Custom board derived from nrf54l15dk failing to build
Currently using NCS v2.9.1 nrf54l15/cpuapp custom board derived from nrf54l15dk, customization to de added after solving the issue below.
The project is successfully compiled and executed on nrf54l15dk, using nrf54l15dk as a target board but it fails if custom board is the target due to the issue below.
under_dev.zip
The project is attached so you can build for both targets, nrf54l15dk and customboard for nrf54l15/cpuapp.
Thank you very much in advance for your support.
    ''The project is successfully compiled and executed on nrf54l15dk, using nrf54l15dk as a target board but it fails if custom board is the target due to the issue below''
    Can you please send me the error log of custom baord?
  • Hi Kazi,
    please, see file .txt inside the zip project file with description of the error when compiling to the custom board.
  • this is the log for both builds, nrf54l15dk and customboard.
    Building under_dev
    C:\WINDOWS\system32\cmd.exe /d /s /c "west build --build-dir c:/nordic/workspace/under_dev/build_1 c:/nordic/workspace/under_dev --pristine --board nrf54l15dk/nrf54l15/cpuapp -- -DNCS_TOOLCHAIN_VERSION=NONE -DBOARD_ROOT=c:/nordic/workspace/under_dev"
    Loading Zephyr module(s) (Zephyr base): sysbuild_default
    -- Found Python3: C:/ncs/toolchains/b620d30767/opt/bin/python.exe (found suitable version "3.12.4", minimum required is "3.8") found components: Interpreter
    -- Cache files will be written to: C:/ncs/v2.9.1/zephyr/.cache
    -- Board: nrf54l15dk, qualifiers: nrf54l15/cpuapp
    Parsing C:/ncs/v2.9.1/zephyr/share/sysbuild/Kconfig
    Loaded configuration 'C:/nordic/workspace/under_dev/build_1/_sysbuild/empty.conf'
    Merged configuration 'c:/nordic/workspace/under_dev/sysbuild.conf'
    Configuration saved to 'C:/nordic/workspace/under_dev/build_1/zephyr/.config'
    Kconfig header saved to 'C:/nordic/workspace/under_dev/build_1/_sysbuild/autoconf.h'
       * Running CMake for mcuboot *
    -- Application: C:/ncs/v2.9.1/bootloader/mcuboot/boot/zephyr
    -- CMake version: 3.21.0
    -- Zephyr version: 3.7.99 (C:/ncs/v2.9.1/zephyr)
    -- Found host-tools: zephyr 0.17.0 (C:/ncs/toolchains/b620d30767/opt/zephyr-sdk)
    -- Found toolchain: zephyr 0.17.0 (C:/ncs/toolchains/b620d30767/opt/zephyr-sdk)
    -- Found Dtc: C:/ncs/toolchains/b620d30767/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
    -- Found BOARD.dts: C:/ncs/v2.9.1/zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l15_cpuapp.dts
    -- Found devicetree overlay: C:/ncs/v2.9.1/bootloader/mcuboot/boot/zephyr/app.overlay
    unit address and first address in 'reg' (0x5004c000) don't match for /soc/peripheral@50000000/vpr@4c000/mailbox@1
    -- Generated zephyr.dts: C:/nordic/workspace/under_dev/build_1/mcuboot/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: C:/nordic/workspace/under_dev/build_1/mcuboot/zephyr/include/generated/zephyr/devicetree_generated.h
    -- Including generated dts.cmake file: C:/nordic/workspace/under_dev/build_1/mcuboot/zephyr/dts.cmake
    warning: FPROTECT_ALLOW_COMBINED_REGIONS (defined at C:/ncs/v2.9.1/nrf\lib\fprotect/Kconfig:76) was
    assigned the value 'y' but got the value 'n'. Check these unsatisfied dependencies: FPROTECT (=n).
    See http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_FPROTECT_ALLOW_COMBINED_REGIONS and/or
    look up FPROTECT_ALLOW_COMBINED_REGIONS in the menuconfig/guiconfig interface. The Application
    Development Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices sections of
    the manual might be helpful too.
    warning: NRF_RTC_TIMER_USER_CHAN_COUNT (defined at
    C:/ncs/v2.9.1/zephyr/soc/nordic\nrf53\Kconfig.sync_rtc:23, drivers/timer/Kconfig.nrf_rtc:20) was
    assigned the value '0' but got the value ''. Check these unsatisfied dependencies: ((NRF53_SYNC_RTC
    && SOC_SERIES_NRF53X && SOC_FAMILY_NORDIC_NRF) || (NRF_RTC_TIMER && SYS_CLOCK_EXISTS)) (=n). See
    http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT and/or look
    up NRF_RTC_TIMER_USER_CHAN_COUNT in the menuconfig/guiconfig interface. The Application Development
    Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual
    Parsing C:/ncs/v2.9.1/bootloader/mcuboot/boot/zephyr/Kconfig
    Loaded configuration 'C:/ncs/v2.9.1/zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l15_cpuapp_defconfig'
    Merged configuration 'C:/ncs/v2.9.1/bootloader/mcuboot/boot/zephyr/prj.conf'
    Merged configuration 'C:/ncs/v2.9.1/bootloader/mcuboot/boot/zephyr/boards/nrf54l15dk_nrf54l15_cpuapp.conf'
    Merged configuration 'C:/nordic/workspace/under_dev/build_1/mcuboot/zephyr/.config.sysbuild'
    Configuration saved to 'C:/nordic/workspace/under_dev/build_1/mcuboot/zephyr/.config'
    Kconfig header saved to 'C:/nordic/workspace/under_dev/build_1/mcuboot/zephyr/include/generated/zephyr/autoconf.h'
    -- Found GnuLd: c:/ncs/toolchains/b620d30767/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi/bin/ld.bfd.exe (found version "2.38")
    -- Found assembler: C:/ncs/toolchains/b620d30767/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
    -- Setting build type to 'MinSizeRel' as none was specified.
    MCUBoot bootloader key file: C:/ncs/v2.9.1/bootloader/mcuboot/root-rsa-2048.pem
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/nordic/workspace/under_dev/build_1/mcuboot
       * Running CMake for under_dev *
    -- Application: C:/nordic/workspace/under_dev
    -- Found devicetree overlay: C:/nordic/workspace/under_dev/boards/nrf54l15dk_nrf54l15_cpuapp.overlay
    -- Generated zephyr.dts: C:/nordic/workspace/under_dev/build_1/under_dev/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: C:/nordic/workspace/under_dev/build_1/under_dev/zephyr/include/generated/zephyr/devicetree_generated.h
    -- Including generated dts.cmake file: C:/nordic/workspace/under_dev/build_1/under_dev/zephyr/dts.cmake
    Parsing C:/ncs/v2.9.1/zephyr/Kconfig
    Merged configuration 'C:/nordic/workspace/under_dev/prj.conf'
    Merged configuration 'C:/nordic/workspace/under_dev/build_1/under_dev/zephyr/.config.sysbuild'
    Configuration saved to 'C:/nordic/workspace/under_dev/build_1/under_dev/zephyr/.config'
    Kconfig header saved to 'C:/nordic/workspace/under_dev/build_1/under_dev/zephyr/include/generated/zephyr/autoconf.h'
    =========== Generating psa_crypto_config ===============
    Backup: CONFIG_MBEDTLS_PSA_CRYPTO_SPM: False
    Backup: CONFIG_MBEDTLS_PSA_CRYPTO_C: True
    Backup: CONFIG_MBEDTLS_PSA_CRYPTO_KEY_ID_ENCODES_OWNER: False
    Backup: CONFIG_MBEDTLS_PLATFORM_SETUP_TEARDOWN_ALT: False
    Backup: CONFIG_MBEDTLS_THREADING: False
    Backup: CONFIG_MBEDTLS_THREADING_ALT: True
    =========== Checkpoint: backup ===============
    Restore: CONFIG_MBEDTLS_PSA_CRYPTO_SPM: False
    Restore: CONFIG_MBEDTLS_PSA_CRYPTO_C: True
    Restore: CONFIG_MBEDTLS_PSA_CRYPTO_KEY_ID_ENCODES_OWNER: False
    Restore: CONFIG_MBEDTLS_PLATFORM_SETUP_TEARDOWN_ALT: False
    Restore: CONFIG_MBEDTLS_THREADING: False
    Restore: CONFIG_MBEDTLS_THREADING_ALT: True
    =========== End psa_crypto_config ===============
    =========== Generating psa_crypto_library_config ===============
    Backup: CONFIG_MBEDTLS_USE_PSA_CRYPTO: True
    Backup: CONFIG_MBEDTLS_PLATFORM_PRINTF_ALT: False
    Restore: CONFIG_MBEDTLS_USE_PSA_CRYPTO: True
    Restore: CONFIG_MBEDTLS_PLATFORM_PRINTF_ALT: False
    =========== End psa_crypto_library_config ===============
    -- Including signing script: C:/ncs/v2.9.1/nrf/cmake/sysbuild/image_signing.cmake
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/nordic/workspace/under_dev/build_1/under_dev
    -- Found partition manager static configuration : C:/nordic/workspace/under_dev/pm_static_nrf54l15dk_nrf54l15_cpuapp.yml
    Partition 'littlefs_storage' is not included in the dynamic resolving since it is statically defined.
    Partition 'mcuboot' is not included in the dynamic resolving since it is statically defined.
    Partition 'mcuboot_pad' is not included in the dynamic resolving since it is statically defined.
    Partition 'mcuboot_primary' is not included in the dynamic resolving since it is statically defined.
    Partition 'mcuboot_primary_app' is not included in the dynamic resolving since it is statically defined.
    Partition 'mcuboot_secondary' is not included in the dynamic resolving since it is statically defined.
    -- Configuring done
    -- Generating done
    [0/1] Re-running CMake...
    Loading Zephyr default modules (Zephyr base (cached)).
    Loaded configuration 'C:/nordic/workspace/under_dev/build_1/under_dev/zephyr/.config'
    No change to configuration in 'C:/nordic/workspace/under_dev/build_1/under_dev/zephyr/.config'
    No change to Kconfig header in 'C:/nordic/workspace/under_dev/build_1/under_dev/zephyr/include/generated/zephyr/autoconf.h'
    -- Configuring done
    -- Generating done
    [21/394] Generating include/generated/zephyr/version.h
    -- Zephyr version: 3.7.99 (C:/ncs/v2.9.1/zephyr), build: v3.7.99-ncs2-1
    [394/394] Linking C executable zephyr\zephyr.elf
               FLASH:      236476 B       722 KB     31.99%
                 RAM:       60740 B       188 KB     31.55%
            IDT_LIST:          0 GB        32 KB      0.00%
    Generating files from C:/nordic/workspace/under_dev/build_1/under_dev/zephyr/zephyr.elf for board: nrf54l15dk
    image.py: sign the payload
    [10/280] Generating include/generated/zephyr/version.h
    [280/280] Linking C executable zephyr\zephyr.elf
               FLASH:       35728 B        48 KB     72.69%
                 RAM:       24624 B       188 KB     12.79%
    Generating files from C:/nordic/workspace/under_dev/build_1/mcuboot/zephyr/zephyr.elf for board: nrf54l15dk
    [20/20] Generating ../merged.hex
     *  Executing task: nRF Connect: Generate config customboard/nrf54l15/cpuapp for c:\nordic\workspace\under_dev
    Building under_dev
    C:\WINDOWS\system32\cmd.exe /d /s /c "west build --build-dir c:/nordic/workspace/under_dev/build c:/nordic/workspace/under_dev --pristine --board customboard/nrf54l15/cpuapp -- -DNCS_TOOLCHAIN_VERSION=NONE -DBOARD_ROOT=c:/nordic/workspace/under_dev"
    -- Board: customboard, qualifiers: nrf54l15/cpuapp
    Loaded configuration 'C:/nordic/workspace/under_dev/build/_sysbuild/empty.conf'
    Configuration saved to 'C:/nordic/workspace/under_dev/build/zephyr/.config'
    Kconfig header saved to 'C:/nordic/workspace/under_dev/build/_sysbuild/autoconf.h'
    -- Found BOARD.dts: C:/nordic/workspace/under_dev/boards/embeddedcode/customboard/customboard_nrf54l15_cpuapp.dts
    -- Generated zephyr.dts: C:/nordic/workspace/under_dev/build/mcuboot/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: C:/nordic/workspace/under_dev/build/mcuboot/zephyr/include/generated/zephyr/devicetree_generated.h
    -- Including generated dts.cmake file: C:/nordic/workspace/under_dev/build/mcuboot/zephyr/dts.cmake
    Loaded configuration 'C:/nordic/workspace/under_dev/boards/embeddedcode/customboard/customboard_nrf54l15_cpuapp_defconfig'
    Merged configuration 'C:/nordic/workspace/under_dev/build/mcuboot/zephyr/.config.sysbuild'
    Configuration saved to 'C:/nordic/workspace/under_dev/build/mcuboot/zephyr/.config'
    Kconfig header saved to 'C:/nordic/workspace/under_dev/build/mcuboot/zephyr/include/generated/zephyr/autoconf.h'
    CMake Warning at C:/ncs/v2.9.1/zephyr/CMakeLists.txt:952 (message):
      No SOURCES given to Zephyr library: drivers__spi
      Excluding target from build.
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/nordic/workspace/under_dev/build/mcuboot
    -- Found devicetree overlay: C:/nordic/workspace/under_dev/boards/customboard_nrf54l15_cpuapp.overlay
    -- Generated zephyr.dts: C:/nordic/workspace/under_dev/build/under_dev/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: C:/nordic/workspace/under_dev/build/under_dev/zephyr/include/generated/zephyr/devicetree_generated.h
    -- Including generated dts.cmake file: C:/nordic/workspace/under_dev/build/under_dev/zephyr/dts.cmake
    Merged configuration 'C:/nordic/workspace/under_dev/build/under_dev/zephyr/.config.sysbuild'
    Configuration saved to 'C:/nordic/workspace/under_dev/build/under_dev/zephyr/.config'
    Kconfig header saved to 'C:/nordic/workspace/under_dev/build/under_dev/zephyr/include/generated/zephyr/autoconf.h'
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/nordic/workspace/under_dev/build/under_dev
    CMake Warning at C:/ncs/v2.9.1/nrf/cmake/sysbuild/partition_manager.cmake:106 (message):
            --- WARNING: Using a bootloader without pm_static.yml.            ---
            --- There are cases where a deployed product can consist of       ---
            --- multiple images, and only a subset of these images can be     ---
            --- upgraded through a firmware update mechanism. In such cases,  ---
            --- the upgradable images must have partitions that are static    ---
            --- and are matching the partition map used by the bootloader     ---
            --- programmed onto the device.                                   ---
      C:/ncs/v2.9.1/nrf/cmake/sysbuild/partition_manager.cmake:634 (partition_manager)
      C:/ncs/v2.9.1/nrf/sysbuild/CMakeLists.txt:703 (include)
      cmake/modules/sysbuild_extensions.cmake:583 (nrf_POST_CMAKE)
      cmake/modules/sysbuild_extensions.cmake:583 (cmake_language)
      cmake/modules/sysbuild_images.cmake:23 (sysbuild_module_call)
      cmake/modules/sysbuild_default.cmake:20 (include)
      C:/ncs/v2.9.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:75 (include)
      C:/ncs/v2.9.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
      C:/ncs/v2.9.1/zephyr/share/sysbuild-package/cmake/SysbuildConfig.cmake:8 (include)
      template/CMakeLists.txt:10 (find_package)
    -- Configuring done
    -- Generating done
    Loaded configuration 'C:/nordic/workspace/under_dev/build/under_dev/zephyr/.config'
    No change to configuration in 'C:/nordic/workspace/under_dev/build/under_dev/zephyr/.config'
    No change to Kconfig header in 'C:/nordic/workspace/under_dev/build/under_dev/zephyr/include/generated/zephyr/autoconf.h'
    -- Configuring done
    -- Generating done
    [5/394] Generating include/generated/zephyr/version.h
    Generating files from C:/nordic/workspace/under_dev/build/under_dev/zephyr/zephyr.elf for board: customboard
    [10/285] Generating include/generated/zephyr/version.h
    [280/285] Linking C executable zephyr\zephyr_pre0.elf
    FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map C:/nordic/workspace/under_dev/build/mcuboot/zephyr/zephyr_pre0.map
    cmd.exe /C "cd . && C:\ncs\toolchains\b620d30767\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe -Os -DNDEBUG -gdwarf-4 -gdwarf-4 zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj -o zephyr\zephyr_pre0.elf  zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj  -T  zephyr/linker_zephyr_pre0.cmd  -Wl,-Map=C:/nordic/workspace/under_dev/build/mcuboot/zephyr/zephyr_pre0.map  -Wl,--whole-archive  app/libapp.a  zephyr/libzephyr.a  zephyr/arch/common/libarch__common.a  zephyr/arch/arch/arm/core/libarch__arm__core.a  zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a  zephyr/arch/arch/arm/core/cortex_m/cmse/libarch__arm__core__cortex_m__cmse.a  zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a  zephyr/lib/libc/minimal/liblib__libc__minimal.a  zephyr/lib/libc/common/liblib__libc__common.a  zephyr/soc/soc/nrf54l15/libsoc__nordic.a  zephyr/drivers/cache/libdrivers__cache.a  zephyr/drivers/clock_control/libdrivers__clock_control.a  zephyr/drivers/console/libdrivers__console.a  zephyr/drivers/flash/libdrivers__flash.a  zephyr/drivers/gpio/libdrivers__gpio.a  zephyr/drivers/pinctrl/libdrivers__pinctrl.a  zephyr/drivers/serial/libdrivers__serial.a  zephyr/drivers/timer/libdrivers__timer.a  modules/nrf/lib/fprotect/lib..__nrf__lib__fprotect.a  modules/mcuboot/boot/bootutil/zephyr/libmcuboot_util.a  modules/mbedtls/libmbedTLSBase.a  modules/mbedtls/libmbedTLSCrypto.a  modules/mbedtls/libmbedTLSX509.a  modules/mbedtls/libmodules__mbedtls.a  modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a  -Wl,--no-whole-archive  zephyr/kernel/libkernel.a  -LC:/nordic/workspace/under_dev/build/mcuboot/zephyr  zephyr/arch/common/libisr_tables.a  modules/mbedtls/libmbedTLSBase.a  modules/mbedtls/libmbedTLSCrypto.a  modules/mbedtls/libmbedTLSX509.a  -mcpu=cortex-m33  -mthumb  -mabi=aapcs  -mfp16-format=ieee  -fuse-ld=bfd  -Wl,--gc-sections  -Wl,--build-id=none  -Wl,--sort-common=descending  -Wl,--sort-section=alignment  -Wl,-u,_OffsetAbsSyms  -Wl,-u,_ConfigAbsSyms  -nostdlib  -static  -Wl,-X  -Wl,-N  -Wl,--orphan-handling=warn  -Wl,-no-pie -L"c:/ncs/toolchains/b620d30767/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/thumb/v8-m.main/nofp" -lc -lgcc && cmd.exe /C "cd /D C:\nordic\workspace\under_dev\build\mcuboot\zephyr && C:\ncs\toolchains\b620d30767\opt\bin\cmake.exe -E true""
    c:/ncs/toolchains/b620d30767/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: zephyr/drivers/flash/libdrivers__flash.a(spi_nor.c.obj):(.rodata.spi_nor_0_config+0x0): undefined reference to `__device_dts_ord_114'
    collect2.exe: error: ld returned 1 exit status
    [15/20] Generating ../dfu_application.zip
    FAILED: _sysbuild/sysbuild/images/bootloader/mcuboot-prefix/src/mcuboot-stamp/mcuboot-build C:/nordic/workspace/under_dev/build/_sysbuild/sysbuild/images/bootloader/mcuboot-prefix/src/mcuboot-stamp/mcuboot-build
    cmd.exe /C "cd /D C:\nordic\workspace\under_dev\build\mcuboot && C:\ncs\toolchains\b620d30767\opt\bin\cmake.exe --build ."
    FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\b620d30767\opt\bin\cmake.EXE' --build C:/nordic/workspace/under_dev/build
     *  The terminal process terminated with exit code: 1.
  • It looks like the error occurred when compiling mcuboot:
    You might want to try adding the file sysbuild/mcuboot.conf, and putting the following in it:
    CONFIG_SPI=y
    CONFIG_SPI_NOR=y
    CONFIG_MULTITHREADING=y
  • adding or changing these settings did not resolve the issue.
