[NCS 2.6.1] NFC T4T response timing
I am trying to use nfc_t4t_lib and I have some issues because processing incoming data takes some time (around 100 ms) and therefore sending the response occurs late after receiving the command.
There is a similar post but in my case, I am not using BLE at the same time, thus it is not exactly the same: devzone.nordicsemi.com/.../nfc-t4t-response-timing-sdk-15-3
If I have a delay (> 4 ms) after NFC_T4T_EVENT_DATA_IND,
  • nfc_t4t_response_pdu_send() returns success
  • But reader receives 6E00 status word, although this is absolutely not the data I have sent with nfc_t4t_response_pdu_send()
  • Moreover in the log, I observe the following error:
<err> nfc_platform: Tried to read data pointer: 4 bytes, read 0.
<err> nfc_platform: Reading nfc ring buffer failed, resetting ring buffer.
I was expecting the NFC T4T lib would send WTX to the reader until I call nfc_t4t_response_pdu_send() but it seems this is not the case. Am I missing something ?
Moreover, I was wondering: why NFC T4T library source code is not available ? Would it be possible to have access to it ?
Thanks and best regards,
Jean
  • I was expecting the NFC T4T lib would send WTX to the reader until I call nfc_t4t_response_pdu_send() but it seems this is not the case. Am I missing something ?
    You are not missing something. Will investigate internally.
    Proposal for possible workaround:
    • set different FWI (Frame Wait Time) through nfc_t4t_parameter_set() to see if the possible race condition is resolved
    • change the NFC callback processing: modify the IRQ priority of the callback or change the processing flow to use a dedicated thread instead of Work Queue: CONFIG_NFC_OWN_THREAD, CONFIG_NFC_THREAD_PRIORITY and maybe some others to see if it can help
    Jonathan
    Thanks for this first answer, I am waiting for your investigation concerning WTX that seems to be not sent.
    I had already tested to set FWI to the maximum (8 if I have correctly understood) but this has no effect.
    I just tested to change callback processing with CONFIG_NFC_OWN_THREAD and the behavior is the same on reader side. However the errors raised by nfc_platform that I have mentioned in my initial query are not raised in this configuration case. Thus, this configuration has an impact but it is not sufficient.
    Jean
  • Hi Jean,
    Which NFC reader is used?
    I'd like to understand what the error code (6E00) means. No response from the tag, delayed response or invalid block?
    Jonathan
  • I am using this reader: https://www.hidglobal.com/products/omnikey-5422
    I am also a bit confused about this Status Word. So far I don't know if this SW comes from the NRF chip or if this is a default SW returned by the reader.
    This is also why I asked if access to NFC T4T source code library would be possible to debug this.
    BR
    Jean
  • Hi Jean, sorry for the slow response time here, but currently it is difficult for us to speed things up and I understand that that causes issues for you.
    Also providing you access to the lib is not a easy task as there is a legal machinery that need to be involved and its slow.
    I will try to get a more concrete timeline for you hare and follow up. Also pleas feel free to ask or push for updates if you want, fully understand that this is a timely issue for you.
    Jonathan
