Hi nordic:
When I open VS Code, it stays like this and doesn't display the menu. How can I fix this? Thank you!!
best regards
jermi
Hi nordic:
best regards
jermi
Hi Jermi,
Were you able to use nRF Connect extension without issues previously.? Or is it newly installed.?
Swathy
That issue usually happens if VS Code's UI components fail to load properly — it could be due to an extension conflict, corrupted cache, or incomplete update. A few things you can try:
Launch VS Code with the --disable-extensions flag to check if an extension is causing it:
code --disable-extensions
Try resetting the user data by deleting the contents of the User folder in your VS Code config (but back it up first!).
Reinstalling VS Code completely can also help — especially if it was interrupted during an update.
Hope that helps!
Also, side tip: if you're working with demo videos or dev clips and need to grab clean TikTok content (no watermark), snaptik is a solid downloader I often use for quick HD grabs.
