why flash memory pstorage_module pages are not contiguous
I have two p_storage_param modules param and param2. param would store 3 blocks of 16 bytes and param2 would store 10240 bytes (10 pages). I called pstorage_register (param2 first then pstorage_register (param in order to put param data next to bootlader (to preserve data after DFU) according to this answer. after reading flash memory content I found that param2 pages are not contigneous (param data page is located between two param2 pages). what should I do to to set all param2 pages on contigous way and especilaly to put param next to bootlader (after swap page) in order to keep those data after DFU. I configured #define DFU_APP_DATA_RESERVED 0xC00 which woould save 3 pages after DFU. please check the flash memory dump file (param2 data are 0xXX 0XXX 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF )
what I found bad is that modules pages locations are unpredictable (sometimes it stores on second page, sometimes one third) how can fix modules pages location to know the amount of data to keep after DFU
pstorage_module_param_t param; pstorage_module_param_t param2;
param.block_size    = 16;
param.block_count   = 3;
param.cb            = flash_callback_handler;
param2.block_size    = 256; // data are in uint16_t (step and slope)
param2.block_count   = (10240/ 256); // max data to save is 10KB
param2.cb            = flash_callback_handler;
err_code = pstorage_init();
err_code = pstorage_register(&param2, &steps_store_flash_handler);
err_code = pstorage_register(&param, flash_handler);
  • I doubt this question is correct. If you look at the pstorage code, which isn't that complicated, you'll see that each registration allocates a load of contigious pages to the handle and each get of a block for a handle just returns the start of the memory for that handle + ( block size * offset) which is also contiguous from the start of the block. Blocks don't move, blocks don't become dis-contigious, data for the different handles is properly separated.
    Since the blocks returned are just addresses really, it's quite easy to track and confirm this with a debugger.
    So if you're really getting data moving around memory and getting mixed in the flash, you're misusing pstorage in some manner, start checking your code and logging where you're writing to.
  • the blocks within a page a contiguous, but unfortunately I can see from memory dump that a page of pstorage_register is located between two pages or another pstorage. perhaps I missed something, I'll make further checks. thanks
  • What RK is saying here is correct. The first registered pstorage instance will be allocated to the lowest allocated page address. The next registered instance will then be placed on top of the first block(s), and so on. The handles won't change unless you change the order you register them or if change the PSTORAGE_NUM_OF_PAGES in pstorage config.
    With that said, it is important to note that the pstorage data is not being erased when you re-program the application FW (default setting). This may cause confusion while debugging if one is not aware of it.
  • is there any issue if I use the same call back to two pstorage_regsiter??? (param.cb = handler)
  • I said param data page is located between two param2 pages. is it because some data of param2 are written in swap, then I saw param data between two param2 pages????. I noticed that when I write to flash, the first page above bootlader (swap) is also written by the same thing. (I dont use device manger)
