MCUboot with sysbuild does not compile for anything but DK
I'm playing a bit with MCU boot and folowed the tuturial. When I compile the sample with mcuboot from Zephyr, it works fine for the 52840DK, but when I try to compile for the 52840 dongle or the XIAO ble (also 52840) I get errors. What is going on and how do I continue? I first used sdk/toolchain 2.8.0. I upgraded to 2.9.1, but have the same issue. The project is almost completely empty and I did not add anything to it.
XIAO:
Compiling the C compiler identification source file "CMakeCCompilerId.c" failed.
Compiler: /home/bergm006/ncs/toolchains/b77d8c1312/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc
Build flags:
Id flags:
The output was:
1
/home/bergm006/ncs/toolchains/b77d8c1312/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld: /home/bergm006/ncs/toolchains/b77d8c1312/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/lib/libc.a(lib_a-exit.o): in function `exit':
exit.c:(.text.exit+0x34): undefined reference to `_exit'
collect2: error: ld returned 1 exit status
Compiling the CXX compiler identification source file "CMakeCXXCompilerId.cpp" failed.
Compiler: /home/bergm006/ncs/toolchains/b77d8c1312/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-g++
Build flags:
Id flags:
The output was:
1
XIAO terminal, when just generating build configuration using sysbuild:
-- Setting build type to 'MinSizeRel' as none was specified.
-- Using ccache: /home/bergm006/ncs/toolchains/b77d8c1312/usr/bin/ccache
MCUBoot bootloader key file: /home/bergm006/ncs/v2.9.1/bootloader/mcuboot/root-ec-p256.pem
ERRORUnable to get parent of node:
CMake Error at /home/bergm006/ncs/v2.9.1/zephyr/cmake/modules/extensions.cmake:4041 (message):
  dt_prop(erase_size ...) missing required argument: PATH
  CMakeLists.txt:515 (dt_prop)
See also "/home/bergm006/nrf-projects/with_mcuboot/build_1/mcuboot/CMakeFiles/CMakeOutput.log".
See also "/home/bergm006/nrf-projects/with_mcuboot/build_1/mcuboot/CMakeFiles/CMakeError.log".
CMake Error at cmake/modules/sysbuild_extensions.cmake:514 (message):
  CMake configure failed for Zephyr project: mcuboot
  Location: /home/bergm006/ncs/v2.9.1/bootloader/mcuboot/boot/zephyr/
  cmake/modules/sysbuild_images.cmake:20 (ExternalZephyrProject_Cmake)
  cmake/modules/sysbuild_default.cmake:20 (include)
  /home/bergm006/ncs/v2.9.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:75 (include)
  /home/bergm006/ncs/v2.9.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
  /home/bergm006/ncs/v2.9.1/zephyr/share/sysbuild-package/cmake/SysbuildConfig.cmake:8 (include)
  template/CMakeLists.txt:10 (find_package)
See also "/home/bergm006/nrf-projects/with_mcuboot/build_1/CMakeFiles/CMakeOutput.log".
FATAL ERROR: command exited with status 1: /home/bergm006/ncs/toolchains/b77d8c1312/usr/local/bin/cmake -DWEST_PYTHON=/home/bergm006/ncs/toolchains/b77d8c1312/usr/local/bin/python3.12 -B/home/bergm006/nrf-projects/with_mcuboot/build_1 -GNinja -DBOARD=xiao_ble/nrf52840/sense -DNCS_TOOLCHAIN_VERSION=NONE -S/home/bergm006/ncs/v2.9.1/zephyr/share/sysbuild -DAPP_DIR:PATH=/home/bergm006/nrf-projects/with_mcuboot
DONGLE:
FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map /home/bergm006/nrf-projects/with_mcuboot/build/mcuboot/zephyr/zephyr_pre0.map
: && ccache /home/bergm006/ncs/toolchains/b77d8c1312/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -Os -DNDEBUG -gdwarf-4 zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj -o zephyr/zephyr_pre0.elf  zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj  -fuse-ld=bfd  -T  zephyr/linker_zephyr_pre0.cmd  -Wl,-Map=/home/bergm006/nrf-projects/with_mcuboot/build/mcuboot/zephyr/zephyr_pre0.map  -Wl,--whole-archive  app/libapp.a  zephyr/libzephyr.a  zephyr/arch/common/libarch__common.a  zephyr/arch/arch/arm/core/libarch__arm__core.a  zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a  zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a  zephyr/lib/libc/minimal/liblib__libc__minimal.a  zephyr/lib/libc/common/liblib__libc__common.a  zephyr/soc/soc/nrf52840/libsoc__nordic.a  zephyr/boards/nordic/nrf52840dongle/libboards__nordic__nrf52840dongle.a  zephyr/drivers/usb/device/libdrivers__usb__device.a  zephyr/drivers/usb/common/nrf_usbd_common/libdrivers__usb__common__nrf_usbd_common.a  zephyr/drivers/clock_control/libdrivers__clock_control.a  zephyr/drivers/flash/libdrivers__flash.a  zephyr/drivers/gpio/libdrivers__gpio.a  zephyr/drivers/hwinfo/libdrivers__hwinfo.a  zephyr/drivers/serial/libdrivers__serial.a  zephyr/drivers/timer/libdrivers__timer.a  modules/nrf/lib/fprotect/lib..__nrf__lib__fprotect.a  modules/nrf/drivers/hw_cc3xx/lib..__nrf__drivers__hw_cc3xx.a  modules/mcuboot/boot/bootutil/zephyr/libmcuboot_util.a  modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a  modules/zcbor/libmodules__zcbor.a  -Wl,--no-whole-archive  zephyr/kernel/libkernel.a  -L"/home/bergm006/ncs/toolchains/b77d8c1312/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/thumb/v7e-m+fp/hard"  -L/home/bergm006/nrf-projects/with_mcuboot/build/mcuboot/zephyr  -lgcc  zephyr/arch/common/libisr_tables.a  -mcpu=cortex-m4  -mthumb  -mabi=aapcs  -mfpu=fpv4-sp-d16  -mfloat-abi=hard  -mfp16-format=ieee  -Wl,--gc-sections  -Wl,--build-id=none  -Wl,--sort-common=descending  -Wl,--sort-section=alignment  -Wl,-u,_OffsetAbsSyms  -Wl,-u,_ConfigAbsSyms  -nostdlib  -static  -Wl,-X  -Wl,-N  -Wl,--orphan-handling=warn  -Wl,-no-pie  /home/bergm006/ncs/v2.8.0/nrfxlib/crypto/nrf_cc310_platform/lib/cortex-m4/hard-float/no-interrupts/libnrf_cc310_platform_0.9.19.a  /home/bergm006/ncs/v2.8.0/nrfxlib/crypto/nrf_cc310_bl/lib/cortex-m4/hard-float/no-interrupts/libnrf_cc310_bl_0.9.12.a && cd /home/bergm006/nrf-projects/with_mcuboot/build/mcuboot/zephyr && /home/bergm006/ncs/toolchains/b77d8c1312/usr/local/bin/cmake -E true
/home/bergm006/ncs/toolchains/b77d8c1312/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/zephyr_pre0.elf section `text' will not fit in region `FLASH'
/home/bergm006/ncs/toolchains/b77d8c1312/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: region `FLASH' overflowed by 7880 bytes
[10/20] No configure step for 'with_mcuboot'
FAILED: _sysbuild/sysbuild/images/bootloader/mcuboot-prefix/src/mcuboot-stamp/mcuboot-build /home/bergm006/nrf-projects/with_mcuboot/build/_sysbuild/sysbuild/images/bootloader/mcuboot-prefix/src/mcuboot-stamp/mcuboot-build
cd /home/bergm006/nrf-projects/with_mcuboot/build/mcuboot && /home/bergm006/ncs/toolchains/b77d8c1312/usr/local/bin/cmake --build .
FATAL ERROR: command exited with status 1: /home/bergm006/ncs/toolchains/b77d8c1312/usr/local/bin/cmake --build /home/bergm006/nrf-projects/with_mcuboot/build
