NRF9161 based LTE-M tracker data drops while moving – can it be optimized?
Hi everyone,
I’m using a custom board (a tracker) that can travel at speeds up to 65 km/h and transmits data regularly every 200 ms. I expect, therefore, that the inactivity timer should not be activated. While the device is in motion, I’m seeing intermittent data gaps ranging up to several seconds, which is unacceptable for our application.
Could this be caused by non-optimal cell-handover settings? I’ve attached a few logs below for reference.
Any suggestions would be greatly appreciated.
Martin
Three log fragments examples, related to data send drops:
17:31:57.179 +CSCON: 0
17:31:57.230 <inf> main: RRC mode: Idle
17:31:57.276 +CEREG: 1,"04D3","0DBC2351",7,,,"11100000","11100000"
17:31:57.298 <inf> main: Cell update, cell tac: 1235, cell id: 230433617
17:31:57.371 +CSCON: 1
17:31:57.429 <inf> main: RRC mode: Connected
17:31:57.539 +CSCON: 0
17:31:57.568 <inf> main: RRC mode: Idle
17:31:57.907 +CSCON: 1
17:31:57.926 <inf> main: RRC mode: Connected
17:37:54.095 +CEREG: 1,"04D3","0DC18750",7,,,"11100000","11100000"
17:37:54.154 [00:54:10.770,263] <inf> main: Cell update, cell tac: 1235, cell id: 230786896
17:38:05.373 +CEREG: 1,"04D3","0DDD4350",7,,,"11100000","11100000"
17:38:05.434 <inf> main: Cell update, cell tac: 1235, cell id: 232604496
Modem firmware: mfw_nrf91x1_2.0.2
Current 9161 modem initiation sequence is:
AT+CFUN=0
AT%XSYSTEMMODE=1,0,0,0
AT+CPSMS=0
AT+CEDRXS=0
AT%RAI=0
AT+CSCON=1
AT+CEREG=5
AT+CFUN=1
  • Sorry, I am trying RTT. In my app, I do:
    ### wrk - trace
    CONFIG_NRF_MODEM_LIB_TRACE_BACKEND_RTT=y
    CONFIG_USE_SEGGER_RTT=y
    CONFIG_NRF_MODEM_LIB_TRACE=y
    CONFIG_LOG=y
    CONFIG_LOG_BACKEND_RTT=y
    CONFIG_LOG_BACKEND_RTT_BUFFER_SIZE=4096
    CONFIG_SEGGER_RTT_INIT_PRIORITY=40
    Then in RTT viewer I cannot see anything logged after "Terminal logging started":
    LOG: J-Link RTT Viewer V8.30: Logging started.
    LOG: Terminal 0 added.
    LOG: Connecting to J-Link via USB...
    LOG: Device "NRF9161_XXCA" selected.
    LOG: ConfigTargetSettings() start
    LOG: ---Setting ROM table---
    LOG: ConfigTargetSettings() end - Took 25us
    LOG: InitTarget() start
    LOG: InitTarget() end - Took 3.80ms
    LOG: Found SW-DP with ID 0x6BA02477
    LOG: DPIDR: 0x6BA02477
    LOG: CoreSight SoC-400 or earlier
    LOG: AP map detection skipped. Manually configured AP map found.
    LOG: AP[0]: AHB-AP (IDR: Not set, ADDR: 0x00000000)
    LOG: AP[0]: Core found
    LOG: AP[0]: AHB-AP ROM base: 0xE00FF000
    LOG: CPUID register: 0x410FD212. Implementer code: 0x41 (ARM)
    LOG: Feature set: Mainline
    LOG: Cache: No cache
    LOG: Found Cortex-M33 r0p2, Little endian.
    LOG: FPUnit: 8 code (BP) slots and 0 literal slots
    LOG: Security extension: implemented
    LOG: Secure debug: enabled
    LOG: CoreSight components:
    LOG: ROMTbl[0] @ E00FF000
    LOG: [0][0]: E000E000 CID B105900D PID 000BBD21 DEVARCH 47702A04 DEVTYPE 00 Cortex-M33
    LOG: [0][1]: E0001000 CID B105900D PID 000BBD21 DEVARCH 47701A02 DEVTYPE 00 DWT
    LOG: [0][2]: E0002000 CID B105900D PID 000BBD21 DEVARCH 47701A03 DEVTYPE 00 FPB
    LOG: [0][3]: E0000000 CID B105900D PID 000BBD21 DEVARCH 47701A01 DEVTYPE 43 ITM
    LOG: [0][5]: E0041000 CID B105900D PID 002BBD21 DEVARCH 47724A13 DEVTYPE 13 ETM
    LOG: [0][6]: E0042000 CID B105900D PID 000BBD21 DEVARCH 47701A14 DEVTYPE 14 CSS600-CTI
    LOG: RTT Viewer connected.
    LOG: Terminal logging started.
    Edit: full .config attached
    zephyr.config.txt
    Have you started data logging?
    You can capture modem trace from JLink Viewer by clicking on Logging -> Start Data Logging and saving data log to .bin file.
    Dejan
  • Oh, thank you for your patience, dejans...
    Please download the trace from here: https://e.pcloud.link/publink/show?code=XZ0rTqZdiRVUEHQm9hG8n3zxMfHOHDJ2bRy
    The trace is from a short car ride, observing cells switching. Thank you very much!
    Below is what I did meanwhile (lock for band 20 for Czechia as O2 operator is used who has no other bands for LTE-M. full .config is FYI here: https://e.pcloud.link/publink/show?code=XZmrTqZUNoHFDGILALna6f7gRDrRzMaOtFk):
    ### LTE
    CONFIG_LTE_NETWORK_MODE_LTE_M=y
    CONFIG_LTE_LINK_CONTROL=y
    CONFIG_LTE_PSM_REQ=n
    CONFIG_LTE_EDRX_REQ=n
    CONFIG_LTE_RAI_REQ=n
    CONFIG_LTE_NETWORK_TIMEOUT=60
    CONFIG_LTE_LC_TAU_PRE_WARNING_NOTIFICATIONS=n
    CONFIG_LTE_LOCK_BANDS=y
    CONFIG_LTE_LOCK_BAND_MASK="10000000000000000000"
    And in runtime (possibly duplicate to config), I am sending:
    "AT+CFUN=0";
    "AT%%XSYSTEMMODE=1,0,0,0";
    "AT+CPSMS=0";
    "AT+CEDRXS=0";
    "AT%%RAI=0";
    "AT%%XBANDLOCK=2,\"10000000000000000000\"";
    "AT+CSCON=1";
    "AT+CEREG=5";
    "AT+CFUN=1";
    Thank you for the trace and additional information.
    There seems to be only one cell change in your log. Increased delay which you observed might be normal, but we will check this further. I will get back to you during next week.
    Dejan
  • Thanks, dejans, a lot!
    Well, the best case could be that the descibed changes could have improved the behavior described in the very first email.
    I have made the changes described in the previous email with trace link and only then I was recording the trace. Before the change, at the same path, I had observed number of cell switch changes with 1-2 secs data transfer breaks. In general, my question would be if the described settings are OK and/or what could be done more. Big thanks again.
