for 18 milliseconds with result 0 [2025-Apr-19 15:43:46] [debug] [ Client] - connect_to_emu_with_snr [2025-Apr-19 15:43:46] [debug] [ nRFXX] - enum_emu_con_info [2025-Apr-19 15:43:46] [debug] [SeggerBackend] - is_connected_to_emu [2025-Apr-19 15:43:46] [debug] [SeggerBackend] - enum_emu_con_info [2025-Apr-19 15:43:46] [debug] [SeggerBackend] - is_connected_to_emu [2025-Apr-19 15:43:46] [trace] [ Worker] - Command enum_emu_con_info executed for 8 milliseconds with result 0 [2025-Apr-19 15:43:46] [debug] [ nRFXX] - connect_to_emu_with_snr [2025-Apr-19 15:43:46] [debug] [SeggerBackend] - is_connected_to_emu [2025-Apr-19 15:43:46] [debug] [SeggerBackend] - connect_to_emu_with_snr [2025-Apr-19 15:43:46] [debug] [SeggerBackend] - is_connected_to_emu [2025-Apr-19 15:43:46] [debug] [SeggerBackend] - ---just_enum_emu_snr [2025-Apr-19 15:43:46] [debug] [SeggerBackend] - ---just_get_num_emus [2025-Apr-19 15:43:46] [debug] [SeggerBackend] - ---just_connect_to_emu_with_snr [2025-Apr-19 15:43:46] [debug] [SeggerBackend] - ---just_connect_to_emu_without_snr [2025-Apr-19 15:43:46] [debug] [SeggerBackend] - Segger logging enabled. [2025-Apr-19 15:43:46] [trace] [ JLink] - Firmware: J-Link V11 compiled Apr 1 2025 10:02:30 [2025-Apr-19 15:43:46] [trace] [ JLink] - Firmware: J-Link V11 compiled Apr 1 2025 10:02:30 [2025-Apr-19 15:43:46] [trace] [ JLink] - Hardware: V11.00 [2025-Apr-19 15:43:46] [trace] [ JLink] - S/N: ********* [2025-Apr-19 15:43:46] [trace] [ JLink] - OEM: SEGGER [2025-Apr-19 15:43:46] [trace] [ JLink] - Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB [2025-Apr-19 15:43:46] [trace] [ JLink] - Bootloader: 2019 Jul 04 [2025-Apr-19 15:43:46] [trace] [ JLink] - USB speed mode: High speed (480 MBit/s) [2025-Apr-19 15:43:46] [trace] [ JLink] - TELNET listener socket opened on port 19021 [2025-Apr-19 15:43:46] [trace] [ JLink] - WEBSRV WEBSRV_Init(): Starting webserver thread(s) [2025-Apr-19 15:43:46] [trace] [ JLink] - WEBSRV Failed to put socket into listener state (port 19080) [2025-Apr-19 15:43:46] [trace] [ JLink] - WEBSRV Webserver running on local port 19081 [2025-Apr-19 15:43:46] [trace] [ JLink] - Looking for J-Link GUI Server exe at: /Applications/SEGGER/JLink_V826/JLinkGUIServerExe [2025-Apr-19 15:43:46] [trace] [ JLink] - Forking J-Link GUI Server: /Applications/SEGGER/JLink_V826/JLinkGUIServerExe [2025-Apr-19 15:43:46] [trace] [ JLink] - J-Link GUI Server info: "J-Link GUI server V8.12a " [2025-Apr-19 15:43:46] [trace] [ JLink] - - 15.564ms returns "O.K." [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_Lock() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_ExecCommand("SetRestartOnClose = 0", ...). [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.003ms returns 0x01 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_ExecCommand("DisableFlashDL", ...). [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.000ms returns 0x00 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...). [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.001ms returns 0x00 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_SetHookUnsecureDialog [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_SetHookUnsecureDialog(...) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.003ms returns 0 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_TIF_Select(JLINKARM_TIF_SWD) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 2.487ms returns 0x00 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_GetSpeedInfo() [2025-Apr-19 15:43:46] [trace] [ JLink] - 180000000 Hz / n, n >= 12 [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.003ms [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [debug] [SeggerBackend] - Connected emulator supports SWD speeds up to 15000kHz [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_SetSpeed(2000) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.251ms [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_GetSpeed() [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.003ms returns 2000 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [debug] [SeggerBackend] - SWD clock set to 2000kHz [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_GetSN() [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.001ms returns ********* [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.001ms [2025-Apr-19 15:43:46] [debug] [ nRFXX] - read_device_family [2025-Apr-19 15:43:46] [debug] [ nRFXX] - read_device_family [2025-Apr-19 15:43:46] [debug] [SeggerBackend] - is_connected_to_emu [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_IsOpen() [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.001ms returns 0x01 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_Lock() [2025-Apr-19 15:43:46] [debug] [SeggerBackend] - is_connected_to_emu [2025-Apr-19 15:43:46] [debug] [SeggerBackend] - read_debug_port_idr [2025-Apr-19 15:43:46] [debug] [SeggerBackend] - read_debug_port_register [2025-Apr-19 15:43:46] [debug] [SeggerBackend] - ---just_read_debug_port_register [2025-Apr-19 15:43:46] [debug] [SeggerBackend] - coresight_configure [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_GetHWStatus(...) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.293ms returns 0 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_Configure() [2025-Apr-19 15:43:46] [trace] [ JLink] - - 100.513ms returns 0 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [debug] [SeggerBackend] - read_debug_port_idr [2025-Apr-19 15:43:46] [debug] [SeggerBackend] - read_debug_port_register [2025-Apr-19 15:43:46] [debug] [SeggerBackend] - ---just_read_debug_port_register [2025-Apr-19 15:43:46] [debug] [SeggerBackend] - ---just_select_debug_port_register [2025-Apr-19 15:43:46] [debug] [SeggerBackend] - Select AP 255, DP Bank 0, AP Bank 255 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.839ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [debug] [SeggerBackend] - ---just_abort_debug_action [2025-Apr-19 15:43:46] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection. [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.700ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.708ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.669ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.705ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.665ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.647ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.624ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [debug] [SeggerBackend] - ---just_abort_debug_action [2025-Apr-19 15:43:46] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection. [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.631ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.615ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.616ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.614ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.714ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.725ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.674ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [debug] [SeggerBackend] - ---just_abort_debug_action [2025-Apr-19 15:43:46] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection. [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.669ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.647ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.661ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.607ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.679ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.635ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.643ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [debug] [SeggerBackend] - ---just_abort_debug_action [2025-Apr-19 15:43:46] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection. [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.654ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.766ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.702ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.648ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.625ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.573ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.612ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [debug] [SeggerBackend] - ---just_abort_debug_action [2025-Apr-19 15:43:46] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection. [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.655ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.621ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.678ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.624ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.588ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.604ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.637ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [debug] [SeggerBackend] - ---just_abort_debug_action [2025-Apr-19 15:43:46] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection. [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.693ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.677ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.715ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.695ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:43:46] [error] [ Client] - Encountered error -102: Command connect_to_emu_with_snr executed for 177 milliseconds with result -102 [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.664ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.670ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.047ms [2025-Apr-19 15:43:46] [error] [ Worker] - An unknown error. [2025-Apr-19 15:43:46] [trace] [ Worker] - Command connect_to_emu_with_snr executed for 174 milliseconds with result -102 [2025-Apr-19 15:43:46] [debug] [ nRFXX] - close [2025-Apr-19 15:43:46] [debug] [SeggerBackend] - is_connected_to_emu [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_IsOpen() [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.005ms returns 0x01 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_Lock() [2025-Apr-19 15:43:46] [debug] [SeggerBackend] - close [2025-Apr-19 15:43:46] [debug] [SeggerBackend] - disconnect_from_emu [2025-Apr-19 15:43:46] [debug] [SeggerBackend] - ---just_disconnect_from_emu [2025-Apr-19 15:43:46] [debug] [SeggerBackend] - is_connected_to_device [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_IsConnected() [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.003ms returns FALSE [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [debug] [SeggerBackend] - ---just_is_debug_region_powered [2025-Apr-19 15:43:46] [debug] [SeggerBackend] - ---just_read_debug_port_register [2025-Apr-19 15:43:46] [debug] [SeggerBackend] - ---just_select_debug_port_register [2025-Apr-19 15:43:46] [debug] [SeggerBackend] - Select AP 255, DP Bank 0, AP Bank 255 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.860ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [debug] [SeggerBackend] - ---just_abort_debug_action [2025-Apr-19 15:43:46] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection. [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.743ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.722ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.713ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.630ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.668ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.554ms returns 0 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.617ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [debug] [SeggerBackend] - ---just_abort_debug_action [2025-Apr-19 15:43:46] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection. [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.639ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.652ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.706ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.635ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.591ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.569ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.587ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [debug] [SeggerBackend] - ---just_abort_debug_action [2025-Apr-19 15:43:46] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection. [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.594ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.607ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.589ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.612ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.683ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.677ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.659ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [debug] [SeggerBackend] - ---just_abort_debug_action [2025-Apr-19 15:43:46] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection. [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.697ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.704ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.713ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.608ms returns 0 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.622ms returns -1 [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_HasError() [2025-Apr-19 15:43:46] [debug] [SeggerBackend] - ---just_abort_debug_action [2025-Apr-19 15:43:46] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection. [2025-Apr-19 15:43:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F) [2025-Apr-19 15:43:46] [trace] [ JLink] - - 0.608ms returns -1 [2025-Apr-19 15:43:4
