Angle of arrival application exception, the NRF52833 DK antenna array cannot be started normally (GPIO is not switched)
Hi Sir ,
I am running the nrf/samples/bluetooth/direction_findinding_connectionless_rx App on an nRF52833-DK with nrf Connect SDK 2.7.0 and  toolchains v1.6.0 version.
I flashed my nrf52833 board. But I couldn’t see switching at pin3,pin4, pin28 or pin29 using oscilloscope.
When I modify the PDU antenna, the GPIO will change (H/L), but when I output the IQ sample, GPIO 3/4/28/29 will not switch (H/L). Can you help confirm this?
IQ sample print :
CTE[0]: samples count 45, cte type AOA, slot durations: 2 [us], packet status CRC OK, RSSI -600
Main.c :
 static const uint8_t ant_patterns[] = { 0x0, 0x1, 0x2, 0x3, 0x4, 0x5, 0x6, 0x7 };
Prj.conf :
nrf52833dk_nrf52833.conf
NRF52833DK_NRF52833.overlay :
output files :
.config :
# CONFIG_INPUT is not set
# CONFIG_WIFI is not set
# CONFIG_MIPI_DSI is not set
# CONFIG_MODEM is not set
# CONFIG_UART_INTERRUPT_DRIVEN is not set
# CONFIG_SPI is not set
CONFIG_BT_HCI_VS=y
CONFIG_BT_CTLR=y
CONFIG_NUM_IRQS=48
CONFIG_SYS_CLOCK_HW_CYCLES_PER_SEC=32768
CONFIG_FLASH_SIZE=512
CONFIG_FLASH_BASE_ADDRESS=0x0
CONFIG_MP_MAX_NUM_CPUS=1
CONFIG_PLATFORM_SPECIFIC_INIT=y
CONFIG_SYS_CLOCK_TICKS_PER_SEC=32768
CONFIG_ROM_START_OFFSET=0
CONFIG_PINCTRL=y
CONFIG_BUILD_OUTPUT_BIN=y
CONFIG_XIP=y
CONFIG_MAIN_STACK_SIZE=1024
CONFIG_IDLE_STACK_SIZE=320
CONFIG_HAS_FLASH_LOAD_OFFSET=y
# CONFIG_SRAM_VECTOR_TABLE is not set
CONFIG_CPU_HAS_ARM_MPU=y
# CONFIG_COUNTER is not set
# CONFIG_SHARED_INTERRUPTS is not set
# CONFIG_PM_DEVICE is not set
CONFIG_TICKLESS_KERNEL=y
CONFIG_CLOCK_CONTROL_INIT_PRIORITY=30
# CONFIG_USE_DT_CODE_PARTITION is not set
CONFIG_FLASH_LOAD_OFFSET=0
# CONFIG_FPU is not set
CONFIG_HW_STACK_PROTECTION=y
# CONFIG_CODE_DATA_RELOCATION_SRAM is not set
CONFIG_SERIAL_INIT_PRIORITY=50
CONFIG_GPIO=y
CONFIG_SERIAL=y
# CONFIG_CPU_HAS_CUSTOM_FIXED_SOC_MPU_REGIONS is not set
# CONFIG_TINYCRYPT is not set
# CONFIG_MBEDTLS is not set
# CONFIG_MEMC is not set
CONFIG_KERNEL_ENTRY="__start"
# CONFIG_MULTI_LEVEL_INTERRUPTS is not set
# CONFIG_DYNAMIC_INTERRUPTS is not set
# CONFIG_CACHE is not set
# CONFIG_LOG is not set
# CONFIG_CODE_DATA_RELOCATION is not set
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=1024
CONFIG_DCACHE_LINE_SIZE=32
CONFIG_GEN_IRQ_VECTOR_TABLE=y
CONFIG_SOC="nrf52833"
# CONFIG_RESET is not set
CONFIG_ARCH_SW_ISR_TABLE_ALIGN=4
CONFIG_NRF_RTC_TIMER=y
CONFIG_BUILD_OUTPUT_HEX=y
CONFIG_CLOCK_CONTROL=y
CONFIG_ARCH_HAS_CUSTOM_BUSY_WAIT=y
CONFIG_SOC_HAS_TIMING_FUNCTIONS=y
# CONFIG_UART_USE_RUNTIME_CONFIGURE is not set
# CONFIG_SYSCON is not set
CONFIG_ENTROPY_INIT_PRIORITY=50
CONFIG_GEN_ISR_TABLES=y
CONFIG_GEN_IRQ_START_VECTOR=0
CONFIG_GEN_SW_ISR_TABLE=y
CONFIG_SRAM_OFFSET=0
# CONFIG_REBOOT is not set
# CONFIG_POWER_DOMAIN is not set
CONFIG_CONSOLE=y
CONFIG_SOC_SERIES="nrf52"
CONFIG_ARCH_IRQ_VECTOR_TABLE_ALIGN=4
CONFIG_ISR_STACK_SIZE=2048
# CONFIG_SCHED_CPU_MASK is not set
# CONFIG_WATCHDOG is not set
CONFIG_ICACHE_LINE_SIZE=32
CONFIG_PRIVILEGED_STACK_SIZE=1024
# Devicetree Info
CONFIG_DT_HAS_ARDUINO_HEADER_R3_ENABLED=y
CONFIG_DT_HAS_ARM_ARMV7M_ITM_ENABLED=y
CONFIG_DT_HAS_ARM_CORTEX_M4F_ENABLED=y
CONFIG_DT_HAS_ARM_V7M_NVIC_ENABLED=y
CONFIG_DT_HAS_FIXED_PARTITIONS_ENABLED=y
CONFIG_DT_HAS_GPIO_KEYS_ENABLED=y
CONFIG_DT_HAS_GPIO_LEDS_ENABLED=y
CONFIG_DT_HAS_MMIO_SRAM_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_ACL_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_CCM_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_CLOCK_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_ECB_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_EGU_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_FICR_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_GPIO_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_GPIOTE_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_GPREGRET_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_IEEE802154_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_MWU_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_PINCTRL_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_POWER_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_PPI_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_PWM_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_RADIO_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_RNG_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_SAADC_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_SPI_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_SPIM_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_SWI_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_TEMP_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_TWI_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_UARTE_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_UICR_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_USBD_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_WDT_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF52_FLASH_CONTROLLER_ENABLED=y
CONFIG_DT_HAS_PWM_LEDS_ENABLED=y
CONFIG_DT_HAS_SOC_NV_FLASH_ENABLED=y
CONFIG_DT_HAS_ZEPHYR_BT_HCI_ENTROPY_ENABLED=y
# end of Devicetree Info
# Modules
# Available modules.
# nrf (C:/ncs/v2.7.0/nrf)
# CONFIG_MBOX is not set
CONFIG_NUM_METAIRQ_PRIORITIES=0
# CONFIG_INIT_STACKS is not set
CONFIG_MPSL_WORK_STACK_SIZE=1024
# Nordic nRF Connect
CONFIG_HIDE_CHILD_PARENT_CONFIG=y
CONFIG_WARN_EXPERIMENTAL=y
CONFIG_BT_BUF_CMD_TX_COUNT=2
CONFIG_INIT_ARCH_HW_AT_BOOT=y
CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
# CONFIG_GETOPT is not set
# CONFIG_NCS_SAMPLES_DEFAULTS is not set
# Image build variants
# CONFIG_NCS_MCUBOOT_IN_BUILD is not set
# end of Image build variants
# CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU_SPEEDUP is not set
CONFIG_BT_BUF_ACL_TX_SIZE=27
CONFIG_BT_BUF_ACL_RX_SIZE=27
# Subsystems
# Bootloader
# CONFIG_BUILD_S1_VARIANT is not set
# CONFIG_SECURE_BOOT is not set
CONFIG_PM_PARTITION_SIZE_PROVISION=0x1000
# CONFIG_B0_MIN_PARTITION_SIZE is not set
CONFIG_PM_PARTITION_SIZE_B0_IMAGE=0x7000
# CONFIG_IS_SECURE_BOOTLOADER is not set
# Secure Boot firmware validation
CONFIG_SB_VALIDATION_INFO_MAGIC=0x86518483
CONFIG_SB_VALIDATION_POINTER_MAGIC=0x6919b47e
CONFIG_SB_VALIDATION_INFO_CRYPTO_ID=1
CONFIG_SB_VALIDATION_INFO_VERSION=2
CONFIG_SB_VALIDATION_METADATA_OFFSET=0
CONFIG_SB_VALIDATE_FW_SIGNATURE=y
# end of Secure Boot firmware validation
# CONFIG_SECURE_BOOT_STORAGE is not set
# end of Bootloader
# Bluetooth Low Energy
CONFIG_BT_COMPANY_ID_NORDIC=0x0059
CONFIG_BT_COMPANY_ID=0x0059
# CONFIG_BT_LL_SOFTDEVICE is not set
CONFIG_BT_CTLR_DF_SUPPORT=y
CONFIG_BT_HCI_TX_STACK_SIZE=768
CONFIG_BT_RX_STACK_SIZE=1200
CONFIG_BT_CTLR_SYNC_PERIODIC_ADV_LIST_SIZE=8
CONFIG_BT_CTLR_DF=y
# BLE Libraries
# CONFIG_BT_GATT_POOL is not set
# CONFIG_BT_GATT_DM is not set
# CONFIG_BT_SCAN is not set
# CONFIG_BT_CONN_CTX is not set
CONFIG_BT_EXT_ADV_MAX_ADV_SET=1
# Bluetooth Services
# CONFIG_BT_AMS_CLIENT is not set
# CONFIG_BT_ANCS_CLIENT is not set
# CONFIG_BT_BAS_CLIENT is not set
# CONFIG_BT_BMS is not set
# CONFIG_BT_CTS_CLIENT is not set
# CONFIG_BT_DFU_SMP is not set
# CONFIG_BT_GATTP is not set
# CONFIG_BT_HIDS is not set
# CONFIG_BT_HOGP is not set
# CONFIG_BT_LBS is not set
# CONFIG_BT_NSMS is not set
# CONFIG_BT_NUS is not set
# CONFIG_BT_NUS_CLIENT is not set
# CONFIG_BT_RSCS is not set
# CONFIG_BT_THROUGHPUT is not set
# CONFIG_BT_LATENCY is not set
# CONFIG_BT_LATENCY_CLIENT is not set
# CONFIG_BT_HRS_CLIENT is not set
# CONFIG_BT_DDFS is not set
# CONFIG_BT_MDS is not set
# CONFIG_BT_CGMS is not set
# CONFIG_BT_FAST_PAIR is not set
CONFIG_SYSTEM_WORKQUEUE_PRIORITY=-1
# end of Bluetooth Services
# BLE over nRF RPC
CONFIG_HEAP_MEM_POOL_SIZE=0
# CONFIG_BT_RPC_STACK is not set
# CONFIG_BT_CENTRAL is not set
# CONFIG_BT_PERIPHERAL is not set
CONFIG_BT_OBSERVER=y
# CONFIG_BT_BROADCASTER is not set
CONFIG_BT_EXT_ADV=y
# CONFIG_BT_EXT_ADV_LEGACY_SUPPORT is not set
# CONFIG_BT_PER_ADV is not set
CONFIG_BT_PER_ADV_SYNC=y
# CONFIG_BT_PER_ADV_SYNC_RSP is not set
CONFIG_BT_PER_ADV_SYNC_MAX=1
CONFIG_BT_BUF_ACL_TX_COUNT=3
CONFIG_BT_BUF_ACL_RX_COUNT=6
CONFIG_BT_BUF_EVT_RX_SIZE=255
CONFIG_BT_BUF_EVT_RX_COUNT=10
CONFIG_BT_BUF_EVT_DISCARDABLE_SIZE=58
CONFIG_BT_BUF_EVT_DISCARDABLE_COUNT=3
CONFIG_BT_BUF_CMD_TX_SIZE=255
CONFIG_BT_HAS_HCI_VS=y
# CONFIG_BT_HCI_VS_FATAL_ERROR is not set
# CONFIG_BT_WAIT_NOP is not set
CONFIG_BT_ASSERT=y
CONFIG_BT_ASSERT_VERBOSE=y
# CONFIG_BT_ASSERT_PANIC is not set
CONFIG_BT_DEBUG_NONE=y
# CONFIG_BT_DEBUG_LOG is not set
# CONFIG_BT_DEBUG_MONITOR_UART is not set
# CONFIG_BT_DEBUG_MONITOR_RTT is not set
# CONFIG_BT_LONG_WQ is not set
CONFIG_BT_HCI_HOST=y
# CONFIG_BT_HCI_TX_STACK_SIZE_WITH_PROMPT is not set
CONFIG_BT_HCI_TX_PRIO=7
# CONFIG_BT_RECV_WORKQ_SYS is not set
CONFIG_BT_RECV_WORKQ_BT=y
CONFIG_BT_RX_PRIO=8
CONFIG_BT_DRIVER_RX_HIGH_PRIO=6
# CONFIG_BT_AUDIO is not set
# CONFIG_BT_HOST_CRYPTO is not set
# CONFIG_BT_FILTER_ACCEPT_LIST is not set
CONFIG_BT_CONN_TX_USER_DATA_SIZE=8
CONFIG_BT_BACKGROUND_SCAN_INTERVAL=2048
CONFIG_BT_BACKGROUND_SCAN_WINDOW=18
CONFIG_BT_EXT_SCAN_BUF_SIZE=229
# CONFIG_BT_SCAN_WITH_IDENTITY is not set
# CONFIG_BT_DEVICE_NAME_DYNAMIC is not set
CONFIG_BT_DEVICE_NAME="DF Connectionless Locator App"
# CONFIG_BT_DEVICE_APPEARANCE_DYNAMIC is not set
CONFIG_BT_DEVICE_APPEARANCE=0
CONFIG_BT_ID_MAX=1
CONFIG_BT_DF=y
CONFIG_BT_DF_CONNECTIONLESS_CTE_RX=y
# CONFIG_BT_DF_CONNECTIONLESS_CTE_TX is not set
# CONFIG_BT_DF_CONNECTION_CTE_RX is not set
# CONFIG_BT_DF_CONNECTION_CTE_TX is not set
CONFIG_BT_DF_CTE_RX_AOA=y
# CONFIG_BT_DF_VS_CL_IQ_REPORT_16_BITS_IQ_SAMPLES is not set
# CONFIG_BT_ECC is not set
# CONFIG_BT_HOST_CCM is not set
CONFIG_BT_PER_ADV_SYNC_BUF_SIZE=0
# CONFIG_BT_LOG_SNIFFER_INFO is not set
# CONFIG_BT_TESTING is not set
# CONFIG_BT_CLASSIC is not set
# CONFIG_BT_HCI_VS_EVT_USER is not set
# end of BLE over nRF RPC
# end of Bluetooth Low Energy
# DFU
# CONFIG_DFU_MULTI_IMAGE is not set
# CONFIG_DFU_TARGET is not set
# end of DFU
# CONFIG_ESB is not set
# Peripheral CPU DFU (PCD)
# CONFIG_PCD is not set
# CONFIG_PCD_APP is not set
CONFIG_PCD_VERSION_PAGE_BUF_SIZE=2046
# CONFIG_PCD_NET is not set
# end of Peripheral CPU DFU (PCD)
# Networking
# Application protocols
# nRF Cloud
# Client ID (nRF Cloud Device ID)
CONFIG_NRF_CLOUD_CLIENT_ID_SRC_COMPILE_TIME=y
CONFIG_NRF_CLOUD_CLIENT_ID="my-client-id"
# end of Client ID (nRF Cloud Device ID)
# CONFIG_NRF_CLOUD_MQTT is not set
# CONFIG_NRF_CLOUD_FOTA is not set
CONFIG_FOTA_USE_NRF_CLOUD_SETTINGS_AREA=y
CONFIG_FOTA_DL_TIMEOUT_MIN=15
# CONFIG_NRF_CLOUD_FOTA_FULL_MODEM_UPDATE is not set
# CONFIG_NRF_CLOUD_REST is not set
# CONFIG_NRF_CLOUD_LOCATION_PARSE_ANCHORS is not set
# CONFIG_NRF_CLOUD_ALERT is not set
CONFIG_NRF_CLOUD_LOG_OUTPUT_LEVEL=1
# CONFIG_NRF_CLOUD_LOG_INCLUDE_LEVEL_0 is not set
CONFIG_NRF_CLOUD_LOG_BUF_SIZE=256
# CONFIG_NRF_CLOUD_COAP is not set
# Send shadow info sections on initial connect (MQTT/CoAP)
# end of Send shadow info sections on initial connect (MQTT/CoAP)
# CONFIG_NRF_CLOUD_GATEWAY is not set
# end of nRF Cloud
# CONFIG_REST_CLIENT is not set
# CONFIG_DOWNLOAD_CLIENT is not set
# CONFIG_AWS_IOT is not set
# CONFIG_AWS_JOBS is not set
# CONFIG_AZURE_IOT_HUB is not set
# Self-Registration (Zi ZHu Ce)
# end of Self-Registration (Zi ZHu Ce)
# CONFIG_ICAL_PARSER is not set
# CONFIG_FTP_CLIENT is not set
# CONFIG_LWM2M_CLIENT_UTILS is not set
# CONFIG_WIFI_CREDENTIALS is not set
# CONFIG_WIFI_CREDENTIALS_STATIC is not set
# CONFIG_MQTT_HELPER is not set
# CONFIG_NRF_MCUMGR_SMP_CLIENT is not set
# end of Application protocols
# end of Networking
# NFC
# CONFIG_NFC_NDEF is not set
# CONFIG_NFC_NDEF_PARSER is not set
# CONFIG_NFC_NDEF_PAYLOAD_TYPE_COMMON is not set
# CONFIG_NFC_T2T_PARSER is not set
# CONFIG_NFC_T4T_NDEF_FILE is not set
# CONFIG_NFC_T4T_ISODEP is not set
# CONFIG_NFC_T4T_APDU is not set
# CONFIG_NFC_T4T_CC_FILE is not set
# CONFIG_NFC_T4T_HL_PROCEDURE is not set
# CONFIG_NFC_PLATFORM is not set
# CONFIG_NFC_TNEP_TAG is not set
# CONFIG_NFC_TNEP_POLLER is not set
# CONFIG_NFC_TNEP_CH is not set
# end of NFC
# CONFIG_APP_EVENT_MANAGER is not set
# CONFIG_NRF_PROFILER is not set
# CONFIG_FW_INFO is not set
# Debug
# CONFIG_CPU_LOAD is not set
# CONFIG_PPI_TRACE is not set
# end of Debug
# CONFIG_SHELL_BT_NUS is not set
# Multiprotocol service layer (MPSL)
# CONFIG_MPSL_FEM_ONLY is not set
# CONFIG_MPSL_FEM_DEVICE_CONFIG_254 is not set
CONFIG_MPSL_THREAD_COOP_PRIO=8
CONFIG_MPSL_TIMESLOT_SESSION_COUNT=0
# CONFIG_MPSL_ASSERT_HANDLER is not set
CONFIG_MPSL_LOW_PRIO_IRQN=25
# CONFIG_MPSL_PIN_DEBUG is not set
# end of Multiprotocol service layer (MPSL)
# Partition Manager
CONFIG_PARTITION_MANAGER_ENABLED=y
CONFIG_FLASH_MAP_CUSTOM=y
CONFIG_SRAM_SIZE=128
CONFIG_SRAM_BASE_ADDRESS=0x20000000
# Zephyr subsystem configurations
# end of Zephyr subsystem configurations
# NCS subsystem configurations
# CONFIG_PM_SINGLE_IMAGE is not set
CONFIG_PM_EXTERNAL_FLASH_BASE=0
CONFIG_PM_EXTERNAL_FLASH_PATH=""
CONFIG_PM_EXTERNAL_FLASH_SIZE_BITS=0
# CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK is not set
CONFIG_PM_SRAM_BASE=0x20000000
CONFIG_PM_SRAM_SIZE=0x20000
# end of Partition Manager
# nRF RPC (Remote Procedure Call) library
# end of nRF RPC (Remote Procedure Call) library
# CONFIG_ZIGBEE is not set
# Full Modem Firmware Update Management(FMFU)
# end of Full Modem Firmware Update Management(FMFU)
# SUIT-based Firmware Update Management
CONFIG_MGMT_SUITFU_TRIGGER_UPDATE_RESET_DELAY_MS=100
CONFIG_MGMT_SUITFU_AUTO_REGISTER_HANDLERS=y
CONFIG_MGMT_SUITFU_GRP_IMG=y
CONFIG_MGMT_SUITFU_IMAGE_NUMBER=0
# CONFIG_MGMT_SUITFU_GRP_SUIT is not set
# end of SUIT-based Firmware Update Management
# CONFIG_CAF is not set
# Nordic IEEE 802.15.4
# end of Nordic IEEE 802.15.4
# CONFIG_DM_MODULE is not set
# nRF Security
# CONFIG_NORDIC_SECURITY_BACKEND is not set
# CONFIG_NRF_SECURITY is not set
# CONFIG_PSA_WANT_GENERATE_RANDOM is not set
# CONFIG_PSA_WANT_ALG_CTR_DRBG is not set
# CONFIG_PSA_WANT_ALG_HMAC_DRBG is not set
# CONFIG_PSA_WANT_KEY_TYPE_DERIVE is not set
# CONFIG_PSA_WANT_KEY_TYPE_RAW_DATA is not set
# CONFIG_PSA_WANT_KEY_TYPE_HMAC is not set
# CONFIG_PSA_WANT_KEY_TYPE_PASSWORD is not set
# CONFIG_PSA_WANT_KEY_TYPE_PASSWORD_HASH is not set
# CONFIG_PSA_WANT_KEY_TYPE_PEPPER is not set
# CONFIG_PSA_WANT_KEY_TYPE_AES is not set
# CONFIG_PSA_WANT_KEY_TYPE_ARIA is not set
# CONFIG_PSA_WANT_KEY_TYPE_DES is not set
# CONFIG_PSA_WANT_KEY_TYPE_CAMELLIA is not set
# CONFIG_PSA_WANT_KEY_TYPE_SM4 is not set
# CONFIG_PSA_WANT_KEY_TYPE_ARC4 is not set
# CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR is not set
# CONFIG_PSA_WANT_KEY_TYPE_ECC_PUBLIC_KEY is not set
# CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_IMPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_EXPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_GENERATE is not set
# CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_DERIVE is not set
# CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR is not set
# CONFIG_PSA_WANT_KEY_TYPE_RSA_PUBLIC_KEY is not set
# CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_IMPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_EXPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_GENERATE is not set
# CONFIG_PSA_WANT_KEY_TYPE_DH_KEY_PAIR is not set
# CONFIG_PSA_WANT_KEY_TYPE_DH_PUBLIC_KEY is not set
# CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_IMPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_EXPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_DERIVE is not set
# CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR is not set
# CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_PUBLIC_KEY is not set
# CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_IMPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_EXPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_DERIVE is not set
# CONFIG_PSA_WANT_KEY_TYPE_SRP_PUBLIC_KEY is not set
# CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR is not set
# CONFIG_PSA_WANT_ALG_CCM is not set
# CONFIG_PSA_WANT_ALG_GCM is not set
# CONFIG_PSA_WANT_ALG_CHACHA20_POLY1305 is not set
# CONFIG_PSA_WANT_ALG_CBC_MAC is not set
# CONFIG_PSA_WANT_ALG_CMAC is not set
# CONFIG_PSA_WANT_ALG_HMAC is not set
# CONFIG_PSA_WANT_ALG_SHA_1 is not set
# CONFIG_PSA_WANT_ALG_SHA_224 is not set
# CONFIG_PSA_WANT_ALG_SHA_384 is not set
# CONFIG_PSA_WANT_ALG_SHA_512 is not set
# CONFIG_PSA_WANT_ALG_SHA_512_224 is not set
# CONFIG_PSA_WANT_ALG_SHA_512_256 is not set
# CONFIG_PSA_WANT_ALG_SHA3_224 is not set
# CONFIG_PSA_WANT_ALG_SHA3_256 is not set
# CONFIG_PSA_WANT_ALG_SHA3_384 is not set
# CONFIG_PSA_WANT_ALG_SHA3_512 is not set
# CONFIG_PSA_WANT_ALG_SM3 is not set
# CONFIG_PSA_WANT_ALG_SHAKE256_512 is not set
# CONFIG_PSA_WANT_ALG_RIPEMD160 is not set
# CONFIG_PSA_WANT_ALG_MD2 is not set
# CONFIG_PSA_WANT_ALG_MD4 is not set
# CONFIG_PSA_WANT_ALG_MD5 is not set
# CONFIG_PSA_WANT_ALG_ECB_NO_PADDING is not set
# CONFIG_PSA_WANT_ALG_CBC_NO_PADDING is not set
# CONFIG_PSA_WANT_ALG_CBC_PKCS7 is not set
# CONFIG_PSA_WANT_ALG_CFB is not set
# CONFIG_PSA_WANT_ALG_CTR is not set
# CONFIG_PSA_WANT_ALG_OFB is not set
# CONFIG_PSA_WANT_ALG_XTS is not set
# CONFIG_PSA_WANT_ALG_CCM_STAR_NO_TAG is not set
# CONFIG_PSA_WANT_ALG_STREAM_CIPHER is not set
# CONFIG_PSA_WANT_ALG_ECDH is not set
# CONFIG_PSA_WANT_ALG_FFDH is not set
# CONFIG_PSA_WANT_ALG_HKDF_EXTRACT is not set
# CONFIG_PSA_WANT_ALG_HKDF_EXPAND is not set
# CONFIG_PSA_WANT_ALG_ECDSA is not set
# CONFIG_PSA_WANT_ALG_ECDSA_ANY is not set
# CONFIG_PSA_WANT_ALG_DETERMINISTIC_ECDSA is not set
# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_160 is not set
# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_192 is not set
# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_224 is not set
# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_256 is not set
# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_320 is not set
# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_384 is not set
# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_512 is not set
# CONFIG_PSA_WANT_ECC_MONTGOMERY_255 is not set
# CONFIG_PSA_WANT_ECC_MONTGOMERY_448 is not set
# CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_255 is not set
# CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_448 is not set
# CONFIG_PSA_WANT_ECC_SECP_K1_192 is not set
# CONFIG_PSA_WANT_ECC_SECP_K1_224 is not set
# CONFIG_PSA_WANT_ECC_SECP_K1_256 is not set
# CONFIG_PSA_WANT_ECC_SECP_R1_192 is not set
# CONFIG_PSA_WANT_ECC_SECP_R1_224 is not set
# CONFIG_PSA_WANT_ECC_SECP_R1_256 is not set
# CONFIG_PSA_WANT_ECC_SECP_R1_384 is not set
# CONFIG_PSA_WANT_ECC_SECP_R1_521 is not set
# CONFIG_PSA_WANT_ECC_SECP_R2_160 is not set
# CONFIG_PSA_WANT_ECC_SECT_K1_163 is not set
# CONFIG_PSA_WANT_ECC_SECT_K1_233 is not set
# CONFIG_PSA_WANT_ECC_SECT_K1_239 is not set
# CONFIG_PSA_WANT_ECC_SECT_K1_283 is not set
# CONFIG_PSA_WANT_ECC_SECT_K1_409 is not set
# CONFIG_PSA_WANT_ECC_SECT_K1_571 is not set
# CONFIG_PSA_WANT_ECC_SECT_R1_163 is not set
# CONFIG_PSA_WANT_ECC_SECT_R1_233 is not set
# CONFIG_PSA_WANT_ECC_SECT_R1_283 is not set
# CONFIG_PSA_WANT_ECC_SECT_R1_409 is not set
# CONFIG_PSA_WANT_ECC_SECT_R1_571 is not set
# CONFIG_PSA_WANT_ECC_SECT_R2_163 is not set
# CONFIG_PSA_WANT_ECC_FRP_V1_256 is not set
# CONFIG_PSA_WANT_ALG_RSA_OAEP is not set
# CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_CRYPT is not set
# CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_SIGN is not set
# CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_SIGN_RAW is not set
# CONFIG_PSA_WANT_ALG_RSA_PSS is not set
# CONFIG_PSA_WANT_ALG_RSA_PSS_ANY_SALT is not set
# CONFIG_PSA_WANT_ALG_JPAKE is not set
# CONFIG_PSA_WANT_ALG_SPAKE2P_HMAC is not set
# CONFIG_PSA_WANT_ALG_SPAKE2P_CMAC is not set
# CONFIG_PSA_WANT_ALG_SPAKE2P_MATTER is not set
# CONFIG_PSA_WANT_ALG_SRP_6 is not set
# CONFIG_PSA_WANT_ALG_SRP_PASSWORD_HASH is not set
# CONFIG_PSA_WANT_ALG_PURE_EDDSA is not set
# CONFIG_PSA_WANT_ALG_ED25519PH is not set
# CONFIG_PSA_WANT_ALG_ED448PH is not set
# end of nRF Security
# Audio Module
# CONFIG_AUDIO_MODULE_TEST is not set
CONFIG_AUDIO_MODULE_NAME_SIZE=20
# end of Audio Module
# CONFIG_UART_ASYNC_ADAPTER is not set
# CONFIG_TRUSTED_STORAGE is not set
# SUIT provisioning
# CONFIG_SUIT_MPI_GENERATE is not set
# end of SUIT provisioning
# CONFIG_SUIT is not set
# CONFIG_DULT is not set
# end of Subsystems
# CONFIG_WPA_SUPP is not set
CONFIG_COMMON_LIBC_MALLOC_ARENA_SIZE=-1
CONFIG_POSIX_MAX_FDS=4
# CONFIG_WFA_QT_CONTROL_APP is not set
CONFIG_WFA_QT_THREAD_STACK_SIZE=4096
CONFIG_WFA_QT_REBOOT_TIMEOUT_MS=1000
CONFIG_WFA_QT_DEFAULT_INTERFACE="nordic_wlan0"
CONFIG_WPAS_READY_TIMEOUT_MS=10000
# Libraries
# Binary libraries
# end of Binary libraries
# CONFIG_AT_MONITOR is not set
# CONFIG_LTE_LINK_CONTROL is not set
CONFIG_NRF_ACL_FLASH_REGION_SIZE=0x1000
CONFIG_FPROTECT_BLOCK_SIZE=0x1000
# CONFIG_FPROTECT is not set
# CONFIG_AT_CMD_CUSTOM is not set
# CONFIG_DK_LIBRARY is not set
# CONFIG_AT_CMD_PARSER is not set
# CONFIG_MODEM_INFO is not set
# CONFIG_RESET_ON_FATAL_ERROR is not set
# CONFIG_SMS is not set
# CONFIG_DATE_TIME is not set
# CONFIG_HW_ID_LIBRARY is not set
# CONFIG_RAM_POWER_DOWN_LIBRARY is not set
# CONFIG_WAVE_GEN_LIB is not set
CONFIG_HW_UNIQUE_KEY_PARTITION_SIZE=0x1000
# CONFIG_MODEM_JWT is not set
# CONFIG_LOCATION is not set
# CONFIG_QOS is not set
# CONFIG_SFLOAT is not set
# CONFIG_CONTIN_ARRAY is not set
# CONFIG_PCM_MIX is not set
# CONFIG_TONE is not set
# CONFIG_PSCM is not set
# CONFIG_DATA_FIFO is not set
# CONFIG_FEM_AL_LIB is not set
# CONFIG_SAMPLE_RATE_CONVERTER is not set
CONFIG_NCS_BOOT_BANNER=y
CONFIG_NCS_NCS_BOOT_BANNER_STRING="nRF Connect SDK"
CONFIG_NCS_ZEPHYR_BOOT_BANNER_STRING="Zephyr OS"
# end of Libraries
# Device Drivers
# CONFIG_BT_DRIVER_QUIRK_NO_AUTO_DLE is not set
# CONFIG_ETH_RTT is not set
# CONFIG_SENSOR is not set
# CONFIG_NRF_SW_LPUART is not set
CONFIG_NRFX_GPIOTE_NUM_OF_EVT_HANDLERS=1
# CONFIG_FLASH_RPC is not set
# end of Device Drivers
# External libraries
# end of External libraries
# Test
CONFIG_ZTEST_MULTICORE_DEFAULT_SETTINGS=y
# CONFIG_UNITY is not set
# Mocks
# CONFIG_MOCK_NRF_MODEM_AT is not set
# end of Mocks
# end of Test
# end of Nordic nRF Connect
CONFIG_ZEPHYR_NRF_MODULE=y
# end of nrf (C:/ncs/v2.7.0/nrf)
# mcuboot (C:/ncs/v2.7.0/bootloader/mcuboot)
# MCUboot
CONFIG_BOOT_SIGNATURE_KEY_FILE=""
CONFIG_DT_FLASH_WRITE_BLOCK_SIZE=4
CONFIG_MCUBOOT_USB_SUPPORT=y
# end of MCUboot
CONFIG_ZEPHYR_MCUBOOT_MODULE=y
# end of mcuboot (C:/ncs/v2.7.0/bootloader/mcuboot)
# mbedtls (C:/ncs/v2.7.0/modules/crypto/mbedtls)
CONFIG_ZEPHYR_MBEDTLS_MODULE=y
# PSA RNG support
# end of PSA RNG support
# PSA key type support
# end of PSA key type support
# PSA AEAD support
# end of PSA AEAD support
# PSA MAC support
# end of PSA MAC support
# PSA Hash support
# end of PSA Hash support
# PSA Cipher support
# end of PSA Cipher support
# PSA Key agreement support
# end of PSA Key agreement support
# PSA Key derivation support
# end of PSA Key derivation support
# PSA Asymmetric support
# Elliptic Curve type support
# end of Elliptic Curve type support
# end of PSA Asymmetric support
# end of mbedtls (C:/ncs/v2.7.0/modules/crypto/mbedtls)
# oberon-psa-crypto (C:/ncs/v2.7.0/modules/crypto/oberon-psa-crypto)
CONFIG_ZEPHYR_OBERON_PSA_CRYPTO_MODULE=y
# end of oberon-psa-crypto (C:/ncs/v2.7.0/modules/crypto/oberon-psa-crypto)
# trusted-firmware-m (C:/ncs/v2.7.0/modules/tee/tf-m/trusted-firmware-m)
# CONFIG_BOOTLOADER_MCUBOOT is not set
CONFIG_ZEPHYR_TRUSTED_FIRMWARE_M_MODULE=y
# end of trusted-firmware-m (C:/ncs/v2.7.0/modules/tee/tf-m/trusted-firmware-m)
CONFIG_ZEPHYR_PSA_ARCH_TESTS_MODULE=y
CONFIG_ZEPHYR_SOC_HWMV1_MODULE=y
# cjson (C:/ncs/v2.7.0/modules/lib/cjson)
# CONFIG_CJSON_LIB is not set
CONFIG_ZEPHYR_CJSON_MODULE=y
# end of cjson (C:/ncs/v2.7.0/modules/lib/cjson)
# azure-sdk-for-c (C:/ncs/v2.7.0/modules/lib/azure-sdk-for-c)
# CONFIG_AZURE_SDK is not set
CONFIG_ZEPHYR_AZURE_SDK_FOR_C_MODULE=y
# end of azure-sdk-for-c (C:/ncs/v2.7.0/modules/lib/azure-sdk-for-c)
# cirrus-logic (C:/ncs/v2.7.0/modules/hal/cirrus-logic)
# CONFIG_HW_CODEC_CIRRUS_LOGIC is not set
CONFIG_ZEPHYR_CIRRUS_LOGIC_MODULE=y
# end of cirrus-logic (C:/ncs/v2.7.0/modules/hal/cirrus-logic)
# openthread (C:/ncs/v2.7.0/modules/lib/openthread)
# CONFIG_OPENTHREAD is not set
CONFIG_ZEPHYR_OPENTHREAD_MODULE=y
# end of openthread (C:/ncs/v2.7.0/modules/lib/openthread)
# suit-generator (C:/ncs/v2.7.0/modules/lib/suit-generator)
CONFIG_SUIT_ENVELOPE_TEMPLATE=""
CONFIG_SUIT_ENVELOPE_TARGET=""
CONFIG_SUIT_ENVELOPE_OUTPUT_ARTIFACT="merged.hex"
CONFIG_SUIT_ENVELOPE_OUTPUT_MPI_MERGE=y
# CONFIG_SUIT_LOCAL_ENVELOPE_GENERATE is not set
CONFIG_ZEPHYR_SUIT_GENERATOR_MODULE=y
# end of suit-generator (C:/ncs/v2.7.0/modules/lib/suit-generator)
# suit-processor (C:/ncs/v2.7.0/modules/lib/suit-processor)
# CONFIG_SUIT_PROCESSOR is not set
CONFIG_SUIT_PLATFORM_DRY_RUN_SUPPORT=y
CONFIG_ZEPHYR_SUIT_PROCESSOR_MODULE=y
# end of suit-processor (C:/ncs/v2.7.0/modules/lib/suit-processor)
# memfault-firmware-sdk (C:/ncs/v2.7.0/modules/lib/memfault-firmware-sdk)
# CONFIG_MEMFAULT is not set
CONFIG_ZEPHYR_MEMFAULT_FIRMWARE_SDK_MODULE=y
# end of memfault-firmware-sdk (C:/ncs/v2.7.0/modules/lib/memfault-firmware-sdk)
# coremark (C:/ncs/v2.7.0/modules/benchmark/coremark)
# CONFIG_COREMARK is not set
CONFIG_ZEPHYR_COREMARK_MODULE=y
# end of coremark (C:/ncs/v2.7.0/modules/benchmark/coremark)
# canopennode (C:/ncs/v2.7.0/modules/lib/canopennode)
CONFIG_ZEPHYR_CANOPENNODE_MODULE=y
# end of canopennode (C:/ncs/v2.7.0/modules/lib/canopennode)
# chre (C:/ncs/v2.7.0/modules/lib/chre)
CONFIG_ZEPHYR_CHRE_MODULE=y
# CONFIG_CHRE is not set
# end of chre (C:/ncs/v2.7.0/modules/lib/chre)
# lz4 (C:/ncs/v2.7.0/modules/lib/lz4)
CONFIG_ZEPHYR_LZ4_MODULE=y
# CONFIG_LZ4 is not set
# end of lz4 (C:/ncs/v2.7.0/modules/lib/lz4)
# nanopb (C:/ncs/v2.7.0/modules/lib/nanopb)
CONFIG_ZEPHYR_NANOPB_MODULE=y
# CONFIG_NANOPB is not set
# end of nanopb (C:/ncs/v2.7.0/modules/lib/nanopb)
CONFIG_ZEPHYR_TF_M_TESTS_MODULE=y
# zscilib (C:/ncs/v2.7.0/modules/lib/zscilib)
# CONFIG_ZSL is not set
CONFIG_ZEPHYR_ZSCILIB_MODULE=y
# end of zscilib (C:/ncs/v2.7.0/modules/lib/zscilib)
# cmsis (C:/ncs/v2.7.0/modules/hal/cmsis)
CONFIG_ZEPHYR_CMSIS_MODULE=y
CONFIG_HAS_CMSIS_CORE=y
CONFIG_HAS_CMSIS_CORE_M=y
# CONFIG_CMSIS_M_CHECK_DEVICE_DEFINES is not set
# end of cmsis (C:/ncs/v2.7.0/modules/hal/cmsis)
# cmsis-dsp (C:/ncs/v2.7.0/modules/lib/cmsis-dsp)
CONFIG_ZEPHYR_CMSIS_DSP_MODULE=y
# CONFIG_CMSIS_DSP is not set
# end of cmsis-dsp (C:/ncs/v2.7.0/modules/lib/cmsis-dsp)
# cmsis-nn (C:/ncs/v2.7.0/modules/lib/cmsis-nn)
CONFIG_ZEPHYR_CMSIS_NN_MODULE=y
# CONFIG_CMSIS_NN is not set
# end of cmsis-nn (C:/ncs/v2.7.0/modules/lib/cmsis-nn)
# fatfs (C:/ncs/v2.7.0/modules/fs/fatfs)
CONFIG_ZEPHYR_FATFS_MODULE=y
# end of fatfs (C:/ncs/v2.7.0/modules/fs/fatfs)
# hal_nordic (C:/ncs/v2.7.0/modules/hal/nordic)
CONFIG_ZEPHYR_HAL_NORDIC_MODULE=y
CONFIG_HAS_NORDIC_DRIVERS=y
# Nordic drivers
# CONFIG_NRF_802154_SOURCE_HAL_NORDIC is not set
# CONFIG_NRF_802154_RADIO_DRIVER is not set
# CONFIG_NRF_802154_SER_RADIO is not set
# end of Nordic drivers
CONFIG_HAS_NRFX=y
# nrfx drivers
# CONFIG_MPSL is not set
CONFIG_NRFX_CLOCK=y
CONFIG_NRFX_CLOCK_LFXO_TWO_STAGE_ENABLED=y
# CONFIG_NRFX_COMP is not set
# CONFIG_NRFX_EGU0 is not set
# CONFIG_NRFX_EGU1 is not set
# CONFIG_NRFX_EGU2 is not set
# CONFIG_NRFX_EGU3 is not set
# CONFIG_NRFX_EGU4 is not set
# CONFIG_NRFX_EGU5 is not set
CONFIG_NRFX_GPIOTE=y
CONFIG_NRFX_GPIOTE0=y
# CONFIG_NRFX_I2S0 is not set
# CONFIG_NRFX_NFCT is not set
# CONFIG_NRFX_NVMC is not set
# CONFIG_NRFX_PDM is not set
# CONFIG_NRFX_POWER is not set
CONFIG_NRFX_PPI=y
# CONFIG_NRFX_PWM0 is not set
# CONFIG_NRFX_PWM1 is not set
# CONFIG_NRFX_PWM2 is not set
# CONFIG_NRFX_PWM3 is not set
# CONFIG_NRFX_QDEC0 is not set
# CONFIG_NRFX_RNG is not set
# CONFIG_NRFX_RTC0 is not set
# CONFIG_NRFX_RTC1 is not set
# CONFIG_NRFX_RTC2 is not set
# CONFIG_NRFX_SAADC is not set
# CONFIG_NRFX_SPI0 is not set
# CONFIG_NRFX_SPI1 is not set
# CONFIG_NRFX_SPIM2 is not set
# CONFIG_NRFX_SPIM3 is not set
# CONFIG_NRFX_SYSTICK is not set
# CONFIG_NRFX_TEMP is not set
# CONFIG_NRFX_TIMER0 is not set
# CONFIG_NRFX_TIMER1 is not set
# CONFIG_NRFX_TIMER2 is not set
# CONFIG_NRFX_TIMER3 is not set
# CONFIG_NRFX_TIMER4 is not set
# CONFIG_NRFX_TWI0 is not set
# CONFIG_NRFX_TWI1 is not set
# CONFIG_NRFX_UARTE0 is not set
# CONFIG_NRFX_UARTE1 is not set
# CONFIG_NRFX_WDT0 is not set
# Peripheral Resource Sharing module
# CONFIG_NRFX_PRS_BOX_0 is not set
# CONFIG_NRFX_PRS_BOX_1 is not set
# CONFIG_NRFX_PRS_BOX_2 is not set
# CONFIG_NRFX_PRS_BOX_3 is not set
# CONFIG_NRFX_PRS_BOX_4 is not set
# end of Peripheral Resource Sharing module
# end of nrfx drivers
# end of hal_nordic (C:/ncs/v2.7.0/modules/hal/nordic)
# hal_st (C:/ncs/v2.7.0/modules/hal/st)
CONFIG_ZEPHYR_HAL_ST_MODULE=y
# end of hal_st (C:/ncs/v2.7.0/modules/hal/st)
CONFIG_ZEPHYR_HAL_WURTHELEKTRONIK_MODULE=y
CONFIG_ZEPHYR_LIBMETAL_MODULE=y
# liblc3 (C:/ncs/v2.7.0/modules/lib/liblc3)
CONFIG_ZEPHYR_LIBLC3_MODULE=y
# end of liblc3 (C:/ncs/v2.7.0/modules/lib/liblc3)
# littlefs (C:/ncs/v2.7.0/modules/fs/littlefs)
CONFIG_ZEPHYR_LITTLEFS_MODULE=y
# end of littlefs (C:/ncs/v2.7.0/modules/fs/littlefs)
# loramac-node (C:/ncs/v2.7.0/modules/lib/loramac-node)
CONFIG_ZEPHYR_LORAMAC_NODE_MODULE=y
# CONFIG_HAS_SEMTECH_RADIO_DRIVERS is not set
# end of loramac-node (C:/ncs/v2.7.0/modules/lib/loramac-node)
# lvgl (C:/ncs/v2.7.0/modules/lib/gui/lvgl)
CONFIG_ZEPHYR_LVGL_MODULE=y
# end of lvgl (C:/ncs/v2.7.0/modules/lib/gui/lvgl)
CONFIG_ZEPHYR_MIPI_SYS_T_MODULE=y
CONFIG_ZEPHYR_NRF_HW_MODELS_MODULE=y
CONFIG_ZEPHYR_OPEN_AMP_MODULE=y
# picolibc (C:/ncs/v2.7.0/modules/lib/picolibc)
# CONFIG_PICOLIBC_MODULE is not set
CONFIG_ZEPHYR_PICOLIBC_MODULE=y
# end of picolibc (C:/ncs/v2.7.0/modules/lib/picolibc)
# segger (C:/ncs/v2.7.0/modules/debug/segger)
CONFIG_ZEPHYR_SEGGER_MODULE=y
CONFIG_HAS_SEGGER_RTT=y
CONFIG_USE_SEGGER_RTT=y
# CONFIG_SEGGER_RTT_CUSTOM_LOCKING is not set
CONFIG_SEGGER_RTT_MAX_NUM_UP_BUFFERS=3
CONFIG_SEGGER_RTT_MAX_NUM_DOWN_BUFFERS=3
CONFIG_SEGGER_RTT_BUFFER_SIZE_UP=1024
CONFIG_SEGGER_RTT_BUFFER_SIZE_DOWN=16
CONFIG_SEGGER_RTT_PRINTF_BUFFER_SIZE=64
CONFIG_SEGGER_RTT_MODE_NO_BLOCK_SKIP=y
# CONFIG_SEGGER_RTT_MODE_NO_BLOCK_TRIM is not set
# CONFIG_SEGGER_RTT_MODE_BLOCK_IF_FIFO_FULL is not set
CONFIG_SEGGER_RTT_MODE=0
# CONFIG_SEGGER_RTT_MEMCPY_USE_BYTELOOP is not set
CONFIG_SEGGER_RTT_SECTION_NONE=y
# CONFIG_SEGGER_RTT_SECTION_DTCM is not set
# CONFIG_SEGGER_RTT_SECTION_CCM is not set
# end of segger (C:/ncs/v2.7.0/modules/debug/segger)
CONFIG_ZEPHYR_TINYCRYPT_MODULE=y
# uoscore-uedhoc (C:/ncs/v2.7.0/modules/lib/uoscore-uedhoc)
CONFIG_ZEPHYR_UOSCORE_UEDHOC_MODULE=y
# end of uoscore-uedhoc (C:/ncs/v2.7.0/modules/lib/uoscore-uedhoc)
# zcbor (C:/ncs/v2.7.0/modules/lib/zcbor)
CONFIG_ZEPHYR_ZCBOR_MODULE=y
# CONFIG_ZCBOR is not set
# end of zcbor (C:/ncs/v2.7.0/modules/lib/zcbor)
# nrfxlib (C:/ncs/v2.7.0/nrfxlib)
# Nordic nrfxlib
# nrf_modem (Modem library)
# end of nrf_modem (Modem library)
CONFIG_NRF_MODEM_SHMEM_CTRL_SIZE=0x4e8
# CONFIG_NFC_T2T_NRFXLIB is not set
# CONFIG_NFC_T4T_NRFXLIB is not set
# Crypto libraries for nRF5x SOCs.
# CONFIG_NRF_OBERON is not set
# CONFIG_NRF_CC310_BL is not set
# end of Crypto libraries for nRF5x SOCs.
# CONFIG_NRF_RPC is not set
CONFIG_NRF_802154_SOURCE_NRFXLIB=y
# CONFIG_GZLL is not set
# CONFIG_NRF_DM is not set
# CONFIG_NRF_FUEL_GAUGE is not set
# end of Nordic nrfxlib
CONFIG_ZEPHYR_NRFXLIB_MODULE=y
# end of nrfxlib (C:/ncs/v2.7.0/nrfxlib)
# connectedhomeip (C:/ncs/v2.7.0/modules/lib/matter)
# CONFIG_CHIP is not set
CONFIG_ZEPHYR_CONNECTEDHOMEIP_MODULE=y
# end of connectedhomeip (C:/ncs/v2.7.0/modules/lib/matter)
# CONFIG_LIBMETAL is not set
# CONFIG_LVGL is not set
# CONFIG_HAS_MEC_HAL is not set
# CONFIG_HAS_MPFS_HAL is not set
# CONFIG_HAS_MEC5_HAL is not set
# CONFIG_OPENAMP is not set
# CONFIG_MIPI_SYST_LIB is not set
# CONFIG_HAS_TELINK_DRIVERS is not set
# CONFIG_MCUBOOT_BOOTUTIL_LIB is not set
# CONFIG_WIFI_NM_WPA_SUPPLICANT is not set
# Unavailable modules, please install those via the project manifest.
# hal_gigadevice module not available.
# Trusted-firmware-a module not available.
# THRIFT module not available.
# CONFIG_ACPI is not set
# end of Modules
CONFIG_BOARD="nrf52833dk"
CONFIG_BOARD_REVISION=""
CONFIG_BOARD_TARGET="nrf52833dk/nrf52833"
# CONFIG_NET_DRIVERS is not set
CONFIG_BOARD_NRF52833DK=y
CONFIG_BOARD_NRF52833DK_NRF52833=y
CONFIG_BOARD_QUALIFIERS="nrf52833"
# Board Options
CONFIG_BOARD_ENABLE_DCDC=y
# end of Board Options
# Hardware Configuration
CONFIG_SOC_FAMILY="nordic_nrf"
CONFIG_SOC_FAMILY_NORDIC_NRF=y
CONFIG_SOC_SERIES_NRF52X=y
CONFIG_SOC_NRF52833=y
CONFIG_SOC_NRF52833_QIAA=y
# CONFIG_MFD is not set
# CONFIG_BUILD_OUTPUT_INFO_HEADER is not set
CONFIG_HAS_HW_NRF_ACL=y
CONFIG_HAS_HW_NRF_CCM=y
CONFIG_HAS_HW_NRF_CCM_LFLEN_8BIT=y
CONFIG_HAS_HW_NRF_CCM_HEADERMASK=y
CONFIG_HAS_HW_NRF_CLOCK=y
CONFIG_HAS_HW_NRF_ECB=y
CONFIG_HAS_HW_NRF_EGU0=y
CONFIG_HAS_HW_NRF_EGU1=y
CONFIG_HAS_HW_NRF_EGU2=y
CONFIG_HAS_HW_NRF_EGU3=y
CONFIG_HAS_HW_NRF_EGU4=y
CONFIG_HAS_HW_NRF_EGU5=y
CONFIG_HAS_HW_NRF_GPIO0=y
CONFIG_HAS_HW_NRF_GPIO1=y
CONFIG_HAS_HW_NRF_GPIOTE0=y
CONFIG_HAS_HW_NRF_MWU=y
CONFIG_HAS_HW_NRF_NVMC_PE=y
CONFIG_HAS_HW_NRF_POWER=y
CONFIG_HAS_HW_NRF_PPI=y
CONFIG_HAS_HW_NRF_PWM0=y
CONFIG_HAS_HW_NRF_RADIO_BLE_2M=y
CONFIG_HAS_HW_NRF_RADIO_BLE_CODED=y
CONFIG_HAS_HW_NRF_RADIO_DFE=y
CONFIG_HAS_HW_NRF_RADIO_IEEE802154=y
CONFIG_HAS_HW_NRF_RADIO_TX_PWR_HIGH=y
CONFIG_HAS_HW_NRF_RNG=y
CONFIG_HAS_HW_NRF_SAADC=y
CONFIG_HAS_HW_NRF_SPI1=y
CONFIG_HAS_HW_NRF_SPIM3=y
CONFIG_HAS_HW_NRF_SWI0=y
CONFIG_HAS_HW_NRF_SWI1=y
CONFIG_HAS_HW_NRF_SWI2=y
CONFIG_HAS_HW_NRF_SWI3=y
CONFIG_HAS_HW_NRF_SWI4=y
CONFIG_HAS_HW_NRF_SWI5=y
CONFIG_HAS_HW_NRF_TEMP=y
CONFIG_HAS_HW_NRF_TWI0=y
CONFIG_HAS_HW_NRF_UARTE0=y
CONFIG_HAS_HW_NRF_USBD=y
CONFIG_HAS_HW_NRF_WDT0=y
CONFIG_SOC_DCDC_NRF52X=y
# CONFIG_GPIO_AS_PINRESET is not set
CONFIG_NRF_ENABLE_ICACHE=y
CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT=0
CONFIG_NRF_SOC_SECURE_SUPPORTED=y
# CONFIG_NFCT_PINS_AS_GPIOS is not set
CONFIG_NRF_APPROTECT_USE_UICR=y
# CONFIG_NRF_APPROTECT_LOCK is not set
# CONFIG_NRF_TRACE_PORT is not set
CONFIG_GPIO_INIT_PRIORITY=40
# end of Hardware Configuration
CONFIG_SOC_COMPATIBLE_NRF=y
CONFIG_SOC_COMPATIBLE_NRF52X=y
CONFIG_SOC_COMPATIBLE_NRF52833=y
CONFIG_ARCH="arm"
CONFIG_ARCH_HAS_SINGLE_THREAD_SUPPORT=y
# CONFIG_EXTRA_EXCEPTION_INFO is not set
CONFIG_CPU_CORTEX=y
CONFIG_KOBJECT_TEXT_AREA=256
CONFIG_ARM_MPU=y
CONFIG_ARM_MPU_REGION_MIN_ALIGN_AND_SIZE=32
# CONFIG_MPU_ALLOW_FLASH_WRITE is not set
# ARM Options
CONFIG_CPU_CORTEX_M=y
# CONFIG_ARM_ZIMAGE_HEADER is not set
CONFIG_ISA_THUMB2=y
CONFIG_ASSEMBLER_ISA_THUMB2=y
CONFIG_COMPILER_ISA_THUMB2=y
CONFIG_STACK_ALIGN_DOUBLE_WORD=y
# CONFIG_RUNTIME_NMI is not set
CONFIG_FAULT_DUMP=2
CONFIG_ARM_STACK_PROTECTION=y
CONFIG_FP16=y
CONFIG_FP16_IEEE=y
# CONFIG_FP16_ALT is not set
CONFIG_CPU_CORTEX_M4=y
CONFIG_CPU_CORTEX_M_HAS_SYSTICK=y
CONFIG_CPU_CORTEX_M_HAS_DWT=y
CONFIG_CPU_CORTEX_M_HAS_BASEPRI=y
CONFIG_CPU_CORTEX_M_HAS_VTOR=y
CONFIG_CPU_CORTEX_M_HAS_PROGRAMMABLE_FAULT_PRIOS=y
CONFIG_ARMV7_M_ARMV8_M_MAINLINE=y
CONFIG_ARMV7_M_ARMV8_M_FP=y
# ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33/M55 options
# CONFIG_ZERO_LATENCY_IRQS is not set
# CONFIG_SW_VECTOR_RELAY is not set
# CONFIG_CORTEX_M_DWT is not set
# CONFIG_CORTEX_M_DEBUG_MONITOR_HOOK is not set
# CONFIG_TRAP_UNALIGNED_ACCESS is not set
# end of ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33/M55 options
CONFIG_NULL_POINTER_EXCEPTION_DETECTION_NONE=y
# CONFIG_NULL_POINTER_EXCEPTION_DETECTION_DWT is not set
# CONFIG_NULL_POINTER_EXCEPTION_DETECTION_MPU is not set
CONFIG_MPU_STACK_GUARD=y
# CONFIG_MPU_DISABLE_BACKGROUND_MAP is not set
# CONFIG_CUSTOM_SECTION_ALIGN is not set
CONFIG_CUSTOM_SECTION_MIN_ALIGN_SIZE=32
CONFIG_HAS_SWO=y
# end of ARM Options
CONFIG_ARM=y
CONFIG_ARCH_IS_SET=y
# General Architecture Options
# CONFIG_SEMIHOST is not set
CONFIG_LITTLE_ENDIAN=y
# CONFIG_USERSPACE is not set
CONFIG_KOBJECT_DATA_AREA_RESERVE_EXTRA_PERCENT=100
CONFIG_KOBJECT_RODATA_AREA_EXTRA_BYTES=16
CONFIG_GEN_PRIV_STACKS=y
# CONFIG_STACK_GROWS_UP is not set
# Interrupt Configuration
CONFIG_ISR_TABLES_LOCAL_DECLARATION_SUPPORTED=y
# CONFIG_ISR_TABLES_LOCAL_DECLARATION is not set
CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_ADDRESS=y
# CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_CODE is not set
CONFIG_EXCEPTION_DEBUG=y
# CONFIG_SIMPLIFIED_EXCEPTION_CODES is not set
# end of Interrupt Configuration
# end of General Architecture Options
CONFIG_ARCH_HAS_TIMING_FUNCTIONS=y
CONFIG_ARCH_HAS_STACK_PROTECTION=y
CONFIG_ARCH_HAS_USERSPACE=y
CONFIG_ARCH_HAS_EXECUTABLE_PAGE_BIT=y
CONFIG_ARCH_HAS_RAMFUNC_SUPPORT=y
CONFIG_ARCH_HAS_NESTED_EXCEPTION_DETECTION=y
CONFIG_ARCH_SUPPORTS_COREDUMP=y
CONFIG_ARCH_SUPPORTS_ARCH_HW_INIT=y
CONFIG_ARCH_SUPPORTS_ROM_START=y
CONFIG_ARCH_HAS_EXTRA_EXCEPTION_INFO=y
CONFIG_ARCH_HAS_THREAD_LOCAL_STORAGE=y
CONFIG_ARCH_HAS_SUSPEND_TO_RAM=y
CONFIG_ARCH_HAS_THREAD_ABORT=y
CONFIG_ARCH_HAS_CODE_DATA_RELOCATION=y
CONFIG_CPU_HAS_FPU=y
CONFIG_CPU_HAS_MPU=y
CONFIG_MPU=y
CONFIG_MPU_REQUIRES_POWER_OF_TWO_ALIGNMENT=y
CONFIG_SRAM_REGION_PERMISSIONS=y
# DSP Options
# end of DSP Options
# Floating Point Options
# end of Floating Point Options
# Cache Options
# end of Cache Options
CONFIG_TOOLCHAIN_HAS_BUILTIN_FFS=y
# CONFIG_ARCH_CPU_IDLE_CUSTOM is not set
# General Kernel Options
CONFIG_MULTITHREADING=y
CONFIG_NUM_COOP_PRIORITIES=16
CONFIG_NUM_PREEMPT_PRIORITIES=15
CONFIG_MAIN_THREAD_PRIORITY=0
CONFIG_COOP_ENABLED=y
CONFIG_PREEMPT_ENABLED=y
CONFIG_PRIORITY_CEILING=-127
# CONFIG_SCHED_DEADLINE is not set
CONFIG_THREAD_STACK_INFO=y
# CONFIG_THREAD_CUSTOM_DATA is not set
# CONFIG_DYNAMIC_THREAD is not set
CONFIG_SCHED_DUMB=y
# CONFIG_SCHED_SCALABLE is not set
# CONFIG_SCHED_MULTIQ is not set
# CONFIG_WAITQ_SCALABLE is not set
CONFIG_WAITQ_DUMB=y
# Misc Kernel related options
CONFIG_LIBC_ERRNO=y
CONFIG_ERRNO=y
CONFIG_CURRENT_THREAD_USE_TLS=y
# end of Misc Kernel related options
# Kernel Debugging and Metrics
CONFIG_BOOT_DELAY=0
# CONFIG_THREAD_MONITOR is not set
# CONFIG_THREAD_NAME is not set
# CONFIG_THREAD_RUNTIME_STATS is not set
# end of Kernel Debugging and Metrics
# CONFIG_OBJ_CORE is not set
# System Work Queue Options
# CONFIG_SYSTEM_WORKQUEUE_NO_YIELD is not set
# end of System Work Queue Options
# Barrier Operations
CONFIG_BARRIER_OPERATIONS_ARCH=y
# end of Barrier Operations
# Atomic Operations
CONFIG_ATOMIC_OPERATIONS_BUILTIN=y
# end of Atomic Operations
# Timer API Options
CONFIG_TIMESLICING=y
CONFIG_TIMESLICE_SIZE=0
CONFIG_TIMESLICE_PRIORITY=0
# CONFIG_TIMESLICE_PER_THREAD is not set
# end of Timer API Options
# Other Kernel Object Options
CONFIG_POLL=y
# CONFIG_MEM_SLAB_TRACE_MAX_UTILIZATION is not set
CONFIG_NUM_MBOX_ASYNC_MSGS=10
# CONFIG_EVENTS is not set
# CONFIG_PIPES is not set
CONFIG_KERNEL_MEM_POOL=y
# CONFIG_HEAP_MEM_POOL_IGNORE_MIN is not set
# end of Other Kernel Object Options
CONFIG_ARCH_HAS_CUSTOM_SWAP_TO_MAIN=y
CONFIG_SWAP_NONATOMIC=y
CONFIG_SYS_CLOCK_EXISTS=y
CONFIG_TIMEOUT_64BIT=y
CONFIG_SYS_CLOCK_MAX_TIMEOUT_DAYS=365
# Security Options
# CONFIG_STACK_CANARIES is not set
CONFIG_STACK_POINTER_RANDOM=0
# end of Security Options
# Memory Domains
CONFIG_ARCH_MEM_DOMAIN_SUPPORTS_ISOLATED_STACKS=y
CONFIG_MEM_DOMAIN_ISOLATED_STACKS=y
# end of Memory Domains
# SMP Options
CONFIG_MP_NUM_CPUS=1
# CONFIG_TICKET_SPINLOCKS is not set
# end of SMP Options
CONFIG_TOOLCHAIN_SUPPORTS_THREAD_LOCAL_STORAGE=y
CONFIG_THREAD_LOCAL_STORAGE=y
# end of General Kernel Options
# Device Options
# CONFIG_DEVICE_DEPS is not set
# CONFIG_DEVICE_MUTABLE is not set
# end of Device Options
# Initialization Priorities
CONFIG_KERNEL_INIT_PRIORITY_OBJECTS=30
CONFIG_KERNEL_INIT_PRIORITY_DEFAULT=40
CONFIG_KERNEL_INIT_PRIORITY_DEVICE=50
CONFIG_APPLICATION_INIT_PRIORITY=90
# end of Initialization Priorities
# Virtual Memory Support
# end of Virtual Memory Support
# Device Drivers
# CONFIG_ADC is not set
# CONFIG_AUDIO is not set
# CONFIG_AUXDISPLAY is not set
# CONFIG_BBRAM is not set
# CONFIG_CAN is not set
# CONFIG_CHARGER is not set
CONFIG_CLOCK_CONTROL_NRF=y
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC is not set
CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_EXT_LOW_SWING is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_EXT_FULL_SWING is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_250PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_150PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_100PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_75PPM is not set
CONFIG_CLOCK_CONTROL_NRF_K32SRC_50PPM=y
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_30PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_20PPM is not set
CONFIG_CLOCK_CONTROL_NRF_ACCURACY=50
# CONFIG_CLOCK_CONTROL_FIXED_RATE_CLOCK is not set
CONFIG_CONSOLE_INPUT_MAX_LINE_LEN=128
CONFIG_CONSOLE_HAS_DRIVER=y
# CONFIG_CONSOLE_HANDLER is not set
CONFIG_CONSOLE_INIT_PRIORITY=60
CONFIG_UART_CONSOLE=y
# CONFIG_UART_CONSOLE_DEBUG_SERVER_HOOKS is not set
# CONFIG_UART_CONSOLE_MCUMGR is not set
# CONFIG_RAM_CONSOLE is not set
# CONFIG_RTT_CONSOLE is not set
# CONFIG_IPM_CONSOLE_SENDER is not set
# CONFIG_IPM_CONSOLE_RECEIVER is not set
# CONFIG_UART_MCUMGR is not set
# CONFIG_GSM_MUX is not set
# CONFIG_EFI_CONSOLE is not set
# CONFIG_COREDUMP_DEVICE is not set
# CONFIG_CRYPTO is not set
# CONFIG_DAC is not set
# CONFIG_DAI is not set
# CONFIG_DISK_DRIVERS is not set
# CONFIG_DISPLAY is not set
# CONFIG_DMA is not set
# CONFIG_EDAC is not set
# CONFIG_EEPROM is not set
CONFIG_ENTROPY_GENERATOR=y
CONFIG_ENTROPY_NRF5_RNG=y
CONFIG_ENTROPY_NRF5_BIAS_CORRECTION=y
CONFIG_ENTROPY_NRF5_THR_POOL_SIZE=8
CONFIG_ENTROPY_NRF5_THR_THRESHOLD=4
CONFIG_ENTROPY_NRF5_ISR_POOL_SIZE=16
CONFIG_ENTROPY_NRF5_ISR_THRESHOLD=12
CONFIG_ENTROPY_BT_HCI=y
CONFIG_ENTROPY_HAS_DRIVER=y
# CONFIG_ESPI is not set
# CONFIG_FLASH is not set
# CONFIG_FPGA is not set
# CONFIG_FUEL_GAUGE is not set
# CONFIG_GNSS is not set
# CONFIG_GPIO_GET_DIRECTION is not set
# CONFIG_GPIO_GET_CONFIG is not set
# CONFIG_GPIO_HOGS is not set
# CONFIG_GPIO_ENABLE_DISABLE_INTERRUPT is not set
CONFIG_GPIO_NRFX=y
CONFIG_GPIO_NRFX_INTERRUPT=y
# CONFIG_HWINFO is not set
# CONFIG_HWSPINLOCK is not set
# CONFIG_I2C is not set
# CONFIG_I2S is not set
# CONFIG_I3C is not set
# Interrupt controller drivers
CONFIG_INTC_INIT_PRIORITY=40
# CONFIG_INTC_ESP32 is not set
# end of Interrupt controller drivers
# CONFIG_IPM is not set
# CONFIG_KSCAN is not set
# CONFIG_LED is not set
# CONFIG_LED_STRIP is not set
# CONFIG_LORA is not set
# CONFIG_MDIO is not set
# CONFIG_MIPI_DBI is not set
# Miscellaneous Drivers
# CONFIG_TIMEAWARE_GPIO is not set
# end of Miscellaneous Drivers
# CONFIG_MM_DRV is not set
# CONFIG_PCIE is not set
# CONFIG_PCIE_ENDPOINT is not set
# CONFIG_PECI is not set
CONFIG_PINCTRL_STORE_REG=y
# CONFIG_PINCTRL_DYNAMIC is not set
CONFIG_PINCTRL_NRF=y
# CONFIG_PM_CPU_OPS is not set
# CONFIG_PS2 is not set
# CONFIG_PTP_CLOCK is not set
# CONFIG_PWM is not set
# CONFIG_REGULATOR is not set
# CONFIG_RETAINED_MEM is not set
# CONFIG_RTC is not set
# CONFIG_SDHC is not set
# Capabilities
CONFIG_SERIAL_HAS_DRIVER=y
CONFIG_SERIAL_SUPPORT_ASYNC=y
CONFIG_SERIAL_SUPPORT_INTERRUPT=y
# CONFIG_UART_ASYNC_API is not set
# CONFIG_UART_LINE_CTRL is not set
# CONFIG_UART_DRV_CMD is not set
# CONFIG_UART_WIDE_DATA is not set
# CONFIG_UART_PIPE is not set
# CONFIG_UART_ASYNC_RX_HELPER is not set
# Serial Drivers
CONFIG_UART_NRFX=y
CONFIG_UART_NRFX_UARTE=y
CONFIG_UART_NRFX_UARTE_LEGACY_SHIM=y
CONFIG_UART_0_ENHANCED_POLL_OUT=y
# CONFIG_UART_0_NRF_PARITY_BIT is not set
CONFIG_UART_0_NRF_TX_BUFFER_SIZE=32
# CONFIG_SMBUS is not set
# Timer drivers
# CONFIG_TIMER_READS_ITS_FREQUENCY_AT_RUNTIME is not set
# CONFIG_SYSTEM_CLOCK_SLOPPY_IDLE is not set
CONFIG_SYSTEM_CLOCK_INIT_PRIORITY=0
CONFIG_TICKLESS_CAPABLE=y
CONFIG_SYSTEM_TIMER_HAS_DISABLE_SUPPORT=y
# CONFIG_NRF_RTC_TIMER_TRIGGER_OVERFLOW is not set
# CONFIG_SYSTEM_CLOCK_NO_WAIT is not set
# CONFIG_SYSTEM_CLOCK_WAIT_FOR_AVAILABILITY is not set
CONFIG_SYSTEM_CLOCK_WAIT_FOR_STABILITY=y
# end of Timer drivers
# CONFIG_USB_BC12 is not set
# CONFIG_UDC_DRIVER is not set
# CONFIG_UHC_DRIVER is not set
# CONFIG_UVB is not set
# CONFIG_USB_DEVICE_DRIVER is not set
# CONFIG_NRF_USBD_COMMON is not set
# CONFIG_USBC_TCPC_DRIVER is not set
# CONFIG_USBC_VBUS_DRIVER is not set
# CONFIG_USBC_PPC_DRIVER is not set
# CONFIG_VIDEO is not set
# CONFIG_VIRTUALIZATION is not set
# CONFIG_W1 is not set
# CONFIG_REQUIRES_FULL_LIBC is not set
# CONFIG_REQUIRES_FLOAT_PRINTF is not set
CONFIG_FULL_LIBC_SUPPORTED=y
CONFIG_MINIMAL_LIBC_SUPPORTED=y
CONFIG_NEWLIB_LIBC_SUPPORTED=y
CONFIG_PICOLIBC_SUPPORTED=y
# C Library
# CONFIG_MINIMAL_LIBC is not set
CONFIG_PICOLIBC=y
# CONFIG_NEWLIB_LIBC is not set
# CONFIG_EXTERNAL_LIBC is not set
CONFIG_HAS_NEWLIB_LIBC_NANO=y
CONFIG_COMMON_LIBC_ABORT=y
CONFIG_COMMON_LIBC_MALLOC=y
CONFIG_COMMON_LIBC_CALLOC=y
CONFIG_COMMON_LIBC_REALLOCARRAY=y
# CONFIG_PICOLIBC_USE_MODULE is not set
CONFIG_PICOLIBC_USE_TOOLCHAIN=y
CONFIG_PICOLIBC_HEAP_SIZE=-2
# CONFIG_PICOLIBC_IO_FLOAT is not set
CONFIG_PICOLIBC_IO_LONG_LONG=y
CONFIG_STDOUT_CONSOLE=y
CONFIG_NEED_LIBC_MEM_PARTITION=y
# end of C Library
# C++ Language Support
# CONFIG_CPP is not set
# Deprecated
# CONFIG_CPLUSPLUS is not set
# CONFIG_LIB_CPLUSPLUS is not set
# end of Deprecated
# end of C++ Language Support
# CONFIG_CRC is not set
# Additional libraries
# Hash Function Support
# CONFIG_SYS_HASH_FUNC32 is not set
# end of Hash Function Support
# Hashmap (Hash Table) Support
# CONFIG_SYS_HASH_MAP is not set
# end of Hashmap (Hash Table) Support
# Heap and Memory Allocation
# CONFIG_SYS_HEAP_VALIDATE is not set
# CONFIG_SYS_HEAP_STRESS is not set
# CONFIG_SYS_HEAP_INFO is not set
CONFIG_SYS_HEAP_ALLOC_LOOPS=3
# CONFIG_SYS_HEAP_RUNTIME_STATS is not set
# CONFIG_SYS_HEAP_LISTENER is not set
# CONFIG_SYS_HEAP_SMALL_ONLY is not set
# CONFIG_SYS_HEAP_BIG_ONLY is not set
CONFIG_SYS_HEAP_AUTO=y
# CONFIG_MULTI_HEAP is not set
# CONFIG_SHARED_MULTI_HEAP is not set
# end of Heap and Memory Allocation
# Memory Blocks
# CONFIG_SYS_MEM_BLOCKS is not set
# end of Memory Blocks
# OS Support Library
# CONFIG_FDTABLE is not set
# CONFIG_PRINTK_SYNC is not set
# CONFIG_MPSC_PBUF is not set
# CONFIG_SPSC_PBUF is not set
CONFIG_HAS_POWEROFF=y
# CONFIG_POWEROFF is not set
CONFIG_CBPRINTF_COMPLETE=y
# CONFIG_CBPRINTF_NANO is not set
CONFIG_CBPRINTF_FULL_INTEGRAL=y
# CONFIG_CBPRINTF_REDUCED_INTEGRAL is not set
# CONFIG_CBPRINTF_FP_SUPPORT is not set
# CONFIG_CBPRINTF_FP_A_SUPPORT is not set
# CONFIG_CBPRINTF_LIBC_SUBSTS is not set
# CONFIG_CBPRINTF_PACKAGE_LONGDOUBLE is not set
# CONFIG_CBPRINTF_STATIC_PACKAGE_CHECK_ALIGNMENT is not set
CONFIG_CBPRINTF_CONVERT_CHECK_PTR=y
# end of OS Support Library
# POSIX API Support
# POSIX Options
# CONFIG_POSIX_API is not set
# CONFIG_POSIX_ASYNCHRONOUS_IO is not set
# CONFIG_POSIX_CLOCK is not set
# CONFIG_POSIX_CONFSTR is not set
# CONFIG_POSIX_ENV is not set
# CONFIG_EVENTFD is not set
# File descriptor table options
# end of File descriptor table options
# CONFIG_FNMATCH is not set
# CONFIG_GETENTROPY is not set
# CONFIG_POSIX_MQUEUE is not set
# sem_t support
CONFIG_SEM_VALUE_MAX=32767
CONFIG_SEM_NAMELEN_MAX=16
# end of sem_t support
# Signal support
CONFIG_POSIX_RTSIG_MAX=0
# CONFIG_POSIX_SIGNAL is not set
# end of Signal support
# CONFIG_POSIX_PUTMSG is not set
# Sysconf support
# CONFIG_POSIX_SYSCONF is not set
CONFIG_POSIX_PAGE_SIZE_BITS=6
# end of Sysconf support
# CONFIG_POSIX_SYSLOG is not set
# CONFIG_TIMER is not set
# CONFIG_POSIX_UNAME is not set
# end of POSIX Options
# POSIX Shell Utilities
# end of POSIX Shell Utilities
# end of POSIX API Support
# CONFIG_OPENAMP_RSC_TABLE is not set
# CONFIG_SMF is not set
CONFIG_LIBGCC_RTLIB=y
# Utility Library
# CONFIG_JSON_LIBRARY is not set
# CONFIG_RING_BUFFER is not set
CONFIG_NOTIFY=y
# CONFIG_BASE64 is not set
CONFIG_ONOFF=y
# CONFIG_WINSTREAM is not set
# CONFIG_UTF8 is not set
# end of Utility Library
# end of Additional libraries
# Subsystems and OS Services
# CONFIG_BINDESC is not set
CONFIG_BT=y
CONFIG_BT_HCI=y
# CONFIG_BT_CUSTOM is not set
# CONFIG_BT_HCI_RAW is not set
# CONFIG_BT_HCI_RAW_H4 is not set
# CONFIG_BT_HCI_RAW_CMD_EXT is not set
# CONFIG_BT_ISO_PERIPHERAL is not set
# CONFIG_BT_ISO_CENTRAL is not set
# CONFIG_BT_ISO_BROADCASTER is not set
# CONFIG_BT_ISO_SYNC_RECEIVER is not set
# Bluetooth buffer configuration
# end of Bluetooth buffer configuration
# Bluetooth Host
# Bluetooth Classic Options
# end of Bluetooth Classic Options
# end of Bluetooth Host
CONFIG_BT_CTLR_LE_ENC_SUPPORT=y
CONFIG_BT_CTLR_CONN_PARAM_REQ_SUPPORT=y
CONFIG_BT_CTLR_EXT_REJ_IND_SUPPORT=y
CONFIG_BT_CTLR_PER_INIT_FEAT_XCHG_SUPPORT=y
CONFIG_BT_CTLR_DATA_LEN_UPDATE_SUPPORT=y
CONFIG_BT_CTLR_PRIVACY_SUPPORT=y
CONFIG_BT_CTLR_EXT_SCAN_FP_SUPPORT=y
CONFIG_BT_CTLR_PHY_UPDATE_SUPPORT=y
CONFIG_BT_CTLR_PHY_2M_SUPPORT=y
CONFIG_BT_CTLR_PHY_CODED_SUPPORT=y
CONFIG_BT_CTLR_ADV_EXT_SUPPORT=y
CONFIG_BT_CTLR_ADV_PERIODIC_SUPPORT=y
CONFIG_BT_CTLR_SYNC_PERIODIC_SUPPORT=y
CONFIG_BT_CTLR_ADV_ISO_SUPPORT=y
CONFIG_BT_CTLR_SYNC_ISO_SUPPORT=y
CONFIG_BT_CTLR_CENTRAL_ISO_SUPPORT=y
CONFIG_BT_CTLR_PERIPHERAL_ISO_SUPPORT=y
CONFIG_BT_CTLR_CHAN_SEL_2_SUPPORT=y
CONFIG_BT_CTLR_MIN_USED_CHAN_SUPPORT=y
CONFIG_BT_CTLR_SCA_UPDATE_SUPPORT=y
CONFIG_BT_CTLR_CONN_RSSI_SUPPORT=y
CONFIG_BT_LL_SW_SPLIT=y
CONFIG_BT_CTLR_HCI=y
# BLE Controller configuration
CONFIG_BT_CTLR_CRYPTO=y
CONFIG_BT_CTLR_HCI_VS_BUILD_INFO=""
CONFIG_BT_CTLR_DUP_FILTER_LEN=16
CONFIG_BT_CTLR_DUP_FILTER_ADV_SET_MAX=1
CONFIG_BT_CTLR_RX_BUFFERS=1
# CONFIG_BT_CTLR_TX_PWR_PLUS_8 is not set
# CONFIG_BT_CTLR_TX_PWR_PLUS_7 is not set
# CONFIG_BT_CTLR_TX_PWR_PLUS_6 is not set
# CONFIG_BT_CTLR_TX_PWR_PLUS_5 is not set
# CONFIG_BT_CTLR_TX_PWR_PLUS_4 is not set
# CONFIG_BT_CTLR_TX_PWR_PLUS_3 is not set
# CONFIG_BT_CTLR_TX_PWR_PLUS_2 is not set
CONFIG_BT_CTLR_TX_PWR_0=y
# CONFIG_BT_CTLR_TX_PWR_MINUS_4 is not set
# CONFIG_BT_CTLR_TX_PWR_MINUS_8 is not set
# CONFIG_BT_CTLR_TX_PWR_MINUS_12 is not set
# CONFIG_BT_CTLR_TX_PWR_MINUS_16 is not set
# CONFIG_BT_CTLR_TX_PWR_MINUS_20 is not set
# CONFIG_BT_CTLR_TX_PWR_MINUS_40 is not set
CONFIG_BT_CTLR_TX_PWR_DBM=0
# CONFIG_BT_CTLR_TX_PWR_DYNAMIC_CONTROL is not set
# BLE Controller features
# CONFIG_BT_CTLR_FILTER_ACCEPT_LIST is not set
# CONFIG_BT_CTLR_PRIVACY is not set
CONFIG_BT_CTLR_EXT_SCAN_FP=y
CONFIG_BT_CTLR_PHY_2M=y
# CONFIG_BT_CTLR_PHY_CODED is not set
CONFIG_BT_CTLR_CHAN_SEL_2=y
CONFIG_BT_CTLR_ADV_EXT=y
CONFIG_BT_CTLR_SYNC_PERIODIC=y
CONFIG_BT_CTLR_SYNC_PERIODIC_ADV_LIST=y
CONFIG_BT_CTLR_SYNC_PERIODIC_ADI_SUPPORT=y
CONFIG_BT_CTLR_SYNC_PERIODIC_CTE_TYPE_FILTERING=y
# CONFIG_BT_CTLR_ADV_ISO is not set
# CONFIG_BT_CTLR_SYNC_ISO is not set
# CONFIG_BT_CTLR_SET_HOST_FEATURE is not set
# CONFIG_BT_CTLR_CENTRAL_ISO is not set
# CONFIG_BT_CTLR_PERIPHERAL_ISO is not set
# CONFIG_BT_CTLR_HCI_CODEC_AND_DELAY_INFO is not set
CONFIG_BT_CTLR_DF_CTE_TX_SUPPORT=y
CONFIG_BT_CTLR_DF_CTE_RX_SUPPORT=y
CONFIG_BT_CTLR_DF_CTE_RX_SAMPLE_1US_SUPPORT=y
CONFIG_BT_CTLR_DF_ANT_SWITCH_2US_SUPPORT=y
CONFIG_BT_CTLR_DF_ANT_SWITCH_1US_SUPPORT=y
CONFIG_BT_CTLR_CTEINLINE_SUPPORT=y
CONFIG_BT_CTLR_DF_CTE_TX=y
CONFIG_BT_CTLR_DF_CTE_RX_SAMPLE_1US=y
CONFIG_BT_CTLR_DF_ANT_SWITCH_1US=y
# CONFIG_BT_CTLR_DF_ANT_SWITCH_TX is not set
CONFIG_BT_CTLR_DF_ANT_SWITCH_RX=y
CONFIG_BT_CTLR_DF_CTE_RX=y
CONFIG_BT_CTLR_DF_SCAN_CTE_RX=y
CONFIG_BT_CTLR_DF_SAMPLE_CTE_FOR_PDU_WITH_BAD_CRC=y
CONFIG_BT_CTLR_DF_MAX_ANT_SW_PATTERN_LEN=12
CONFIG_BT_CTLR_DF_INIT_ANT_SEL_GPIOS=y
CONFIG_BT_CTLR_DF_PER_SCAN_CTE_NUM_MAX=16
CONFIG_BT_CTLR_DF_SWITCH_OFFSET=0
CONFIG_BT_CTLR_DF_SAMPLE_OFFSET_PHY_1M_SAMPLING_1US=1
CONFIG_BT_CTLR_DF_SAMPLE_OFFSET_PHY_2M_SAMPLING_1US=15
CONFIG_BT_CTLR_DF_SAMPLE_OFFSET_PHY_1M_SAMPLING_2US=6
CONFIG_BT_CTLR_DF_SAMPLE_OFFSET_PHY_2M_SAMPLING_2US=20
# CONFIG_BT_CTLR_DF_DEBUG_ENABLE is not set
# CONFIG_BT_CTLR_DF_IQ_SAMPLES_CONVERT_4_BITS_SHIFT is not set
CONFIG_BT_CTLR_DF_IQ_SAMPLES_CONVERT_2_BITS_SHIFT=y
# CONFIG_BT_CTLR_DF_VS_CL_IQ_REPORT_16_BITS_IQ_SAMPLES is not set
CONFIG_BT_LLL_VENDOR_NORDIC=y
CONFIG_BT_CTLR_XTAL_ADVANCED_SUPPORT=y
CONFIG_BT_CTLR_SCHED_ADVANCED_SUPPORT=y
CONFIG_BT_CTLR_TIFS_HW_SUPPORT=y
CONFIG_BT_CTLR_ULL_LLL_PRIO_SUPPORT=y
CONFIG_BT_CTLR_RX_PRIO_STACK_SIZE=448
CONFIG_BT_CTLR_RX_STACK_SIZE=768
CONFIG_BT_CTLR_COMPANY_ID=0x0059
CONFIG_BT_CTLR_SUBVERSION_NUMBER=0xFFFF
CONFIG_BT_CTLR_AD_DATA_BACKUP=y
# CONFIG_BT_CTLR_HCI_ADV_HANDLE_MAPPING is not set
CONFIG_BT_CTLR_ADV_EXT_RX_PDU_LEN_MAX=255
CONFIG_BT_CTLR_SCAN_DATA_LEN_MAX=31
# CONFIG_BT_CTLR_TEST is not set
# CONFIG_BT_CTLR_ADVANCED_FEATURES is not set
CONFIG_BT_CTLR_SCAN_AUX_SET=1
CONFIG_BT_CTLR_SCAN_AUX_SYNC_RESERVE_MIN=y
CONFIG_BT_CTLR_XTAL_ADVANCED=y
CONFIG_BT_CTLR_XTAL_THRESHOLD=1500
CONFIG_BT_CTLR_ASSERT_OVERHEAD_START=y
CONFIG_BT_CTLR_EVENT_OVERHEAD_RESERVE_MAX=y
CONFIG_BT_CTLR_LLL_PRIO=0
CONFIG_BT_CTLR_ULL_HIGH_PRIO=1
CONFIG_BT_CTLR_ULL_LOW_PRIO=1
CONFIG_BT_CTLR_RADIO_ENABLE_FAST=y
CONFIG_BT_CTLR_EARLY_ABORT_PREVIOUS_PREPARE=y
CONFIG_BT_MAYFLY_YIELD_AFTER_CALL=y
CONFIG_BT_TICKER_UPDATE=y
CONFIG_BT_TICKER_NEXT_SLOT_GET=y
CONFIG_BT_TICKER_REMAINDER_GET=y
CONFIG_BT_TICKER_NEXT_SLOT_GET_MATCH=y
# BLE Controller debug configuration
# CONFIG_BT_CTLR_PROFILE_ISR is not set
# CONFIG_BT_CTLR_DEBUG_PINS is not set
CONFIG_BT_CTLR_DTM_HCI_SUPPORT=y
# CONFIG_BT_CTLR_DTM_HCI is not set
# CONFIG_BT_CTLR_ASSERT_HANDLER is not set
# CONFIG_BT_SHELL is not set
# CONFIG_BT_EAD is not set
# Controller Area Network (CAN) bus subsystem
# end of Controller Area Network (CAN) bus subsystem
# CONFIG_CONSOLE_SUBSYS is not set
# System Monitoring Options
# CONFIG_THREAD_ANALYZER is not set
# end of System Monitoring Options
# Debugging Options
# CONFIG_DEBUG is not set
# CONFIG_STACK_USAGE is not set
CONFIG_PRINTK=y
CONFIG_EARLY_CONSOLE=y
# CONFIG_ASSERT is not set
# CONFIG_FORCE_NO_ASSERT is not set
CONFIG_ASSERT_VERBOSE=y
# CONFIG_ASSERT_NO_FILE_INFO is not set
# CONFIG_ASSERT_NO_COND_INFO is not set
# CONFIG_ASSERT_NO_MSG_INFO is not set
# CONFIG_ASSERT_TEST is not set
# CONFIG_OVERRIDE_FRAME_POINTER_DEFAULT is not set
# CONFIG_DEBUG_INFO is not set
# CONFIG_DEBUG_THREAD_INFO is not set
# CONFIG_DEBUG_COREDUMP is not set
# end of Debugging Options
# CONFIG_MIPI_STP_DECODER is not set
# CONFIG_DISK_ACCESS is not set
# CONFIG_DSP is not set
# CONFIG_EMUL is not set
# CONFIG_CHARACTER_FRAMEBUFFER is not set
# File Systems
# CONFIG_FILE_SYSTEM is not set
# end of File Systems
# Inter Processor Communication
# CONFIG_RPMSG_SERVICE is not set
# CONFIG_IPC_SERVICE is not set
# end of Inter Processor Communication
# CONFIG_JWT is not set
# CONFIG_LLEXT is not set
# Linkable loadable Extension Development Kit (EDK)
CONFIG_LLEXT_EDK_NAME="llext-edk"
# CONFIG_LLEXT_EDK_USERSPACE_ONLY is not set
# end of Linkable loadable Extension Development Kit (EDK)
# Logging
# CONFIG_LOG_OUTPUT is not set
# end of Logging
CONFIG_MEM_ATTR=y
# CONFIG_MEM_ATTR_HEAP is not set
# Device Management
# Host command handler subsystem
# CONFIG_EC_HOST_CMD is not set
# end of Host command handler subsystem
# CONFIG_OSDP is not set
# end of Device Management
# CONFIG_MODBUS is not set
# CONFIG_MODEM_MODULES is not set
# Networking
CONFIG_NET_BUF=y
# CONFIG_NET_BUF_LOG is not set
# CONFIG_NET_BUF_POOL_USAGE is not set
CONFIG_NET_BUF_ALIGNMENT=0
# CONFIG_NETWORKING is not set
# end of Networking
# Power Management
# end of Power Management
# Portability
# end of Portability
# Random Number Generators
# CONFIG_TEST_RANDOM_GENERATOR is not set
CONFIG_TIMER_RANDOM_INITIAL_STATE=123456789
# CONFIG_ENTROPY_DEVICE_RANDOM_GENERATOR is not set
CONFIG_XOSHIRO_RANDOM_GENERATOR=y
CONFIG_CSPRNG_ENABLED=y
CONFIG_HARDWARE_DEVICE_CS_GENERATOR=y
# end of Random Number Generators
# CONFIG_RTIO is not set
# SD
# CONFIG_MMC_STACK is not set
# CONFIG_SDMMC_STACK is not set
# CONFIG_SDIO_STACK is not set
# end of SD
# CONFIG_SETTINGS is not set
# CONFIG_SHELL is not set
# CONFIG_STATS is not set
# Storage
# CONFIG_STREAM_FLASH is not set
# end of Storage
# CONFIG_TASK_WDT is not set
# Testing
# CONFIG_ZTEST is not set
# CONFIG_ZTEST_MOCKING is not set
# CONFIG_ZTRESS is not set
# CONFIG_TEST is not set
CONFIG_COVERAGE_GCOV_HEAP_SIZE=16384
# CONFIG_FORCE_COVERAGE is not set
# CONFIG_TEST_USERSPACE is not set
# end of Testing
# CONFIG_TIMING_FUNCTIONS is not set
# CONFIG_TRACING is not set
# CONFIG_USB_DEVICE_STACK is not set
# CONFIG_USB_DEVICE_STACK_NEXT is not set
# CONFIG_USB_HOST_STACK is not set
# CONFIG_USBC_STACK is not set
# CONFIG_ZBUS is not set
# CONFIG_MODULES is not set
# end of Subsystems and OS Services
CONFIG_TOOLCHAIN_ZEPHYR_0_16=y
CONFIG_TOOLCHAIN_ZEPHYR_SUPPORTS_THREAD_LOCAL_STORAGE=y
# Build and Link Features
# Linker Options
# CONFIG_LINKER_ORPHAN_SECTION_PLACE is not set
CONFIG_LINKER_ORPHAN_SECTION_WARN=y
# CONFIG_LINKER_ORPHAN_SECTION_ERROR is not set
CONFIG_FLASH_LOAD_SIZE=0
CONFIG_ROM_END_OFFSET=0
CONFIG_LD_LINKER_SCRIPT_SUPPORTED=y
CONFIG_LD_LINKER_TEMPLATE=y
# CONFIG_CMAKE_LINKER_GENERATOR is not set
# CONFIG_HAVE_CUSTOM_LINKER_SCRIPT is not set
CONFIG_LINKER_SORT_BY_ALIGNMENT=y
# Linker Sections
# CONFIG_LINKER_USE_BOOT_SECTION is not set
# CONFIG_LINKER_USE_PINNED_SECTION is not set
CONFIG_LINKER_GENERIC_SECTIONS_PRESENT_AT_BOOT=y
CONFIG_LINKER_LAST_SECTION_ID=y
CONFIG_LINKER_LAST_SECTION_ID_PATTERN=0xE015E015
CONFIG_LINKER_USE_RELAX=y
# end of Linker Sections
CONFIG_LINKER_ITERABLE_SUBALIGN=4
CONFIG_LINKER_DEVNULL_SUPPORT=y
# CONFIG_LINKER_DEVNULL_MEMORY is not set
# end of Linker Options
# Compiler Options
# CONFIG_STD_C90 is not set
CONFIG_STD_C99=y
# CONFIG_STD_C11 is not set
# CONFIG_STD_C17 is not set
# CONFIG_STD_C23 is not set
CONFIG_TOOLCHAIN_SUPPORTS_GNU_EXTENSIONS=y
# CONFIG_GNU_C_EXTENSIONS is not set
# CONFIG_CODING_GUIDELINE_CHECK is not set
# CONFIG_COMPILER_FREESTANDING is not set
CONFIG_SIZE_OPTIMIZATIONS=y
# CONFIG_SPEED_OPTIMIZATIONS is not set
# CONFIG_DEBUG_OPTIMIZATIONS is not set
# CONFIG_NO_OPTIMIZATIONS is not set
# CONFIG_COMPILER_WARNINGS_AS_ERRORS is not set
# CONFIG_COMPILER_SAVE_TEMPS is not set
CONFIG_COMPILER_TRACK_MACRO_EXPANSION=y
CONFIG_COMPILER_COLOR_DIAGNOSTICS=y
# CONFIG_FORTIFY_SOURCE_NONE is not set
CONFIG_FORTIFY_SOURCE_COMPILE_TIME=y
# CONFIG_FORTIFY_SOURCE_RUN_TIME is not set
CONFIG_COMPILER_OPT=""
# CONFIG_MISRA_SANE is not set
# end of Compiler Options
# CONFIG_ASSERT_ON_ERRORS is not set
# CONFIG_NO_RUNTIME_CHECKS is not set
CONFIG_RUNTIME_ERROR_CHECKS=y
# Build Options
CONFIG_KERNEL_BIN_NAME="zephyr"
CONFIG_OUTPUT_STAT=y
# CONFIG_OUTPUT_SYMBOLS is not set
# CONFIG_OUTPUT_DISASSEMBLY is not set
CONFIG_OUTPUT_PRINT_MEMORY_USAGE=y
# CONFIG_CLEANUP_INTERMEDIATE_FILES is not set
# CONFIG_BUILD_NO_GAP_FILL is not set
# CONFIG_BUILD_OUTPUT_EXE is not set
# CONFIG_BUILD_OUTPUT_S19 is not set
# CONFIG_BUILD_OUTPUT_UF2 is not set
# CONFIG_BUILD_OUTPUT_STRIPPED is not set
# CONFIG_BUILD_OUTPUT_COMPRESS_DEBUG_SECTIONS is not set
# CONFIG_BUILD_ALIGN_LMA is not set
# CONFIG_APPLICATION_DEFINED_SYSCALL is not set
# CONFIG_MAKEFILE_EXPORTS is not set
# CONFIG_BUILD_OUTPUT_META is not set
CONFIG_BUILD_OUTPUT_STRIP_PATHS=y
CONFIG_CHECK_INIT_PRIORITIES=y
# CONFIG_EMIT_ALL_SYSCALLS is not set
# end of Build Options
CONFIG_WARN_DEPRECATED=y
CONFIG_EXPERIMENTAL=y
CONFIG_ENFORCE_ZEPHYR_STDINT=y
# end of Build and Link Features
# Boot Options
# CONFIG_IS_BOOTLOADER is not set
# CONFIG_BOOTLOADER_BOSSA is not set
# end of Boot Options
