Hi all
I found the following thread that mentions that the "radio test example" can be used for FCC testing: devzone.nordicsemi.com/.../
Now the certification lab requires, amongst others, a modulated carrier with a duty cycle over 99%. From the "radio test example" I would use the function "radio_modulated_tx_carrier" to generate the modulated carrier. But the duty cycle is only 96% (measured on the VDD_PA signal).
Therefore, instead of the shortcuts from the original example:
NRF_RADIO->SHORTS = (
RADIO_SHORTS_END_DISABLE_Msk |
RADIO_SHORTS_READY_START_Msk |
RADIO_SHORTS_DISABLED_TXEN_Msk);
I tried the following shortcuts:
RADIO_SHORTS_END_START_Msk);
With it, I get a duty cycle of 100%. But according to chapter "17.1.9 Maximum consecutive transmission time" of the nRF51 reference manual, the maximum transmission time should not exceed 16ms.
Is that a problem for this special FCC test mode? If yes, what do you suggest to get the duty cycle of 99% for this test mode?
Kind regards
Remo
