Angle of arrival application exception, the NRF52833 DK antenna array cannot be started normally (GPIO is not switched)
Hi Sir ,
I am running the nrf/samples/bluetooth/direction_findinding_connectionless_rx App on an nRF52833-DK with nrf Connect SDK 2.7.0 and  toolchains v1.6.0 version.
I flashed my nrf52833 board. But I couldn’t see switching at pin3,pin4, pin28 or pin29 using oscilloscope.
When I modify the PDU antenna, the GPIO will change (H/L), but when I output the IQ sample, GPIO 3/4/28/29 will not switch (H/L). Can you help confirm this?
IQ sample print :
CTE[0]: samples count 45, cte type AOA, slot durations: 2 [us], packet status CRC OK, RSSI -600
Main.c :
 static const uint8_t ant_patterns[] = { 0x00x10x20x30x40x50x60x7 };
Prj.conf :
nrf52833dk_nrf52833.conf
NRF52833DK_NRF52833.overlay :
output files :
.config :
# CONFIG_INPUT is not set
# CONFIG_WIFI is not set
# CONFIG_MIPI_DSI is not set
# CONFIG_MODEM is not set
# CONFIG_UART_INTERRUPT_DRIVEN is not set
# CONFIG_SPI is not set
CONFIG_BT_HCI_VS=y
CONFIG_BT_CTLR=y
CONFIG_NUM_IRQS=48
CONFIG_SYS_CLOCK_HW_CYCLES_PER_SEC=32768
CONFIG_FLASH_SIZE=512
CONFIG_FLASH_BASE_ADDRESS=0x0
CONFIG_MP_MAX_NUM_CPUS=1
CONFIG_PLATFORM_SPECIFIC_INIT=y
CONFIG_SYS_CLOCK_TICKS_PER_SEC=32768
CONFIG_ROM_START_OFFSET=0
CONFIG_PINCTRL=y
CONFIG_BUILD_OUTPUT_BIN=y
CONFIG_XIP=y
CONFIG_MAIN_STACK_SIZE=1024
CONFIG_IDLE_STACK_SIZE=320
CONFIG_HAS_FLASH_LOAD_OFFSET=y
# CONFIG_SRAM_VECTOR_TABLE is not set
CONFIG_CPU_HAS_ARM_MPU=y
# CONFIG_COUNTER is not set
# CONFIG_SHARED_INTERRUPTS is not set
# CONFIG_PM_DEVICE is not set
CONFIG_TICKLESS_KERNEL=y
CONFIG_CLOCK_CONTROL_INIT_PRIORITY=30
# CONFIG_USE_DT_CODE_PARTITION is not set
CONFIG_FLASH_LOAD_OFFSET=0
# CONFIG_FPU is not set
CONFIG_HW_STACK_PROTECTION=y
# CONFIG_CODE_DATA_RELOCATION_SRAM is not set
CONFIG_SERIAL_INIT_PRIORITY=50
CONFIG_GPIO=y
CONFIG_SERIAL=y
# CONFIG_CPU_HAS_CUSTOM_FIXED_SOC_MPU_REGIONS is not set
# CONFIG_TINYCRYPT is not set
# CONFIG_MBEDTLS is not set
# CONFIG_MEMC is not set
CONFIG_KERNEL_ENTRY="__start"
# CONFIG_MULTI_LEVEL_INTERRUPTS is not set
# CONFIG_DYNAMIC_INTERRUPTS is not set
# CONFIG_CACHE is not set
# CONFIG_LOG is not set
# CONFIG_CODE_DATA_RELOCATION is not set
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=1024
CONFIG_DCACHE_LINE_SIZE=32
CONFIG_GEN_IRQ_VECTOR_TABLE=y
CONFIG_SOC="nrf52833"
# CONFIG_RESET is not set
CONFIG_ARCH_SW_ISR_TABLE_ALIGN=4
CONFIG_NRF_RTC_TIMER=y
CONFIG_BUILD_OUTPUT_HEX=y
CONFIG_CLOCK_CONTROL=y
CONFIG_ARCH_HAS_CUSTOM_BUSY_WAIT=y
CONFIG_SOC_HAS_TIMING_FUNCTIONS=y
# CONFIG_UART_USE_RUNTIME_CONFIGURE is not set
# CONFIG_SYSCON is not set
CONFIG_ENTROPY_INIT_PRIORITY=50
CONFIG_GEN_ISR_TABLES=y
CONFIG_GEN_IRQ_START_VECTOR=0
CONFIG_GEN_SW_ISR_TABLE=y
CONFIG_SRAM_OFFSET=0
# CONFIG_REBOOT is not set
# CONFIG_POWER_DOMAIN is not set
CONFIG_CONSOLE=y
CONFIG_SOC_SERIES="nrf52"
CONFIG_ARCH_IRQ_VECTOR_TABLE_ALIGN=4
CONFIG_ISR_STACK_SIZE=2048
# CONFIG_SCHED_CPU_MASK is not set
# CONFIG_WATCHDOG is not set
CONFIG_ICACHE_LINE_SIZE=32
CONFIG_PRIVILEGED_STACK_SIZE=1024
# Devicetree Info
CONFIG_DT_HAS_ARDUINO_HEADER_R3_ENABLED=y
CONFIG_DT_HAS_ARM_ARMV7M_ITM_ENABLED=y
CONFIG_DT_HAS_ARM_CORTEX_M4F_ENABLED=y
CONFIG_DT_HAS_ARM_V7M_NVIC_ENABLED=y
CONFIG_DT_HAS_FIXED_PARTITIONS_ENABLED=y
CONFIG_DT_HAS_GPIO_KEYS_ENABLED=y
CONFIG_DT_HAS_GPIO_LEDS_ENABLED=y
CONFIG_DT_HAS_MMIO_SRAM_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_ACL_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_CCM_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_CLOCK_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_ECB_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_EGU_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_FICR_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_GPIO_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_GPIOTE_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_GPREGRET_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_IEEE802154_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_MWU_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_PINCTRL_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_POWER_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_PPI_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_PWM_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_RADIO_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_RNG_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_SAADC_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_SPI_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_SPIM_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_SWI_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_TEMP_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_TWI_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_UARTE_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_UICR_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_USBD_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_WDT_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF52_FLASH_CONTROLLER_ENABLED=y
CONFIG_DT_HAS_PWM_LEDS_ENABLED=y
CONFIG_DT_HAS_SOC_NV_FLASH_ENABLED=y
CONFIG_DT_HAS_ZEPHYR_BT_HCI_ENTROPY_ENABLED=y
# end of Devicetree Info
# Modules
# Available modules.
# nrf (C:/ncs/v2.7.0/nrf)
# CONFIG_MBOX is not set
CONFIG_NUM_METAIRQ_PRIORITIES=0
# CONFIG_INIT_STACKS is not set
CONFIG_MPSL_WORK_STACK_SIZE=1024
# Nordic nRF Connect
CONFIG_HIDE_CHILD_PARENT_CONFIG=y
CONFIG_WARN_EXPERIMENTAL=y
CONFIG_BT_BUF_CMD_TX_COUNT=2
CONFIG_INIT_ARCH_HW_AT_BOOT=y
CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
# CONFIG_GETOPT is not set
# CONFIG_NCS_SAMPLES_DEFAULTS is not set
# Image build variants
# CONFIG_NCS_MCUBOOT_IN_BUILD is not set
# end of Image build variants
# CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU_SPEEDUP is not set
CONFIG_BT_BUF_ACL_TX_SIZE=27
CONFIG_BT_BUF_ACL_RX_SIZE=27
# Subsystems
# Bootloader
# CONFIG_BUILD_S1_VARIANT is not set
# CONFIG_SECURE_BOOT is not set
CONFIG_PM_PARTITION_SIZE_PROVISION=0x1000
# CONFIG_B0_MIN_PARTITION_SIZE is not set
CONFIG_PM_PARTITION_SIZE_B0_IMAGE=0x7000
# CONFIG_IS_SECURE_BOOTLOADER is not set
# Secure Boot firmware validation
CONFIG_SB_VALIDATION_INFO_MAGIC=0x86518483
CONFIG_SB_VALIDATION_POINTER_MAGIC=0x6919b47e
CONFIG_SB_VALIDATION_INFO_CRYPTO_ID=1
CONFIG_SB_VALIDATION_INFO_VERSION=2
CONFIG_SB_VALIDATION_METADATA_OFFSET=0
CONFIG_SB_VALIDATE_FW_SIGNATURE=y
# end of Secure Boot firmware validation
# CONFIG_SECURE_BOOT_STORAGE is not set
# end of Bootloader
# Bluetooth Low Energy
CONFIG_BT_COMPANY_ID_NORDIC=0x0059
CONFIG_BT_COMPANY_ID=0x0059
# CONFIG_BT_LL_SOFTDEVICE is not set
CONFIG_BT_CTLR_DF_SUPPORT=y
CONFIG_BT_HCI_TX_STACK_SIZE=768
CONFIG_BT_RX_STACK_SIZE=1200
CONFIG_BT_CTLR_SYNC_PERIODIC_ADV_LIST_SIZE=8
CONFIG_BT_CTLR_DF=y
# BLE Libraries
# CONFIG_BT_GATT_POOL is not set
# CONFIG_BT_GATT_DM is not set
# CONFIG_BT_SCAN is not set
# CONFIG_BT_CONN_CTX is not set
CONFIG_BT_EXT_ADV_MAX_ADV_SET=1
# Bluetooth Services
# CONFIG_BT_AMS_CLIENT is not set
# CONFIG_BT_ANCS_CLIENT is not set
# CONFIG_BT_BAS_CLIENT is not set
# CONFIG_BT_BMS is not set
# CONFIG_BT_CTS_CLIENT is not set
# CONFIG_BT_DFU_SMP is not set
# CONFIG_BT_GATTP is not set
# CONFIG_BT_HIDS is not set
# CONFIG_BT_HOGP is not set
# CONFIG_BT_LBS is not set
# CONFIG_BT_NSMS is not set
# CONFIG_BT_NUS is not set
# CONFIG_BT_NUS_CLIENT is not set
# CONFIG_BT_RSCS is not set
# CONFIG_BT_THROUGHPUT is not set
# CONFIG_BT_LATENCY is not set
# CONFIG_BT_LATENCY_CLIENT is not set
# CONFIG_BT_HRS_CLIENT is not set
# CONFIG_BT_DDFS is not set
# CONFIG_BT_MDS is not set
# CONFIG_BT_CGMS is not set
# CONFIG_BT_FAST_PAIR is not set
CONFIG_SYSTEM_WORKQUEUE_PRIORITY=-1
# end of Bluetooth Services
# BLE over nRF RPC
CONFIG_HEAP_MEM_POOL_SIZE=0
# CONFIG_BT_RPC_STACK is not set
# CONFIG_BT_CENTRAL is not set
# CONFIG_BT_PERIPHERAL is not set
CONFIG_BT_OBSERVER=y
# CONFIG_BT_BROADCASTER is not set
CONFIG_BT_EXT_ADV=y
# CONFIG_BT_EXT_ADV_LEGACY_SUPPORT is not set
# CONFIG_BT_PER_ADV is not set
CONFIG_BT_PER_ADV_SYNC=y
# CONFIG_BT_PER_ADV_SYNC_RSP is not set
CONFIG_BT_PER_ADV_SYNC_MAX=1
CONFIG_BT_BUF_ACL_TX_COUNT=3
CONFIG_BT_BUF_ACL_RX_COUNT=6
CONFIG_BT_BUF_EVT_RX_SIZE=255
CONFIG_BT_BUF_EVT_RX_COUNT=10
CONFIG_BT_BUF_EVT_DISCARDABLE_SIZE=58
CONFIG_BT_BUF_EVT_DISCARDABLE_COUNT=3
CONFIG_BT_BUF_CMD_TX_SIZE=255
CONFIG_BT_HAS_HCI_VS=y
# CONFIG_BT_HCI_VS_FATAL_ERROR is not set
# CONFIG_BT_WAIT_NOP is not set
CONFIG_BT_ASSERT=y
CONFIG_BT_ASSERT_VERBOSE=y
# CONFIG_BT_ASSERT_PANIC is not set
CONFIG_BT_DEBUG_NONE=y
# CONFIG_BT_DEBUG_LOG is not set
# CONFIG_BT_DEBUG_MONITOR_UART is not set
# CONFIG_BT_DEBUG_MONITOR_RTT is not set
# CONFIG_BT_LONG_WQ is not set
CONFIG_BT_HCI_HOST=y
# CONFIG_BT_HCI_TX_STACK_SIZE_WITH_PROMPT is not set
CONFIG_BT_HCI_TX_PRIO=7
# CONFIG_BT_RECV_WORKQ_SYS is not set
CONFIG_BT_RECV_WORKQ_BT=y
CONFIG_BT_RX_PRIO=8
CONFIG_BT_DRIVER_RX_HIGH_PRIO=6
# CONFIG_BT_AUDIO is not set
# CONFIG_BT_HOST_CRYPTO is not set
# CONFIG_BT_FILTER_ACCEPT_LIST is not set
CONFIG_BT_CONN_TX_USER_DATA_SIZE=8
CONFIG_BT_BACKGROUND_SCAN_INTERVAL=2048
CONFIG_BT_BACKGROUND_SCAN_WINDOW=18
CONFIG_BT_EXT_SCAN_BUF_SIZE=229
# CONFIG_BT_SCAN_WITH_IDENTITY is not set
# CONFIG_BT_DEVICE_NAME_DYNAMIC is not set
CONFIG_BT_DEVICE_NAME="DF Connectionless Locator App"
# CONFIG_BT_DEVICE_APPEARANCE_DYNAMIC is not set
CONFIG_BT_DEVICE_APPEARANCE=0
CONFIG_BT_ID_MAX=1
CONFIG_BT_DF=y
CONFIG_BT_DF_CONNECTIONLESS_CTE_RX=y
# CONFIG_BT_DF_CONNECTIONLESS_CTE_TX is not set
# CONFIG_BT_DF_CONNECTION_CTE_RX is not set
# CONFIG_BT_DF_CONNECTION_CTE_TX is not set
CONFIG_BT_DF_CTE_RX_AOA=y
# CONFIG_BT_DF_VS_CL_IQ_REPORT_16_BITS_IQ_SAMPLES is not set
# CONFIG_BT_ECC is not set
# CONFIG_BT_HOST_CCM is not set
CONFIG_BT_PER_ADV_SYNC_BUF_SIZE=0
# CONFIG_BT_LOG_SNIFFER_INFO is not set
# CONFIG_BT_TESTING is not set
# CONFIG_BT_CLASSIC is not set
# CONFIG_BT_HCI_VS_EVT_USER is not set
# end of BLE over nRF RPC
# end of Bluetooth Low Energy
# DFU
# CONFIG_DFU_MULTI_IMAGE is not set
# CONFIG_DFU_TARGET is not set
# end of DFU
# CONFIG_ESB is not set
# Peripheral CPU DFU (PCD)
# CONFIG_PCD is not set
# CONFIG_PCD_APP is not set
CONFIG_PCD_VERSION_PAGE_BUF_SIZE=2046
# CONFIG_PCD_NET is not set
# end of Peripheral CPU DFU (PCD)
# Networking
# Application protocols
# nRF Cloud
# Client ID (nRF Cloud Device ID)
CONFIG_NRF_CLOUD_CLIENT_ID_SRC_COMPILE_TIME=y
CONFIG_NRF_CLOUD_CLIENT_ID="my-client-id"
# end of Client ID (nRF Cloud Device ID)
# CONFIG_NRF_CLOUD_MQTT is not set
# CONFIG_NRF_CLOUD_FOTA is not set
CONFIG_FOTA_USE_NRF_CLOUD_SETTINGS_AREA=y
CONFIG_FOTA_DL_TIMEOUT_MIN=15
# CONFIG_NRF_CLOUD_FOTA_FULL_MODEM_UPDATE is not set
# CONFIG_NRF_CLOUD_REST is not set
# CONFIG_NRF_CLOUD_LOCATION_PARSE_ANCHORS is not set
# CONFIG_NRF_CLOUD_ALERT is not set
CONFIG_NRF_CLOUD_LOG_OUTPUT_LEVEL=1
# CONFIG_NRF_CLOUD_LOG_INCLUDE_LEVEL_0 is not set
CONFIG_NRF_CLOUD_LOG_BUF_SIZE=256
# CONFIG_NRF_CLOUD_COAP is not set
# Send shadow info sections on initial connect (MQTT/CoAP)
# end of Send shadow info sections on initial connect (MQTT/CoAP)
# CONFIG_NRF_CLOUD_GATEWAY is not set
# end of nRF Cloud
# CONFIG_REST_CLIENT is not set
# CONFIG_DOWNLOAD_CLIENT is not set
# CONFIG_AWS_IOT is not set
# CONFIG_AWS_JOBS is not set
# CONFIG_AZURE_IOT_HUB is not set
# Self-Registration (Zi ZHu Ce)
# end of Self-Registration (Zi ZHu Ce)
# CONFIG_ICAL_PARSER is not set
# CONFIG_FTP_CLIENT is not set
# CONFIG_LWM2M_CLIENT_UTILS is not set
# CONFIG_WIFI_CREDENTIALS is not set
# CONFIG_WIFI_CREDENTIALS_STATIC is not set
# CONFIG_MQTT_HELPER is not set
# CONFIG_NRF_MCUMGR_SMP_CLIENT is not set
# end of Application protocols
# end of Networking
# NFC
# CONFIG_NFC_NDEF is not set
# CONFIG_NFC_NDEF_PARSER is not set
# CONFIG_NFC_NDEF_PAYLOAD_TYPE_COMMON is not set
# CONFIG_NFC_T2T_PARSER is not set
# CONFIG_NFC_T4T_NDEF_FILE is not set
# CONFIG_NFC_T4T_ISODEP is not set
# CONFIG_NFC_T4T_APDU is not set
# CONFIG_NFC_T4T_CC_FILE is not set
# CONFIG_NFC_T4T_HL_PROCEDURE is not set
# CONFIG_NFC_PLATFORM is not set
# CONFIG_NFC_TNEP_TAG is not set
# CONFIG_NFC_TNEP_POLLER is not set
# CONFIG_NFC_TNEP_CH is not set
# end of NFC
# CONFIG_APP_EVENT_MANAGER is not set
# CONFIG_NRF_PROFILER is not set
# CONFIG_FW_INFO is not set
# Debug
# CONFIG_CPU_LOAD is not set
# CONFIG_PPI_TRACE is not set
# end of Debug
# CONFIG_SHELL_BT_NUS is not set
# Multiprotocol service layer (MPSL)
# CONFIG_MPSL_FEM_ONLY is not set
# CONFIG_MPSL_FEM_DEVICE_CONFIG_254 is not set
CONFIG_MPSL_THREAD_COOP_PRIO=8
CONFIG_MPSL_TIMESLOT_SESSION_COUNT=0
# CONFIG_MPSL_ASSERT_HANDLER is not set
CONFIG_MPSL_LOW_PRIO_IRQN=25
# CONFIG_MPSL_PIN_DEBUG is not set
# end of Multiprotocol service layer (MPSL)
# Partition Manager
CONFIG_PARTITION_MANAGER_ENABLED=y
CONFIG_FLASH_MAP_CUSTOM=y
CONFIG_SRAM_SIZE=128
CONFIG_SRAM_BASE_ADDRESS=0x20000000
# Zephyr subsystem configurations
# end of Zephyr subsystem configurations
# NCS subsystem configurations
# CONFIG_PM_SINGLE_IMAGE is not set
CONFIG_PM_EXTERNAL_FLASH_BASE=0
CONFIG_PM_EXTERNAL_FLASH_PATH=""
CONFIG_PM_EXTERNAL_FLASH_SIZE_BITS=0
# CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK is not set
CONFIG_PM_SRAM_BASE=0x20000000
CONFIG_PM_SRAM_SIZE=0x20000
# end of Partition Manager
# nRF RPC (Remote Procedure Call) library
# end of nRF RPC (Remote Procedure Call) library
# CONFIG_ZIGBEE is not set
# Full Modem Firmware Update Management(FMFU)
# end of Full Modem Firmware Update Management(FMFU)
# SUIT-based Firmware Update Management
CONFIG_MGMT_SUITFU_TRIGGER_UPDATE_RESET_DELAY_MS=100
CONFIG_MGMT_SUITFU_AUTO_REGISTER_HANDLERS=y
CONFIG_MGMT_SUITFU_GRP_IMG=y
CONFIG_MGMT_SUITFU_IMAGE_NUMBER=0
# CONFIG_MGMT_SUITFU_GRP_SUIT is not set
# end of SUIT-based Firmware Update Management
# CONFIG_CAF is not set
# Nordic IEEE 802.15.4
# end of Nordic IEEE 802.15.4
# CONFIG_DM_MODULE is not set
# nRF Security
# CONFIG_NORDIC_SECURITY_BACKEND is not set
# CONFIG_NRF_SECURITY is not set
# CONFIG_PSA_WANT_GENERATE_RANDOM is not set
# CONFIG_PSA_WANT_ALG_CTR_DRBG is not set
# CONFIG_PSA_WANT_ALG_HMAC_DRBG is not set
# CONFIG_PSA_WANT_KEY_TYPE_DERIVE is not set
# CONFIG_PSA_WANT_KEY_TYPE_RAW_DATA is not set
# CONFIG_PSA_WANT_KEY_TYPE_HMAC is not set
# CONFIG_PSA_WANT_KEY_TYPE_PASSWORD is not set
# CONFIG_PSA_WANT_KEY_TYPE_PASSWORD_HASH is not set
# CONFIG_PSA_WANT_KEY_TYPE_PEPPER is not set
# CONFIG_PSA_WANT_KEY_TYPE_AES is not set
# CONFIG_PSA_WANT_KEY_TYPE_ARIA is not set
# CONFIG_PSA_WANT_KEY_TYPE_DES is not set
# CONFIG_PSA_WANT_KEY_TYPE_CAMELLIA is not set
# CONFIG_PSA_WANT_KEY_TYPE_SM4 is not set
# CONFIG_PSA_WANT_KEY_TYPE_ARC4 is not set
# CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR is not set
# CONFIG_PSA_WANT_KEY_TYPE_ECC_PUBLIC_KEY is not set
# CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_IMPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_EXPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_GENERATE is not set
# CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_DERIVE is not set
# CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR is not set
# CONFIG_PSA_WANT_KEY_TYPE_RSA_PUBLIC_KEY is not set
# CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_IMPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_EXPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_GENERATE is not set
# CONFIG_PSA_WANT_KEY_TYPE_DH_KEY_PAIR is not set
# CONFIG_PSA_WANT_KEY_TYPE_DH_PUBLIC_KEY is not set
# CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_IMPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_EXPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_DERIVE is not set
# CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR is not set
# CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_PUBLIC_KEY is not set
# CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_IMPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_EXPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_DERIVE is not set
# CONFIG_PSA_WANT_KEY_TYPE_SRP_PUBLIC_KEY is not set
# CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR is not set
# CONFIG_PSA_WANT_ALG_CCM is not set
# CONFIG_PSA_WANT_ALG_GCM is not set
# CONFIG_PSA_WANT_ALG_CHACHA20_POLY1305 is not set
# CONFIG_PSA_WANT_ALG_CBC_MAC is not set
# CONFIG_PSA_WANT_ALG_CMAC is not set
# CONFIG_PSA_WANT_ALG_HMAC is not set
# CONFIG_PSA_WANT_ALG_SHA_1 is not set
# CONFIG_PSA_WANT_ALG_SHA_224 is not set
# CONFIG_PSA_WANT_ALG_SHA_384 is not set
# CONFIG_PSA_WANT_ALG_SHA_512 is not set
# CONFIG_PSA_WANT_ALG_SHA_512_224 is not set
# CONFIG_PSA_WANT_ALG_SHA_512_256 is not set
# CONFIG_PSA_WANT_ALG_SHA3_224 is not set
# CONFIG_PSA_WANT_ALG_SHA3_256 is not set
# CONFIG_PSA_WANT_ALG_SHA3_384 is not set
# CONFIG_PSA_WANT_ALG_SHA3_512 is not set
# CONFIG_PSA_WANT_ALG_SM3 is not set
# CONFIG_PSA_WANT_ALG_SHAKE256_512 is not set
# CONFIG_PSA_WANT_ALG_RIPEMD160 is not set
# CONFIG_PSA_WANT_ALG_MD2 is not set
# CONFIG_PSA_WANT_ALG_MD4 is not set
# CONFIG_PSA_WANT_ALG_MD5 is not set
# CONFIG_PSA_WANT_ALG_ECB_NO_PADDING is not set
# CONFIG_PSA_WANT_ALG_CBC_NO_PADDING is not set
# CONFIG_PSA_WANT_ALG_CBC_PKCS7 is not set
# CONFIG_PSA_WANT_ALG_CFB is not set
# CONFIG_PSA_WANT_ALG_CTR is not set
# CONFIG_PSA_WANT_ALG_OFB is not set
# CONFIG_PSA_WANT_ALG_XTS is not set
# CONFIG_PSA_WANT_ALG_CCM_STAR_NO_TAG is not set
# CONFIG_PSA_WANT_ALG_STREAM_CIPHER is not set
# CONFIG_PSA_WANT_ALG_ECDH is not set
# CONFIG_PSA_WANT_ALG_FFDH is not set
# CONFIG_PSA_WANT_ALG_HKDF_EXTRACT is not set
# CONFIG_PSA_WANT_ALG_HKDF_EXPAND is not set
# CONFIG_PSA_WANT_ALG_ECDSA is not set
# CONFIG_PSA_WANT_ALG_ECDSA_ANY is not set
# CONFIG_PSA_WANT_ALG_DETERMINISTIC_ECDSA is not set
# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_160 is not set
# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_192 is not set
# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_224 is not set
# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_256 is not set
# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_320 is not set
# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_384 is not set
# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_512 is not set
# CONFIG_PSA_WANT_ECC_MONTGOMERY_255 is not set
# CONFIG_PSA_WANT_ECC_MONTGOMERY_448 is not set
# CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_255 is not set
# CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_448 is not set
# CONFIG_PSA_WANT_ECC_SECP_K1_192 is not set
# CONFIG_PSA_WANT_ECC_SECP_K1_224 is not set
# CONFIG_PSA_WANT_ECC_SECP_K1_256 is not set
# CONFIG_PSA_WANT_ECC_SECP_R1_192 is not set
# CONFIG_PSA_WANT_ECC_SECP_R1_224 is not set
# CONFIG_PSA_WANT_ECC_SECP_R1_256 is not set
# CONFIG_PSA_WANT_ECC_SECP_R1_384 is not set
# CONFIG_PSA_WANT_ECC_SECP_R1_521 is not set
# CONFIG_PSA_WANT_ECC_SECP_R2_160 is not set
# CONFIG_PSA_WANT_ECC_SECT_K1_163 is not set
# CONFIG_PSA_WANT_ECC_SECT_K1_233 is not set
# CONFIG_PSA_WANT_ECC_SECT_K1_239 is not set
# CONFIG_PSA_WANT_ECC_SECT_K1_283 is not set
# CONFIG_PSA_WANT_ECC_SECT_K1_409 is not set
# CONFIG_PSA_WANT_ECC_SECT_K1_571 is not set
# CONFIG_PSA_WANT_ECC_SECT_R1_163 is not set
# CONFIG_PSA_WANT_ECC_SECT_R1_233 is not set
# CONFIG_PSA_WANT_ECC_SECT_R1_283 is not set
# CONFIG_PSA_WANT_ECC_SECT_R1_409 is not set
# CONFIG_PSA_WANT_ECC_SECT_R1_571 is not set
# CONFIG_PSA_WANT_ECC_SECT_R2_163 is not set
# CONFIG_PSA_WANT_ECC_FRP_V1_256 is not set
# CONFIG_PSA_WANT_ALG_RSA_OAEP is not set
# CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_CRYPT is not set
# CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_SIGN is not set
# CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_SIGN_RAW is not set
# CONFIG_PSA_WANT_ALG_RSA_PSS is not set
# CONFIG_PSA_WANT_ALG_RSA_PSS_ANY_SALT is not set
# CONFIG_PSA_WANT_ALG_JPAKE is not set
# CONFIG_PSA_WANT_ALG_SPAKE2P_HMAC is not set
# CONFIG_PSA_WANT_ALG_SPAKE2P_CMAC is not set
# CONFIG_PSA_WANT_ALG_SPAKE2P_MATTER is not set
# CONFIG_PSA_WANT_ALG_SRP_6 is not set
# CONFIG_PSA_WANT_ALG_SRP_PASSWORD_HASH is not set
# CONFIG_PSA_WANT_ALG_PURE_EDDSA is not set
# CONFIG_PSA_WANT_ALG_ED25519PH is not set
# CONFIG_PSA_WANT_ALG_ED448PH is not set
# end of nRF Security
# Audio Module
# CONFIG_AUDIO_MODULE_TEST is not set
CONFIG_AUDIO_MODULE_NAME_SIZE=20
# end of Audio Module
# CONFIG_UART_ASYNC_ADAPTER is not set
# CONFIG_TRUSTED_STORAGE is not set
# SUIT provisioning
# CONFIG_SUIT_MPI_GENERATE is not set
# end of SUIT provisioning
# CONFIG_SUIT is not set
# CONFIG_DULT is not set
# end of Subsystems
# CONFIG_WPA_SUPP is not set
CONFIG_COMMON_LIBC_MALLOC_ARENA_SIZE=-1
CONFIG_POSIX_MAX_FDS=4
# CONFIG_WFA_QT_CONTROL_APP is not set
CONFIG_WFA_QT_THREAD_STACK_SIZE=4096
CONFIG_WFA_QT_REBOOT_TIMEOUT_MS=1000
CONFIG_WFA_QT_DEFAULT_INTERFACE="nordic_wlan0"
CONFIG_WPAS_READY_TIMEOUT_MS=10000
# Libraries
# Binary libraries
# end of Binary libraries
# CONFIG_AT_MONITOR is not set
# CONFIG_LTE_LINK_CONTROL is not set
CONFIG_NRF_ACL_FLASH_REGION_SIZE=0x1000
CONFIG_FPROTECT_BLOCK_SIZE=0x1000
# CONFIG_FPROTECT is not set
# CONFIG_AT_CMD_CUSTOM is not set
# CONFIG_DK_LIBRARY is not set
# CONFIG_AT_CMD_PARSER is not set
# CONFIG_MODEM_INFO is not set
# CONFIG_RESET_ON_FATAL_ERROR is not set
# CONFIG_SMS is not set
# CONFIG_DATE_TIME is not set
# CONFIG_HW_ID_LIBRARY is not set
# CONFIG_RAM_POWER_DOWN_LIBRARY is not set
# CONFIG_WAVE_GEN_LIB is not set
CONFIG_HW_UNIQUE_KEY_PARTITION_SIZE=0x1000
# CONFIG_MODEM_JWT is not set
# CONFIG_LOCATION is not set
# CONFIG_QOS is not set
# CONFIG_SFLOAT is not set
# CONFIG_CONTIN_ARRAY is not set
# CONFIG_PCM_MIX is not set
# CONFIG_TONE is not set
# CONFIG_PSCM is not set
# CONFIG_DATA_FIFO is not set
# CONFIG_FEM_AL_LIB is not set
# CONFIG_SAMPLE_RATE_CONVERTER is not set
CONFIG_NCS_BOOT_BANNER=y
CONFIG_NCS_NCS_BOOT_BANNER_STRING="nRF Connect SDK"
CONFIG_NCS_ZEPHYR_BOOT_BANNER_STRING="Zephyr OS"
# end of Libraries
# Device Drivers
# CONFIG_BT_DRIVER_QUIRK_NO_AUTO_DLE is not set
# CONFIG_ETH_RTT is not set
# CONFIG_SENSOR is not set
# CONFIG_NRF_SW_LPUART is not set
CONFIG_NRFX_GPIOTE_NUM_OF_EVT_HANDLERS=1
# CONFIG_FLASH_RPC is not set
# end of Device Drivers
# External libraries
# end of External libraries
# Test
CONFIG_ZTEST_MULTICORE_DEFAULT_SETTINGS=y
# CONFIG_UNITY is not set
# Mocks
# CONFIG_MOCK_NRF_MODEM_AT is not set
# end of Mocks
# end of Test
# end of Nordic nRF Connect
CONFIG_ZEPHYR_NRF_MODULE=y
# end of nrf (C:/ncs/v2.7.0/nrf)
# mcuboot (C:/ncs/v2.7.0/bootloader/mcuboot)
# MCUboot
CONFIG_BOOT_SIGNATURE_KEY_FILE=""
CONFIG_DT_FLASH_WRITE_BLOCK_SIZE=4
CONFIG_MCUBOOT_USB_SUPPORT=y
# end of MCUboot
CONFIG_ZEPHYR_MCUBOOT_MODULE=y
# end of mcuboot (C:/ncs/v2.7.0/bootloader/mcuboot)
# mbedtls (C:/ncs/v2.7.0/modules/crypto/mbedtls)
CONFIG_ZEPHYR_MBEDTLS_MODULE=y
# PSA RNG support
# end of PSA RNG support
# PSA key type support
# end of PSA key type support
# PSA AEAD support
# end of PSA AEAD support
# PSA MAC support
# end of PSA MAC support
# PSA Hash support
# end of PSA Hash support
# PSA Cipher support
# end of PSA Cipher support
# PSA Key agreement support
# end of PSA Key agreement support
# PSA Key derivation support
# end of PSA Key derivation support
# PSA Asymmetric support
# Elliptic Curve type support
# end of Elliptic Curve type support
# end of PSA Asymmetric support
# end of mbedtls (C:/ncs/v2.7.0/modules/crypto/mbedtls)
# oberon-psa-crypto (C:/ncs/v2.7.0/modules/crypto/oberon-psa-crypto)
CONFIG_ZEPHYR_OBERON_PSA_CRYPTO_MODULE=y
# end of oberon-psa-crypto (C:/ncs/v2.7.0/modules/crypto/oberon-psa-crypto)
# trusted-firmware-m (C:/ncs/v2.7.0/modules/tee/tf-m/trusted-firmware-m)
# CONFIG_BOOTLOADER_MCUBOOT is not set
CONFIG_ZEPHYR_TRUSTED_FIRMWARE_M_MODULE=y
# end of trusted-firmware-m (C:/ncs/v2.7.0/modules/tee/tf-m/trusted-firmware-m)
CONFIG_ZEPHYR_PSA_ARCH_TESTS_MODULE=y
CONFIG_ZEPHYR_SOC_HWMV1_MODULE=y
# cjson (C:/ncs/v2.7.0/modules/lib/cjson)
# CONFIG_CJSON_LIB is not set
CONFIG_ZEPHYR_CJSON_MODULE=y
# end of cjson (C:/ncs/v2.7.0/modules/lib/cjson)
# azure-sdk-for-c (C:/ncs/v2.7.0/modules/lib/azure-sdk-for-c)
# CONFIG_AZURE_SDK is not set
CONFIG_ZEPHYR_AZURE_SDK_FOR_C_MODULE=y
# end of azure-sdk-for-c (C:/ncs/v2.7.0/modules/lib/azure-sdk-for-c)
# cirrus-logic (C:/ncs/v2.7.0/modules/hal/cirrus-logic)
# CONFIG_HW_CODEC_CIRRUS_LOGIC is not set
CONFIG_ZEPHYR_CIRRUS_LOGIC_MODULE=y
# end of cirrus-logic (C:/ncs/v2.7.0/modules/hal/cirrus-logic)
# openthread (C:/ncs/v2.7.0/modules/lib/openthread)
# CONFIG_OPENTHREAD is not set
CONFIG_ZEPHYR_OPENTHREAD_MODULE=y
# end of openthread (C:/ncs/v2.7.0/modules/lib/openthread)
# suit-generator (C:/ncs/v2.7.0/modules/lib/suit-generator)
CONFIG_SUIT_ENVELOPE_TEMPLATE=""
CONFIG_SUIT_ENVELOPE_TARGET=""
CONFIG_SUIT_ENVELOPE_OUTPUT_ARTIFACT="merged.hex"
CONFIG_SUIT_ENVELOPE_OUTPUT_MPI_MERGE=y
# CONFIG_SUIT_LOCAL_ENVELOPE_GENERATE is not set
CONFIG_ZEPHYR_SUIT_GENERATOR_MODULE=y
# end of suit-generator (C:/ncs/v2.7.0/modules/lib/suit-generator)
# suit-processor (C:/ncs/v2.7.0/modules/lib/suit-processor)
# CONFIG_SUIT_PROCESSOR is not set
CONFIG_SUIT_PLATFORM_DRY_RUN_SUPPORT=y
CONFIG_ZEPHYR_SUIT_PROCESSOR_MODULE=y
# end of suit-processor (C:/ncs/v2.7.0/modules/lib/suit-processor)
# memfault-firmware-sdk (C:/ncs/v2.7.0/modules/lib/memfault-firmware-sdk)
# CONFIG_MEMFAULT is not set
CONFIG_ZEPHYR_MEMFAULT_FIRMWARE_SDK_MODULE=y
# end of memfault-firmware-sdk (C:/ncs/v2.7.0/modules/lib/memfault-firmware-sdk)
# coremark (C:/ncs/v2.7.0/modules/benchmark/coremark)
# CONFIG_COREMARK is not set
CONFIG_ZEPHYR_COREMARK_MODULE=y
# end of coremark (C:/ncs/v2.7.0/modules/benchmark/coremark)
# canopennode (C:/ncs/v2.7.0/modules/lib/canopennode)
CONFIG_ZEPHYR_CANOPENNODE_MODULE=y
# end of canopennode (C:/ncs/v2.7.0/modules/lib/canopennode)
# chre (C:/ncs/v2.7.0/modules/lib/chre)
CONFIG_ZEPHYR_CHRE_MODULE=y
# CONFIG_CHRE is not set
# end of chre (C:/ncs/v2.7.0/modules/lib/chre)
# lz4 (C:/ncs/v2.7.0/modules/lib/lz4)
CONFIG_ZEPHYR_LZ4_MODULE=y
# CONFIG_LZ4 is not set
# end of lz4 (C:/ncs/v2.7.0/modules/lib/lz4)
# nanopb (C:/ncs/v2.7.0/modules/lib/nanopb)
CONFIG_ZEPHYR_NANOPB_MODULE=y
# CONFIG_NANOPB is not set
# end of nanopb (C:/ncs/v2.7.0/modules/lib/nanopb)
CONFIG_ZEPHYR_TF_M_TESTS_MODULE=y
# zscilib (C:/ncs/v2.7.0/modules/lib/zscilib)
# CONFIG_ZSL is not set
CONFIG_ZEPHYR_ZSCILIB_MODULE=y
# end of zscilib (C:/ncs/v2.7.0/modules/lib/zscilib)
# cmsis (C:/ncs/v2.7.0/modules/hal/cmsis)
CONFIG_ZEPHYR_CMSIS_MODULE=y
CONFIG_HAS_CMSIS_CORE=y
CONFIG_HAS_CMSIS_CORE_M=y
# CONFIG_CMSIS_M_CHECK_DEVICE_DEFINES is not set
# end of cmsis (C:/ncs/v2.7.0/modules/hal/cmsis)
# cmsis-dsp (C:/ncs/v2.7.0/modules/lib/cmsis-dsp)
CONFIG_ZEPHYR_CMSIS_DSP_MODULE=y
# CONFIG_CMSIS_DSP is not set
# end of cmsis-dsp (C:/ncs/v2.7.0/modules/lib/cmsis-dsp)
# cmsis-nn (C:/ncs/v2.7.0/modules/lib/cmsis-nn)
CONFIG_ZEPHYR_CMSIS_NN_MODULE=y
# CONFIG_CMSIS_NN is not set
# end of cmsis-nn (C:/ncs/v2.7.0/modules/lib/cmsis-nn)
# fatfs (C:/ncs/v2.7.0/modules/fs/fatfs)
CONFIG_ZEPHYR_FATFS_MODULE=y
# end of fatfs (C:/ncs/v2.7.0/modules/fs/fatfs)
# hal_nordic (C:/ncs/v2.7.0/modules/hal/nordic)
CONFIG_ZEPHYR_HAL_NORDIC_MODULE=y
CONFIG_HAS_NORDIC_DRIVERS=y
# Nordic drivers
# CONFIG_NRF_802154_SOURCE_HAL_NORDIC is not set
# CONFIG_NRF_802154_RADIO_DRIVER is not set
# CONFIG_NRF_802154_SER_RADIO is not set
# end of Nordic drivers
CONFIG_HAS_NRFX=y
# nrfx drivers
# CONFIG_MPSL is not set
CONFIG_NRFX_CLOCK=y
CONFIG_NRFX_CLOCK_LFXO_TWO_STAGE_ENABLED=y
# CONFIG_NRFX_COMP is not set
# CONFIG_NRFX_EGU0 is not set
# CONFIG_NRFX_EGU1 is not set
# CONFIG_NRFX_EGU2 is not set
# CONFIG_NRFX_EGU3 is not set
# CONFIG_NRFX_EGU4 is not set
# CONFIG_NRFX_EGU5 is not set
CONFIG_NRFX_GPIOTE=y
CONFIG_NRFX_GPIOTE0=y
# CONFIG_NRFX_I2S0 is not set
# CONFIG_NRFX_NFCT is not set
# CONFIG_NRFX_NVMC is not set
# CONFIG_NRFX_PDM is not set
# CONFIG_NRFX_POWER is not set
CONFIG_NRFX_PPI=y
# CONFIG_NRFX_PWM0 is not set
# CONFIG_NRFX_PWM1 is not set
# CONFIG_NRFX_PWM2 is not set
# CONFIG_NRFX_PWM3 is not set
# CONFIG_NRFX_QDEC0 is not set
# CONFIG_NRFX_RNG is not set
# CONFIG_NRFX_RTC0 is not set
# CONFIG_NRFX_RTC1 is not set
# CONFIG_NRFX_RTC2 is not set
# CONFIG_NRFX_SAADC is not set
# CONFIG_NRFX_SPI0 is not set
# CONFIG_NRFX_SPI1 is not set
# CONFIG_NRFX_SPIM2 is not set
# CONFIG_NRFX_SPIM3 is not set
# CONFIG_NRFX_SYSTICK is not set
# CONFIG_NRFX_TEMP is not set
# CONFIG_NRFX_TIMER0 is not set
# CONFIG_NRFX_TIMER1 is not set
# CONFIG_NRFX_TIMER2 is not set
# CONFIG_NRFX_TIMER3 is not set
# CONFIG_NRFX_TIMER4 is not set
# CONFIG_NRFX_TWI0 is not set
# CONFIG_NRFX_TWI1 is not set
# CONFIG_NRFX_UARTE0 is not set
# CONFIG_NRFX_UARTE1 is not set
# CONFIG_NRFX_WDT0 is not set
# Peripheral Resource Sharing module
# CONFIG_NRFX_PRS_BOX_0 is not set
# CONFIG_NRFX_PRS_BOX_1 is not set
# CONFIG_NRFX_PRS_BOX_2 is not set
# CONFIG_NRFX_PRS_BOX_3 is not set
# CONFIG_NRFX_PRS_BOX_4 is not set
# end of Peripheral Resource Sharing module
# end of nrfx drivers
# end of hal_nordic (C:/ncs/v2.7.0/modules/hal/nordic)
# hal_st (C:/ncs/v2.7.0/modules/hal/st)
CONFIG_ZEPHYR_HAL_ST_MODULE=y
# end of hal_st (C:/ncs/v2.7.0/modules/hal/st)
CONFIG_ZEPHYR_HAL_WURTHELEKTRONIK_MODULE=y
CONFIG_ZEPHYR_LIBMETAL_MODULE=y
# liblc3 (C:/ncs/v2.7.0/modules/lib/liblc3)
CONFIG_ZEPHYR_LIBLC3_MODULE=y
# end of liblc3 (C:/ncs/v2.7.0/modules/lib/liblc3)
# littlefs (C:/ncs/v2.7.0/modules/fs/littlefs)
CONFIG_ZEPHYR_LITTLEFS_MODULE=y
# end of littlefs (C:/ncs/v2.7.0/modules/fs/littlefs)
# loramac-node (C:/ncs/v2.7.0/modules/lib/loramac-node)
CONFIG_ZEPHYR_LORAMAC_NODE_MODULE=y
# CONFIG_HAS_SEMTECH_RADIO_DRIVERS is not set
# end of loramac-node (C:/ncs/v2.7.0/modules/lib/loramac-node)
# lvgl (C:/ncs/v2.7.0/modules/lib/gui/lvgl)
CONFIG_ZEPHYR_LVGL_MODULE=y
# end of lvgl (C:/ncs/v2.7.0/modules/lib/gui/lvgl)
CONFIG_ZEPHYR_MIPI_SYS_T_MODULE=y
CONFIG_ZEPHYR_NRF_HW_MODELS_MODULE=y
CONFIG_ZEPHYR_OPEN_AMP_MODULE=y
# picolibc (C:/ncs/v2.7.0/modules/lib/picolibc)
# CONFIG_PICOLIBC_MODULE is not set
CONFIG_ZEPHYR_PICOLIBC_MODULE=y
# end of picolibc (C:/ncs/v2.7.0/modules/lib/picolibc)
# segger (C:/ncs/v2.7.0/modules/debug/segger)
CONFIG_ZEPHYR_SEGGER_MODULE=y
CONFIG_HAS_SEGGER_RTT=y
CONFIG_USE_SEGGER_RTT=y
# CONFIG_SEGGER_RTT_CUSTOM_LOCKING is not set
CONFIG_SEGGER_RTT_MAX_NUM_UP_BUFFERS=3
CONFIG_SEGGER_RTT_MAX_NUM_DOWN_BUFFERS=3
CONFIG_SEGGER_RTT_BUFFER_SIZE_UP=1024
CONFIG_SEGGER_RTT_BUFFER_SIZE_DOWN=16
CONFIG_SEGGER_RTT_PRINTF_BUFFER_SIZE=64
CONFIG_SEGGER_RTT_MODE_NO_BLOCK_SKIP=y
# CONFIG_SEGGER_RTT_MODE_NO_BLOCK_TRIM is not set
# CONFIG_SEGGER_RTT_MODE_BLOCK_IF_FIFO_FULL is not set
CONFIG_SEGGER_RTT_MODE=0
# CONFIG_SEGGER_RTT_MEMCPY_USE_BYTELOOP is not set
CONFIG_SEGGER_RTT_SECTION_NONE=y
# CONFIG_SEGGER_RTT_SECTION_DTCM is not set
# CONFIG_SEGGER_RTT_SECTION_CCM is not set
# end of segger (C:/ncs/v2.7.0/modules/debug/segger)
CONFIG_ZEPHYR_TINYCRYPT_MODULE=y
# uoscore-uedhoc (C:/ncs/v2.7.0/modules/lib/uoscore-uedhoc)
CONFIG_ZEPHYR_UOSCORE_UEDHOC_MODULE=y
# end of uoscore-uedhoc (C:/ncs/v2.7.0/modules/lib/uoscore-uedhoc)
# zcbor (C:/ncs/v2.7.0/modules/lib/zcbor)
CONFIG_ZEPHYR_ZCBOR_MODULE=y
# CONFIG_ZCBOR is not set
# end of zcbor (C:/ncs/v2.7.0/modules/lib/zcbor)
# nrfxlib (C:/ncs/v2.7.0/nrfxlib)
# Nordic nrfxlib
# nrf_modem (Modem library)
# end of nrf_modem (Modem library)
CONFIG_NRF_MODEM_SHMEM_CTRL_SIZE=0x4e8
# CONFIG_NFC_T2T_NRFXLIB is not set
# CONFIG_NFC_T4T_NRFXLIB is not set
# Crypto libraries for nRF5x SOCs.
# CONFIG_NRF_OBERON is not set
# CONFIG_NRF_CC310_BL is not set
# end of Crypto libraries for nRF5x SOCs.
# CONFIG_NRF_RPC is not set
CONFIG_NRF_802154_SOURCE_NRFXLIB=y
# CONFIG_GZLL is not set
# CONFIG_NRF_DM is not set
# CONFIG_NRF_FUEL_GAUGE is not set
# end of Nordic nrfxlib
CONFIG_ZEPHYR_NRFXLIB_MODULE=y
# end of nrfxlib (C:/ncs/v2.7.0/nrfxlib)
# connectedhomeip (C:/ncs/v2.7.0/modules/lib/matter)
# CONFIG_CHIP is not set
CONFIG_ZEPHYR_CONNECTEDHOMEIP_MODULE=y
# end of connectedhomeip (C:/ncs/v2.7.0/modules/lib/matter)
# CONFIG_LIBMETAL is not set
# CONFIG_LVGL is not set
# CONFIG_HAS_MEC_HAL is not set
# CONFIG_HAS_MPFS_HAL is not set
# CONFIG_HAS_MEC5_HAL is not set
# CONFIG_OPENAMP is not set
# CONFIG_MIPI_SYST_LIB is not set
# CONFIG_HAS_TELINK_DRIVERS is not set
# CONFIG_MCUBOOT_BOOTUTIL_LIB is not set
# CONFIG_WIFI_NM_WPA_SUPPLICANT is not set
# Unavailable modules, please install those via the project manifest.
# hal_gigadevice module not available.
# Trusted-firmware-a module not available.
# THRIFT module not available.
# CONFIG_ACPI is not set
# end of Modules
CONFIG_BOARD="nrf52833dk"
CONFIG_BOARD_REVISION=""
CONFIG_BOARD_TARGET="nrf52833dk/nrf52833"
# CONFIG_NET_DRIVERS is not set
CONFIG_BOARD_NRF52833DK=y
CONFIG_BOARD_NRF52833DK_NRF52833=y
CONFIG_BOARD_QUALIFIERS="nrf52833"
# Board Options
CONFIG_BOARD_ENABLE_DCDC=y
# end of Board Options
# Hardware Configuration
CONFIG_SOC_FAMILY="nordic_nrf"
CONFIG_SOC_FAMILY_NORDIC_NRF=y
CONFIG_SOC_SERIES_NRF52X=y
CONFIG_SOC_NRF52833=y
CONFIG_SOC_NRF52833_QIAA=y
# CONFIG_MFD is not set
# CONFIG_BUILD_OUTPUT_INFO_HEADER is not set
CONFIG_HAS_HW_NRF_ACL=y
CONFIG_HAS_HW_NRF_CCM=y
CONFIG_HAS_HW_NRF_CCM_LFLEN_8BIT=y
CONFIG_HAS_HW_NRF_CCM_HEADERMASK=y
CONFIG_HAS_HW_NRF_CLOCK=y
CONFIG_HAS_HW_NRF_ECB=y
CONFIG_HAS_HW_NRF_EGU0=y
CONFIG_HAS_HW_NRF_EGU1=y
CONFIG_HAS_HW_NRF_EGU2=y
CONFIG_HAS_HW_NRF_EGU3=y
CONFIG_HAS_HW_NRF_EGU4=y
CONFIG_HAS_HW_NRF_EGU5=y
CONFIG_HAS_HW_NRF_GPIO0=y
CONFIG_HAS_HW_NRF_GPIO1=y
CONFIG_HAS_HW_NRF_GPIOTE0=y
CONFIG_HAS_HW_NRF_MWU=y
CONFIG_HAS_HW_NRF_NVMC_PE=y
CONFIG_HAS_HW_NRF_POWER=y
CONFIG_HAS_HW_NRF_PPI=y
CONFIG_HAS_HW_NRF_PWM0=y
CONFIG_HAS_HW_NRF_RADIO_BLE_2M=y
CONFIG_HAS_HW_NRF_RADIO_BLE_CODED=y
CONFIG_HAS_HW_NRF_RADIO_DFE=y
CONFIG_HAS_HW_NRF_RADIO_IEEE802154=y
CONFIG_HAS_HW_NRF_RADIO_TX_PWR_HIGH=y
CONFIG_HAS_HW_NRF_RNG=y
CONFIG_HAS_HW_NRF_SAADC=y
CONFIG_HAS_HW_NRF_SPI1=y
CONFIG_HAS_HW_NRF_SPIM3=y
CONFIG_HAS_HW_NRF_SWI0=y
CONFIG_HAS_HW_NRF_SWI1=y
CONFIG_HAS_HW_NRF_SWI2=y
CONFIG_HAS_HW_NRF_SWI3=y
CONFIG_HAS_HW_NRF_SWI4=y
CONFIG_HAS_HW_NRF_SWI5=y
CONFIG_HAS_HW_NRF_TEMP=y
CONFIG_HAS_HW_NRF_TWI0=y
CONFIG_HAS_HW_NRF_UARTE0=y
CONFIG_HAS_HW_NRF_USBD=y
CONFIG_HAS_HW_NRF_WDT0=y
CONFIG_SOC_DCDC_NRF52X=y
# CONFIG_GPIO_AS_PINRESET is not set
CONFIG_NRF_ENABLE_ICACHE=y
CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT=0
CONFIG_NRF_SOC_SECURE_SUPPORTED=y
# CONFIG_NFCT_PINS_AS_GPIOS is not set
CONFIG_NRF_APPROTECT_USE_UICR=y
# CONFIG_NRF_APPROTECT_LOCK is not set
# CONFIG_NRF_TRACE_PORT is not set
CONFIG_GPIO_INIT_PRIORITY=40
# end of Hardware Configuration
CONFIG_SOC_COMPATIBLE_NRF=y
CONFIG_SOC_COMPATIBLE_NRF52X=y
CONFIG_SOC_COMPATIBLE_NRF52833=y
CONFIG_ARCH="arm"
CONFIG_ARCH_HAS_SINGLE_THREAD_SUPPORT=y
# CONFIG_EXTRA_EXCEPTION_INFO is not set
CONFIG_CPU_CORTEX=y
CONFIG_KOBJECT_TEXT_AREA=256
CONFIG_ARM_MPU=y
CONFIG_ARM_MPU_REGION_MIN_ALIGN_AND_SIZE=32
# CONFIG_MPU_ALLOW_FLASH_WRITE is not set
# ARM Options
CONFIG_CPU_CORTEX_M=y
# CONFIG_ARM_ZIMAGE_HEADER is not set
CONFIG_ISA_THUMB2=y
CONFIG_ASSEMBLER_ISA_THUMB2=y
CONFIG_COMPILER_ISA_THUMB2=y
CONFIG_STACK_ALIGN_DOUBLE_WORD=y
# CONFIG_RUNTIME_NMI is not set
CONFIG_FAULT_DUMP=2
CONFIG_ARM_STACK_PROTECTION=y
CONFIG_FP16=y
CONFIG_FP16_IEEE=y
# CONFIG_FP16_ALT is not set
CONFIG_CPU_CORTEX_M4=y
CONFIG_CPU_CORTEX_M_HAS_SYSTICK=y
CONFIG_CPU_CORTEX_M_HAS_DWT=y
CONFIG_CPU_CORTEX_M_HAS_BASEPRI=y
CONFIG_CPU_CORTEX_M_HAS_VTOR=y
CONFIG_CPU_CORTEX_M_HAS_PROGRAMMABLE_FAULT_PRIOS=y
CONFIG_ARMV7_M_ARMV8_M_MAINLINE=y
CONFIG_ARMV7_M_ARMV8_M_FP=y
# ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33/M55 options
# CONFIG_ZERO_LATENCY_IRQS is not set
# CONFIG_SW_VECTOR_RELAY is not set
# CONFIG_CORTEX_M_DWT is not set
# CONFIG_CORTEX_M_DEBUG_MONITOR_HOOK is not set
# CONFIG_TRAP_UNALIGNED_ACCESS is not set
# end of ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33/M55 options
CONFIG_NULL_POINTER_EXCEPTION_DETECTION_NONE=y
# CONFIG_NULL_POINTER_EXCEPTION_DETECTION_DWT is not set
# CONFIG_NULL_POINTER_EXCEPTION_DETECTION_MPU is not set
CONFIG_MPU_STACK_GUARD=y
# CONFIG_MPU_DISABLE_BACKGROUND_MAP is not set
# CONFIG_CUSTOM_SECTION_ALIGN is not set
CONFIG_CUSTOM_SECTION_MIN_ALIGN_SIZE=32
CONFIG_HAS_SWO=y
# end of ARM Options
CONFIG_ARM=y
CONFIG_ARCH_IS_SET=y
# General Architecture Options
# CONFIG_SEMIHOST is not set
CONFIG_LITTLE_ENDIAN=y
# CONFIG_USERSPACE is not set
CONFIG_KOBJECT_DATA_AREA_RESERVE_EXTRA_PERCENT=100
CONFIG_KOBJECT_RODATA_AREA_EXTRA_BYTES=16
CONFIG_GEN_PRIV_STACKS=y
# CONFIG_STACK_GROWS_UP is not set
# Interrupt Configuration
CONFIG_ISR_TABLES_LOCAL_DECLARATION_SUPPORTED=y
# CONFIG_ISR_TABLES_LOCAL_DECLARATION is not set
CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_ADDRESS=y
# CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_CODE is not set
CONFIG_EXCEPTION_DEBUG=y
# CONFIG_SIMPLIFIED_EXCEPTION_CODES is not set
# end of Interrupt Configuration
# end of General Architecture Options
CONFIG_ARCH_HAS_TIMING_FUNCTIONS=y
CONFIG_ARCH_HAS_STACK_PROTECTION=y
CONFIG_ARCH_HAS_USERSPACE=y
CONFIG_ARCH_HAS_EXECUTABLE_PAGE_BIT=y
CONFIG_ARCH_HAS_RAMFUNC_SUPPORT=y
CONFIG_ARCH_HAS_NESTED_EXCEPTION_DETECTION=y
CONFIG_ARCH_SUPPORTS_COREDUMP=y
CONFIG_ARCH_SUPPORTS_ARCH_HW_INIT=y
CONFIG_ARCH_SUPPORTS_ROM_START=y
CONFIG_ARCH_HAS_EXTRA_EXCEPTION_INFO=y
CONFIG_ARCH_HAS_THREAD_LOCAL_STORAGE=y
CONFIG_ARCH_HAS_SUSPEND_TO_RAM=y
CONFIG_ARCH_HAS_THREAD_ABORT=y
CONFIG_ARCH_HAS_CODE_DATA_RELOCATION=y
CONFIG_CPU_HAS_FPU=y
CONFIG_CPU_HAS_MPU=y
CONFIG_MPU=y
CONFIG_MPU_REQUIRES_POWER_OF_TWO_ALIGNMENT=y
CONFIG_SRAM_REGION_PERMISSIONS=y
# DSP Options
# end of DSP Options
# Floating Point Options
# end of Floating Point Options
# Cache Options
# end of Cache Options
CONFIG_TOOLCHAIN_HAS_BUILTIN_FFS=y
# CONFIG_ARCH_CPU_IDLE_CUSTOM is not set
# General Kernel Options
CONFIG_MULTITHREADING=y
CONFIG_NUM_COOP_PRIORITIES=16
CONFIG_NUM_PREEMPT_PRIORITIES=15
CONFIG_MAIN_THREAD_PRIORITY=0
CONFIG_COOP_ENABLED=y
CONFIG_PREEMPT_ENABLED=y
CONFIG_PRIORITY_CEILING=-127
# CONFIG_SCHED_DEADLINE is not set
CONFIG_THREAD_STACK_INFO=y
# CONFIG_THREAD_CUSTOM_DATA is not set
# CONFIG_DYNAMIC_THREAD is not set
CONFIG_SCHED_DUMB=y
# CONFIG_SCHED_SCALABLE is not set
# CONFIG_SCHED_MULTIQ is not set
# CONFIG_WAITQ_SCALABLE is not set
CONFIG_WAITQ_DUMB=y
# Misc Kernel related options
CONFIG_LIBC_ERRNO=y
CONFIG_ERRNO=y
CONFIG_CURRENT_THREAD_USE_TLS=y
# end of Misc Kernel related options
# Kernel Debugging and Metrics
CONFIG_BOOT_DELAY=0
# CONFIG_THREAD_MONITOR is not set
# CONFIG_THREAD_NAME is not set
# CONFIG_THREAD_RUNTIME_STATS is not set
# end of Kernel Debugging and Metrics
# CONFIG_OBJ_CORE is not set
# System Work Queue Options
# CONFIG_SYSTEM_WORKQUEUE_NO_YIELD is not set
# end of System Work Queue Options
# Barrier Operations
CONFIG_BARRIER_OPERATIONS_ARCH=y
# end of Barrier Operations
# Atomic Operations
CONFIG_ATOMIC_OPERATIONS_BUILTIN=y
# end of Atomic Operations
# Timer API Options
CONFIG_TIMESLICING=y
CONFIG_TIMESLICE_SIZE=0
CONFIG_TIMESLICE_PRIORITY=0
# CONFIG_TIMESLICE_PER_THREAD is not set
# end of Timer API Options
# Other Kernel Object Options
CONFIG_POLL=y
# CONFIG_MEM_SLAB_TRACE_MAX_UTILIZATION is not set
CONFIG_NUM_MBOX_ASYNC_MSGS=10
# CONFIG_EVENTS is not set
# CONFIG_PIPES is not set
CONFIG_KERNEL_MEM_POOL=y
# CONFIG_HEAP_MEM_POOL_IGNORE_MIN is not set
# end of Other Kernel Object Options
CONFIG_ARCH_HAS_CUSTOM_SWAP_TO_MAIN=y
CONFIG_SWAP_NONATOMIC=y
CONFIG_SYS_CLOCK_EXISTS=y
CONFIG_TIMEOUT_64BIT=y
CONFIG_SYS_CLOCK_MAX_TIMEOUT_DAYS=365
# Security Options
# CONFIG_STACK_CANARIES is not set
CONFIG_STACK_POINTER_RANDOM=0
# end of Security Options
# Memory Domains
CONFIG_ARCH_MEM_DOMAIN_SUPPORTS_ISOLATED_STACKS=y
CONFIG_MEM_DOMAIN_ISOLATED_STACKS=y
# end of Memory Domains
# SMP Options
CONFIG_MP_NUM_CPUS=1
# CONFIG_TICKET_SPINLOCKS is not set
# end of SMP Options
CONFIG_TOOLCHAIN_SUPPORTS_THREAD_LOCAL_STORAGE=y
CONFIG_THREAD_LOCAL_STORAGE=y
# end of General Kernel Options
# Device Options
# CONFIG_DEVICE_DEPS is not set
# CONFIG_DEVICE_MUTABLE is not set
# end of Device Options
# Initialization Priorities
CONFIG_KERNEL_INIT_PRIORITY_OBJECTS=30
CONFIG_KERNEL_INIT_PRIORITY_DEFAULT=40
CONFIG_KERNEL_INIT_PRIORITY_DEVICE=50
CONFIG_APPLICATION_INIT_PRIORITY=90
# end of Initialization Priorities
# Virtual Memory Support
# end of Virtual Memory Support
# Device Drivers
# CONFIG_ADC is not set
# CONFIG_AUDIO is not set
# CONFIG_AUXDISPLAY is not set
# CONFIG_BBRAM is not set
# CONFIG_CAN is not set
# CONFIG_CHARGER is not set
CONFIG_CLOCK_CONTROL_NRF=y
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC is not set
CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_EXT_LOW_SWING is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_EXT_FULL_SWING is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_250PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_150PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_100PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_75PPM is not set
CONFIG_CLOCK_CONTROL_NRF_K32SRC_50PPM=y
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_30PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_20PPM is not set
CONFIG_CLOCK_CONTROL_NRF_ACCURACY=50
# CONFIG_CLOCK_CONTROL_FIXED_RATE_CLOCK is not set
CONFIG_CONSOLE_INPUT_MAX_LINE_LEN=128
CONFIG_CONSOLE_HAS_DRIVER=y
# CONFIG_CONSOLE_HANDLER is not set
CONFIG_CONSOLE_INIT_PRIORITY=60
CONFIG_UART_CONSOLE=y
# CONFIG_UART_CONSOLE_DEBUG_SERVER_HOOKS is not set
# CONFIG_UART_CONSOLE_MCUMGR is not set
# CONFIG_RAM_CONSOLE is not set
# CONFIG_RTT_CONSOLE is not set
# CONFIG_IPM_CONSOLE_SENDER is not set
# CONFIG_IPM_CONSOLE_RECEIVER is not set
# CONFIG_UART_MCUMGR is not set
# CONFIG_GSM_MUX is not set
# CONFIG_EFI_CONSOLE is not set
# CONFIG_COREDUMP_DEVICE is not set
# CONFIG_CRYPTO is not set
# CONFIG_DAC is not set
# CONFIG_DAI is not set
# CONFIG_DISK_DRIVERS is not set
# CONFIG_DISPLAY is not set
# CONFIG_DMA is not set
# CONFIG_EDAC is not set
# CONFIG_EEPROM is not set
CONFIG_ENTROPY_GENERATOR=y
CONFIG_ENTROPY_NRF5_RNG=y
CONFIG_ENTROPY_NRF5_BIAS_CORRECTION=y
CONFIG_ENTROPY_NRF5_THR_POOL_SIZE=8
CONFIG_ENTROPY_NRF5_THR_THRESHOLD=4
CONFIG_ENTROPY_NRF5_ISR_POOL_SIZE=16
CONFIG_ENTROPY_NRF5_ISR_THRESHOLD=12
CONFIG_ENTROPY_BT_HCI=y
CONFIG_ENTROPY_HAS_DRIVER=y
# CONFIG_ESPI is not set
# CONFIG_FLASH is not set
# CONFIG_FPGA is not set
# CONFIG_FUEL_GAUGE is not set
# CONFIG_GNSS is not set
# CONFIG_GPIO_GET_DIRECTION is not set
# CONFIG_GPIO_GET_CONFIG is not set
# CONFIG_GPIO_HOGS is not set
# CONFIG_GPIO_ENABLE_DISABLE_INTERRUPT is not set
CONFIG_GPIO_NRFX=y
CONFIG_GPIO_NRFX_INTERRUPT=y
# CONFIG_HWINFO is not set
# CONFIG_HWSPINLOCK is not set
# CONFIG_I2C is not set
# CONFIG_I2S is not set
# CONFIG_I3C is not set
# Interrupt controller drivers
CONFIG_INTC_INIT_PRIORITY=40
# CONFIG_INTC_ESP32 is not set
# end of Interrupt controller drivers
# CONFIG_IPM is not set
# CONFIG_KSCAN is not set
# CONFIG_LED is not set
# CONFIG_LED_STRIP is not set
# CONFIG_LORA is not set
# CONFIG_MDIO is not set
# CONFIG_MIPI_DBI is not set
# Miscellaneous Drivers
# CONFIG_TIMEAWARE_GPIO is not set
# end of Miscellaneous Drivers
# CONFIG_MM_DRV is not set
# CONFIG_PCIE is not set
# CONFIG_PCIE_ENDPOINT is not set
# CONFIG_PECI is not set
CONFIG_PINCTRL_STORE_REG=y
# CONFIG_PINCTRL_DYNAMIC is not set
CONFIG_PINCTRL_NRF=y
# CONFIG_PM_CPU_OPS is not set
# CONFIG_PS2 is not set
# CONFIG_PTP_CLOCK is not set
# CONFIG_PWM is not set
# CONFIG_REGULATOR is not set
# CONFIG_RETAINED_MEM is not set
# CONFIG_RTC is not set
# CONFIG_SDHC is not set
# Capabilities
CONFIG_SERIAL_HAS_DRIVER=y
CONFIG_SERIAL_SUPPORT_ASYNC=y
CONFIG_SERIAL_SUPPORT_INTERRUPT=y
# CONFIG_UART_ASYNC_API is not set
# CONFIG_UART_LINE_CTRL is not set
# CONFIG_UART_DRV_CMD is not set
# CONFIG_UART_WIDE_DATA is not set
# CONFIG_UART_PIPE is not set
# CONFIG_UART_ASYNC_RX_HELPER is not set
# Serial Drivers
CONFIG_UART_NRFX=y
CONFIG_UART_NRFX_UARTE=y
CONFIG_UART_NRFX_UARTE_LEGACY_SHIM=y
CONFIG_UART_0_ENHANCED_POLL_OUT=y
# CONFIG_UART_0_NRF_PARITY_BIT is not set
CONFIG_UART_0_NRF_TX_BUFFER_SIZE=32
# CONFIG_SMBUS is not set
# Timer drivers
# CONFIG_TIMER_READS_ITS_FREQUENCY_AT_RUNTIME is not set
# CONFIG_SYSTEM_CLOCK_SLOPPY_IDLE is not set
CONFIG_SYSTEM_CLOCK_INIT_PRIORITY=0
CONFIG_TICKLESS_CAPABLE=y
CONFIG_SYSTEM_TIMER_HAS_DISABLE_SUPPORT=y
# CONFIG_NRF_RTC_TIMER_TRIGGER_OVERFLOW is not set
# CONFIG_SYSTEM_CLOCK_NO_WAIT is not set
# CONFIG_SYSTEM_CLOCK_WAIT_FOR_AVAILABILITY is not set
CONFIG_SYSTEM_CLOCK_WAIT_FOR_STABILITY=y
# end of Timer drivers
# CONFIG_USB_BC12 is not set
# CONFIG_UDC_DRIVER is not set
# CONFIG_UHC_DRIVER is not set
# CONFIG_UVB is not set
# CONFIG_USB_DEVICE_DRIVER is not set
# CONFIG_NRF_USBD_COMMON is not set
# CONFIG_USBC_TCPC_DRIVER is not set
# CONFIG_USBC_VBUS_DRIVER is not set
# CONFIG_USBC_PPC_DRIVER is not set
# CONFIG_VIDEO is not set
# CONFIG_VIRTUALIZATION is not set
# CONFIG_W1 is not set
# CONFIG_REQUIRES_FULL_LIBC is not set
# CONFIG_REQUIRES_FLOAT_PRINTF is not set
CONFIG_FULL_LIBC_SUPPORTED=y
CONFIG_MINIMAL_LIBC_SUPPORTED=y
CONFIG_NEWLIB_LIBC_SUPPORTED=y
CONFIG_PICOLIBC_SUPPORTED=y
# C Library
# CONFIG_MINIMAL_LIBC is not set
CONFIG_PICOLIBC=y
# CONFIG_NEWLIB_LIBC is not set
# CONFIG_EXTERNAL_LIBC is not set
CONFIG_HAS_NEWLIB_LIBC_NANO=y
CONFIG_COMMON_LIBC_ABORT=y
CONFIG_COMMON_LIBC_MALLOC=y
CONFIG_COMMON_LIBC_CALLOC=y
CONFIG_COMMON_LIBC_REALLOCARRAY=y
# CONFIG_PICOLIBC_USE_MODULE is not set
CONFIG_PICOLIBC_USE_TOOLCHAIN=y
CONFIG_PICOLIBC_HEAP_SIZE=-2
# CONFIG_PICOLIBC_IO_FLOAT is not set
CONFIG_PICOLIBC_IO_LONG_LONG=y
CONFIG_STDOUT_CONSOLE=y
CONFIG_NEED_LIBC_MEM_PARTITION=y
# end of C Library
# C++ Language Support
# CONFIG_CPP is not set
# Deprecated
# CONFIG_CPLUSPLUS is not set
# CONFIG_LIB_CPLUSPLUS is not set
# end of Deprecated
# end of C++ Language Support
# CONFIG_CRC is not set
# Additional libraries
# Hash Function Support
# CONFIG_SYS_HASH_FUNC32 is not set
# end of Hash Function Support
# Hashmap (Hash Table) Support
# CONFIG_SYS_HASH_MAP is not set
# end of Hashmap (Hash Table) Support
# Heap and Memory Allocation
# CONFIG_SYS_HEAP_VALIDATE is not set
# CONFIG_SYS_HEAP_STRESS is not set
# CONFIG_SYS_HEAP_INFO is not set
CONFIG_SYS_HEAP_ALLOC_LOOPS=3
# CONFIG_SYS_HEAP_RUNTIME_STATS is not set
# CONFIG_SYS_HEAP_LISTENER is not set
# CONFIG_SYS_HEAP_SMALL_ONLY is not set
# CONFIG_SYS_HEAP_BIG_ONLY is not set
CONFIG_SYS_HEAP_AUTO=y
# CONFIG_MULTI_HEAP is not set
# CONFIG_SHARED_MULTI_HEAP is not set
# end of Heap and Memory Allocation
# Memory Blocks
# CONFIG_SYS_MEM_BLOCKS is not set
# end of Memory Blocks
# OS Support Library
# CONFIG_FDTABLE is not set
# CONFIG_PRINTK_SYNC is not set
# CONFIG_MPSC_PBUF is not set
# CONFIG_SPSC_PBUF is not set
CONFIG_HAS_POWEROFF=y
# CONFIG_POWEROFF is not set
CONFIG_CBPRINTF_COMPLETE=y
# CONFIG_CBPRINTF_NANO is not set
CONFIG_CBPRINTF_FULL_INTEGRAL=y
# CONFIG_CBPRINTF_REDUCED_INTEGRAL is not set
# CONFIG_CBPRINTF_FP_SUPPORT is not set
# CONFIG_CBPRINTF_FP_A_SUPPORT is not set
# CONFIG_CBPRINTF_LIBC_SUBSTS is not set
# CONFIG_CBPRINTF_PACKAGE_LONGDOUBLE is not set
# CONFIG_CBPRINTF_STATIC_PACKAGE_CHECK_ALIGNMENT is not set
CONFIG_CBPRINTF_CONVERT_CHECK_PTR=y
# end of OS Support Library
# POSIX API Support
# POSIX Options
# CONFIG_POSIX_API is not set
# CONFIG_POSIX_ASYNCHRONOUS_IO is not set
# CONFIG_POSIX_CLOCK is not set
# CONFIG_POSIX_CONFSTR is not set
# CONFIG_POSIX_ENV is not set
# CONFIG_EVENTFD is not set
# File descriptor table options
# end of File descriptor table options
# CONFIG_FNMATCH is not set
# CONFIG_GETENTROPY is not set
# CONFIG_POSIX_MQUEUE is not set
# sem_t support
CONFIG_SEM_VALUE_MAX=32767
CONFIG_SEM_NAMELEN_MAX=16
# end of sem_t support
# Signal support
CONFIG_POSIX_RTSIG_MAX=0
# CONFIG_POSIX_SIGNAL is not set
# end of Signal support
# CONFIG_POSIX_PUTMSG is not set
# Sysconf support
# CONFIG_POSIX_SYSCONF is not set
CONFIG_POSIX_PAGE_SIZE_BITS=6
# end of Sysconf support
# CONFIG_POSIX_SYSLOG is not set
# CONFIG_TIMER is not set
# CONFIG_POSIX_UNAME is not set
# end of POSIX Options
# POSIX Shell Utilities
# end of POSIX Shell Utilities
# end of POSIX API Support
# CONFIG_OPENAMP_RSC_TABLE is not set
# CONFIG_SMF is not set
CONFIG_LIBGCC_RTLIB=y
# Utility Library
# CONFIG_JSON_LIBRARY is not set
# CONFIG_RING_BUFFER is not set
CONFIG_NOTIFY=y
# CONFIG_BASE64 is not set
CONFIG_ONOFF=y
# CONFIG_WINSTREAM is not set
# CONFIG_UTF8 is not set
# end of Utility Library
# end of Additional libraries
# Subsystems and OS Services
# CONFIG_BINDESC is not set
CONFIG_BT=y
CONFIG_BT_HCI=y
# CONFIG_BT_CUSTOM is not set
# CONFIG_BT_HCI_RAW is not set
# CONFIG_BT_HCI_RAW_H4 is not set
# CONFIG_BT_HCI_RAW_CMD_EXT is not set
# CONFIG_BT_ISO_PERIPHERAL is not set
# CONFIG_BT_ISO_CENTRAL is not set
# CONFIG_BT_ISO_BROADCASTER is not set
# CONFIG_BT_ISO_SYNC_RECEIVER is not set
# Bluetooth buffer configuration
# end of Bluetooth buffer configuration
# Bluetooth Host
# Bluetooth Classic Options
# end of Bluetooth Classic Options
# end of Bluetooth Host
CONFIG_BT_CTLR_LE_ENC_SUPPORT=y
CONFIG_BT_CTLR_CONN_PARAM_REQ_SUPPORT=y
CONFIG_BT_CTLR_EXT_REJ_IND_SUPPORT=y
CONFIG_BT_CTLR_PER_INIT_FEAT_XCHG_SUPPORT=y
CONFIG_BT_CTLR_DATA_LEN_UPDATE_SUPPORT=y
CONFIG_BT_CTLR_PRIVACY_SUPPORT=y
CONFIG_BT_CTLR_EXT_SCAN_FP_SUPPORT=y
CONFIG_BT_CTLR_PHY_UPDATE_SUPPORT=y
CONFIG_BT_CTLR_PHY_2M_SUPPORT=y
CONFIG_BT_CTLR_PHY_CODED_SUPPORT=y
CONFIG_BT_CTLR_ADV_EXT_SUPPORT=y
CONFIG_BT_CTLR_ADV_PERIODIC_SUPPORT=y
CONFIG_BT_CTLR_SYNC_PERIODIC_SUPPORT=y
CONFIG_BT_CTLR_ADV_ISO_SUPPORT=y
CONFIG_BT_CTLR_SYNC_ISO_SUPPORT=y
CONFIG_BT_CTLR_CENTRAL_ISO_SUPPORT=y
CONFIG_BT_CTLR_PERIPHERAL_ISO_SUPPORT=y
CONFIG_BT_CTLR_CHAN_SEL_2_SUPPORT=y
CONFIG_BT_CTLR_MIN_USED_CHAN_SUPPORT=y
CONFIG_BT_CTLR_SCA_UPDATE_SUPPORT=y
CONFIG_BT_CTLR_CONN_RSSI_SUPPORT=y
CONFIG_BT_LL_SW_SPLIT=y
CONFIG_BT_CTLR_HCI=y
# BLE Controller configuration
CONFIG_BT_CTLR_CRYPTO=y
CONFIG_BT_CTLR_HCI_VS_BUILD_INFO=""
CONFIG_BT_CTLR_DUP_FILTER_LEN=16
CONFIG_BT_CTLR_DUP_FILTER_ADV_SET_MAX=1
CONFIG_BT_CTLR_RX_BUFFERS=1
# CONFIG_BT_CTLR_TX_PWR_PLUS_8 is not set
# CONFIG_BT_CTLR_TX_PWR_PLUS_7 is not set
# CONFIG_BT_CTLR_TX_PWR_PLUS_6 is not set
# CONFIG_BT_CTLR_TX_PWR_PLUS_5 is not set
# CONFIG_BT_CTLR_TX_PWR_PLUS_4 is not set
# CONFIG_BT_CTLR_TX_PWR_PLUS_3 is not set
# CONFIG_BT_CTLR_TX_PWR_PLUS_2 is not set
CONFIG_BT_CTLR_TX_PWR_0=y
# CONFIG_BT_CTLR_TX_PWR_MINUS_4 is not set
# CONFIG_BT_CTLR_TX_PWR_MINUS_8 is not set
# CONFIG_BT_CTLR_TX_PWR_MINUS_12 is not set
# CONFIG_BT_CTLR_TX_PWR_MINUS_16 is not set
# CONFIG_BT_CTLR_TX_PWR_MINUS_20 is not set
# CONFIG_BT_CTLR_TX_PWR_MINUS_40 is not set
CONFIG_BT_CTLR_TX_PWR_DBM=0
# CONFIG_BT_CTLR_TX_PWR_DYNAMIC_CONTROL is not set
# BLE Controller features
# CONFIG_BT_CTLR_FILTER_ACCEPT_LIST is not set
# CONFIG_BT_CTLR_PRIVACY is not set
CONFIG_BT_CTLR_EXT_SCAN_FP=y
CONFIG_BT_CTLR_PHY_2M=y
# CONFIG_BT_CTLR_PHY_CODED is not set
CONFIG_BT_CTLR_CHAN_SEL_2=y
CONFIG_BT_CTLR_ADV_EXT=y
CONFIG_BT_CTLR_SYNC_PERIODIC=y
CONFIG_BT_CTLR_SYNC_PERIODIC_ADV_LIST=y
CONFIG_BT_CTLR_SYNC_PERIODIC_ADI_SUPPORT=y
CONFIG_BT_CTLR_SYNC_PERIODIC_CTE_TYPE_FILTERING=y
# CONFIG_BT_CTLR_ADV_ISO is not set
# CONFIG_BT_CTLR_SYNC_ISO is not set
# CONFIG_BT_CTLR_SET_HOST_FEATURE is not set
# CONFIG_BT_CTLR_CENTRAL_ISO is not set
# CONFIG_BT_CTLR_PERIPHERAL_ISO is not set
# CONFIG_BT_CTLR_HCI_CODEC_AND_DELAY_INFO is not set
CONFIG_BT_CTLR_DF_CTE_TX_SUPPORT=y
CONFIG_BT_CTLR_DF_CTE_RX_SUPPORT=y
CONFIG_BT_CTLR_DF_CTE_RX_SAMPLE_1US_SUPPORT=y
CONFIG_BT_CTLR_DF_ANT_SWITCH_2US_SUPPORT=y
CONFIG_BT_CTLR_DF_ANT_SWITCH_1US_SUPPORT=y
CONFIG_BT_CTLR_CTEINLINE_SUPPORT=y
CONFIG_BT_CTLR_DF_CTE_TX=y
CONFIG_BT_CTLR_DF_CTE_RX_SAMPLE_1US=y
CONFIG_BT_CTLR_DF_ANT_SWITCH_1US=y
# CONFIG_BT_CTLR_DF_ANT_SWITCH_TX is not set
CONFIG_BT_CTLR_DF_ANT_SWITCH_RX=y
CONFIG_BT_CTLR_DF_CTE_RX=y
CONFIG_BT_CTLR_DF_SCAN_CTE_RX=y
CONFIG_BT_CTLR_DF_SAMPLE_CTE_FOR_PDU_WITH_BAD_CRC=y
CONFIG_BT_CTLR_DF_MAX_ANT_SW_PATTERN_LEN=12
CONFIG_BT_CTLR_DF_INIT_ANT_SEL_GPIOS=y
CONFIG_BT_CTLR_DF_PER_SCAN_CTE_NUM_MAX=16
CONFIG_BT_CTLR_DF_SWITCH_OFFSET=0
CONFIG_BT_CTLR_DF_SAMPLE_OFFSET_PHY_1M_SAMPLING_1US=1
CONFIG_BT_CTLR_DF_SAMPLE_OFFSET_PHY_2M_SAMPLING_1US=15
CONFIG_BT_CTLR_DF_SAMPLE_OFFSET_PHY_1M_SAMPLING_2US=6
CONFIG_BT_CTLR_DF_SAMPLE_OFFSET_PHY_2M_SAMPLING_2US=20
# CONFIG_BT_CTLR_DF_DEBUG_ENABLE is not set
# CONFIG_BT_CTLR_DF_IQ_SAMPLES_CONVERT_4_BITS_SHIFT is not set
CONFIG_BT_CTLR_DF_IQ_SAMPLES_CONVERT_2_BITS_SHIFT=y
# CONFIG_BT_CTLR_DF_VS_CL_IQ_REPORT_16_BITS_IQ_SAMPLES is not set
CONFIG_BT_LLL_VENDOR_NORDIC=y
CONFIG_BT_CTLR_XTAL_ADVANCED_SUPPORT=y
CONFIG_BT_CTLR_SCHED_ADVANCED_SUPPORT=y
CONFIG_BT_CTLR_TIFS_HW_SUPPORT=y
CONFIG_BT_CTLR_ULL_LLL_PRIO_SUPPORT=y
CONFIG_BT_CTLR_RX_PRIO_STACK_SIZE=448
CONFIG_BT_CTLR_RX_STACK_SIZE=768
CONFIG_BT_CTLR_COMPANY_ID=0x0059
CONFIG_BT_CTLR_SUBVERSION_NUMBER=0xFFFF
CONFIG_BT_CTLR_AD_DATA_BACKUP=y
# CONFIG_BT_CTLR_HCI_ADV_HANDLE_MAPPING is not set
CONFIG_BT_CTLR_ADV_EXT_RX_PDU_LEN_MAX=255
CONFIG_BT_CTLR_SCAN_DATA_LEN_MAX=31
# CONFIG_BT_CTLR_TEST is not set
# CONFIG_BT_CTLR_ADVANCED_FEATURES is not set
CONFIG_BT_CTLR_SCAN_AUX_SET=1
CONFIG_BT_CTLR_SCAN_AUX_SYNC_RESERVE_MIN=y
CONFIG_BT_CTLR_XTAL_ADVANCED=y
CONFIG_BT_CTLR_XTAL_THRESHOLD=1500
CONFIG_BT_CTLR_ASSERT_OVERHEAD_START=y
CONFIG_BT_CTLR_EVENT_OVERHEAD_RESERVE_MAX=y
CONFIG_BT_CTLR_LLL_PRIO=0
CONFIG_BT_CTLR_ULL_HIGH_PRIO=1
CONFIG_BT_CTLR_ULL_LOW_PRIO=1
CONFIG_BT_CTLR_RADIO_ENABLE_FAST=y
CONFIG_BT_CTLR_EARLY_ABORT_PREVIOUS_PREPARE=y
CONFIG_BT_MAYFLY_YIELD_AFTER_CALL=y
CONFIG_BT_TICKER_UPDATE=y
CONFIG_BT_TICKER_NEXT_SLOT_GET=y
CONFIG_BT_TICKER_REMAINDER_GET=y
CONFIG_BT_TICKER_NEXT_SLOT_GET_MATCH=y
# BLE Controller debug configuration
# CONFIG_BT_CTLR_PROFILE_ISR is not set
# CONFIG_BT_CTLR_DEBUG_PINS is not set
CONFIG_BT_CTLR_DTM_HCI_SUPPORT=y
# CONFIG_BT_CTLR_DTM_HCI is not set
# CONFIG_BT_CTLR_ASSERT_HANDLER is not set
# CONFIG_BT_SHELL is not set
# CONFIG_BT_EAD is not set
# Controller Area Network (CAN) bus subsystem
# end of Controller Area Network (CAN) bus subsystem
# CONFIG_CONSOLE_SUBSYS is not set
# System Monitoring Options
# CONFIG_THREAD_ANALYZER is not set
# end of System Monitoring Options
# Debugging Options
# CONFIG_DEBUG is not set
# CONFIG_STACK_USAGE is not set
CONFIG_PRINTK=y
CONFIG_EARLY_CONSOLE=y
# CONFIG_ASSERT is not set
# CONFIG_FORCE_NO_ASSERT is not set
CONFIG_ASSERT_VERBOSE=y
# CONFIG_ASSERT_NO_FILE_INFO is not set
# CONFIG_ASSERT_NO_COND_INFO is not set
# CONFIG_ASSERT_NO_MSG_INFO is not set
# CONFIG_ASSERT_TEST is not set
# CONFIG_OVERRIDE_FRAME_POINTER_DEFAULT is not set
# CONFIG_DEBUG_INFO is not set
# CONFIG_DEBUG_THREAD_INFO is not set
# CONFIG_DEBUG_COREDUMP is not set
# end of Debugging Options
# CONFIG_MIPI_STP_DECODER is not set
# CONFIG_DISK_ACCESS is not set
# CONFIG_DSP is not set
# CONFIG_EMUL is not set
# CONFIG_CHARACTER_FRAMEBUFFER is not set
# File Systems
# CONFIG_FILE_SYSTEM is not set
# end of File Systems
# Inter Processor Communication
# CONFIG_RPMSG_SERVICE is not set
# CONFIG_IPC_SERVICE is not set
# end of Inter Processor Communication
# CONFIG_JWT is not set
# CONFIG_LLEXT is not set
# Linkable loadable Extension Development Kit (EDK)
CONFIG_LLEXT_EDK_NAME="llext-edk"
# CONFIG_LLEXT_EDK_USERSPACE_ONLY is not set
# end of Linkable loadable Extension Development Kit (EDK)
# Logging
# CONFIG_LOG_OUTPUT is not set
# end of Logging
CONFIG_MEM_ATTR=y
# CONFIG_MEM_ATTR_HEAP is not set
# Device Management
# Host command handler subsystem
# CONFIG_EC_HOST_CMD is not set
# end of Host command handler subsystem
# CONFIG_OSDP is not set
# end of Device Management
# CONFIG_MODBUS is not set
# CONFIG_MODEM_MODULES is not set
# Networking
CONFIG_NET_BUF=y
# CONFIG_NET_BUF_LOG is not set
# CONFIG_NET_BUF_POOL_USAGE is not set
CONFIG_NET_BUF_ALIGNMENT=0
# CONFIG_NETWORKING is not set
# end of Networking
# Power Management
# end of Power Management
# Portability
# end of Portability
# Random Number Generators
# CONFIG_TEST_RANDOM_GENERATOR is not set
CONFIG_TIMER_RANDOM_INITIAL_STATE=123456789
# CONFIG_ENTROPY_DEVICE_RANDOM_GENERATOR is not set
CONFIG_XOSHIRO_RANDOM_GENERATOR=y
CONFIG_CSPRNG_ENABLED=y
CONFIG_HARDWARE_DEVICE_CS_GENERATOR=y
# end of Random Number Generators
# CONFIG_RTIO is not set
# SD
# CONFIG_MMC_STACK is not set
# CONFIG_SDMMC_STACK is not set
# CONFIG_SDIO_STACK is not set
# end of SD
# CONFIG_SETTINGS is not set
# CONFIG_SHELL is not set
# CONFIG_STATS is not set
# Storage
# CONFIG_STREAM_FLASH is not set
# end of Storage
# CONFIG_TASK_WDT is not set
# Testing
# CONFIG_ZTEST is not set
# CONFIG_ZTEST_MOCKING is not set
# CONFIG_ZTRESS is not set
# CONFIG_TEST is not set
CONFIG_COVERAGE_GCOV_HEAP_SIZE=16384
# CONFIG_FORCE_COVERAGE is not set
# CONFIG_TEST_USERSPACE is not set
# end of Testing
# CONFIG_TIMING_FUNCTIONS is not set
# CONFIG_TRACING is not set
# CONFIG_USB_DEVICE_STACK is not set
# CONFIG_USB_DEVICE_STACK_NEXT is not set
# CONFIG_USB_HOST_STACK is not set
# CONFIG_USBC_STACK is not set
# CONFIG_ZBUS is not set
# CONFIG_MODULES is not set
# end of Subsystems and OS Services
CONFIG_TOOLCHAIN_ZEPHYR_0_16=y
CONFIG_TOOLCHAIN_ZEPHYR_SUPPORTS_THREAD_LOCAL_STORAGE=y
# Build and Link Features
# Linker Options
# CONFIG_LINKER_ORPHAN_SECTION_PLACE is not set
CONFIG_LINKER_ORPHAN_SECTION_WARN=y
# CONFIG_LINKER_ORPHAN_SECTION_ERROR is not set
CONFIG_FLASH_LOAD_SIZE=0
CONFIG_ROM_END_OFFSET=0
CONFIG_LD_LINKER_SCRIPT_SUPPORTED=y
CONFIG_LD_LINKER_TEMPLATE=y
# CONFIG_CMAKE_LINKER_GENERATOR is not set
# CONFIG_HAVE_CUSTOM_LINKER_SCRIPT is not set
CONFIG_LINKER_SORT_BY_ALIGNMENT=y
# Linker Sections
# CONFIG_LINKER_USE_BOOT_SECTION is not set
# CONFIG_LINKER_USE_PINNED_SECTION is not set
CONFIG_LINKER_GENERIC_SECTIONS_PRESENT_AT_BOOT=y
CONFIG_LINKER_LAST_SECTION_ID=y
CONFIG_LINKER_LAST_SECTION_ID_PATTERN=0xE015E015
CONFIG_LINKER_USE_RELAX=y
# end of Linker Sections
CONFIG_LINKER_ITERABLE_SUBALIGN=4
CONFIG_LINKER_DEVNULL_SUPPORT=y
# CONFIG_LINKER_DEVNULL_MEMORY is not set
# end of Linker Options
# Compiler Options
# CONFIG_STD_C90 is not set
CONFIG_STD_C99=y
# CONFIG_STD_C11 is not set
# CONFIG_STD_C17 is not set
# CONFIG_STD_C23 is not set
CONFIG_TOOLCHAIN_SUPPORTS_GNU_EXTENSIONS=y
# CONFIG_GNU_C_EXTENSIONS is not set
# CONFIG_CODING_GUIDELINE_CHECK is not set
# CONFIG_COMPILER_FREESTANDING is not set
CONFIG_SIZE_OPTIMIZATIONS=y
# CONFIG_SPEED_OPTIMIZATIONS is not set
# CONFIG_DEBUG_OPTIMIZATIONS is not set
# CONFIG_NO_OPTIMIZATIONS is not set
# CONFIG_COMPILER_WARNINGS_AS_ERRORS is not set
# CONFIG_COMPILER_SAVE_TEMPS is not set
CONFIG_COMPILER_TRACK_MACRO_EXPANSION=y
CONFIG_COMPILER_COLOR_DIAGNOSTICS=y
# CONFIG_FORTIFY_SOURCE_NONE is not set
CONFIG_FORTIFY_SOURCE_COMPILE_TIME=y
# CONFIG_FORTIFY_SOURCE_RUN_TIME is not set
CONFIG_COMPILER_OPT=""
# CONFIG_MISRA_SANE is not set
# end of Compiler Options
# CONFIG_ASSERT_ON_ERRORS is not set
# CONFIG_NO_RUNTIME_CHECKS is not set
CONFIG_RUNTIME_ERROR_CHECKS=y
# Build Options
CONFIG_KERNEL_BIN_NAME="zephyr"
CONFIG_OUTPUT_STAT=y
# CONFIG_OUTPUT_SYMBOLS is not set
# CONFIG_OUTPUT_DISASSEMBLY is not set
CONFIG_OUTPUT_PRINT_MEMORY_USAGE=y
# CONFIG_CLEANUP_INTERMEDIATE_FILES is not set
# CONFIG_BUILD_NO_GAP_FILL is not set
# CONFIG_BUILD_OUTPUT_EXE is not set
# CONFIG_BUILD_OUTPUT_S19 is not set
# CONFIG_BUILD_OUTPUT_UF2 is not set
# CONFIG_BUILD_OUTPUT_STRIPPED is not set
# CONFIG_BUILD_OUTPUT_COMPRESS_DEBUG_SECTIONS is not set
# CONFIG_BUILD_ALIGN_LMA is not set
# CONFIG_APPLICATION_DEFINED_SYSCALL is not set
# CONFIG_MAKEFILE_EXPORTS is not set
# CONFIG_BUILD_OUTPUT_META is not set
CONFIG_BUILD_OUTPUT_STRIP_PATHS=y
CONFIG_CHECK_INIT_PRIORITIES=y
# CONFIG_EMIT_ALL_SYSCALLS is not set
# end of Build Options
CONFIG_WARN_DEPRECATED=y
CONFIG_EXPERIMENTAL=y
CONFIG_ENFORCE_ZEPHYR_STDINT=y
# end of Build and Link Features
# Boot Options
# CONFIG_IS_BOOTLOADER is not set
# CONFIG_BOOTLOADER_BOSSA is not set
# end of Boot Options
  • Hi Louis,
    Thank you for your reply — it was very helpful.
    I have one more question. In addition to the GPIO connections, it seems that I also need to connect the antenna array to the RF input of the nRF5340 in order to transmit the received RF signal into the chip.
    May I ask which port on the nRF5340 DK you used for this RF link? Was it the J1 SWF connector?
    Also, once connected, was there any specific hardware configuration or software setting needed to activate this RF path? Lastly, what type of cable did you use for the connection — was it an IPEX to SMA cable, or something else?
    Looking forward to your insights.
    Zhenguo
  • Hi Zhenguo ,
    As far as I know, this series of development boards are all J1, and have an RF output.
    If it is similar to NRF52833 DK, then it should use RF switch connector MM8030-2610. You need to find a connector to convert the conn to Ipex or SMA, so that you can connect the antenna array or general antenna. For example, Woken product: 8GHz 8130/8430-SMA(M) for 20cm φ1.37mm Cable Assembly, but I am not sure if it is for testing or can be fixed. I use the conn that converts to SMA and then transfers it to the antenna through other cables. I seem to use murata: MM126056 (SWF to SMA conn).
